root/radiance/ray/src/util/Rmakefile
Thu May 26 17:53:28 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.40: +5 -5 lines
Diff to previous 2.40 , to selected 2.22
Wed May 25 04:44:26 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.39: +9 -2 lines
Diff to previous 2.39 , to selected 2.22
Fri Nov 5 03:31:39 2004 UTC (19 years, 5 months ago) by greg
Changes since 2.38: +2 -27 lines
Diff to previous 2.38 , to selected 2.22
Wed Oct 27 23:23:48 2004 UTC (19 years, 6 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.37 , to selected 2.22
Wed May 19 14:44:06 2004 UTC (19 years, 11 months ago) by greg
Changes since 2.36: +3 -2 lines
Diff to previous 2.36 , to selected 2.22
Added genambpos.csh to the install list
Mon Nov 10 16:52:24 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.35: +1 -3 lines
Diff to previous 2.35 , to selected 2.22
Fri Jun 27 06:53:23 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.34: +17 -7 lines
Diff to previous 2.34 , to selected 2.22
Fri Jun 6 18:38:19 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.33: +3 -4 lines
Diff to previous 2.33 , to selected 2.22
Thu Jun 5 19:29:35 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 2.32 , to selected 2.22
Wed May 14 21:40:40 2003 UTC (20 years, 11 months ago) by greg
Diff to previous 2.31 , to selected 2.22
Changed to more traditional link style for .o library files
Changes since 2.30: +28 -6 lines
Diff to previous 2.30 , to selected 2.22
Thu Sep 3 10:50:38 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to previous 2.29 , to selected 2.22
Wed Jun 10 17:50:34 1998 UTC (25 years, 10 months ago) by gwlarson
Diff to previous 2.28 , to selected 2.22
fixed libraries included on glrad compile for stereo viewing
Tue Jun 9 16:19:02 1998 UTC (25 years, 10 months ago) by gwlarson
Diff to previous 2.27 , to selected 2.22
added missing SPECIAL entries
Tue Jun 9 11:43:09 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 2.26: +13 -1 lines
Diff to previous 2.26 , to selected 2.22
added glrad program
Fri Jan 23 17:17:32 1998 UTC (26 years, 3 months ago) by gregl
Diff to previous 2.25 , to selected 2.22
Fri Jan 23 15:20:42 1998 UTC (26 years, 3 months ago) by gregl
Changes since 2.24: +4 -2 lines
Diff to previous 2.24 , to selected 2.22
added compamb.csh script
Fri Oct 17 10:36:44 1997 UTC (26 years, 6 months ago) by gregl
Changes since 2.23: +4 -1 lines
Diff to previous 2.23 , to selected 2.22
created vwrays program
Tue Mar 18 15:59:39 1997 UTC (27 years, 1 month ago) by greg
Diff to previous 2.22
Revision 2.22 - (view) (download) (annotate) - [selected]
Wed Jul 24 16:49:48 1996 UTC (27 years, 9 months ago) by greg
Diff to previous 2.21
Mon Jun 24 09:58:11 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.20: +2 -0 lines
Diff to previous 2.20 , to selected 2.22
added conditional use of getwd() or getcwd()
Thu Jan 18 11:25:09 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.19: +10 -4 lines
Diff to previous 2.19 , to selected 2.22
Fri Jan 12 12:16:32 1996 UTC (28 years, 3 months ago) by greg
Diff to previous 2.18 , to selected 2.22
created ranimate animation controller
Tue Dec 12 13:27:01 1995 UTC (28 years, 4 months ago) by greg
Changes since 2.17: +4 -2 lines
Diff to previous 2.17 , to selected 2.22
Thu Oct 26 18:50:41 1995 UTC (28 years, 6 months ago) by greg
Diff to previous 2.16 , to selected 2.22
added objline and remove ivprep and ivpict
Wed Sep 13 16:15:36 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.15: +1 -11 lines
Diff to previous 2.15 , to selected 2.22
Tue Jun 27 12:29:39 1995 UTC (28 years, 10 months ago) by greg
Changes since 2.14: +5 -4 lines
Diff to previous 2.14 , to selected 2.22
reordered sed call for trad so installation works w/o Tcl/Tk
Mon Nov 21 16:50:03 1994 UTC (29 years, 5 months ago) by greg
Diff to previous 2.13 , to selected 2.22
added vwright utility
Fri Nov 4 17:40:46 1994 UTC (29 years, 5 months ago) by greg
