root/Development/ray/src/util/Rmakefile
Sat Apr 19 17:12:59 2025 UTC (7 months, 2 weeks ago) by greg
CVS Tags: rad6R0
Changes since 2.109: +13 -13 lines
Diff to previous 2.109 , to selected 2.40
refactor: Isolated RMATRIX<->CMATRIX conversion routines
Fri Apr 18 23:59:03 2025 UTC (7 months, 2 weeks ago) by greg
Changes since 2.108: +5 -5 lines
Diff to previous 2.108 , to selected 2.40
Thu Mar 27 01:26:55 2025 UTC (8 months, 1 week ago) by greg
Changes since 2.107: +9 -4 lines
Diff to previous 2.107 , to selected 2.40
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
Mon May 20 23:21:29 2024 UTC (18 months, 2 weeks ago) by greg
Changes since 2.106: +2 -2 lines
Diff to previous 2.106 , to selected 2.40
Mon Feb 26 18:22:16 2024 UTC (21 months, 1 week ago) by greg
Changes since 2.105: +6 -3 lines
Diff to previous 2.105 , to selected 2.40
chore(rcomb): Added missing dependencies
Thu Feb 8 02:26:01 2024 UTC (21 months, 4 weeks ago) by greg
Changes since 2.104: +2 -2 lines
Diff to previous 2.104 , to selected 2.40
Tue Dec 12 16:31:45 2023 UTC (23 months, 3 weeks ago) by greg
Changes since 2.103: +4 -4 lines
Diff to previous 2.103 , to selected 2.40
Tue Dec 5 01:06:10 2023 UTC (2 years ago) by greg
Changes since 2.102: +6 -2 lines
Diff to previous 2.102 , to selected 2.40
feat(rmtxcomb): Initial check-in of new matrix combining tool
Thu Feb 9 00:18:05 2023 UTC (2 years, 9 months ago) by greg
Changes since 2.101: +4 -2 lines
Diff to previous 2.101 , to selected 2.40
Wed Jun 1 17:22:31 2022 UTC (3 years, 6 months ago) by greg
Changes since 2.100: +2 -2 lines
Diff to previous 2.100 , to selected 2.40
chore: Moved hsv_rgb.cal to build directory with dependency, where it belongs
Mon Mar 14 23:28:14 2022 UTC (3 years, 8 months ago) by greg
Changes since 2.99: +8 -2 lines
Diff to previous 2.99 , to selected 2.40
fix(rmtxop): Fixed recently introduced bug in RGBE/XYZE load function
Tue Nov 24 16:30:15 2020 UTC (5 years ago) by greg
Changes since 2.98: +3 -2 lines
Diff to previous 2.98 , to selected 2.40
chore(ltview,ltpict,bsdfview): Added to chmod list
Mon Mar 2 22:00:05 2020 UTC (5 years, 9 months ago) by greg
Changes since 2.97: +3 -2 lines
Diff to previous 2.97 , to selected 2.40
Switched pipe output to use open_process() call on Unix
Tue Sep 10 17:25:02 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.96: +4 -2 lines
Diff to previous 2.96 , to selected 2.40
Fixed dependencies
Mon Sep 9 17:19:51 2019 UTC (6 years, 3 months ago) by greg
Changes since 2.95: +6 -2 lines
Diff to previous 2.95 , to selected 2.40
Thu Sep 5 17:35:44 2019 UTC (6 years, 3 months ago) by greg
Changes since 2.94: +2 -2 lines
Diff to previous 2.94 , to selected 2.40
Forgot to set rcode2bmp as executable
Wed Aug 14 04:18:12 2019 UTC (6 years, 3 months ago) by greg
Changes since 2.93: +5 -3 lines
Diff to previous 2.93 , to selected 2.40
Fri Jul 26 16:18:07 2019 UTC (6 years, 4 months ago) by greg
Changes since 2.92: +14 -19 lines
Diff to previous 2.92 , to selected 2.40
Fri Jul 26 00:34:07 2019 UTC (6 years, 4 months ago) by greg
Changes since 2.91: +3 -2 lines
Diff to previous 2.91 , to selected 2.40
Fri Jul 19 22:25:03 2019 UTC (6 years, 4 months ago) by greg
Changes since 2.90: +13 -6 lines
Diff to previous 2.90 , to selected 2.40
Fri Jul 19 02:18:44 2019 UTC (6 years, 4 months ago) by greg
Changes since 2.89: +12 -2 lines
Diff to previous 2.89 , to selected 2.40
Thu Jul 18 18:51:56 2019 UTC (6 years, 4 months ago) by greg
Changes since 2.88: +13 -2 lines
Diff to previous 2.88 , to selected 2.40
Sat Nov 17 20:15:51 2018 UTC (7 years ago) by greg
Diff to previous 2.87 , to selected 2.40
