root/radiance/ray/src/util/CMakeLists.txt
Fri Jul 25 20:39:22 2014 UTC (10 years, 8 months ago) by greg
Changes since 1.18: +9 -4 lines
Diff to previous 1.18
Patches for cmake build of rfluxmtx
Sun Jun 1 03:20:29 2014 UTC (10 years, 9 months ago) by greg
Changes since 1.17: +5 -1 lines
Diff to previous 1.17
Added number of rows to dctimestep output and rmtxop to cmake build
Mon Apr 28 21:01:12 2014 UTC (10 years, 11 months ago) by greg
Changes since 1.16: +11 -9 lines
Diff to previous 1.16
Install new objpict and objview scripts
Thu Apr 17 16:56:37 2014 UTC (10 years, 11 months ago) by greg
Changes since 1.15: +0 -2 lines
Diff to previous 1.15
Eliminated a couple of mentions of removed script
Tue Apr 15 22:36:25 2014 UTC (10 years, 11 months ago) by greg
Changes since 1.14: +4 -0 lines
Diff to previous 1.14
Thu Mar 20 22:49:21 2014 UTC (11 years ago) by greg
Diff to previous 1.13
Changes to speed installation on cloud computing systems
Mon Feb 10 17:50:02 2014 UTC (11 years, 1 month ago) by greg
Changes since 1.12: +4 -1 lines
Diff to previous 1.12
Rob updated cmake for eplus_adduvf and I added check for missing energy
Fri Feb 7 23:11:58 2014 UTC (11 years, 1 month ago) by greg
Diff to previous 1.11
Forgot a dependency
Fri Feb 7 22:40:32 2014 UTC (11 years, 1 month ago) by greg
Diff to previous 1.10
Broke out cm_* routines from dctimestep
Thu Sep 5 17:53:22 2013 UTC (11 years, 6 months ago) by greg
Changes since 1.9: +4 -1 lines
Diff to previous 1.9
Thu Jun 6 03:24:49 2013 UTC (11 years, 9 months ago) by greg
Changes since 1.8: +1 -5 lines
Diff to previous 1.8
Removed rtcontrib (again), which has been supplanted by rcontrib in src/rt
Wed Jun 5 23:30:11 2013 UTC (11 years, 9 months ago) by greg
Changes since 1.7: +4 -1 lines
Diff to previous 1.7
Added rtcontrib back and rttree_reduce
Fri Aug 10 21:18:19 2012 UTC (12 years, 7 months ago) by greg
Diff to previous 1.6
Build fixes for cmake
Tue Aug 7 18:17:17 2012 UTC (12 years, 7 months ago) by greg
Diff to previous 1.5
Wed May 30 18:31:11 2012 UTC (12 years, 10 months ago) by greg
Changes since 1.4: +5 -1 lines
Diff to previous 1.4
Patches to cmake build system and QT driver for rvu
Wed Apr 25 22:21:06 2012 UTC (12 years, 11 months ago) by greg
Changes since 1.3: +46 -19 lines
Diff to previous 1.3
Fri Oct 28 20:46:47 2011 UTC (13 years, 5 months ago) by greg
Changes since 1.2: +1 -8 lines
Diff to previous 1.2
Fixes to Version.c update in cmake build system
Wed Oct 26 16:48:01 2011 UTC (13 years, 5 months ago) by greg
Sat Oct 22 22:38:10 2011 UTC (13 years, 5 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
