root/radiance/ray/src/util/CMakeLists.txt
Revision: 1.50
Committed: Fri Apr 18 23:59:03 2025 UTC (13 days, 13 hours ago) by greg
Changes since 1.49: +2 -2 lines
1 set(VERSION_FILE "${radiance_BINARY_DIR}/src/util/Version.c")
2 create_version_file("${VERSION_FILE}")
3
4 add_executable(dctimestep dctimestep.c cmbsdf.c cmatrix.c)
5 target_link_libraries(dctimestep rtrad)
6
7 add_executable(findglare findglare.c glareval.c glaresrc.c setscan.c)
8 target_link_libraries(findglare rtrad)
9
10 add_executable(getinfo getinfo.c)
11 target_link_libraries(getinfo rtrad)
12
13 add_executable(glarendx glarendx.c)
14 target_link_libraries(glarendx rtrad)
15
16 add_executable(rad rad.c)
17 target_link_libraries(rad rtrad)
18
19 add_executable(rcrop rcrop.c)
20 target_link_libraries(rcrop rtrad)
21
22 if(WIN32)
23 set(netproc_SOURCES win_netproc.c)
24 else()
25 set(netproc_SOURCES netproc.c)
26 endif()
27
28 add_executable(ranimate ranimate.c ${netproc_SOURCES})
29 target_link_libraries(ranimate rtrad)
30
31 add_executable(rpiece rpiece.c "${VERSION_FILE}")
32 target_link_libraries(rpiece rtrad)
33
34 add_executable(vwrays vwrays.c)
35 target_link_libraries(vwrays rtrad)
36
37 add_executable(vwright vwright.c)
38 target_link_libraries(vwright rtrad)
39
40 add_executable(dcglare dcglare.c cmbsdf.c cmatrix.c cmglare.c)
41 target_link_libraries(dcglare rtrad)
42
43 #the next few libraries all need to include header files from the rt directory
44 include_directories("${CMAKE_CURRENT_SOURCE_DIR}/../rt")
45
46 add_executable(ranimove ranimove.c ranimove1.c ranimove2.c)
47 target_link_libraries(ranimove raycalls radiance rtrad)
48
49 add_executable(rsensor rsensor.c)
50 target_link_libraries(rsensor raycalls radiance rtrad)
51
52 add_executable(rttree_reduce rttree_reduce.c)
53 target_link_libraries(rttree_reduce rtrad)
54
55 add_executable(rcollate rcollate.c)
56 target_link_libraries(rcollate rtrad)
57
58 add_executable(rmtxop rmtxop.c rmatrix.c cmbsdf.c cmatrix.c)
59 target_link_libraries(rmtxop rtrad)
60
61 add_executable(rcomb rcomb.c rmatrix.c cmatrix.c)
62 target_link_libraries(rcomb rtrad)
63
64 add_executable(pvsum pvsum.c rmatrix.c cmatrix.c)
65 target_link_libraries(pvsum rtrad)
66
67 add_executable(wrapBSDF wrapBSDF.c)
68 target_link_libraries(wrapBSDF rtrad)
69
70 add_executable(eplus_adduvf eplus_adduvf.c eplus_idf.c)
71 target_link_libraries(eplus_adduvf rtrad)
72
73 add_executable(rfluxmtx rfluxmtx.c)
74 target_link_libraries(rfluxmtx rtrad)
75
76 add_executable(evalglare evalglare.c pictool.c)
77 target_link_libraries(evalglare rtrad reetz)
78
79 add_executable(radcompare radcompare.c)
80 target_link_libraries(radcompare rtrad)
81
82 add_executable(rcode_depth rcode_depth.c)
83 target_link_libraries(rcode_depth rtrad)
84
85 add_executable(rcode_norm rcode_norm.c)
86 target_link_libraries(rcode_norm rtrad)
87
88 add_executable(rcode_ident rcode_ident.c)
89 target_link_libraries(rcode_ident rtrad)
90
91 if(X11_FOUND)
92 add_executable(xglaresrc
93 xglaresrc.c
94 "${CMAKE_CURRENT_SOURCE_DIR}/../common/x11findwind.c"
95 )
96 target_link_libraries(xglaresrc rtrad ${X11_LIBRARIES})
97 install(TARGETS xglaresrc
98 RUNTIME DESTINATION "bin"
99 )
100 endif()
101
102 #glrad needs to link against OpenGL libraries
103 if(APPLE)
104 find_library(OPENGL_gl_LIBRARY
105 NAMES GL MesaGL
106 PATHS ${X11_LIB_SEARCH_PATH}
107 )
108 find_library(OPENGL_glu_LIBRARY
109 NAMES GLU MesaGLU
110 PATHS ${X11_LIB_SEARCH_PATH}
111 )
112 set(OPENGL_LIBRARIES ${OPENGL_gl_LIBRARY} ${OPENGL_glu_LIBRARY})
113 else()
114 find_package(OpenGL REQUIRED)
115 include_directories(${OPENGL_INCLUDE_DIR})
116 endif()
117
118 #check if we have SGIStereo.h
119 find_file(HAVE_SGISTEREO_H "SGIStereo.h" ${OPENGL_INCLUDE_DIR})
120 if(NOT HAVE_SGISTEREO_H)
121 add_definitions(-DNOSTEREO)
122 endif()
123 if(UNIX AND X11_FOUND)
124 add_executable(glrad glrad.c)
