root/radiance/ray/src/util/README
Revision: 2.8
Committed: Fri Mar 15 21:06:18 1996 UTC (29 years, 4 months ago) by greg
Changes since 2.7: +5 -0 lines
added netproc., vars.h, loadvars.c, netproc.c and ranimate.c
1 RADIANCE UTILITY PROGRAMS
2 SCCSid "$SunId$ LBL"
3
4 This directory contains glare calculation programs and other utilites
5 that combine functions and do not fit under the usual catagories.
6
7 glare.h common data structures for glare source finding routines
8 netproc.h header file for network process routines
9 setscan.h defines for programs using setscan()
10 vars.h header file for loadvars.c routines (used by rad and ranimate)
11 Version.c symbolic link to ../rt/Version.c (current Radiance version)
12 findglare.c find glare sources in a scene or image
13 glarendx.c compute Glare Index given by program name or -t option
14 glaresrc.c gather samples and compute glare sources
15 glareval.c compute pixels for glare calculation
16 loadvars.c routines to read variables for rad and ranimate
17 makedist.c program to make a source distribution (obsolete with mkillum)
18 netproc.c routines to control processes on local and remote hosts
19 rad.c executive program to run oconv, rpict and pfilt (and rview)
20 ranimate.c animation control program
21 rpiece.c program to control parallel generation of a picture
22 setscan.c convert angle ranges of the form a-b:s,c to discrete values
23 vwright.c short program to read in and modify views
24 x11findwind.c find an X11 window from its name
25 xglaresrc.c circle glare sources in a displayed image
26 dayfact.csh compute and plot daylight factors on user-specified workplane
27 debugcal.csh C-shell script for debugging .cal files
28 objpict.csh script to compute 4-view picture of an object
29 objview.csh script to run rview on an object
30 glare.csh interactive script to run findglare, glarendx, xglaresrc
31 tradinstall.csh script called by make to install trad on systems running wish
32 trad.wsh graphical user interface to "rad" based on Tcl/Tk (wish script)
33 do_action.tcl action submenu for trad
34 do_file.tcl file submenu for trad
35 do_options.tcl options submenu for trad
36 do_results.tcl results submenu for trad
37 do_scene.tcl scene submenu for trad
38 do_views.tcl views submenu for trad
39 do_zone.tcl zone submenu for trad
40 getfile.tcl file browsing utility
41 gethelp.tcl help utility
42 util.tcl miscellaneous utilities
43 do_results3.6.tcl version of do_results.tcl for wish3.6
44 do_scene3.6.tcl version of do_results.tcl for wish3.6
45 do_views3.6.tcl version of do_views.tcl for wish3.6
46 getfile3.6.tcl version of getfile.tcl for wish3.6
47 gethelp3.6.tcl version of gethelp.tcl for wish3.6
48 tclIndex procedure index for Tcl/Tk library directory
49 file.hlp help file for getfile.tcl
50 help.hlp help file for gethelp.tcl
51 trad.hlp help file for trad.wsh
52 trad.icon X11 bitmap for trad icon
53 help2roff script for converting help files to troff/nroff for printing
