chore(trad): corrections to cmake build for trad
chore(trad): getting trad to install properly with cmake (thanks to Mingbo)
chore: fixed double appearance of genklemsamp
chore: added custom Windows compilation of Perl scripts
fix(dcglare,rcode_depth,rcode_ident,rcode_norm): added missing installer targets
Windows cleaning (thanks to Nathaniel Jones for pointing out errors)
Added radcompare utility
Changes by Randolph Fritz to make cmake compiles smoother on Mac
Removed rtpict from Windows build, while fixing quoting so it *could* run
Added rtpict.pl install
Update to CMake build system from Rob G. and Alex S., adding test cases
Minor fix for 5.1 release
Checked in fix from RobG to fix packaging issues
Commit to support evalglare in cmake build system (Rob G.)
Added XML files to library
Added wrapBSDF to targets
Patches for cmake build of rfluxmtx
Added number of rows to dctimestep output and rmtxop to cmake build
Install new objpict and objview scripts
Eliminated a couple of mentions of removed script
Changes to speed installation on cloud computing systems
Rob updated cmake for eplus_adduvf and I added check for missing energy
Forgot a dependency
Broke out cm_* routines from dctimestep
Removed rtcontrib (again), which has been supplanted by rcontrib in src/rt
Added rtcontrib back and rttree_reduce
Build fixes for cmake
Patches to cmake build system and QT driver for rvu
Fixes to Version.c update in cmake build system
Added qt interface for rvu and cmake files from Bill Hoffman
