--- ray/src/util/CMakeLists.txt 2016/04/25 16:15:19 1.23 +++ ray/src/util/CMakeLists.txt 2023/12/05 01:06:10 1.47 @@ -15,11 +15,16 @@ target_link_libraries(glarendx rtrad) add_executable(rad rad.c) target_link_libraries(rad rtrad) + +add_executable(rcrop rcrop.c) +target_link_libraries(rcrop rtrad) + if(WIN32) set(netproc_SOURCES win_netproc.c) else() set(netproc_SOURCES netproc.c) endif() + add_executable(ranimate ranimate.c ${netproc_SOURCES}) target_link_libraries(ranimate rtrad) @@ -32,8 +37,11 @@ target_link_libraries(vwrays rtrad) add_executable(vwright vwright.c) target_link_libraries(vwright rtrad) +add_executable(dcglare dcglare.c cmbsdf.c cmatrix.c cmglare.c) +target_link_libraries(dcglare rtrad) + #the next few libraries all need to include header files from the rt directory -include_directories(${CMAKE_CURRENT_SOURCE_DIR}/../rt) +include_directories("${CMAKE_CURRENT_SOURCE_DIR}/../rt") add_executable(ranimove ranimove.c ranimove1.c ranimove2.c) target_link_libraries(ranimove raycalls radiance rtrad) @@ -50,6 +58,9 @@ target_link_libraries(rcollate rtrad) add_executable(rmtxop rmtxop.c rmatrix.c cmbsdf.c cmatrix.c) target_link_libraries(rmtxop rtrad) +add_executable(rmtxcomb rmtxcomb.c rmatrix.c cmbsdf.c cmatrix.c) +target_link_libraries(rmtxcomb rtrad) + add_executable(wrapBSDF wrapBSDF.c) target_link_libraries(wrapBSDF rtrad) @@ -60,24 +71,40 @@ add_executable(rfluxmtx rfluxmtx.c) target_link_libraries(rfluxmtx rtrad) add_executable(evalglare evalglare.c pictool.c) -target_link_libraries(evalglare rtrad libreetz) +target_link_libraries(evalglare rtrad reetz) +add_executable(radcompare radcompare.c) +target_link_libraries(radcompare rtrad) + +add_executable(rcode_depth rcode_depth.c) +target_link_libraries(rcode_depth rtrad) + +add_executable(rcode_norm rcode_norm.c) +target_link_libraries(rcode_norm rtrad) + +add_executable(rcode_ident rcode_ident.c) +target_link_libraries(rcode_ident rtrad) + if(X11_FOUND) add_executable(xglaresrc - xglaresrc.c ${CMAKE_CURRENT_SOURCE_DIR}/../common/x11findwind.c) + xglaresrc.c + "${CMAKE_CURRENT_SOURCE_DIR}/../common/x11findwind.c" + ) target_link_libraries(xglaresrc rtrad ${X11_LIBRARIES}) - install(TARGETS xglaresrc RUNTIME DESTINATION bin) + install(TARGETS xglaresrc + RUNTIME DESTINATION "bin" + ) endif() #glrad needs to link against OpenGL libraries if(APPLE) find_library(OPENGL_gl_LIBRARY NAMES GL MesaGL - PATHS /usr/X11R6/lib + PATHS ${X11_LIB_SEARCH_PATH} ) find_library(OPENGL_glu_LIBRARY NAMES GLU MesaGLU - PATHS /usr/X11R6/lib + PATHS ${X11_LIB_SEARCH_PATH} ) set(OPENGL_LIBRARIES ${OPENGL_gl_LIBRARY} ${OPENGL_glu_LIBRARY}) else() @@ -85,58 +112,147 @@ else() include_directories(${OPENGL_INCLUDE_DIR}) endif() -#check if we have SGIStereo.h +#check if we have SGIStereo.h find_file(HAVE_SGISTEREO_H "SGIStereo.h" ${OPENGL_INCLUDE_DIR}) if(NOT HAVE_SGISTEREO_H) - add_definitions(-DNOSTEREO) + add_definitions(-DNOSTEREO) endif() if(UNIX AND X11_FOUND) - add_executable(glrad glrad.c) - target_link_libraries(glrad rgl rtrad ${OPENGL_LIBRARIES} ${X11_LIBRARIES}) - install(TARGETS glrad RUNTIME DESTINATION bin) + add_executable(glrad glrad.c) + target_link_libraries(glrad rgl rtrad ${OPENGL_LIBRARIES} ${X11_LIBRARIES}) + install(TARGETS glrad + RUNTIME DESTINATION "bin" + ) if(CMAKE_SYSTEM_NAME STREQUAL "SunOS") target_link_libraries(glrad rt) endif() endif() if(UNIX) - install (TARGETS rpiece RUNTIME DESTINATION bin) + install(TARGETS rpiece + RUNTIME DESTINATION "bin" + ) endif() -install(TARGETS dctimestep findglare getinfo glarendx rad ranimate - vwrays vwright ranimove rsensor rttree_reduce rcollate - eplus_adduvf rfluxmtx rmtxop wrapBSDF evalglare - RUNTIME DESTINATION bin) +install(TARGETS + dcglare + dctimestep + eplus_adduvf + evalglare + findglare + getinfo + glarendx + rad + radcompare + ranimate + ranimove + rcode_depth + rcode_ident + rcode_norm + rcollate + rcrop + rfluxmtx + rmtxop + rmtxcomb + rsensor + rttree_reduce + vwrays + vwright + wrapBSDF + RUNTIME DESTINATION "bin" +) -install(FILES rambpos.cal ambpos.cal tregsamp.dat reinhartb.cal - klems_full.cal klems_half.cal klems_quarter.cal disk2square.cal - WINDOW6BSDFt.xml minimalBSDFt.xml - DESTINATION