--- ray/src/rt/x11twind.h 2003/02/22 02:07:29 2.2 +++ ray/src/rt/x11twind.h 2003/06/27 06:53:23 2.6 @@ -1,4 +1,4 @@ -/* RCSid: $Id: x11twind.h,v 2.2 2003/02/22 02:07:29 greg Exp $ */ +/* RCSid $Id: x11twind.h,v 2.6 2003/06/27 06:53:23 greg Exp $ */ /* * xtwind.h - header for X text window routines. * @@ -8,64 +8,12 @@ * Modified for X11 B. V. Smith * 9/26/88 */ +#ifndef _RAD_X11TWIND_H_ +#define _RAD_X11TWIND_H_ +#ifdef __cplusplus +extern "C" { +#endif -/* ==================================================================== - * The Radiance Software License, Version 1.0 - * - * Copyright (c) 1990 - 2002 The Regents of the University of California, - * through Lawrence Berkeley National Laboratory. All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * 1. Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * - * 2. Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * - * 3. The end-user documentation included with the redistribution, - * if any, must include the following acknowledgment: - * "This product includes Radiance software - * (http://radsite.lbl.gov/) - * developed by the Lawrence Berkeley National Laboratory - * (http://www.lbl.gov/)." - * Alternately, this acknowledgment may appear in the software itself, - * if and wherever such third-party acknowledgments normally appear. - * - * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" - * and "The Regents of the University of California" must - * not be used to endorse or promote products derived from this - * software without prior written permission. For written - * permission, please contact radiance@radsite.lbl.gov. - * - * 5. Products derived from this software may not be called "Radiance", - * nor may "Radiance" appear in their name, without prior written - * permission of Lawrence Berkeley National Laboratory. - * - * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED - * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES - * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR - * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF - * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, - * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT - * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - * ==================================================================== - * - * This software consists of voluntary contributions made by many - * individuals on behalf of Lawrence Berkeley National Laboratory. For more - * information on Lawrence Berkeley National Laboratory, please see - * . - */ - #define LEFTMAR 2 /* left margin width */ typedef struct { @@ -82,27 +30,12 @@ typedef struct { #define TNOCURS 0 #define TBLKCURS 1 -#ifdef NOPROTO - -extern TEXTWIND *xt_open(); -extern void xt_puts(); -extern void xt_putc(); -extern void xt_delete(); -extern void xt_insert(); -extern void xt_redraw(); -extern void xt_clear(); -extern void xt_move(); -extern int xt_cursor(); -extern void xt_close(); - -#else - extern TEXTWIND *xt_open(Display *dpy, Window parent, int x, int y, int width, int height, int bw, unsigned long fore, unsigned long back, char *fontname); extern void xt_puts(char *s, TEXTWIND *t); -extern void xt_putc(char c, TEXTWIND *t); +extern void xt_putc(int c, TEXTWIND *t); extern void xt_delete(TEXTWIND *t, int r); extern void xt_insert(TEXTWIND *t, int r); extern void xt_redraw(TEXTWIND *t); @@ -111,4 +44,9 @@ extern void xt_move(TEXTWIND *t, int r, int c); extern int xt_cursor(TEXTWIND *t, int curs); extern void xt_close(TEXTWIND *t); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_X11TWIND_H_ */ +
