root/radiance/ray/src/util/CMakeLists.txt
Sat Apr 19 17:54:52 2025 UTC (3 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 1.51: +3 -3 lines
Diff to previous 1.51 , to selected 1.50
chore: Adjustments to matrix modules rearrangement
Sat Apr 19 17:12:59 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 1.50: +5 -5 lines
Diff to previous 1.50
refactor: Isolated RMATRIX<->CMATRIX conversion routines
Revision 1.50 - (view) (download) (annotate) - [selected]
Fri Apr 18 23:59:03 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 1.49: +2 -2 lines
Diff to previous 1.49
Thu Mar 27 01:26:55 2025 UTC (4 months, 2 weeks ago) by greg
Changes since 1.48: +3 -0 lines
Diff to previous 1.48 , to selected 1.50
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
Tue Dec 12 16:31:45 2023 UTC (20 months ago) by greg
Changes since 1.47: +3 -3 lines
Diff to previous 1.47 , to selected 1.50
Tue Dec 5 01:06:10 2023 UTC (20 months, 1 week ago) by greg
Changes since 1.46: +4 -0 lines
Diff to previous 1.46 , to selected 1.50
feat(rmtxcomb): Initial check-in of new matrix combining tool
Wed Nov 22 17:12:58 2023 UTC (20 months, 3 weeks ago) by greg
Changes since 1.45: +8 -8 lines
Diff to previous 1.45 , to selected 1.50
chore: Fixes to cmake builds for holodeck and OpenGL thanks to Randolph Fritz
Wed Jun 1 17:22:31 2022 UTC (3 years, 2 months ago) by greg
Changes since 1.44: +1 -0 lines
Diff to previous 1.44 , to selected 1.50
chore: Moved hsv_rgb.cal to build directory with dependency, where it belongs
Sun Mar 20 01:34:09 2022 UTC (3 years, 4 months ago) by greg
Changes since 1.43: +1 -0 lines
Diff to previous 1.43 , to selected 1.50
chore(rcrop): Forgot install copy for rcrop
Tue Mar 15 00:25:50 2022 UTC (3 years, 5 months ago) by greg
Changes since 1.42: +3 -0 lines
Diff to previous 1.42 , to selected 1.50
feat(rcrop): Created simple cropping utility for matrices and pictures
Mon Oct 18 16:20:21 2021 UTC (3 years, 9 months ago) by greg
Changes since 1.41: +1 -1 lines
Diff to previous 1.41 , to selected 1.50
chore(evalglare): Changed libreetz to just reetz
Thu Aug 27 22:00:27 2020 UTC (4 years, 11 months ago) by greg
Changes since 1.40: +6 -5 lines
Diff to previous 1.40 , to selected 1.50
chore(trad): corrections to cmake build for trad
Thu Aug 27 17:46:52 2020 UTC (4 years, 11 months ago) by greg
Changes since 1.39: +6 -4 lines
Diff to previous 1.39 , to selected 1.50
chore(trad): getting trad to install properly with cmake (thanks to Mingbo)
Thu Aug 20 03:37:10 2020 UTC (4 years, 11 months ago) by greg
Changes since 1.38: +5 -5 lines
Diff to previous 1.38 , to selected 1.50
chore: fixed double appearance of genklemsamp
Tue Aug 18 19:33:58 2020 UTC (4 years, 11 months ago) by greg
Changes since 1.37: +50 -10 lines
Diff to previous 1.37 , to selected 1.50
chore: added custom Windows compilation of Perl scripts
Thu Jul 16 19:57:29 2020 UTC (5 years ago) by greg
Changes since 1.36: +4 -0 lines
Diff to previous 1.36 , to selected 1.50
fix(dcglare,rcode_depth,rcode_ident,rcode_norm): added missing installer targets
Mon Sep 9 17:19:51 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 1.35 , to selected 1.50
Tue Aug 13 16:31:35 2019 UTC (6 years ago) by greg
Changes since 1.34: +1 -1 lines
Diff to previous 1.34 , to selected 1.50
Windows cleaning (thanks to Nathaniel Jones for pointing out errors)
Fri Jul 26 16:18:07 2019 UTC (6 years ago) by greg
Changes since 1.33: +3 -3 lines
Diff to previous 1.33 , to selected 1.50
Fri Jul 26 00:34:07 2019 UTC (6 years ago) by greg
Changes since 1.32: +1 -0 lines
Diff to previous 1.32 , to selected 1.50
Fri Jul 19 22:25:03 2019 UTC (6 years ago) by greg
Changes since 1.31: +3 -0 lines
Diff to previous 1.31 , to selected 1.50
Fri Jul 19 02:18:44 2019 UTC (6 years ago) by greg
Diff to previous 1.30 , to selected 1.50
Thu Jul 18 18:51:56 2019 UTC (6 years ago) by greg
Diff to previous 1.29 , to selected 1.50
Mon Oct 15 19:12:54 2018 UTC (6 years, 9 months ago) by greg
Changes since 1.28: +4 -0 lines
Diff to previous 1.28 , to selected 1.50
Added radcompare utility
Wed Jun 20 03:04:44 2018 UTC (7 years, 1 month ago) by greg
Diff to previous 1.27 , to selected 1.50
Changes by Randolph Fritz to make cmake compiles smoother on Mac
Tue Mar 20 22:48:10 2018 UTC (7 years, 4 months ago) by greg
Changes since 1.26: +0 -1 lines
Diff to previous 1.26 , to selected 1.50
Removed rtpict from Windows build, while fixing quoting so it *could* run
Tue Mar 20 17:53:48 2018 UTC (7 years, 4 months ago) by greg
Changes since 1.25: +2 -0 lines
Diff to previous 1.25 , to selected 1.50
Added rtpict.pl install
Mon Jan 8 16:51:32 2018 UTC (7 years, 7 months ago) by greg
Changes since 1.24: +84 -44 lines
Diff to previous 1.24 , to selected 1.50
Update to CMake build system from Rob G. and Alex S., adding test cases
Tue Aug 22 19:28:54 2017 UTC (7 years, 11 months ago) by greg
Diff to previous 1.23 , to selected 1.50
Minor fix for 5.1 release
Mon Apr 25 16:15:19 2016 UTC (9 years, 3 months ago) by greg
Changes since 1.22: +6 -1 lines
Diff to previous 1.22 , to selected 1.50
Checked in fix from RobG to fix packaging issues
Tue Aug 18 17:28:11 2015 UTC (9 years, 11 months ago) by greg
Changes since 1.21: +4 -1 lines
Diff to previous 1.21 , to selected 1.50
Commit to support evalglare in cmake build system (Rob G.)
