--- ray/src/util/Rmakefile 1991/10/24 17:20:18 1.15 +++ ray/src/util/Rmakefile 2019/09/05 17:35:44 2.95 @@ -1,71 +1,285 @@ +# RCSid: $Id: Rmakefile,v 2.95 2019/09/05 17:35:44 greg Exp $ # -# SCCSid "$SunId$ LBL" +# Radiance makefile for utility programs # -MACH = -DBSD -DSTRUCTASSIGN +MACH = -DBSD OPT = -O -CFLAGS = $(MACH) $(OPT) -I../common -L../lib +CFLAGS = -I../common -I../rt -L../lib $(OPT) $(MACH) +MLIB = -lm + +CC = cc + +SPECIAL = + INSTDIR = /usr/local/bin -PROGS = findglare xglaresrc glarendx +LIBDIR = /usr/local/lib/ray +PROGS = findglare glarendx rpiece rad ranimate ranimove vwright getinfo \ + vwrays xglaresrc rsensor dctimestep rttree_reduce rcollate \ + eplus_adduvf rfluxmtx rmtxop wrapBSDF evalglare radcompare \ + rcode_depth rcode_norm rcode_ident + +LIBFILES = rambpos.cal ambpos.cal tregsamp.dat reinhartb.cal \ +klems_full.cal klems_half.cal klems_quarter.cal disk2square.cal \ +minimalBSDFt.xml WINDOW6BSDFt.xml + all: $(PROGS) -install: all objview.csh objpict.csh proj.csh glare.csh dayfact.csh +install: all $(SPECIAL) objview.pl objpict.pl glare.csh dayfact.csh \ +rlux.csh raddepend.csh trad.wsh objline.csh compamb.csh vinfo.csh \ +ltview.pl ltpict.pl genambpos.pl fieldcomb.csh genklemsamp.pl \ +genskyvec.pl genBSDF.pl bsdfview.pl rtpict.pl rcode2bmp.pl $(LIBFILES) cp $(PROGS) $(INSTDIR) - cp objview.csh $(INSTDIR)/objview - cp objpict.csh $(INSTDIR)/objpict + cp objview.pl $(INSTDIR)/objview + cp objline.csh $(INSTDIR)/objline + cp objpict.pl $(INSTDIR)/objpict cp glare.csh $(INSTDIR)/glare cp dayfact.csh $(INSTDIR)/dayfact cp debugcal.csh $(INSTDIR)/debugcal - chmod 755 $(INSTDIR)/objview $(INSTDIR)/objpict \ - $(INSTDIR)/glare $(INSTDIR)/dayfact $(INSTDIR)/debugcal + cp rlux.csh $(INSTDIR)/rlux + cp raddepend.csh $(INSTDIR)/raddepend + cp compamb.csh $(INSTDIR)/compamb + cp vinfo.csh $(INSTDIR)/vinfo + cp genambpos.pl $(INSTDIR)/genambpos + cp fieldcomb.csh $(INSTDIR)/fieldcomb + cp genklemsamp.pl $(INSTDIR)/genklemsamp + cp genskyvec.pl $(INSTDIR)/genskyvec + cp genBSDF.pl $(INSTDIR)/genBSDF + cp bsdfview.pl $(INSTDIR)/bsdfview + cp ltview.pl $(INSTDIR)/ltview + cp ltpict.pl $(INSTDIR)/ltpict + cp rtpict.pl $(INSTDIR)/rtpict + cp rcode2bmp.pl $(INSTDIR)/rcode2bmp + cd $(INSTDIR) ; chmod 755 objview objpict \ + glare dayfact debugcal rlux raddepend objline \ + compamb vinfo genambpos fieldcomb genklemsamp \ + genskyvec genBSDF rtpict rcode2bmp + cd $(LIBDIR) && rm -f $(LIBFILES) + cp $(LIBFILES) $(LIBDIR) + csh -f tradinstall.csh $(INSTDIR) $(LIBDIR)/tcl clean: - set nonomatch; rm -f *.o $(PROGS) core + set nonomatch; rm -f *.o $(PROGS) glrad Version.c x11findwind.c -scanner: scanner.o - cc $(CFLAGS) -o scanner scanner.o -lm +ogl: glrad + cp glrad $(INSTDIR) -makedist: makedist.o setscan.o - cc $(CFLAGS) -o makedist makedist.o setscan.o -lrt -lm +sgi: +sun: + findglare: findglare.o glareval.o glaresrc.o setscan.o - cc $(CFLAGS) -o findglare findglare.o glareval.o glaresrc.o \ -setscan.o -lrt -lm + $(CC) $(CFLAGS) -o findglare findglare.o glareval.o glaresrc.o \ +setscan.o -lrtrad $(MLIB) glarendx: glarendx.o - cc $(CFLAGS) -o glarendx glarendx.o -lrt -lm + $(CC) $(CFLAGS) -o glarendx glarendx.o -lrtrad $(MLIB) xglaresrc: xglaresrc.o x11findwind.o - cc $(CFLAGS) -o xglaresrc xglaresrc.o \ -x11findwind.o -lrt -lX11 -lm + $(CC) $(CFLAGS) -o xglaresrc xglaresrc.o \ +x11findwind.o -lrtrad -lX11 $(MLIB) -contour: contour.o - cc $(CFLAGS) -o contour contour.o -lm +rad: rad.o + $(CC) $(CFLAGS) -o rad rad.o -lrtrad $(MLIB) -pranim: pranim.o client/libclient.a - cc $(CFLAGS) -o pranim pranim.o \ -client/libclient.a -lrpcsvc +ranimate: ranimate.o netproc.o + $(CC) $(CFLAGS) -o ranimate ranimate.o netproc.o -lrtrad $(MLIB) -t16anim: t16anim.o client/libclient.a - cc $(CFLAGS) -o t16anim t16anim.o \ -client/libclient.a -lrpcsvc +ranimove: ranimove.o ranimove1.o ranimove2.o + $(CC) $(CFLAGS) -o ranimove ranimove.o ranimove1.o ranimove2.o \ +-lraycalls -lradiance -lrtrad $(MLIB) -t16anim.o pranim.o: client/clnt.h +rsensor: rsensor.o + $(CC) $(CFLAGS) -o rsensor rsensor.o \ +-lraycalls -lradiance -lrtrad $(MLIB) -setscan.o makedist.o: setscan.h +rpiece: rpiece.o Version.o + $(CC) $(CFLAGS) -o rpiece rpiece.o Version.o -lrtrad $(MLIB) +vwright: vwright.o + $(CC) $(CFLAGS) -o vwright vwright.o -lrtrad $(MLIB) + +vwrays: vwrays.o + $(CC) $(CFLAGS) -o vwrays vwrays.o -lrtrad $(MLIB) + +getinfo: getinfo.o + $(CC) $(CFLAGS) -o getinfo getinfo.o -lrtrad + +glrad: glrad.o + $(CC) $(CFLAGS) -o glrad glrad.o -lrgl -lrtrad -lGLU -lGL \ +-lX11 -lXext $(MLIB) + +dctimestep: dctimestep.o cmbsdf.o cmatrix.o + $(CC) $(CFLAGS) -o dctimestep dctimestep.o cmbsdf.o cmatrix.o \ +-lrtrad $(MLIB) + +rttree_reduce: rttree_reduce.o + $(CC) $(CFLAGS) -o rttree_reduce rttree_reduce.o -lrtrad $(MLIB) + +rcollate: rcollate.o + $(CC) $(CFLAGS) -o rcollate rcollate.o -lrtrad + +eplus_adduvf: eplus_adduvf.o eplus_idf.o + $(CC) $(CFLAGS) -o eplus_adduvf eplus_adduvf.o eplus_idf.o \ +-lrtrad $(MLIB) + +rfluxmtx: rfluxmtx.o + $(CC) $(CFLAGS) -o rfluxmtx rfluxmtx.o -lrtrad $(MLIB) + +rmtxop: rmtxop.o rmatrix.o cmatrix.o cmbsdf.o + $(CC) $(CFLAGS) -o rmtxop rmtxop.o rmatrix.o cmatrix.o cmbsdf.o \ +-lrtrad $(MLIB) + +wrapBSDF: wrapBSDF.o + $(CC) $(CFLAGS) -o wrapBSDF wrapBSDF.o -lrtrad $(MLIB) + +evalglare: evalglare.o pictool.o + $(CC) $(CFLAGS) -o evalglare evalglare.o pictool.o -lreetz -lrtrad $(MLIB) + +radcompare: radcompare.o + $(CC) $(CFLAGS) -o radcompare radcompare.o -lrtrad $(MLIB) + +setscan.o: setscan.h + +rcode_depth: rcode_depth.o + $(CC) $(CFLAGS) -o rcode_depth rcode_depth.o \ +-lrtrad $(MLIB) + +rcode_norm: rcode_norm.o + $(CC) $(CFLAGS) -o rcode_norm rcode_norm.o \ +-lrtrad $(MLIB) + +rcode_ident: rcode_ident.o + $(CC) $(CFLAGS) -o rcode_ident rcode_ident.o -lrtrad + +eplus_adduvf.o: ../common/triangulate.h ../common/rtprocess.h \ +../common/paths.h ../common/rtio.h ../common/random.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h + +eplus_adduvf.o eplus_idf.o: eplus_idf.h \ +../common/lookup.h + findglare.o glareval.o \ -glaresrc.o: glare.h ../common/standard.h ../common/mat4.h \ -../common/fvect.h ../common/view.h ../common/color.h setscan.h +glaresrc.o: glare.h ../common/standard.h \ +../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h ../common/view.h ../common/color.h setscan.h glaresrc.o: ../common/linregr.h -image.o xglaresrc.o: ../common/standard.h ../common/mat4.h \ -../common/fvect.h ../common/view.h +rpiece.o: ../common/color.h ../common/view.h ../common/resolu.h -swaprasheader.o: ../common/rasterfile.h +dctimestep.o: ../common/standard.h \ +../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h ../common/resolu.h + +dctimestep.o cmatrix.o cmbsdf.o: cmatrix.h ../common/color.h + +cmatrix.o cmbsdf.o: ../common/standard.h \ +../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h + +cmbsdf.o: ../common/paths.h ../common/bsdf.h ../common/bsdf_m.h + +rfluxmtx.o: ../common/rtio.h ../common/random.h ../common/triangulate.h \ +../common/rtmath.h ../common/fvect.h ../common/mat4.h ../common/tiff.h \ +../common/platform.h ../common/bsdf.h ../common/bsdf_m.h ../common/rtprocess.h + +rmtxop.o dctimestep.o cmatrix.o: ../common/platform.h + +rad.o ranimate.o rpiece.o xglaresrc.o: ../common/standard.h \ +../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h + +xglaresrc.o: ../common/view.h + +glareval.o xglaresrc.o: ../common/resolu.h + +glareval.o: ../common/platform.h ../common/rtprocess.h + +rad.o ranimate.o: ../common/vars.h + +ranimove1.o ranimove2.o vwrays.o: ../common/random.h + +rad.o: ../common/paths.h + +ranimate.o netproc.o: netproc.h + +ranimove1.o: ../common/otypes.h ../rt/otspecial.h ../rt/source.h + +netproc.o: ../common/paths.h + +rad.o ranimate.o ranimove.o: ../common/view.h ../common/resolu.h + +glrad.o: ../common/radogl.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h ../common/rterror.h \ +../common/color.h ../common/object.h ../common/otypes.h ../common/lookup.h + +glrad.o: glradicon.h ../common/view.h ../common/paths.h + +ranimove.o ranimove1.o ranimove2.o: ranimove.h \ +../common/vars.h ../common/view.h \ +../rt/ray.h ../common/octree.h \ +../common/object.h ../common/color.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h + +rsensor.o: ../rt/ray.h ../common/octree.h \ +../common/object.h ../common/color.h \ +../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h + +rsensor.o: ../common/view.h ../common/resolu.h ../rt/source.h + + rcollate.o: ../common/platform.h \ +../common/rtio.h ../common/resolu.h + +Version.c: ../rt/Version.c + cp ../rt/Version.c . + +x11findwind.c: ../common/x11findwind.c + cp ../common/x11findwind.c . + +rttree_reduce.o: ../common/rtio.h ../common/rterror.h + +rmatrix.o: rmatrix.h cmatrix.h ../common/resolu.h + +rmtxop.o: rmatrix.h cmatrix.h ../common/rtio.h ../common/resolu.h + +wrapBSDF.o: ../common/rtio.h ../common/rtprocess.h ../common/ezxml.h \ +../common/bsdf.h ../common/bsdf_m.h ../common/fvect.h ../common/ccolor.h + +pictool.o evalglare.o: pictool.h ../common/g3vector.h ../common/g3affine.h \ +../common/g3flist.h ../common/fvect.h ../common/gbasic.h + +evalglare.o: ../common/rtio.h + +radcompare.o: ../common/rtio.h ../common/color.h ../common/lookup.h \ +../common/platform.h ../common/normcodec.h ../common/depthcodec.h \ +../common/rtmath.h ../common/view.h + +pictool.o: ../common/view.h ../common/color.h + +getinfo.o: ../common/rtprocess.h ../common/platform.h ../common/resolu.h + +rcode_depth.o: ../common/depthcodec.h \ +../common/view.h ../common/fvect.h ../common/resolu.h ../common/rtio.h \ +../common/platform.h + +rcode_norm.o: ../common/normcodec.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/resolu.h ../common/rtio.h ../common/platform.h + +rcode_ident.o: ../common/idmap.h ../common/resolu.h \ +../common/platform.h ../common/rtio.h ../common/lookup.h