lib) +file(COPY + ambpos.cal + disk2square.cal + hsv_rgb.cal + klems_full.cal + klems_half.cal + klems_quarter.cal + minimalBSDFt.xml + rambpos.cal + reinhartb.cal + tregsamp.dat + WINDOW6BSDFt.xml + DESTINATION "${CMAKE_BINARY_DIR}/lib" +) if(WIN32) - install(PROGRAMS genBSDF.pl DESTINATION bin) - install(PROGRAMS genklemsamp.pl DESTINATION bin) - install(PROGRAMS genskyvec.pl DESTINATION bin) - install(PROGRAMS ltview.pl DESTINATION bin) - install(PROGRAMS ltpict.pl DESTINATION bin) - install(PROGRAMS objview.pl DESTINATION bin) - install(PROGRAMS objpict.pl DESTINATION bin) + add_custom_target(bsdfview ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/bsdfview.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/bsdfview.exe -d + ) + add_custom_target(genBSDF ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/genBSDF.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/genBSDF.exe -d + ) + add_custom_target(genklemsamp ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/genklemsamp.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/genklemsamp.exe -d + ) + add_custom_target(genskyvec ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/genskyvec.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/genskyvec.exe -d + ) + add_custom_target(ltpict ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/ltpict.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/ltpict.exe -d + ) + add_custom_target(ltview ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/ltview.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/ltview.exe -d + ) + add_custom_target(objpict ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/objpict.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/objpict.exe -d + ) + add_custom_target(objview ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/objview.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/objview.exe -d + ) + add_custom_target(genambpos ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/genambpos.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/genambpos.exe -d + ) + add_custom_target(rcode2bmp ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/rcode2bmp.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/rcode2bmp.exe -d + ) + add_custom_target(rtpict ALL + COMMAND pp ${CMAKE_CURRENT_SOURCE_DIR}/rtpict.pl -o ${CMAKE_CURRENT_SOURCE_DIR}/rtpict.exe -d + ) + install(PROGRAMS + bsdfview.exe + genBSDF.exe + genklemsamp.exe + genskyvec.exe + ltpict.exe + ltview.exe + objpict.exe + objview.exe + genambpos.exe + rcode2bmp.exe + rtpict.exe + DESTINATION "bin" + ) else() - install(PROGRAMS genBSDF.pl DESTINATION bin RENAME genBSDF) - install(PROGRAMS genklemsamp.pl DESTINATION bin RENAME genklemsamp) - install(PROGRAMS genskyvec.pl DESTINATION bin RENAME genskyvec) - install(PROGRAMS genambpos.csh DESTINATION bin RENAME genambpos) - install(PROGRAMS ltview.pl DESTINATION bin) - install(PROGRAMS ltpict.pl DESTINATION bin) - install(PROGRAMS objview.pl DESTINATION bin RENAME objview) - install(PROGRAMS objpict.pl DESTINATION bin RENAME objpict) - install(PROGRAMS glare.csh DESTINATION bin RENAME glare) - install(PROGRAMS dayfact.csh DESTINATION bin RENAME dayfact) - install(PROGRAMS rlux.csh DESTINATION bin RENAME rlux) - install(PROGRAMS raddepend.csh DESTINATION bin RENAME raddepend) - install(PROGRAMS trad.wsh DESTINATION bin RENAME trad) - install(PROGRAMS objline.csh DESTINATION bin RENAME objline) - install(PROGRAMS compamb.csh DESTINATION bin RENAME compamb) - install(PROGRAMS vinfo.csh DESTINATION bin RENAME vinfo) - install(PROGRAMS fieldcomb.csh DESTINATION bin RENAME fieldcomb) + install_without_extension( + bsdfview.pl + compamb.csh + dayfact.csh + fieldcomb.csh + genBSDF.pl + genambpos.pl + genklemsamp.pl + genskyvec.pl + glare.csh + ltpict.pl + ltview.pl + objline.csh + objpict.pl + objview.pl + raddepend.csh + rcode2bmp.pl + rlux.csh + rtpict.pl + vinfo.csh + ) + # add_custom_target(trad ALL + # COMMAND csh -f ${CMAKE_CURRENT_SOURCE_DIR}/tradinstall.csh ../../build/bin ../../build/lib + # ) + # install(FILES + # ${CMAKE_BINARY_DIR}/bin/trad + # DESTINATION "bin" + # PERMISSIONS OWNER_EXECUTE OWNER_WRITE OWNER_READ GROUP_EXECUTE GROUP_READ + # ) endif()
