--- ray/src/util/Rmakefile 1993/03/11 11:00:49 2.6 +++ ray/src/util/Rmakefile 1998/06/09 16:19:02 2.28 @@ -1,5 +1,6 @@ # -# SCCSid "$SunId$ LBL" +# SCCSid "$SunId$ SGI" +# Radiance makefile for utility programs # MACH = -DBSD @@ -10,28 +11,48 @@ CFLAGS = $(MACH) $(OPT) -I../common -L../lib CC = cc +SPECIAL = + INSTDIR = /usr/local/bin -PROGS = findglare xglaresrc glarendx rpiece render +LIBDIR = /usr/local/lib/ray -all: $(PROGS) +PROGS = findglare xglaresrc glarendx rpiece rad ranimate vwright getinfo vwrays -install: all objview.csh objpict.csh proj.csh glare.csh dayfact.csh \ -rlux.csh +all: $(PROGS) $(SPECIAL) + +install: all objview.csh objpict.csh glare.csh dayfact.csh rlux.csh \ +raddepend.csh trad.wsh objline.csh compamb.csh cp $(PROGS) $(INSTDIR) cp objview.csh $(INSTDIR)/objview + cp objline.csh $(INSTDIR)/objline cp objpict.csh $(INSTDIR)/objpict cp glare.csh $(INSTDIR)/glare cp dayfact.csh $(INSTDIR)/dayfact cp debugcal.csh $(INSTDIR)/debugcal cp rlux.csh $(INSTDIR)/rlux + cp raddepend.csh $(INSTDIR)/raddepend + cp compamb.csh $(INSTDIR)/compamb chmod 755 $(INSTDIR)/objview $(INSTDIR)/objpict \ $(INSTDIR)/glare $(INSTDIR)/dayfact $(INSTDIR)/debugcal \ - $(INSTDIR)/rlux + $(INSTDIR)/rlux $(INSTDIR)/raddepend $(INSTDIR)/objline \ + $(INSTDIR)/compamb + csh -f tradinstall.csh $(INSTDIR) $(LIBDIR)/tcl clean: set nonomatch; rm -f *.o $(PROGS) core +ogl: glrad + cp glrad $(INSTDIR) + +x10: + +aed: + +sgi: + +sun: + scanner: scanner.o $(CC) $(CFLAGS) -o scanner scanner.o -lm @@ -49,12 +70,27 @@ xglaresrc: xglaresrc.o x11findwind.o $(CC) $(CFLAGS) -o xglaresrc xglaresrc.o \ x11findwind.o -lrt -lX11 -lm -render: render.o - $(CC) $(CFLAGS) -o render render.o -lrt -lm +rad: rad.o + $(CC) $(CFLAGS) -o rad rad.o -lrt -lm +ranimate: ranimate.o netproc.o + $(CC) $(CFLAGS) -o ranimate ranimate.o netproc.o -lrt -lm + rpiece: rpiece.o Version.o $(CC) $(CFLAGS) -o rpiece rpiece.o Version.o -lrt -lm +vwright: vwright.o + $(CC) $(CFLAGS) -o vwright vwright.o -lrt -lm + +vwrays: vwrays.o + $(CC) $(CFLAGS) -o vwrays vwrays.o -lrt -lm + +getinfo: getinfo.o + $(CC) $(CFLAGS) -o getinfo getinfo.o -lrt + +glrad: glrad.o + $(CC) $(CFLAGS) -o glrad glrad.o -lrgl -lrt -lGLU -lGL -lX11 -lm + contour: contour.o $(CC) $(CFLAGS) -o contour contour.o -lm @@ -78,7 +114,7 @@ glaresrc.o: ../common/linregr.h rpiece.o: ../common/color.h ../common/view.h ../common/resolu.h -render.o rpiece.o xglaresrc.o: ../common/standard.h \ +rad.o ranimate.o rpiece.o xglaresrc.o: ../common/standard.h \ ../common/mat4.h ../common/fvect.h xglaresrc.o: ../common/view.h @@ -88,3 +124,19 @@ swaprasheader.o: ../common/rasterfile.h glareval.o xglaresrc.o: ../common/resolu.h xglaresrc.o: ../common/vfork.h + +rad.o ranimate.o: ../common/vars.h + +rad.o: ../common/paths.h + +ranimate.o netproc.o: netproc.h + +netproc.o: ../common/paths.h + +rad.o ranimate.o: ../common/view.h + +glrad.o: ../common/radogl.h \ +../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/color.h ../common/object.h ../common/otypes.h ../common/lookup.h + +glrad.o: glradicon.h ../common/view.h ../common/paths.h
