root/radiance/ray/src/rt/x11.c
Revision: 2.32
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
Changes since 2.31: +86 -47 lines
2 static const char RCSid[] = "$Id: x11.c,v 2.31 2003/07/21 22:30:19 schorsch Exp $";
5 * x11.c - driver for X-windows version 11
6 */
7
8 #include "copyright.h"
9
10 #include "standard.h"
11 #include <sys/ioctl.h>
12 #ifdef sparc
13 #include <sys/conf.h>
14 #include <sys/file.h>
15 #include <sys/filio.h>
16 #endif
17 #if !defined(FNDELAY) && defined(O_NONBLOCK)
18 #define FNDELAY O_NONBLOCK
19 #endif
20
21 #include <X11/Xlib.h>
22 #include <X11/cursorfont.h>
23 #include <X11/Xutil.h>
24
25 #include "platform.h"
26 #include "color.h"
27 #include "driver.h"
28 #include "x11twind.h"
29 #include "x11icon.h"
30
31 #define GAMMA 2.2 /* default exponent correction */
32
33 #define MINWIDTH (32*COMCW) /* minimum graphics window width */
34 #define MINHEIGHT (MINWIDTH/2) /* minimum graphics window height */
35
36 #define BORWIDTH 5 /* border width */
37 #define COMHEIGHT (COMLH*COMCH) /* command line height (pixels) */
38
39 #define COMFN "8x13" /* command line font name */
40 #define COMLH 3 /* number of command lines */
41 #define COMCW 8 /* approx. character width (pixels) */
42 #define COMCH 14 /* approx. character height (pixels) */
43
44 #define ourscreen DefaultScreen(ourdisplay)
45 #define ourroot RootWindow(ourdisplay,ourscreen)
46
47 #define levptr(etype) ((etype *)&currentevent)
48
49 static XEvent currentevent; /* current event */
50
51 static int ncolors = 0; /* color table size */
52 static int mapped = 0; /* window is mapped? */
53 static unsigned long *pixval = NULL; /* allocated pixels */
54 static unsigned long ourblack=0, ourwhite=1;
55
56 static Display *ourdisplay = NULL; /* our display */
57
58 static XVisualInfo ourvinfo; /* our visual information */
59
60 static Window gwind = 0; /* our graphics window */
61
62 static Cursor pickcursor = 0; /* cursor used for picking */
63
64 static int gwidth, gheight; /* graphics window size */
65
66 static int comheight; /* desired comline height */
67 static TEXTWIND *comline = NULL; /* our command line */
68
69 static char c_queue[64]; /* input queue */
70 static int c_first = 0; /* first character in queue */
71 static int c_last = 0; /* last character in queue */
72
73 static GC ourgc = 0; /* our graphics context for drawing */
74
75 static Colormap ourmap = 0; /* our color map */
76
77 #define IC_X11 0
78 #define IC_IOCTL 1
79 #define IC_READ 2
80
81 static int inpcheck; /* whence to check input */
82
83 static void x11_errout(char *msg);
84
85 static dr_closef_t x11_close;
86 static dr_clearf_t x11_clear;
87 static dr_paintrf_t x11_paintr;
88 static dr_getcurf_t x11_getcur;
89 static dr_comoutf_t x11_comout;
90 static dr_cominf_t x11_comin;
91 static dr_flushf_t x11_flush;
92
93 static dr_cominf_t std_comin;
94 static dr_comoutf_t std_comout;
95
96 static struct driver x11_driver = {
97 x11_close, x11_clear, x11_paintr, x11_getcur,
98 NULL, NULL, x11_flush, 1.0
99 };
100
101 static dr_getchf_t x11_getc;
102
103 static void freepixels(void);
104 static int getpixels(void);
105 static dr_newcolrf_t xnewcolr;
106 static unsigned long true_pixel(COLOR col);
107 static void getevent(void);
108 static void getkey(XKeyPressedEvent *ekey);
109 static void fixwindow(XExposeEvent *eexp);
110 static void resizewindow(XConfigureEvent *ersz);
111
112 extern dr_initf_t x11_init; /* XXX this should be in a seperate header file */
113
114
115 extern struct driver *
