root/radiance/ray/src/util/CMakeLists.txt
Revision: 1.21
Committed: Fri Feb 13 20:50:52 2015 UTC (10 years, 5 months ago) by greg
Changes since 1.20: +1 -0 lines
Added XML files to library
1 set(VERSION_FILE "${radiance_BINARY_DIR}/src/util/Version.c")
2 create_version_file("${VERSION_FILE}")
3
4 add_executable(dctimestep dctimestep.c cmbsdf.c cmatrix.c)
5 target_link_libraries(dctimestep rtrad)
6
7 add_executable(findglare findglare.c glareval.c glaresrc.c setscan.c)
8 target_link_libraries(findglare rtrad)
9
10 add_executable(getinfo getinfo.c)
11 target_link_libraries(getinfo rtrad)
12
13 add_executable(glarendx glarendx.c)
14 target_link_libraries(glarendx rtrad)
15
16 add_executable(rad rad.c)
17 target_link_libraries(rad rtrad)
18 if(WIN32)
19 set(netproc_SOURCES win_netproc.c)
20 else()
21 set(netproc_SOURCES netproc.c)
22 endif()
23 add_executable(ranimate ranimate.c ${netproc_SOURCES})
24 target_link_libraries(ranimate rtrad)
25
26 add_executable(rpiece rpiece.c "${VERSION_FILE}")
27 target_link_libraries(rpiece rtrad)
28
29 add_executable(vwrays vwrays.c)
30 target_link_libraries(vwrays rtrad)
31
32 add_executable(vwright vwright.c)
33 target_link_libraries(vwright rtrad)
34
35 #the next few libraries all need to include header files from the rt directory
36 include_directories(${CMAKE_CURRENT_SOURCE_DIR}/../rt)
37
38 add_executable(ranimove ranimove.c ranimove1.c ranimove2.c)
39 target_link_libraries(ranimove raycalls radiance rtrad)
40
41 add_executable(rsensor rsensor.c)
42 target_link_libraries(rsensor raycalls radiance rtrad)
43
44 add_executable(rttree_reduce rttree_reduce.c)
45 target_link_libraries(rttree_reduce rtrad)
46
47 add_executable(rcollate rcollate.c)
48 target_link_libraries(rcollate rtrad)
49
50 add_executable(rmtxop rmtxop.c rmatrix.c cmbsdf.c cmatrix.c)
51 target_link_libraries(rmtxop rtrad)
52
53 add_executable(wrapBSDF wrapBSDF.c)
54 target_link_libraries(wrapBSDF rtrad)
55
56 add_executable(eplus_adduvf eplus_adduvf.c eplus_idf.c)
57 target_link_libraries(eplus_adduvf rtrad)
58
59 add_executable(rfluxmtx rfluxmtx.c)
60 target_link_libraries(rfluxmtx rtrad)
61
62 if(X11_FOUND)
63 add_executable(xglaresrc
64 xglaresrc.c ${CMAKE_CURRENT_SOURCE_DIR}/../common/x11findwind.c)
65 target_link_libraries(xglaresrc rtrad ${X11_LIBRARIES})
66 install(TARGETS xglaresrc RUNTIME DESTINATION bin)
67 endif()
68
69 #glrad needs to link against OpenGL libraries
70 if(APPLE)
71 find_library(OPENGL_gl_LIBRARY
72 NAMES GL MesaGL
73 PATHS /usr/X11R6/lib
74 )
75 find_library(OPENGL_glu_LIBRARY
76 NAMES GLU MesaGLU
77 PATHS /usr/X11R6/lib
78 )
79 set(OPENGL_LIBRARIES ${OPENGL_gl_LIBRARY} ${OPENGL_glu_LIBRARY})
80 else()
81 find_package(OpenGL REQUIRED)
82 include_directories(${OPENGL_INCLUDE_DIR})
83 endif()
84
85 #check if we have SGIStereo.h
86 find_file(HAVE_SGISTEREO_H "SGIStereo.h" ${OPENGL_INCLUDE_DIR})
87 if(NOT HAVE_SGISTEREO_H)
88 add_definitions(-DNOSTEREO)
89 endif()
90 if(UNIX AND X11_FOUND)
91 add_executable(glrad glrad.c)
92 target_link_libraries(glrad rgl rtrad ${OPENGL_LIBRARIES} ${X11_LIBRARIES})
93 install(TARGETS rpiece RUNTIME DESTINATION bin)
94 if(CMAKE_SYSTEM_NAME STREQUAL "SunOS")
95 target_link_libraries(glrad rt)
96 endif()
97 endif()
98 install(TARGETS dctimestep findglare getinfo glarendx rad ranimate
99 vwrays vwright ranimove rsensor rttree_reduce rcollate
100 eplus_adduvf rfluxmtx rmtxop wrapBSDF
101 RUNTIME DESTINATION bin)
102
103 install(FILES rambpos.cal ambpos.cal tregsamp.dat reinhartb.cal
104 klems_full.cal klems_half.cal klems_quarter.cal disk2square.cal
105 WINDOW6BSDFt.xml minimalBSDFt.xml
106 DESTINATION lib)
107
108 if(WIN32)
109 install(PROGRAMS genBSDF.pl DESTINATION bin)
110 install(PROGRAMS genklemsamp.pl DESTINATION bin)
111 install(PROGRAMS genskyvec.pl DESTINATION bin)
112 install(PROGRAMS ltview.pl DESTINATION bin)
113 install(PROGRAMS ltpict.pl DESTINATION bin)
114 install(PROGRAMS objview.pl DESTINATION bin)
115 install(PROGRAMS objpict.pl DESTINATION bin)
116 else()
117 install(PROGRAMS genBSDF.pl DESTINATION bin RENAME genBSDF)
118 install(PROGRAMS genklemsamp.pl DESTINATION bin RENAME genklemsamp)
119 install(PROGRAMS genskyvec.pl DESTINATION bin RENAME genskyvec)
120 install(PROGRAMS genambpos.csh DESTINATION bin RENAME genambpos)
121 install(PROGRAMS ltview.pl DESTINATION bin)
122 install(PROGRAMS ltpict.pl DESTINATION bin)
123 install(PROGRAMS objview.pl DESTINATION bin RENAME objview)
124 install(PROGRAMS objpict.pl DESTINATION bin RENAME objpict)
125 install(PROGRAMS glare.csh DESTINATION bin RENAME glare)
126 install(PROGRAMS dayfact.csh DESTINATION bin RENAME dayfact)
127 install(PROGRAMS rlux.csh DESTINATION bin RENAME rlux)
128 install(PROGRAMS raddepend.csh DESTINATION bin RENAME raddepend)
129 install(PROGRAMS trad.wsh DESTINATION bin RENAME trad)
130 install(PROGRAMS objline.csh DESTINATION bin RENAME objline)
131 install(PROGRAMS compamb.csh DESTINATION bin RENAME compamb)
132 install(PROGRAMS vinfo.csh DESTINATION bin RENAME vinfo)
133 install(PROGRAMS fieldcomb.csh DESTINATION bin RENAME fieldcomb)
134 endif()
