root/radiance/ray/src/util/CMakeLists.txt
Revision: 1.23
Committed: Mon Apr 25 16:15:19 2016 UTC (8 years, 1 month ago) by greg
Changes since 1.22: +6 -1 lines
Checked in fix from RobG to fix packaging issues
1 set(VERSION_FILE "${radiance_BINARY_DIR}/src/util/Version.c")
2 create_version_file("${VERSION_FILE}")
3
4 add_executable(dctimestep dctimestep.c cmbsdf.c cmatrix.c)
5 target_link_libraries(dctimestep rtrad)
6
7 add_executable(findglare findglare.c glareval.c glaresrc.c setscan.c)
8 target_link_libraries(findglare rtrad)
9
10 add_executable(getinfo getinfo.c)
11 target_link_libraries(getinfo rtrad)
12
13 add_executable(glarendx glarendx.c)
14 target_link_libraries(glarendx rtrad)
15
16 add_executable(rad rad.c)
17 target_link_libraries(rad rtrad)
18 if(WIN32)
19 set(netproc_SOURCES win_netproc.c)
20 else()
21 set(netproc_SOURCES netproc.c)
22 endif()
23 add_executable(ranimate ranimate.c ${netproc_SOURCES})
24 target_link_libraries(ranimate rtrad)
25
26 add_executable(rpiece rpiece.c "${VERSION_FILE}")
27 target_link_libraries(rpiece rtrad)
28
29 add_executable(vwrays vwrays.c)
30 target_link_libraries(vwrays rtrad)
31
32 add_executable(vwright vwright.c)
33 target_link_libraries(vwright rtrad)
34
35 #the next few libraries all need to include header files from the rt directory
36 include_directories(${CMAKE_CURRENT_SOURCE_DIR}/../rt)
37
38 add_executable(ranimove ranimove.c ranimove1.c ranimove2.c)
39 target_link_libraries(ranimove raycalls radiance rtrad)
40
41 add_executable(rsensor rsensor.c)
42 target_link_libraries(rsensor raycalls radiance rtrad)
43
44 add_executable(rttree_reduce rttree_reduce.c)
45 target_link_libraries(rttree_reduce rtrad)
46
47 add_executable(rcollate rcollate.c)
48 target_link_libraries(rcollate rtrad)
49
50 add_executable(rmtxop rmtxop.c rmatrix.c cmbsdf.c cmatrix.c)
51 target_link_libraries(rmtxop rtrad)
52
53 add_executable(wrapBSDF wrapBSDF.c)
54 target_link_libraries(wrapBSDF rtrad)
55
56 add_executable(eplus_adduvf eplus_adduvf.c eplus_idf.c)
57 target_link_libraries(eplus_adduvf rtrad)
58
59 add_executable(rfluxmtx rfluxmtx.c)
60 target_link_libraries(rfluxmtx rtrad)
61
62 add_executable(evalglare evalglare.c pictool.c)
63 target_link_libraries(evalglare rtrad libreetz)
64
65 if(X11_FOUND)
66 add_executable(xglaresrc
67 xglaresrc.c ${CMAKE_CURRENT_SOURCE_DIR}/../common/x11findwind.c)
68 target_link_libraries(xglaresrc rtrad ${X11_LIBRARIES})
69 install(TARGETS xglaresrc RUNTIME DESTINATION bin)
70 endif()
71
72 #glrad needs to link against OpenGL libraries
73 if(APPLE)
74 find_library(OPENGL_gl_LIBRARY
75 NAMES GL MesaGL
76 PATHS /usr/X11R6/lib
77 )
78 find_library(OPENGL_glu_LIBRARY
79 NAMES GLU MesaGLU
80 PATHS /usr/X11R6/lib
81 )
82 set(OPENGL_LIBRARIES ${OPENGL_gl_LIBRARY} ${OPENGL_glu_LIBRARY})
83 else()
84 find_package(OpenGL REQUIRED)
85 include_directories(${OPENGL_INCLUDE_DIR})
86 endif()
87
88 #check if we have SGIStereo.h
89 find_file(HAVE_SGISTEREO_H "SGIStereo.h" ${OPENGL_INCLUDE_DIR})
90 if(NOT HAVE_SGISTEREO_H)
91 add_definitions(-DNOSTEREO)
92 endif()
93 if(UNIX AND X11_FOUND)
94 add_executable(glrad glrad.c)
95 target_link_libraries(glrad rgl rtrad ${OPENGL_LIBRARIES} ${X11_LIBRARIES})
96 install(TARGETS glrad RUNTIME DESTINATION bin)
97 if(CMAKE_SYSTEM_NAME STREQUAL "SunOS")
98 target_link_libraries(glrad rt)
99 endif()
100 endif()
101
102 if(UNIX)
103 install (TARGETS rpiece RUNTIME DESTINATION bin)
104 endif()
105
106 install(TARGETS dctimestep findglare getinfo glarendx rad ranimate
107 vwrays vwright ranimove rsensor rttree_reduce rcollate
108 eplus_adduvf rfluxmtx rmtxop wrapBSDF evalglare
109 RUNTIME DESTINATION bin)
110
111 install(FILES rambpos.cal ambpos.cal tregsamp.dat reinhartb.cal
112 klems_full.cal klems_half.cal klems_quarter.cal disk2square.cal
113 WINDOW6BSDFt.xml minimalBSDFt.xml
114 DESTINATION lib)
115
116 if(WIN32)
117 install(PROGRAMS genBSDF.pl DESTINATION bin)
118 install(PROGRAMS genklemsamp.pl DESTINATION bin)
119 install(PROGRAMS genskyvec.pl DESTINATION bin)
120 install(PROGRAMS ltview.pl DESTINATION bin)
121 install(PROGRAMS ltpict.pl DESTINATION bin)
122 install(PROGRAMS objview.pl DESTINATION bin)
123 install(PROGRAMS objpict.pl DESTINATION bin)
124 else()
125 install(PROGRAMS genBSDF.pl DESTINATION bin RENAME genBSDF)
126 install(PROGRAMS genklemsamp.pl DESTINATION bin RENAME genklemsamp)
127 install(PROGRAMS genskyvec.pl DESTINATION bin RENAME genskyvec)
128 install(PROGRAMS genambpos.csh DESTINATION bin RENAME genambpos)
129 install(PROGRAMS ltview.pl DESTINATION bin)
130 install(PROGRAMS ltpict.pl DESTINATION bin)
131 install(PROGRAMS objview.pl DESTINATION bin RENAME objview)
132 install(PROGRAMS objpict.pl DESTINATION bin RENAME objpict)
133 install(PROGRAMS glare.csh DESTINATION bin RENAME glare)
134 install(PROGRAMS dayfact.csh DESTINATION bin RENAME dayfact)
135 install(PROGRAMS rlux.csh DESTINATION bin RENAME rlux)
136 install(PROGRAMS raddepend.csh DESTINATION bin RENAME raddepend)
137 install(PROGRAMS trad.wsh DESTINATION bin RENAME trad)
138 install(PROGRAMS objline.csh DESTINATION bin RENAME objline)
139 install(PROGRAMS compamb.csh DESTINATION bin RENAME compamb)
140 install(PROGRAMS vinfo.csh DESTINATION bin RENAME vinfo)
141 install(PROGRAMS fieldcomb.csh DESTINATION bin RENAME fieldcomb)
142 endif()