116 x11_init( /* initialize driver */
117 char *name,
118 char *id
119 )
120 {
121 char *gv;
122 int nplanes;
123 XSetWindowAttributes ourwinattr;
124 XWMHints ourxwmhints;
125 XSizeHints oursizhints;
126 /* open display server */
127 ourdisplay = XOpenDisplay(NULL);
128 if (ourdisplay == NULL) {
129 eputs("cannot open X-windows; DISPLAY variable set?\n");
130 return(NULL);
131 }
132 /* find a usable visual */
133 nplanes = DisplayPlanes(ourdisplay, ourscreen);
134 if (XMatchVisualInfo(ourdisplay,ourscreen,
135 nplanes>12?nplanes:24,TrueColor,&ourvinfo) ||
136 XMatchVisualInfo(ourdisplay,ourscreen,
137 nplanes>12?nplanes:24,DirectColor,&ourvinfo)) {
138 ourblack = 0;
139 ourwhite = ourvinfo.red_mask |
140 ourvinfo.green_mask |
141 ourvinfo.blue_mask ;
142 } else {
143 if (nplanes < 4) {
144 eputs("not enough colors\n");
145 return(NULL);
146 }
147 if (!XMatchVisualInfo(ourdisplay,ourscreen,
148 nplanes,PseudoColor,&ourvinfo) &&
149 !XMatchVisualInfo(ourdisplay,ourscreen,
150 nplanes,GrayScale,&ourvinfo)) {
151 eputs("unsupported visual type\n");
152 return(NULL);
153 }
154 ourblack = BlackPixel(ourdisplay,ourscreen);
155 ourwhite = WhitePixel(ourdisplay,ourscreen);
156 }
157 /* set gamma */
158 if ((gv = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
159 || (gv = getenv("DISPLAY_GAMMA")) != NULL)
160 make_gmap(atof(gv));
161 else
162 make_gmap(GAMMA);
163 /* X11 command line or no? */
164 if (!strcmp(name, "x11"))
165 comheight = COMHEIGHT;
166 else /* "x11d" */ {
167 comheight = 0;
168 #ifndef FNDELAY
169 eputs("warning: x11d driver not fully functional on this machine\n");
170 #endif
171 }
172 /* open window */
173 ourwinattr.background_pixel = ourblack;
174 ourwinattr.border_pixel = ourblack;
175 /* this is stupid */
176 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
177 ourvinfo.visual, AllocNone);
178 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
179 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
180 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
181 BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual,
182 CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr);
183 if (gwind == 0) {
184 eputs("cannot create window\n");
185 return(NULL);
186 }
187 XStoreName(ourdisplay, gwind, id);
188 /* create a cursor */
189 pickcursor = XCreateFontCursor(ourdisplay, XC_diamond_cross);
190 ourgc = XCreateGC(ourdisplay, gwind, 0, NULL);
191 ourxwmhints.flags = InputHint|IconPixmapHint;
192 ourxwmhints.input = True;
193 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
194 gwind, x11icon_bits, x11icon_width, x11icon_height);
195 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
196 oursizhints.min_width = MINWIDTH;
197 oursizhints.min_height = MINHEIGHT+comheight;
198 oursizhints.flags = PMinSize;
199 XSetNormalHints(ourdisplay, gwind, &oursizhints);
200 XSelectInput(ourdisplay, gwind, ExposureMask);
201 XMapWindow(ourdisplay, gwind);
202 XWindowEvent(ourdisplay, gwind, ExposureMask, levptr(XEvent));
203 gwidth = levptr(XExposeEvent)->width;
204 gheight = levptr(XExposeEvent)->height - comheight;
205 x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth;
206 x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight;
207 x11_driver.inpready = 0;
208 mapped = 1;
209 /* set i/o vectors */
210 if (comheight) {
211 x11_driver.comin = x11_comin;
212 x11_driver.comout = x11_comout;
213 erract[COMMAND].pf = x11_comout;
214 if (erract[WARNING].pf != NULL)
215 erract[WARNING].pf = x11_errout;
216 inpcheck = IC_X11;
217 } else {
