root/Development/ray/src/util/README
Revision: 2.18
Committed: Wed Apr 28 17:20:57 2021 UTC (4 years, 4 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
docs: udated ID tag
# User Rev Content
1 greg 1.1 RADIANCE UTILITY PROGRAMS
2 greg 2.18 RCSid: $Id$
3 greg 1.1
4     This directory contains glare calculation programs and other utilites
5     that combine functions and do not fit under the usual catagories.
6
7     glare.h common data structures for glare source finding routines
8 greg 2.8 netproc.h header file for network process routines
9 greg 2.14 ranimove.h header file for ranimove modules
10 greg 1.1 setscan.h defines for programs using setscan()
11 greg 2.8 vars.h header file for loadvars.c routines (used by rad and ranimate)
12 greg 2.2 Version.c symbolic link to ../rt/Version.c (current Radiance version)
13 gregl 2.10 compamb.csh script to compute good ambient value and exposure setting
14 greg 2.16 dctimestep.c tool to compute daylight coefficients, etc.
15     eplus_adduvf.c tool to compute User View Factors for EnergyPlus
16     evalglare.c program by Jan Wienold to evaluate glare
17 greg 1.1 findglare.c find glare sources in a scene or image
18 greg 2.9 getinfo.c program to read and manipulate binary file information headers
19 greg 1.1 glarendx.c compute Glare Index given by program name or -t option
20     glaresrc.c gather samples and compute glare sources
21     glareval.c compute pixels for glare calculation
22 gwlarson 2.11 glrad.c render Radiance scene in OpenGL
23 greg 2.8 loadvars.c routines to read variables for rad and ranimate
24     netproc.c routines to control processes on local and remote hosts
25 greg 2.6 rad.c executive program to run oconv, rpict and pfilt (and rview)
26 greg 2.16 radcompare.c tool to compare Radiance output files
27 greg 2.8 ranimate.c animation control program
28 greg 2.14 ranimove.c main for ranimove program and control file handling
29     ranimove1.c basic frame rendering routines for ranimove
30     ranimove2.c frame refinement routines for ranimove
31 greg 2.16 rcode_depth.c convert to/from encoded 16-bit depth maps
32     rcode_norm.c convert to/from encoded 32-bit normal maps
33     rcode_ident.c convert to/from indexed identifier maps
34     rcollate.c tool to collate (rearrange) data in file
35     rmtxop.c general matrix operations
36 greg 2.2 rpiece.c program to control parallel generation of a picture
37 greg 2.16 rsensor.c tool to simulate sensors
38     rttree_reduce.c internal tool to prune tensor tree data
39     rfluxmtx.c tool to call rcontrib and generate flux transfer matrices
40 greg 1.1 setscan.c convert angle ranges of the form a-b:s,c to discrete values
41 greg 2.6 vwright.c short program to read in and modify views
42 greg 2.16 wrapBSDF.c tool to wrap BSDF data in XML file
43 greg 2.2 x11findwind.c find an X11 window from its name
44 greg 1.1 xglaresrc.c circle glare sources in a displayed image
45 greg 2.7 dayfact.csh compute and plot daylight factors on user-specified workplane
46     debugcal.csh C-shell script for debugging .cal files
47 greg 2.15 fieldcomb.csh script to combine field animations (use with ranimate)
48 gregl 2.10 glare.csh interactive script to run findglare, glarendx, xglaresrc
49 greg 2.7 objpict.csh script to compute 4-view picture of an object
50     objview.csh script to run rview on an object
51 gregl 2.10 raddepend.csh script to find dependencies in Radiance files
52     rlux.csh script to compute lux values using rtrace
53 greg 2.7 tradinstall.csh script called by make to install trad on systems running wish
54 greg 2.4 trad.wsh graphical user interface to "rad" based on Tcl/Tk (wish script)
55     do_action.tcl action submenu for trad
56     do_file.tcl file submenu for trad
57     do_options.tcl options submenu for trad
58     do_results.tcl results submenu for trad
59     do_scene.tcl scene submenu for trad
60     do_views.tcl views submenu for trad
61     do_zone.tcl zone submenu for trad
62     getfile.tcl file browsing utility
63     gethelp.tcl help utility
64     util.tcl miscellaneous utilities
65 greg 2.7 do_results3.6.tcl version of do_results.tcl for wish3.6
66     do_scene3.6.tcl version of do_results.tcl for wish3.6
67     do_views3.6.tcl version of do_views.tcl for wish3.6
68     getfile3.6.tcl version of getfile.tcl for wish3.6
69     gethelp3.6.tcl version of gethelp.tcl for wish3.6
70 greg 2.4 tclIndex procedure index for Tcl/Tk library directory
71     file.hlp help file for getfile.tcl
72     help.hlp help file for gethelp.tcl
73     trad.hlp help file for trad.wsh
74     trad.icon X11 bitmap for trad icon
75     help2roff script for converting help files to troff/nroff for printing