Fixed missing header from findmaterial() move
Mon Oct 15 17:52:52 2018 UTC (7 years, 1 month ago) by greg
Changes since 2.86: +9 -3 lines
Diff to previous 2.86 , to selected 2.40
Tue Mar 20 17:50:16 2018 UTC (7 years, 8 months ago) by greg
Diff to previous 2.85 , to selected 2.40
Fixed typo
Tue Mar 20 17:48:16 2018 UTC (7 years, 8 months ago) by greg
Changes since 2.84: +3 -1 lines
Diff to previous 2.84 , to selected 2.40
Replaced write() call with writebuf()
Mon Mar 19 23:40:33 2018 UTC (7 years, 8 months ago) by greg
Changes since 2.83: +4 -3 lines
Diff to previous 2.83 , to selected 2.40
Fri Aug 11 21:39:52 2017 UTC (8 years, 3 months ago) by greg
Diff to previous 2.82 , to selected 2.40
Thu Aug 18 17:57:57 2016 UTC (9 years, 3 months ago) by greg
Diff to previous 2.81 , to selected 2.40
Wed Aug 12 23:07:59 2015 UTC (10 years, 3 months ago) by greg
Changes since 2.80: +12 -2 lines
Diff to previous 2.80 , to selected 2.40
Fri Feb 13 20:49:59 2015 UTC (10 years, 9 months ago) by greg
Changes since 2.79: +3 -2 lines
Diff to previous 2.79 , to selected 2.40
Added XML templates and fixed bugs for first running version
Wed Feb 11 18:08:10 2015 UTC (10 years, 9 months ago) by greg
Changes since 2.78: +8 -2 lines
Diff to previous 2.78 , to selected 2.40
Checking in first compilable version of new program
Mon Jul 28 16:30:18 2014 UTC (11 years, 4 months ago) by greg
Diff to previous 2.77 , to selected 2.40
Added inclusion of rtprocess.h
Tue Jul 22 02:12:48 2014 UTC (11 years, 4 months ago) by greg
Diff to previous 2.76 , to selected 2.40
Added Reinhart sky cal file
Mon Jul 21 15:59:47 2014 UTC (11 years, 4 months ago) by greg
Changes since 2.75: +3 -2 lines
Diff to previous 2.75 , to selected 2.40
Getting close to working version of rfluxmtx
Sat Jul 19 01:19:49 2014 UTC (11 years, 4 months ago) by greg
Changes since 2.74: +9 -2 lines
Diff to previous 2.74 , to selected 2.40
Checking in incomplete and untested version of rfluxmtx
Sat May 31 05:02:37 2014 UTC (11 years, 6 months ago) by greg
Changes since 2.73: +10 -2 lines
Diff to previous 2.73 , to selected 2.40
Sat Apr 26 15:59:38 2014 UTC (11 years, 7 months ago) by greg
Diff to previous 2.72 , to selected 2.40
Thu Apr 24 23:15:42 2014 UTC (11 years, 7 months ago) by greg
Changes since 2.71: +8 -5 lines
Diff to previous 2.71 , to selected 2.40
Deprecated genambpos and put new Perl script in its place
Tue Apr 15 22:36:25 2014 UTC (11 years, 7 months ago) by greg
Changes since 2.70: +5 -2 lines
Diff to previous 2.70 , to selected 2.40
Tue Apr 8 23:46:05 2014 UTC (11 years, 8 months ago) by greg
Changes since 2.69: +2 -9 lines
Diff to previous 2.69 , to selected 2.40
Formally retired rtcontrib
Fri Feb 14 17:35:09 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.68: +3 -2 lines
Diff to previous 2.68 , to selected 2.40
Added link of eplus_adduvf to math library as needed by some systems
Mon Feb 10 04:51:26 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.67: +4 -2 lines
Diff to previous 2.67 , to selected 2.40
Complete but untested implmentation of eplus_adduvf
Sun Feb 9 22:19:30 2014 UTC (11 years, 10 months ago) by greg
Diff to previous 2.66 , to selected 2.40
Partial implementation of eplus_adduvf
Sun Feb 9 05:49:21 2014 UTC (11 years, 10 months ago) by greg
Changes since 2.65: +9 -3 lines
Diff to previous 2.65 , to selected 2.40
Unfinished implementation of EnergyPlus User View Factors calculation
Sat Feb 1 01:28:43 2014 UTC (11 years, 10 months ago) by greg
Changes since 2.64: +4 -1 lines
Diff to previous 2.64 , to selected 2.40
Added (thus far) untested routines for reading and writing EnergyPlus IDFs