218 x11_driver.comin = std_comin;
219 x11_driver.comout = std_comout;
220 erract[COMMAND].pf = std_comout;
221 inpcheck = IC_IOCTL;
222 }
223 return(&x11_driver);
224 }
225
226
227 static void
228 x11_close(void) /* close our display */
229 {
230 erract[COMMAND].pf = NULL; /* reset error vectors */
231 if (erract[WARNING].pf != NULL)
232 erract[WARNING].pf = wputs;
233 if (ourdisplay == NULL)
234 return;
235 if (comline != NULL) {
236 xt_close(comline);
237 comline = NULL;
238 }
239 freepixels();
240 XFreeGC(ourdisplay, ourgc);
241 XDestroyWindow(ourdisplay, gwind);
242 gwind = 0;
243 ourgc = 0;
244 XFreeCursor(ourdisplay, pickcursor);
245 XCloseDisplay(ourdisplay);
246 ourdisplay = NULL;
247 }
248
249
250 static void
251 x11_clear( /* clear our display */
252 int xres,
253 int yres
254 )
255 {
256 /* check limits */
257 if (xres < MINWIDTH)
258 xres = MINWIDTH;
259 if (yres < MINHEIGHT)
260 yres = MINHEIGHT;
261 /* resize window */
262 if (xres != gwidth || yres != gheight) {
263 XSelectInput(ourdisplay, gwind, 0);
264 XResizeWindow(ourdisplay, gwind, xres, yres+comheight);
265 gwidth = xres;
266 gheight = yres;
267 XFlush(ourdisplay);
268 sleep(2); /* wait for window manager */
269 XSync(ourdisplay, 1); /* discard input */
270 }
271 XClearWindow(ourdisplay, gwind);
272 /* reinitialize color table */
273 if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) {
274 if (getpixels() == 0)
275 eputs("cannot allocate colors\n");
276 else
277 new_ctab(ncolors);
278 }
279 /* get new command line */
280 if (comline != NULL)
281 xt_close(comline);
282 if (comheight) {
283 comline = xt_open(ourdisplay, gwind, 0, gheight, gwidth,
284 comheight, 0, ourblack, ourwhite, COMFN);
285 if (comline == NULL) {
286 eputs("cannot open command line window\n");
287 quit(1);
288 }
289 XSelectInput(ourdisplay, comline->w, ExposureMask);
290 /* remove earmuffs */
291 XSelectInput(ourdisplay, gwind,
292 StructureNotifyMask|ExposureMask|KeyPressMask|ButtonPressMask);
293 } else /* remove earmuffs */
294 XSelectInput(ourdisplay, gwind,
295 StructureNotifyMask|ExposureMask|ButtonPressMask);
296 }
297
298
299 static void
300 x11_paintr( /* fill a rectangle */
301 COLOR col,
302 int xmin,
303 int ymin,
304 int xmax,
305 int ymax
306 )
307 {
308 unsigned long pixel;
309
310 if (!mapped)
311 return;
312 if (ncolors > 0)
313 pixel = pixval[get_pixel(col, xnewcolr)];
314 else
315 pixel = true_pixel(col);
316 XSetForeground(ourdisplay, ourgc, pixel);
317 XFillRectangle(ourdisplay, gwind,
318 ourgc, xmin, gheight-ymax, xmax-xmin, ymax-ymin);
319 }
320
321
322 static void
323 x11_flush(void) /* flush output */
324 {
325 char buf[256];
326 int n;
327 /* check for input */
328 XNoOp(ourdisplay);
329 n = XPending(ourdisplay); /* from X server */
330 while (n-- > 0)
331 getevent();
332 #ifdef FNDELAY
333 if (inpcheck == IC_IOCTL) { /* from stdin */
334 #ifdef FIONREAD
335 if (ioctl(fileno(stdin), FIONREAD, &n) < 0) {
336 #else
337 if (1) {
338 #endif
339 if (fcntl(fileno(stdin), F_SETFL, FNDELAY) < 0) {
340 eputs("cannot change input mode\n");
341 quit(1);
342 }
343 inpcheck = IC_READ;
344 } else
345 x11_driver.inpready += n;
346 }
347 if (inpcheck == IC_READ) {
348 n = read(fileno(stdin), buf, sizeof(buf)-1);
349 if (n > 0) {
350 buf[n] = '\0';
351 tocombuf(buf, &x11_driver);
352 }
353 }
354 #endif
355 }
356
357
358 static void
359 x11_comin( /* read in a command line */
360 char *inp,
361 char *prompt
362 )
363 {
364 if (prompt != NULL) {
365 x11_flush(); /* make sure we get everything */
366 if (fromcombuf(inp, &x11_driver))