Fri Feb 13 20:50:52 2015 UTC (10 years, 6 months ago) by greg
Changes since 1.20: +1 -0 lines
Diff to previous 1.20 , to selected 1.50
Added XML files to library
Wed Feb 11 22:46:42 2015 UTC (10 years, 6 months ago) by greg
Changes since 1.19: +4 -1 lines
Diff to previous 1.19 , to selected 1.50
Added wrapBSDF to targets
Fri Jul 25 20:39:22 2014 UTC (11 years ago) by greg
Changes since 1.18: +9 -4 lines
Diff to previous 1.18 , to selected 1.50
Patches for cmake build of rfluxmtx
Sun Jun 1 03:20:29 2014 UTC (11 years, 2 months ago) by greg
Changes since 1.17: +5 -1 lines
Diff to previous 1.17 , to selected 1.50
Added number of rows to dctimestep output and rmtxop to cmake build
Mon Apr 28 21:01:12 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.16: +11 -9 lines
Diff to previous 1.16 , to selected 1.50
Install new objpict and objview scripts
Thu Apr 17 16:56:37 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.15: +0 -2 lines
Diff to previous 1.15 , to selected 1.50
Eliminated a couple of mentions of removed script
Tue Apr 15 22:36:25 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.14: +4 -0 lines
Diff to previous 1.14 , to selected 1.50
Thu Mar 20 22:49:21 2014 UTC (11 years, 4 months ago) by greg
Diff to previous 1.13 , to selected 1.50
Changes to speed installation on cloud computing systems
Mon Feb 10 17:50:02 2014 UTC (11 years, 6 months ago) by greg
Changes since 1.12: +4 -1 lines
Diff to previous 1.12 , to selected 1.50
Rob updated cmake for eplus_adduvf and I added check for missing energy
Fri Feb 7 23:11:58 2014 UTC (11 years, 6 months ago) by greg
Diff to previous 1.11 , to selected 1.50
Forgot a dependency
Fri Feb 7 22:40:32 2014 UTC (11 years, 6 months ago) by greg
Diff to previous 1.10 , to selected 1.50
Broke out cm_* routines from dctimestep
Thu Sep 5 17:53:22 2013 UTC (11 years, 11 months ago) by greg
Changes since 1.9: +4 -1 lines
Diff to previous 1.9 , to selected 1.50
Thu Jun 6 03:24:49 2013 UTC (12 years, 2 months ago) by greg
Changes since 1.8: +1 -5 lines
Diff to previous 1.8 , to selected 1.50
Removed rtcontrib (again), which has been supplanted by rcontrib in src/rt
Wed Jun 5 23:30:11 2013 UTC (12 years, 2 months ago) by greg
Changes since 1.7: +4 -1 lines
Diff to previous 1.7 , to selected 1.50
Added rtcontrib back and rttree_reduce
Fri Aug 10 21:18:19 2012 UTC (13 years ago) by greg
Diff to previous 1.6 , to selected 1.50
Build fixes for cmake
Tue Aug 7 18:17:17 2012 UTC (13 years ago) by greg
Diff to previous 1.5 , to selected 1.50
Wed May 30 18:31:11 2012 UTC (13 years, 2 months ago) by greg
Changes since 1.4: +5 -1 lines
Diff to previous 1.4 , to selected 1.50
Patches to cmake build system and QT driver for rvu
Wed Apr 25 22:21:06 2012 UTC (13 years, 3 months ago) by greg
Changes since 1.3: +46 -19 lines
Diff to previous 1.3 , to selected 1.50
Fri Oct 28 20:46:47 2011 UTC (13 years, 9 months ago) by greg
Changes since 1.2: +1 -8 lines
Diff to previous 1.2 , to selected 1.50
Fixes to Version.c update in cmake build system
Wed Oct 26 16:48:01 2011 UTC (13 years, 9 months ago) by greg
Diff to previous 1.1 , to selected 1.50
Sat Oct 22 22:38:10 2011 UTC (13 years, 9 months ago) by greg
Diff to selected 1.50
Added qt interface for rvu and cmake files from Bill Hoffman