125 target_link_libraries(glrad rgl rtrad ${OPENGL_LIBRARIES} ${X11_LIBRARIES})
126 install(TARGETS glrad
127 RUNTIME DESTINATION "bin"
128 )
129 if(CMAKE_SYSTEM_NAME STREQUAL "SunOS")
130 target_link_libraries(glrad rt)
131 endif()
132 endif()
133
134 if(UNIX)
135 install(TARGETS rpiece
136 RUNTIME DESTINATION "bin"
137 )
138 endif()
139
140 install(TARGETS
141 dcglare
142 dctimestep
143 eplus_adduvf
144 evalglare
145 findglare
146 getinfo
147 glarendx
148 rad
149 radcompare
150 ranimate
151 ranimove
152 rcode_depth
153 rcode_ident
154 rcode_norm
155 rcollate
156 rcrop
157 rfluxmtx
158 rmtxop
159 rcomb
160 rsensor
161 rttree_reduce
162 vwrays
163 vwright
164 wrapBSDF
165 RUNTIME DESTINATION "bin"
166 )
167
168 file(COPY
169 ambpos.cal
170 disk2square.cal
171 hsv_rgb.cal
172 klems_full.cal
173 klems_half.cal
174 klems_quarter.cal
175 minimalBSDFt.xml
176 rambpos.cal
177 reinhartb.cal
178 tregsamp.dat
179 WINDOW6BSDFt.xml
180 DESTINATION "${CMAKE_BINARY_DIR}/lib"
181 )
182
183 if(WIN32)
184 add_custom_target(bsdfview ALL
185 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/bsdfview.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/bsdfview.exe -d
186 )
187 add_custom_target(genBSDF ALL
188 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/genBSDF.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/genBSDF.exe -d
189 )
190 add_custom_target(genklemsamp ALL
191 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/genklemsamp.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/genklemsamp.exe -d
192 )
193 add_custom_target(genskyvec ALL
194 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/genskyvec.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/genskyvec.exe -d
195 )
196 add_custom_target(ltpict ALL
197 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/ltpict.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/ltpict.exe -d
198 )
199 add_custom_target(ltview ALL
200 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/ltview.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/ltview.exe -d
201 )
202 add_custom_target(objpict ALL
203 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/objpict.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/objpict.exe -d
204 )
205 add_custom_target(objview ALL
206 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/objview.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/objview.exe -d
207 )
208 add_custom_target(genambpos ALL
209 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/genambpos.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/genambpos.exe -d
210 )
211 add_custom_target(rcode2bmp ALL
212 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/rcode2bmp.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/rcode2bmp.exe -d
213 )
214 add_custom_target(rtpict ALL
215 COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/rtpict.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/rtpict.exe -d
216 )
217 install(PROGRAMS
218 bsdfview.exe
219 genBSDF.exe
220 genklemsamp.exe
221 genskyvec.exe
222 ltpict.exe
223 ltview.exe
224 objpict.exe
225 objview.exe
226 genambpos.exe
227 rcode2bmp.exe
228 rtpict.exe
229 DESTINATION "bin"
230 )
231 else()
232 install_without_extension(
233 bsdfview.pl
234 compamb.csh
235 dayfact.csh
236 fieldcomb.csh
237 genBSDF.pl
238 genambpos.pl
239 genklemsamp.pl
240 genskyvec.pl
241 glare.csh
242 ltpict.pl
243 ltview.pl
244 objline.csh
245 objpict.pl
246 objview.pl
247 raddepend.csh
248 rcode2bmp.pl
249 rlux.csh
250 rtpict.pl
251 vinfo.csh
252 )
253 # add_custom_target(trad ALL
254 # COMMAND csh -f ${CMAKE_CURRENT_SOURCE_DIR}/tradinstall.csh ../../build/bin ../../build/lib
255 # )
256 # install(FILES
257 # ${CMAKE_BINARY_DIR}/bin/trad
258 # DESTINATION "bin"
259 # PERMISSIONS OWNER_EXECUTE OWNER_WRITE OWNER_READ GROUP_EXECUTE GROUP_READ
260 # )
261 endif()
