root/Development/ray/src/util/README
Revision: 2.18
Committed: Wed Apr 28 17:20:57 2021 UTC (4 years, 8 months ago) by greg
CVS Tags: rad6R0, rad5R4, HEAD
docs: udated ID tag
1 RADIANCE UTILITY PROGRAMS
2 RCSid: $Id$
3
4 This directory contains glare calculation programs and other utilites
5 that combine functions and do not fit under the usual catagories.
6
7 glare.h common data structures for glare source finding routines
8 netproc.h header file for network process routines
9 ranimove.h header file for ranimove modules
10 setscan.h defines for programs using setscan()
11 vars.h header file for loadvars.c routines (used by rad and ranimate)
12 Version.c symbolic link to ../rt/Version.c (current Radiance version)
13 compamb.csh script to compute good ambient value and exposure setting
14 dctimestep.c tool to compute daylight coefficients, etc.
15 eplus_adduvf.c tool to compute User View Factors for EnergyPlus
16 evalglare.c program by Jan Wienold to evaluate glare
17 findglare.c find glare sources in a scene or image
18 getinfo.c program to read and manipulate binary file information headers
19 glarendx.c compute Glare Index given by program name or -t option
20 glaresrc.c gather samples and compute glare sources
21 glareval.c compute pixels for glare calculation
22 glrad.c render Radiance scene in OpenGL
23 loadvars.c routines to read variables for rad and ranimate
24 netproc.c routines to control processes on local and remote hosts
25 rad.c executive program to run oconv, rpict and pfilt (and rview)
26 radcompare.c tool to compare Radiance output files
27 ranimate.c animation control program
28 ranimove.c main for ranimove program and control file handling
29 ranimove1.c basic frame rendering routines for ranimove
30 ranimove2.c frame refinement routines for ranimove
31 rcode_depth.c convert to/from encoded 16-bit depth maps
32 rcode_norm.c convert to/from encoded 32-bit normal maps
33 rcode_ident.c convert to/from indexed identifier maps
34 rcollate.c tool to collate (rearrange) data in file
35 rmtxop.c general matrix operations
36 rpiece.c program to control parallel generation of a picture
37 rsensor.c tool to simulate sensors
38 rttree_reduce.c internal tool to prune tensor tree data
39 rfluxmtx.c tool to call rcontrib and generate flux transfer matrices
40 setscan.c convert angle ranges of the form a-b:s,c to discrete values
41 vwright.c short program to read in and modify views
42 wrapBSDF.c tool to wrap BSDF data in XML file
43 x11findwind.c find an X11 window from its name
44 xglaresrc.c circle glare sources in a displayed image
45 dayfact.csh compute and plot daylight factors on user-specified workplane
46 debugcal.csh C-shell script for debugging .cal files
47 fieldcomb.csh script to combine field animations (use with ranimate)
48 glare.csh interactive script to run findglare, glarendx, xglaresrc
49 objpict.csh script to compute 4-view picture of an object
50 objview.csh script to run rview on an object
51 raddepend.csh script to find dependencies in Radiance files
52 rlux.csh script to compute lux values using rtrace
53 tradinstall.csh script called by make to install trad on systems running wish
54 trad.wsh graphical user interface to "rad" based on Tcl/Tk (wish script)
55 do_action.tcl action submenu for trad
56 do_file.tcl file submenu for trad
57 do_options.tcl options submenu for trad
58 do_results.tcl results submenu for trad
59 do_scene.tcl scene submenu for trad
60 do_views.tcl views submenu for trad
61 do_zone.tcl zone submenu for trad
62 getfile.tcl file browsing utility
63 gethelp.tcl help utility
64 util.tcl miscellaneous utilities
65 do_results3.6.tcl version of do_results.tcl for wish3.6
66 do_scene3.6.tcl version of do_results.tcl for wish3.6
67 do_views3.6.tcl version of do_views.tcl for wish3.6
68 getfile3.6.tcl version of getfile.tcl for wish3.6
69 gethelp3.6.tcl version of gethelp.tcl for wish3.6
70 tclIndex procedure index for Tcl/Tk library directory
71 file.hlp help file for getfile.tcl
72 help.hlp help file for gethelp.tcl
73 trad.hlp help file for trad.wsh
74 trad.icon X11 bitmap for trad icon
75 help2roff script for converting help files to troff/nroff for printing
