--- ray/src/util/Rmakefile 1991/03/12 13:11:06 1.1 +++ ray/src/util/Rmakefile 1998/09/03 10:50:38 2.30 @@ -1,46 +1,143 @@ # -# SCCSid "$SunId$ LBL" +# SCCSid "$SunId$ SGI" +# Radiance makefile for utility programs # -MACH = -f68881 /usr/lib/libm.il -DIEEE -DBSD +MACH = -DBSD OPT = -O -CFLAGS = $(MACH) $(OPT) +CFLAGS = $(MACH) $(OPT) -I../common -L../lib -INSTDIR = /lumen/lumen/ray/bin.sun3 +CC = cc -PROGS = makedist swaprasheader +SPECIAL = +INSTDIR = /usr/local/bin + +LIBDIR = /usr/local/lib/ray + +PROGS = findglare xglaresrc glarendx rpiece rad ranimate vwright getinfo vwrays + all: $(PROGS) -install: all objview.csh objpict.csh proj.csh +install: all $(SPECIAL) objview.csh objpict.csh glare.csh dayfact.csh \ +rlux.csh raddepend.csh trad.wsh objline.csh compamb.csh cp $(PROGS) $(INSTDIR) cp objview.csh $(INSTDIR)/objview + cp objline.csh $(INSTDIR)/objline cp objpict.csh $(INSTDIR)/objpict - cp proj.csh $(INSTDIR)/proj - chmod 755 $(INSTDIR)/objview $(INSTDIR)/objpict $(INSTDIR)/proj + cp glare.csh $(INSTDIR)/glare + cp dayfact.csh $(INSTDIR)/dayfact + cp debugcal.csh $(INSTDIR)/debugcal + cp rlux.csh $(INSTDIR)/rlux + cp raddepend.csh $(INSTDIR)/raddepend + cp compamb.csh $(INSTDIR)/compamb + chmod 755 $(INSTDIR)/objview $(INSTDIR)/objpict \ + $(INSTDIR)/glare $(INSTDIR)/dayfact $(INSTDIR)/debugcal \ + $(INSTDIR)/rlux $(INSTDIR)/raddepend $(INSTDIR)/objline \ + $(INSTDIR)/compamb + csh -f tradinstall.csh $(INSTDIR) $(LIBDIR)/tcl clean: - rm -f *.o $(PROGS) core + set nonomatch; rm -f *.o $(PROGS) core +ogl: glrad + cp glrad $(INSTDIR) + +x10: + +aed: + +sgi: + +sun: + scanner: scanner.o - cc $(CFLAGS) -o scanner scanner.o -lm + $(CC) $(CFLAGS) -o scanner scanner.o -lm -makedist: makedist.o fvect.o - cc $(CFLAGS) -o makedist makedist.o fvect.o -lm +makedist: makedist.o setscan.o + $(CC) $(CFLAGS) -o makedist makedist.o setscan.o -lrt -lm +findglare: findglare.o glareval.o glaresrc.o setscan.o + $(CC) $(CFLAGS) -o findglare findglare.o glareval.o glaresrc.o \ +setscan.o -lrt -lm + +glarendx: glarendx.o + $(CC) $(CFLAGS) -o glarendx glarendx.o -lrt -lm + +xglaresrc: xglaresrc.o x11findwind.o + $(CC) $(CFLAGS) -o xglaresrc xglaresrc.o \ +x11findwind.o -lrt -lX11 -lm + +rad: rad.o + $(CC) $(CFLAGS) -o rad rad.o -lrt -lm + +ranimate: ranimate.o netproc.o + $(CC) $(CFLAGS) -o ranimate ranimate.o netproc.o -lrt -lm + +rpiece: rpiece.o Version.o + $(CC) $(CFLAGS) -o rpiece rpiece.o Version.o -lrt -lm + +vwright: vwright.o + $(CC) $(CFLAGS) -o vwright vwright.o -lrt -lm + +vwrays: vwrays.o + $(CC) $(CFLAGS) -o vwrays vwrays.o -lrt -lm + +getinfo: getinfo.o + $(CC) $(CFLAGS) -o getinfo getinfo.o -lrt + +glrad: glrad.o + $(CC) $(CFLAGS) -o glrad glrad.o -lrgl -lrt -lGLU -lGL \ +-lX11 -lXext -lm + contour: contour.o - cc $(CFLAGS) -o contour contour.o -lm + $(CC) $(CFLAGS) -o contour contour.o -lm pranim: pranim.o client/libclient.a - cc $(CFLAGS) -o pranim pranim.o \ + $(CC) $(CFLAGS) -o pranim pranim.o \ client/libclient.a -lrpcsvc t16anim: t16anim.o client/libclient.a - cc $(CFLAGS) -o t16anim t16anim.o \ + $(CC) $(CFLAGS) -o t16anim t16anim.o \ client/libclient.a -lrpcsvc t16anim.o pranim.o: client/clnt.h -makedist.o: setscan.c +setscan.o makedist.o: setscan.h + +findglare.o glareval.o \ +glaresrc.o: glare.h ../common/standard.h ../common/mat4.h \ +../common/fvect.h ../common/view.h ../common/color.h setscan.h + +glaresrc.o: ../common/linregr.h + +rpiece.o: ../common/color.h ../common/view.h ../common/resolu.h + +rad.o ranimate.o rpiece.o xglaresrc.o: ../common/standard.h \ +../common/mat4.h ../common/fvect.h + +xglaresrc.o: ../common/view.h + +swaprasheader.o: ../common/rasterfile.h + +glareval.o xglaresrc.o: ../common/resolu.h + +xglaresrc.o: ../common/vfork.h + +rad.o ranimate.o: ../common/vars.h + +rad.o: ../common/paths.h + +ranimate.o netproc.o: netproc.h + +netproc.o: ../common/paths.h + +rad.o ranimate.o: ../common/view.h + +glrad.o: ../common/radogl.h \ +../common/standard.h ../common/mat4.h ../common/fvect.h \ +../common/color.h ../common/object.h ../common/otypes.h ../common/lookup.h + +glrad.o: glradicon.h ../common/view.h ../common/paths.h