Mon Jan 20 21:29:04 2014 UTC (11 years, 10 months ago) by greg
Changes since 2.63: +16 -5 lines
Diff to previous 2.63 , to selected 2.40
Wed Dec 4 20:07:07 2013 UTC (12 years ago) by greg
Changes since 2.62: +4 -4 lines
Diff to previous 2.62 , to selected 2.40
Thu Sep 5 17:53:23 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.61: +7 -2 lines
Diff to previous 2.61 , to selected 2.40
Thu Jun 14 22:42:21 2012 UTC (13 years, 5 months ago) by greg
Diff to previous 2.60 , to selected 2.40
Thu Jun 9 13:17:28 2011 UTC (14 years, 6 months ago) by greg
Diff to previous 2.59 , to selected 2.40
Forgot to link math library for rttree_reduce
Thu May 26 15:32:02 2011 UTC (14 years, 6 months ago) by greg
Changes since 2.58: +7 -2 lines
Diff to previous 2.58 , to selected 2.40
Initial rttree_reduce implementation
Fri Apr 8 18:13:48 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.57: +3 -3 lines
Diff to previous 2.57 , to selected 2.40
Thu Dec 2 18:08:11 2010 UTC (15 years ago) by greg
Changes since 2.56: +3 -1 lines
Diff to previous 2.56 , to selected 2.40
Thu Sep 2 02:29:24 2010 UTC (15 years, 3 months ago) by greg
Changes since 2.55: +5 -3 lines
Diff to previous 2.55 , to selected 2.40
Thu Jul 2 02:13:07 2009 UTC (16 years, 5 months ago) by greg
Changes since 2.54: +4 -4 lines
Diff to previous 2.54 , to selected 2.40
Thu Jun 25 21:32:35 2009 UTC (16 years, 5 months ago) by greg
Diff to previous 2.53 , to selected 2.40
Fixed missing math library
Wed Jun 17 20:41:47 2009 UTC (16 years, 5 months ago) by greg
Changes since 2.52: +11 -2 lines
Diff to previous 2.52 , to selected 2.40
Tue Jun 16 04:54:08 2009 UTC (16 years, 5 months ago) by greg
Changes since 2.51: +5 -3 lines
Diff to previous 2.51 , to selected 2.40
Sun Jun 14 00:33:16 2009 UTC (16 years, 5 months ago) by greg
Changes since 2.50: +6 -7 lines
Diff to previous 2.50 , to selected 2.40
Tue Jun 24 02:01:21 2008 UTC (17 years, 5 months ago) by greg
Changes since 2.49: +6 -8 lines
Diff to previous 2.49 , to selected 2.40
Thu May 1 16:42:06 2008 UTC (17 years, 7 months ago) by greg
Changes since 2.48: +2 -2 lines
Diff to previous 2.48 , to selected 2.40
Thu Feb 21 01:22:06 2008 UTC (17 years, 9 months ago) by greg
Changes since 2.47: +14 -2 lines
Diff to previous 2.47 , to selected 2.40
Thu Feb 7 23:02:14 2008 UTC (17 years, 10 months ago) by greg
Diff to previous 2.46 , to selected 2.40
Sat Nov 24 00:37:28 2007 UTC (18 years ago) by greg
Changes since 2.45: +14 -12 lines
Diff to previous 2.45 , to selected 2.40
Wed Nov 21 17:52:05 2007 UTC (18 years ago) by greg
Diff to previous 2.44 , to selected 2.40
Fri Mar 10 19:40:14 2006 UTC (19 years, 9 months ago) by schorsch
Changes since 2.43: +13 -13 lines
Diff to previous 2.43 , to selected 2.40
Mon Sep 19 04:26:09 2005 UTC (20 years, 2 months ago) by greg
Diff to previous 2.42 , to selected 2.40
Fri Sep 2 04:15:42 2005 UTC (20 years, 3 months ago) by greg
Changes since 2.41: +6 -3 lines
Diff to previous 2.41 , to selected 2.40
Thu May 26 17:53:28 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.40: +5 -5 lines
Diff to previous 2.40
Revision 2.40 - (view) (download) (annotate) - [selected]
Wed May 25 04:44:26 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.39: +9 -2 lines
Diff to previous 2.39
Fri Nov 5 03:31:39 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.38: +2 -27 lines
Diff to previous 2.38 , to selected 2.40
Wed Oct 27 23:23:48 2004 UTC (21 years, 1 month ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.37 , to selected 2.40
Wed May 19 14:44:06 2004 UTC (21 years, 6 months ago) by greg
Changes since 2.36: +3 -2 lines
