Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed libraries included on glrad compile for stereo viewing
added missing SPECIAL entries
added glrad program
added compamb.csh script
created vwrays program
added conditional use of getwd() or getcwd()
created ranimate animation controller
added objline and remove ivprep and ivpict
reordered sed call for trad so installation works w/o Tcl/Tk
added vwright utility
made install script change location of wish automatically
added trad program
added ivprep and ivpict scripts
added raddepend program
removed reference to proj.csh
changed "render" to "rad"
added render program
added rpiece program
added vfork.h include
removed STRUCTASSIGN macro
added debugcal
standardized macro settings
moved librt.a to ../lib
put many routines into a common library
added dayfact.csh
added glare.csh
fixed window finding under twm and other obnoxious window managers
added glarendx
minor bug fixes for system compatibility
added xglaresrc
added findglare
broke setscan.h into its own file
