--- ray/src/util/Rmakefile 2003/02/22 02:07:30 2.31 +++ ray/src/util/Rmakefile 2015/02/13 20:49:59 2.80 @@ -1,4 +1,4 @@ -# RCSid: $Id: Rmakefile,v 2.31 2003/02/22 02:07:30 greg Exp $ +# RCSid: $Id: Rmakefile,v 2.80 2015/02/13 20:49:59 greg Exp $ # # Radiance makefile for utility programs # @@ -9,6 +9,8 @@ OPT = -O CFLAGS = -I../common -I../rt -L../lib $(OPT) $(MACH) +MLIB = -lm + CC = cc SPECIAL = @@ -18,16 +20,23 @@ INSTDIR = /usr/local/bin LIBDIR = /usr/local/lib/ray PROGS = findglare glarendx rpiece rad ranimate ranimove vwright getinfo \ - vwrays xglaresrc + vwrays xglaresrc rsensor dctimestep rttree_reduce rcollate \ + eplus_adduvf rfluxmtx rmtxop wrapBSDF +LIBFILES = rambpos.cal ambpos.cal tregsamp.dat reinhartb.cal \ +klems_full.cal klems_half.cal klems_quarter.cal disk2square.cal \ +minimalBSDFt.xml WINDOW6BSDFt.xml + all: $(PROGS) -install: all $(SPECIAL) objview.csh objpict.csh glare.csh dayfact.csh \ -rlux.csh raddepend.csh trad.wsh objline.csh compamb.csh +install: all $(SPECIAL) objview.pl objpict.pl glare.csh dayfact.csh \ +rlux.csh raddepend.csh trad.wsh objline.csh compamb.csh vinfo.csh \ +ltview.pl ltpict.pl genambpos.pl fieldcomb.csh genklemsamp.pl \ +genskyvec.pl genBSDF.pl $(LIBFILES) cp $(PROGS) $(INSTDIR) - cp objview.csh $(INSTDIR)/objview + cp objview.pl $(INSTDIR)/objview cp objline.csh $(INSTDIR)/objline - cp objpict.csh $(INSTDIR)/objpict + cp objpict.pl $(INSTDIR)/objpict cp glare.csh $(INSTDIR)/glare cp dayfact.csh $(INSTDIR)/dayfact cp debugcal.csh $(INSTDIR)/debugcal @@ -35,107 +44,149 @@ rlux.csh raddepend.csh trad.wsh objline.csh compamb.cs cp raddepend.csh $(INSTDIR)/raddepend cp compamb.csh $(INSTDIR)/compamb cp vinfo.csh $(INSTDIR)/vinfo - chmod 755 $(INSTDIR)/objview $(INSTDIR)/objpict \ - $(INSTDIR)/glare $(INSTDIR)/dayfact $(INSTDIR)/debugcal \ - $(INSTDIR)/rlux $(INSTDIR)/raddepend $(INSTDIR)/objline \ - $(INSTDIR)/compamb $(INSTDIR)/vinfo + cp genambpos.pl $(INSTDIR)/genambpos + cp fieldcomb.csh $(INSTDIR)/fieldcomb + cp genklemsamp.pl $(INSTDIR)/genklemsamp + cp genskyvec.pl $(INSTDIR)/genskyvec + cp genBSDF.pl $(INSTDIR)/genBSDF + cp ltview.pl $(INSTDIR)/ltview + cp ltpict.pl $(INSTDIR)/ltpict + cd $(INSTDIR) ; chmod 755 objview objpict \ + glare dayfact debugcal rlux raddepend objline \ + compamb vinfo genambpos fieldcomb genklemsamp \ + genskyvec genBSDF + cd $(LIBDIR) && rm -f $(LIBFILES) + cp $(LIBFILES) $(LIBDIR) csh -f tradinstall.csh $(INSTDIR) $(LIBDIR)/tcl clean: - set nonomatch; rm -f *.o $(PROGS) glrad core + set nonomatch; rm -f *.o $(PROGS) glrad Version.c x11findwind.c ogl: glrad cp glrad $(INSTDIR) -x10: - -aed: - sgi: sun: -scanner: scanner.o - $(CC) $(CFLAGS) -o scanner scanner.o -lm - -makedist: makedist.o setscan.o - $(CC) $(CFLAGS) -o makedist makedist.o setscan.o -lrt -lm - findglare: findglare.o glareval.o glaresrc.o setscan.o $(CC) $(CFLAGS) -o findglare findglare.o glareval.o glaresrc.o \ -setscan.o -lrt -lm +setscan.o -lrtrad $(MLIB) glarendx: glarendx.o - $(CC) $(CFLAGS) -o glarendx glarendx.o -lrt -lm + $(CC) $(CFLAGS) -o glarendx glarendx.o -lrtrad $(MLIB) xglaresrc: xglaresrc.o x11findwind.o $(CC) $(CFLAGS) -o xglaresrc xglaresrc.o \ -x11findwind.o -lrt -lX11 -lm +x11findwind.o -lrtrad -lX11 $(MLIB) rad: rad.o - $(CC) $(CFLAGS) -o rad rad.o -lrt -lm + $(CC) $(CFLAGS) -o rad rad.o -lrtrad $(MLIB) ranimate: ranimate.o netproc.o - $(CC) $(CFLAGS) -o ranimate ranimate.o netproc.o -lrt -lm + $(CC) $(CFLAGS) -o ranimate ranimate.o netproc.o -lrtrad $(MLIB) -ranimove: ranimove.o ranimove1.o ranimove2.o \ -../lib/raypcalls.o ../lib/raycalls.o +ranimove: ranimove.o ranimove1.o ranimove2.o $(CC) $(CFLAGS) -o ranimove ranimove.o ranimove1.o ranimove2.o \ -../lib/raypcalls.o ../lib/raycalls.o -lradiance -lrt -lm +-lraycalls -lradiance -lrtrad $(MLIB) +rsensor: rsensor.o + $(CC) $(CFLAGS) -o rsensor rsensor.o \ +-lraycalls -lradiance -lrtrad $(MLIB) + rpiece: rpiece.o Version.o - $(CC) $(CFLAGS) -o rpiece rpiece.o Version.o -lrt -lm + $(CC) $(CFLAGS) -o rpiece rpiece.o Version.o -lrtrad $(MLIB) vwright: vwright.o - $(CC) $(CFLAGS) -o vwright vwright.o -lrt -lm + $(CC) $(CFLAGS) -o vwright vwright.o -lrtrad $(MLIB) vwrays: vwrays.o - $(CC) $(CFLAGS) -o vwrays vwrays.o -lrt -lm + $(CC) $(CFLAGS) -o vwrays vwrays.o -lrtrad $(MLIB) getinfo: getinfo.o - $(CC) $(CFLAGS) -o getinfo getinfo.o -lrt + $(CC) $(CFLAGS) -o getinfo getinfo.o -lrtrad glrad: glrad.o - $(CC) $(CFLAGS) -o glrad glrad.o -lrgl -lrt -lGLU -lGL \ --lX11 -lXext -lm + $(CC) $(CFLAGS) -o glrad glrad.o -lrgl -lrtrad -lGLU -lGL \ +-lX11 -lXext $(MLIB) -contour: contour.o - $(CC) $(CFLAGS) -o contour contour.o -lm +dctimestep: dctimestep.o cmbsdf.o cmatrix.o + $(CC) $(CFLAGS) -o dctimestep dctimestep.o cmbsdf.o cmatrix.o \ +-lrtrad $(MLIB) -pranim: pranim.o client/libclient.a - $(CC) $(CFLAGS) -o pranim pranim.o \ -client/libclient.a -lrpcsvc +rttree_reduce: rttree_reduce.o + $(CC) $(CFLAGS) -o rttree_reduce rttree_reduce.o -lrtrad $(MLIB) -t16anim: t16anim.o client/libclient.a - $(CC) $(CFLAGS) -o t16anim t16anim.o \ -client/libclient.a -lrpcsvc +rcollate: rcollate.o + $(CC) $(CFLAGS) -o rcollate rcollate.o -lrtrad -t16anim.o pranim.o: client/clnt.h +eplus_adduvf: eplus_adduvf.o eplus_idf.o + $(CC) $(CFLAGS) -o eplus_adduvf eplus_adduvf.o eplus_idf.o \ +-lrtrad $(MLIB) -setscan.o makedist.o: setscan.h +rfluxmtx: rfluxmtx.o + $(CC) $(CFLAGS) -o rfluxmtx rfluxmtx.o -lrtrad $(MLIB) +rmtxop: rmtxop.o rmatrix.o cmatrix.o cmbsdf.o + $(CC) $(CFLAGS) -o rmtxop rmtxop.o rmatrix.o cmatrix.o cmbsdf.o \ +-lrtrad $(MLIB) + +wrapBSDF: wrapBSDF.o + $(CC) $(CFLAGS) -o wrapBSDF wrapBSDF.o -lrtrad $(MLIB) + +setscan.o: setscan.h + +eplus_adduvf.o: ../common/triangulate.h ../common/rtprocess.h \ +../common/paths.h ../common/rtio.h ../common/random.