Diff to previous 2.12 , to selected 2.22
made install script change location of wish automatically
Thu Oct 27 22:07:06 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.11: +12 -2 lines
Diff to previous 2.11 , to selected 2.22
added trad program
Sat Jan 1 15:10:17 1994 UTC (30 years, 4 months ago) by greg
Diff to previous 2.10 , to selected 2.22
added ivprep and ivpict scripts
Sat Jan 1 12:15:44 1994 UTC (30 years, 4 months ago) by greg
Changes since 2.9: +14 -12 lines
Diff to previous 2.9 , to selected 2.22
added raddepend program
Thu Dec 9 17:32:14 1993 UTC (30 years, 4 months ago) by greg
Changes since 2.8: +10 -8 lines
Diff to previous 2.8 , to selected 2.22
Fri Jul 9 09:08:54 1993 UTC (30 years, 9 months ago) by greg
Diff to previous 2.7 , to selected 2.22
removed reference to proj.csh
Wed Apr 21 09:09:20 1993 UTC (31 years ago) by greg
Diff to previous 2.6 , to selected 2.22
changed "render" to "rad"
Thu Mar 11 11:00:49 1993 UTC (31 years, 1 month ago) by greg
Changes since 2.5: +11 -5 lines
Diff to previous 2.5 , to selected 2.22
added render program
Thu Aug 6 17:16:30 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.4 , to selected 2.22
Thu Aug 6 16:44:40 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.3: +10 -3 lines
Diff to previous 2.3 , to selected 2.22
added rpiece program
Wed Jul 1 15:09:42 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.2: +10 -8 lines
Diff to previous 2.2 , to selected 2.22
Thu Mar 19 09:38:12 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.1 , to selected 2.22
added vfork.h include
Tue Nov 12 17:19:06 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.18 , to selected 2.22
Mon Nov 11 15:09:40 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.17 , to selected 2.22
Mon Nov 11 14:03:02 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.16: +2 -0 lines
Diff to previous 1.16 , to selected 2.22
Thu Nov 7 11:07:09 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.15 , to selected 2.22
removed STRUCTASSIGN macro
Thu Oct 24 17:20:18 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.14: +2 -1 lines
Diff to previous 1.14 , to selected 2.22
added debugcal
Wed Oct 23 10:48:43 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.13 , to selected 2.22
standardized macro settings
Thu Aug 22 09:26:00 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.12 , to selected 2.22
moved librt.a to ../lib
Mon Jul 15 12:52:25 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.11: +16 -20 lines
Diff to previous 1.11 , to selected 2.22
put many routines into a common library
Wed Jun 5 10:04:13 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.10 , to selected 2.22
added dayfact.csh
Tue Apr 30 16:24:06 1991 UTC (33 years ago) by greg
Diff to previous 1.9 , to selected 2.22
Wed Apr 24 13:18:31 1991 UTC (33 years ago) by greg
Diff to previous 1.8 , to selected 2.22
added glare.csh
Mon Apr 22 13:41:52 1991 UTC (33 years ago) by greg
Diff to previous 1.7 , to selected 2.22
fixed window finding under twm and other obnoxious window managers
Tue Apr 16 16:40:40 1991 UTC (33 years ago) by greg
Changes since 1.6: +5 -1 lines
Diff to previous 1.6 , to selected 2.22
added glarendx
Thu Apr 11 09:21:35 1991 UTC (33 years ago) by greg
Diff to previous 1.5 , to selected 2.22
Tue Mar 26 13:02:20 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.4 , to selected 2.22
minor bug fixes for system compatibility
Tue Mar 19 14:12:32 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.3: +6 -2 lines
Diff to previous 1.3 , to selected 2.22
added xglaresrc
Mon Mar 18 12:15:51 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.2: +16 -2 lines
Diff to previous 1.2 , to selected 2.22
added findglare
Thu Mar 14 17:38:42 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.1 , to selected 2.22
broke setscan.h into its own file
Tue Mar 12 13:11:06 1991 UTC (33 years, 1 month ago) by greg
Diff to selected 2.22
