Added XML templates and fixed bugs for first running version
Checking in first compilable version of new program
Added inclusion of rtprocess.h
Added Reinhart sky cal file
Getting close to working version of rfluxmtx
Checking in incomplete and untested version of rfluxmtx
Deprecated genambpos and put new Perl script in its place
Formally retired rtcontrib
Added link of eplus_adduvf to math library as needed by some systems
Complete but untested implmentation of eplus_adduvf
Partial implementation of eplus_adduvf
Unfinished implementation of EnergyPlus User View Factors calculation
Added (thus far) untested routines for reading and writing EnergyPlus IDFs
Forgot to link math library for rttree_reduce
Initial rttree_reduce implementation
Fixed missing math library
Added genambpos.csh to the install list
Changed to more traditional link style for .o library files
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed libraries included on glrad compile for stereo viewing
added missing SPECIAL entries
added glrad program
added compamb.csh script
created vwrays program
added conditional use of getwd() or getcwd()
created ranimate animation controller
added objline and remove ivprep and ivpict
reordered sed call for trad so installation works w/o Tcl/Tk
added vwright utility
made install script change location of wish automatically
added trad program
added ivprep and ivpict scripts
added raddepend program
removed reference to proj.csh
changed "render" to "rad"
added render program
added rpiece program
added vfork.h include
removed STRUCTASSIGN macro
added debugcal
standardized macro settings
moved librt.a to ../lib
put many routines into a common library
added dayfact.csh
added glare.csh
fixed window finding under twm and other obnoxious window managers
added glarendx
minor bug fixes for system compatibility
added xglaresrc
added findglare
broke setscan.h into its own file