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h + +eplus_adduvf.o eplus_idf.o: eplus_idf.h \ +../common/lookup.h + findglare.o glareval.o \ -glaresrc.o: glare.h ../common/standard.h ../common/mat4.h \ -../common/fvect.h ../common/view.h ../common/color.h setscan.h +glaresrc.o: glare.h ../common/standard.h \ +../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h ../common/view.h ../common/color.h setscan.h glaresrc.o: ../common/linregr.h rpiece.o: ../common/color.h ../common/view.h ../common/resolu.h +dctimestep.o: ../common/standard.h \ +../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h ../common/resolu.h + +dctimestep.o cmatrix.o cmbsdf.o: cmatrix.h ../common/color.h + +cmatrix.o cmbsdf.o: ../common/standard.h \ +../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h + +cmbsdf.o: ../common/paths.h ../common/bsdf.h ../common/bsdf_m.h + +rfluxmtx.o: ../common/rtio.h ../common/random.h ../common/triangulate.h \ +../common/rtmath.h ../common/fvect.h ../common/mat4.h ../common/tiff.h \ +../common/platform.h ../common/bsdf.h ../common/bsdf_m.h ../common/rtprocess.h + +dctimestep.o cmatrix.o: ../common/platform.h + rad.o ranimate.o rpiece.o xglaresrc.o: ../common/standard.h \ -../common/mat4.h ../common/fvect.h +../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h xglaresrc.o: ../common/view.h -swaprasheader.o: ../common/rasterfile.h - glareval.o xglaresrc.o: ../common/resolu.h -xglaresrc.o: ../common/vfork.h +glareval.o: ../common/platform.h ../common/rtprocess.h rad.o ranimate.o: ../common/vars.h -ranimove1.o ranimove2.o: ../common/random.h +ranimove1.o ranimove2.o vwrays.o: ../common/random.h rad.o: ../common/paths.h @@ -148,18 +199,41 @@ netproc.o: ../common/paths.h rad.o ranimate.o ranimove.o: ../common/view.h ../common/resolu.h glrad.o: ../common/radogl.h \ -../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h ../common/rterror.h \ ../common/color.h ../common/object.h ../common/otypes.h ../common/lookup.h glrad.o: glradicon.h ../common/view.h ../common/paths.h ranimove.o ranimove1.o ranimove2.o: ranimove.h \ ../common/vars.h ../common/view.h \ -../rt/ray.h ../common/standard.h ../common/octree.h \ -../common/mat4.h ../common/fvect.h ../common/object.h ../common/color.h +../rt/ray.h ../common/octree.h \ +../common/object.h ../common/color.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h +rsensor.o: ../rt/ray.h ../common/octree.h \ +../common/object.h ../common/color.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h + +rsensor.o: ../common/view.h ../common/resolu.h ../rt/source.h + +rcollate.o: ../common/platform.h ../common/rtio.h ../common/resolu.h + Version.c: ../rt/Version.c cp ../rt/Version.c . x11findwind.c: ../common/x11findwind.c cp ../common/x11findwind.c . + +rttree_reduce.o: ../common/rtio.h ../common/rterror.h + +rmatrix.o: rmatrix.h cmatrix.h ../common/resolu.h + +rmtxop.o: rmatrix.h cmatrix.h ../common/rtio.h ../common/resolu.h + +wrapBSDF.o: ../common/rtio.h ../common/rtprocess.h ../common/ezxml.h \ +../common/bsdf.h ../common/bsdf_m.h ../common/fvect.h ../common/ccolor.h