367 return;
368 xt_puts(prompt, comline);
369 }
370 xt_cursor(comline, TBLKCURS);
371 editline(inp, x11_getc, x11_comout);
372 xt_cursor(comline, TNOCURS);
373 }
374
375
376 static void
377 x11_comout( /* output a string to command line */
378 char *outp
379 )
380 {
381 if (comline == NULL || outp == NULL || !outp[0])
382 return;
383 xt_puts(outp, comline);
384 if (outp[strlen(outp)-1] == '\n')
385 XFlush(ourdisplay);
386 }
387
388
389 static void
390 x11_errout( /* output an error message */
391 char *msg
392 )
393 {
394 eputs(msg); /* send to stderr also! */
395 x11_comout(msg);
396 }
397
398
399 static void
400 std_comin( /* read in command line from stdin */
401 char *inp,
402 char *prompt
403 )
404 {
405 if (prompt != NULL) {
406 if (fromcombuf(inp, &x11_driver))
407 return;
408 if (!x11_driver.inpready)
409 std_comout(prompt);
410 }
411 #ifdef FNDELAY
412 if (inpcheck == IC_READ) { /* turn off FNDELAY */
413 if (fcntl(fileno(stdin), F_SETFL, 0) < 0) {
414 eputs("cannot change input mode\n");
415 quit(1);
416 }
417 inpcheck = IC_IOCTL;
418 }
419 #endif
420 if (gets(inp) == NULL) {
421 strcpy(inp, "quit");
422 return;
423 }
424 x11_driver.inpready -= strlen(inp) + 1;
425 if (x11_driver.inpready < 0)
426 x11_driver.inpready = 0;
427 }
428
429
430 static void
431 std_comout( /* write out string to stdout */
432 char *outp
433 )
434 {
435 fputs(outp, stdout);
436 fflush(stdout);
437 }
438
439
440 static int
441 x11_getcur( /* get cursor position */
442 int *xp,
443 int *yp
444 )
445 {
446 while (XGrabPointer(ourdisplay, gwind, True, ButtonPressMask,
447 GrabModeAsync, GrabModeAsync, None, pickcursor,
448 CurrentTime) != GrabSuccess)
449 sleep(2);
450
451 do
452 getevent();
453 while (c_last <= c_first && levptr(XEvent)->type != ButtonPress);
454 *xp = levptr(XButtonPressedEvent)->x;
455 *yp = gheight-1 - levptr(XButtonPressedEvent)->y;
456 XUngrabPointer(ourdisplay, CurrentTime);
457 XFlush(ourdisplay); /* insure release */
458 if (c_last > c_first) /* key pressed */
459 return(x11_getc());
460 /* button pressed */
461 if (levptr(XButtonPressedEvent)->button == Button1)
462 return(MB1);
463 if (levptr(XButtonPressedEvent)->button == Button2)
464 return(MB2);
465 if (levptr(XButtonPressedEvent)->button == Button3)
466 return(MB3);
467 return(ABORT);
468 }
469
470
471 static void
472 xnewcolr( /* enter a color into hardware table */
473 int ndx,
474 int r,
475 int g,
476 int b
477 )
478 {
479 XColor xcolor;
480
481 xcolor.pixel = pixval[ndx];
482 xcolor.red = r << 8;
483 xcolor.green = g << 8;
484 xcolor.blue = b << 8;
485 xcolor.flags = DoRed|DoGreen|DoBlue;
486
487 XStoreColor(ourdisplay, ourmap, &xcolor);
488 }
489
490
491 static int
492 getpixels(void) /* get the color map */
493 {
494 XColor thiscolor;
495 register int i, j;
496
497 if (ncolors > 0)
498 return(ncolors);
499 if (ourvinfo.visual == DefaultVisual(ourdisplay,ourscreen)) {
500 ourmap = DefaultColormap(ourdisplay,ourscreen);
501 goto loop;
502 }
503 newmap:
504 ourmap = XCreateColormap(ourdisplay,gwind,ourvinfo.visual,AllocNone);
505 loop:
506 for (ncolors = ourvinfo.colormap_size;
507 ncolors > ourvinfo.colormap_size/3;
508 ncolors = ncolors*.937) {
509 pixval = (unsigned long *)malloc(ncolors*sizeof(unsigned long));
510 if (pixval == NULL)
511 return(ncolors = 0);
512 if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,pixval,ncolors))
513 break;
514 free((void *)pixval);
515 pixval = NULL;
516 }
517 if (pixval == NULL) {
518 if (ourmap == DefaultColormap(ourdisplay,ourscreen))
