--- ray/src/util/README 2003/02/22 02:07:30 2.12 +++ ray/src/util/README 2021/04/28 17:20:33 2.17 @@ -1,15 +1,19 @@ RADIANCE UTILITY PROGRAMS - SCCSid "@(#)README 2.11 6/9/98 LBL" + RCSid: $Id This directory contains glare calculation programs and other utilites that combine functions and do not fit under the usual catagories. glare.h common data structures for glare source finding routines netproc.h header file for network process routines +ranimove.h header file for ranimove modules setscan.h defines for programs using setscan() vars.h header file for loadvars.c routines (used by rad and ranimate) Version.c symbolic link to ../rt/Version.c (current Radiance version) compamb.csh script to compute good ambient value and exposure setting +dctimestep.c tool to compute daylight coefficients, etc. +eplus_adduvf.c tool to compute User View Factors for EnergyPlus +evalglare.c program by Jan Wienold to evaluate glare findglare.c find glare sources in a scene or image getinfo.c program to read and manipulate binary file information headers glarendx.c compute Glare Index given by program name or -t option @@ -17,17 +21,30 @@ glaresrc.c gather samples and compute glare sources glareval.c compute pixels for glare calculation glrad.c render Radiance scene in OpenGL loadvars.c routines to read variables for rad and ranimate -makedist.c program to make a source distribution (obsolete with mkillum) netproc.c routines to control processes on local and remote hosts rad.c executive program to run oconv, rpict and pfilt (and rview) +radcompare.c tool to compare Radiance output files ranimate.c animation control program +ranimove.c main for ranimove program and control file handling +ranimove1.c basic frame rendering routines for ranimove +ranimove2.c frame refinement routines for ranimove +rcode_depth.c convert to/from encoded 16-bit depth maps +rcode_norm.c convert to/from encoded 32-bit normal maps +rcode_ident.c convert to/from indexed identifier maps +rcollate.c tool to collate (rearrange) data in file +rmtxop.c general matrix operations rpiece.c program to control parallel generation of a picture +rsensor.c tool to simulate sensors +rttree_reduce.c internal tool to prune tensor tree data +rfluxmtx.c tool to call rcontrib and generate flux transfer matrices setscan.c convert angle ranges of the form a-b:s,c to discrete values vwright.c short program to read in and modify views +wrapBSDF.c tool to wrap BSDF data in XML file x11findwind.c find an X11 window from its name xglaresrc.c circle glare sources in a displayed image dayfact.csh compute and plot daylight factors on user-specified workplane debugcal.csh C-shell script for debugging .cal files +fieldcomb.csh script to combine field animations (use with ranimate) glare.csh interactive script to run findglare, glarendx, xglaresrc objpict.csh script to compute 4-view picture of an object objview.csh script to run rview on an object