Diff to previous 2.36 , to selected 2.40
Added genambpos.csh to the install list
Mon Nov 10 16:52:24 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.35: +1 -3 lines
Diff to previous 2.35 , to selected 2.40
Fri Jun 27 06:53:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.34: +17 -7 lines
Diff to previous 2.34 , to selected 2.40
Fri Jun 6 18:38:19 2003 UTC (22 years, 6 months ago) by greg
Changes since 2.33: +3 -4 lines
Diff to previous 2.33 , to selected 2.40
Thu Jun 5 19:29:35 2003 UTC (22 years, 6 months ago) by schorsch
Diff to previous 2.32 , to selected 2.40
Wed May 14 21:40:40 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 2.31 , to selected 2.40
Changed to more traditional link style for .o library files
Sat Feb 22 02:07:30 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.30: +28 -6 lines
Diff to previous 2.30 , to selected 2.40
Thu Sep 3 10:50:38 1998 UTC (27 years, 3 months ago) by gwlarson
Diff to previous 2.29 , to selected 2.40
Wed Jun 10 17:50:34 1998 UTC (27 years, 6 months ago) by gwlarson
Diff to previous 2.28 , to selected 2.40
fixed libraries included on glrad compile for stereo viewing
Tue Jun 9 16:19:02 1998 UTC (27 years, 6 months ago) by gwlarson
Diff to previous 2.27 , to selected 2.40
added missing SPECIAL entries
Tue Jun 9 11:43:09 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 2.26: +13 -1 lines
Diff to previous 2.26 , to selected 2.40
added glrad program
Fri Jan 23 17:17:32 1998 UTC (27 years, 10 months ago) by gregl
Diff to previous 2.25 , to selected 2.40
Fri Jan 23 15:20:42 1998 UTC (27 years, 10 months ago) by gregl
Changes since 2.24: +4 -2 lines
Diff to previous 2.24 , to selected 2.40
added compamb.csh script
Fri Oct 17 10:36:44 1997 UTC (28 years, 1 month ago) by gregl
Changes since 2.23: +4 -1 lines
Diff to previous 2.23 , to selected 2.40
created vwrays program
Tue Mar 18 15:59:39 1997 UTC (28 years, 8 months ago) by greg
Diff to previous 2.22 , to selected 2.40
Wed Jul 24 16:49:48 1996 UTC (29 years, 4 months ago) by greg
Diff to previous 2.21 , to selected 2.40
Mon Jun 24 09:58:11 1996 UTC (29 years, 5 months ago) by greg
Changes since 2.20: +2 -0 lines
Diff to previous 2.20 , to selected 2.40
added conditional use of getwd() or getcwd()
Thu Jan 18 11:25:09 1996 UTC (29 years, 10 months ago) by greg
Changes since 2.19: +10 -4 lines
Diff to previous 2.19 , to selected 2.40
Fri Jan 12 12:16:32 1996 UTC (29 years, 11 months ago) by greg
Diff to previous 2.18 , to selected 2.40
created ranimate animation controller
Tue Dec 12 13:27:01 1995 UTC (30 years ago) by greg
Changes since 2.17: +4 -2 lines
Diff to previous 2.17 , to selected 2.40
Thu Oct 26 18:50:41 1995 UTC (30 years, 1 month ago) by greg
Diff to previous 2.16 , to selected 2.40
added objline and remove ivprep and ivpict
Wed Sep 13 16:15:36 1995 UTC (30 years, 3 months ago) by greg
Changes since 2.15: +1 -11 lines
Diff to previous 2.15 , to selected 2.40
Tue Jun 27 12:29:39 1995 UTC (30 years, 5 months ago) by greg
Changes since 2.14: +5 -4 lines
Diff to previous 2.14 , to selected 2.40
reordered sed call for trad so installation works w/o Tcl/Tk
Mon Nov 21 16:50:03 1994 UTC (31 years ago) by greg
Diff to previous 2.13 , to selected 2.40
added vwright utility
Fri Nov 4 17:40:46 1994 UTC (31 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.40
made install script change location of wish automatically
Thu Oct 27 22:07:06 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.11: +12 -2 lines
Diff to previous 2.11 , to selected 2.40
added trad program
Sat Jan 1 15:10:17 1994 UTC (31 years, 11 months ago) by greg
Diff to previous 2.10 , to selected 2.40