519 goto newmap; /* try it with our map */
520 else
521 return(ncolors = 0); /* failed */
522 }
523 if (ourmap != DefaultColormap(ourdisplay,ourscreen))
524 for (i = 0; i < ncolors; i++) { /* reset black and white */
525 if (pixval[i] != ourblack && pixval[i] != ourwhite)
526 continue;
527 thiscolor.pixel = pixval[i];
528 thiscolor.flags = DoRed|DoGreen|DoBlue;
529 XQueryColor(ourdisplay,
530 DefaultColormap(ourdisplay,ourscreen),
531 &thiscolor);
532 XStoreColor(ourdisplay, ourmap, &thiscolor);
533 for (j = i; j+1 < ncolors; j++)
534 pixval[j] = pixval[j+1];
535 ncolors--;
536 i--;
537 }
538 XSetWindowColormap(ourdisplay, gwind, ourmap);
539 return(ncolors);
540 }
541
542
543 static void
544 freepixels(void) /* free our pixels */
545 {
546 if (ncolors == 0)
547 return;
548 XFreeColors(ourdisplay,ourmap,pixval,ncolors,0L);
549 free((void *)pixval);
550 pixval = NULL;
551 ncolors = 0;
552 if (ourmap != DefaultColormap(ourdisplay,ourscreen))
553 XFreeColormap(ourdisplay, ourmap);
554 ourmap = 0;
555 }
556
557
558 static unsigned long
559 true_pixel( /* return true pixel value for color */
560 COLOR col
561 )
562 {
563 unsigned long rval;
564 BYTE rgb[3];
565
566 map_color(rgb, col);
567 rval = ourvinfo.red_mask*rgb[RED]/255 & ourvinfo.red_mask;
568 rval |= ourvinfo.green_mask*rgb[GRN]/255 & ourvinfo.green_mask;
569 rval |= ourvinfo.blue_mask*rgb[BLU]/255 & ourvinfo.blue_mask;
570 return(rval);
571 }
572
573
574 static int
575 x11_getc(void) /* get a command character */
576 {
577 while (c_last <= c_first) {
578 c_first = c_last = 0; /* reset */
579 getevent(); /* wait for key */
580 }
581 x11_driver.inpready--;
582 return(c_queue[c_first++]);
583 }
584
585
586 static void
587 getevent(void) /* get next event */
588 {
589 XNextEvent(ourdisplay, levptr(XEvent));
590 switch (levptr(XEvent)->type) {
591 case ConfigureNotify:
592 resizewindow(levptr(XConfigureEvent));
593 break;
594 case UnmapNotify:
595 mapped = 0;
596 freepixels();
597 break;
598 case MapNotify:
599 if (ourvinfo.class == PseudoColor ||
600 ourvinfo.class == GrayScale) {
601 if (getpixels() == 0)
602 eputs("cannot allocate colors\n");
603 else
604 new_ctab(ncolors);
605 }
606 mapped = 1;
607 break;
608 case Expose:
609 fixwindow(levptr(XExposeEvent));
610 break;
611 case KeyPress:
612 getkey(levptr(XKeyPressedEvent));
613 break;
614 case ButtonPress:
615 break;
616 }
617 }
618
619
620 static void
621 getkey( /* get input key */
622 register XKeyPressedEvent *ekey
623 )
624 {
625 register int n;
626
627 n = XLookupString(ekey, c_queue+c_last, sizeof(c_queue)-c_last,
628 NULL, NULL);
629 c_last += n;
630 x11_driver.inpready += n;
631 }
632
633
634 static void
635 fixwindow( /* repair damage to window */
636 register XExposeEvent *eexp
637 )
638 {
639 char buf[80];
640
641 if (eexp->window == gwind) {
642 sprintf(buf, "repaint %d %d %d %d\n",
643 eexp->x, gheight - eexp->y - eexp->height,
644 eexp->x + eexp->width, gheight - eexp->y);
645 tocombuf(buf, &x11_driver);
646 } else if (eexp->window == comline->w) {
647 if (eexp->count == 0)
648 xt_redraw(comline);
649 }
650 }
651
652
653 static void
654 resizewindow( /* resize window */
655 register XConfigureEvent *ersz
656 )
657 {
658 if (ersz->width == gwidth && ersz->height-comheight == gheight)
659 return;
660
661 gwidth = ersz->width;
662 gheight = ersz->height-comheight;
663 x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth;
664 x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight;
665
666 tocombuf("new\n", &x11_driver);
667 }