added ivprep and ivpict scripts
Sat Jan 1 12:15:44 1994 UTC (31 years, 11 months ago) by greg
Changes since 2.9: +14 -12 lines
Diff to previous 2.9 , to selected 2.40
added raddepend program
Thu Dec 9 17:32:14 1993 UTC (32 years ago) by greg
Changes since 2.8: +10 -8 lines
Diff to previous 2.8 , to selected 2.40
Fri Jul 9 09:08:54 1993 UTC (32 years, 5 months ago) by greg
Diff to previous 2.7 , to selected 2.40
removed reference to proj.csh
Wed Apr 21 09:09:20 1993 UTC (32 years, 7 months ago) by greg
Diff to previous 2.6 , to selected 2.40
changed "render" to "rad"
Thu Mar 11 11:00:49 1993 UTC (32 years, 9 months ago) by greg
Changes since 2.5: +11 -5 lines
Diff to previous 2.5 , to selected 2.40
added render program
Thu Aug 6 17:16:30 1992 UTC (33 years, 4 months ago) by greg
Diff to previous 2.4 , to selected 2.40
Thu Aug 6 16:44:40 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.3: +10 -3 lines
Diff to previous 2.3 , to selected 2.40
added rpiece program
Wed Jul 1 15:09:42 1992 UTC (33 years, 5 months ago) by greg
Changes since 2.2: +10 -8 lines
Diff to previous 2.2 , to selected 2.40
Thu Mar 19 09:38:12 1992 UTC (33 years, 8 months ago) by greg
Diff to previous 2.1 , to selected 2.40
added vfork.h include
Tue Nov 12 17:19:06 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.18 , to selected 2.40
Mon Nov 11 15:09:40 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.17 , to selected 2.40
Mon Nov 11 14:03:02 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.16: +2 -0 lines
Diff to previous 1.16 , to selected 2.40
Thu Nov 7 11:07:09 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.15 , to selected 2.40
removed STRUCTASSIGN macro
Thu Oct 24 17:20:18 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.14: +2 -1 lines
Diff to previous 1.14 , to selected 2.40
added debugcal
Wed Oct 23 10:48:43 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.13 , to selected 2.40
standardized macro settings
Thu Aug 22 09:26:00 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.12 , to selected 2.40
moved librt.a to ../lib
Mon Jul 15 12:52:25 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.11: +16 -20 lines
Diff to previous 1.11 , to selected 2.40
put many routines into a common library
Wed Jun 5 10:04:13 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.10 , to selected 2.40
added dayfact.csh
Tue Apr 30 16:24:06 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.9 , to selected 2.40
Wed Apr 24 13:18:31 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.8 , to selected 2.40
added glare.csh
Mon Apr 22 13:41:52 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.7 , to selected 2.40
fixed window finding under twm and other obnoxious window managers
Tue Apr 16 16:40:40 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.6: +5 -1 lines
Diff to previous 1.6 , to selected 2.40
added glarendx
Thu Apr 11 09:21:35 1991 UTC (34 years, 8 months ago) by greg
Diff to previous 1.5 , to selected 2.40
Tue Mar 26 13:02:20 1991 UTC (34 years, 8 months ago) by greg
Diff to previous 1.4 , to selected 2.40
minor bug fixes for system compatibility
Tue Mar 19 14:12:32 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.3: +6 -2 lines
Diff to previous 1.3 , to selected 2.40
added xglaresrc
Mon Mar 18 12:15:51 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.2: +16 -2 lines
Diff to previous 1.2 , to selected 2.40
added findglare
Thu Mar 14 17:38:42 1991 UTC (34 years, 9 months ago) by greg
Diff to previous 1.1 , to selected 2.40
broke setscan.h into its own file
Tue Mar 12 13:11:06 1991 UTC (34 years, 9 months ago) by greg
Diff to selected 2.40
