--- ray/src/rt/x11.c 2003/02/25 02:47:23 2.30 +++ ray/src/rt/x11.c 2024/08/05 21:54:01 2.37 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: x11.c,v 2.30 2003/02/25 02:47:23 greg Exp $"; +static const char RCSid[] = "$Id: x11.c,v 2.37 2024/08/05 21:54:01 greg Exp $"; #endif /* * x11.c - driver for X-windows version 11 @@ -9,11 +9,6 @@ static const char RCSid[] = "$Id: x11.c,v 2.30 2003/02 #include "standard.h" #include -#ifdef sparc -#include -#include -#include -#endif #if !defined(FNDELAY) && defined(O_NONBLOCK) #define FNDELAY O_NONBLOCK #endif @@ -22,6 +17,7 @@ static const char RCSid[] = "$Id: x11.c,v 2.30 2003/02 #include #include +#include "platform.h" #include "color.h" #include "driver.h" #include "x11twind.h" @@ -79,27 +75,43 @@ static Colormap ourmap = 0; /* our color map */ static int inpcheck; /* whence to check input */ -static int x11_getcur(); +static void x11_errout(char *msg); -static void x11_close(), x11_clear(), x11_paintr(), x11_errout(), - x11_comout(), x11_comin(), x11_flush(); +static dr_closef_t x11_close; +static dr_clearf_t x11_clear; +static dr_paintrf_t x11_paintr; +static dr_getcurf_t x11_getcur; +static dr_comoutf_t x11_comout; +static dr_cominf_t x11_comin; +static dr_flushf_t x11_flush; -static void std_comin(), std_comout(); +static dr_cominf_t std_comin; +static dr_comoutf_t std_comout; static struct driver x11_driver = { x11_close, x11_clear, x11_paintr, x11_getcur, NULL, NULL, x11_flush, 1.0 }; -static int getpixels(), x11_getc(); -static void xnewcolr(), freepixels(), resizewindow(), - getevent(), getkey(), fixwindow(); -static unsigned long true_pixel(); +static dr_getchf_t x11_getc; +static void freepixels(void); +static int getpixels(void); +static dr_newcolrf_t xnewcolr; +static unsigned long true_pixel(COLOR col); +static void getevent(void); +static void getkey(XKeyPressedEvent *ekey); +static void fixwindow(XExposeEvent *eexp); +static void resizewindow(XConfigureEvent *ersz); -struct driver * -x11_init(name, id) /* initialize driver */ -char *name, *id; +extern dr_initf_t x11_init; /* XXX this should be in a seperate header file */ + + +extern struct driver * +x11_init( /* initialize driver */ + char *name, + char *id +) { char *gv; int nplanes; @@ -194,8 +206,10 @@ char *name, *id; x11_driver.comin = x11_comin; x11_driver.comout = x11_comout; erract[COMMAND].pf = x11_comout; + /* doesn't work with raypcalls.c if (erract[WARNING].pf != NULL) erract[WARNING].pf = x11_errout; + */ inpcheck = IC_X11; } else { x11_driver.comin = std_comin; @@ -208,7 +222,7 @@ char *name, *id; static void -x11_close() /* close our display */ +x11_close(void) /* close our display */ { erract[COMMAND].pf = NULL; /* reset error vectors */ if (erract[WARNING].pf != NULL) @@ -231,8 +245,10 @@ x11_close() /* close our display */ static void -x11_clear(xres, yres) /* clear our display */ -int xres, yres; +x11_clear( /* clear our display */ + int xres, + int yres +) { /* check limits */ if (xres < MINWIDTH) @@ -251,11 +267,12 @@ int xres, yres; } XClearWindow(ourdisplay, gwind); /* reinitialize color table */ - if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) + if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) { if (getpixels() == 0) eputs("cannot allocate colors\n"); else new_ctab(ncolors); + } /* get new command line */ if (comline != NULL) xt_close(comline); @@ -277,9 +294,13 @@ int xres, yres; static void -x11_paintr(col, xmin, ymin, xmax, ymax) /* fill a rectangle */ -COLOR col; -int xmin, ymin, xmax, ymax; +x11_paintr( /* fill a rectangle */ + COLOR col, + int xmin, + int ymin, + int xmax, + int ymax +) { unsigned long pixel; @@ -296,7 +317,7 @@ int xmin, ymin, xmax, ymax; static void -x11_flush() /* flush output */ +x11_flush(void) /* flush output */ { char buf[256]; int n; @@ -332,8 +353,10 @@ x11_flush() /* flush output */ static void -x11_comin(inp, prompt) /* read in a command line */ -char *inp, *prompt; +x11_comin( /* read in a command line */ + char *inp, + char *prompt +) { if (prompt != NULL) { x11_flush(); /* make sure we get everything */ @@ -348,8 +371,9 @@ char *inp, *prompt; static void -x11_comout(outp) /* output a string to command line */ -char *outp; +x11_comout( /* output a string to command line */ + const char *outp +) { if (comline == NULL || outp == NULL || !outp[0]) return; @@ -360,8 +384,9 @@ char *outp; static void -x11_errout(msg) /* output an error message */ -char *msg; +x11_errout( /* output an error message */ + char *msg +) { eputs(msg); /* send to stderr also! */ x11_comout(msg); @@ -369,9 +394,13 @@ char *msg; static void -std_comin(inp, prompt) /* read in command line from stdin */ -char *inp, *prompt; +std_comin( /* read in command line from stdin */ + char *inp, + char *prompt +) { + int n, c; + if (prompt != NULL) { if (fromcombuf(inp, &x11_driver)) return; @@ -387,19 +416,24 @@ char *inp, *prompt; inpcheck = IC_IOCTL; } #endif - if (gets(inp) == NULL) { + n = 0; /* gets() no longer exists... */ + while ((c = getchar()) != EOF && c != '\n') + inp[n++] = c; + + if (!n & (c == EOF)) { strcpy(inp, "quit"); return; } - x11_driver.inpready -= strlen(inp) + 1; - if (x11_driver.inpready < 0) - x11_driver.inpready = 0; + inp[n] = '\0'; + x11_driver.inpready -= n + 1; + x11_driver.inpready *= (x11_driver.inpready > 0); } static void -std_comout(outp) /* write out string to stdout */ -char *outp; +std_comout( /* write out string to stdout */ + const char *outp +) { fputs(outp, stdout); fflush(stdout); @@ -407,8 +441,10 @@ char *outp; static int -x11_getcur(xp, yp) /* get cursor position */ -int *xp, *yp; +x11_getcur( /* get cursor position */ + int *xp, + int *yp +) { while (XGrabPointer(ourdisplay, gwind, True, ButtonPressMask, GrabModeAsync, GrabModeAsync, None, pickcursor, @@ -436,9 +472,12 @@ int *xp, *yp; static void -xnewcolr(ndx, r, g, b) /* enter a color into hardware table */ -int ndx; -int r, g, b; +xnewcolr( /* enter a color into hardware table */ + int ndx, + int r, + int g, + int b +) { XColor xcolor; @@ -453,7 +492,7 @@ int r, g, b; static int -getpixels() /* get the color map */ +getpixels(void) /* get the color map */ { XColor thiscolor; register int i, j; @@ -505,7 +544,7 @@ loop: static void -freepixels() /* free our pixels */ +freepixels(void) /* free our pixels */ { if (ncolors == 0) return; @@ -520,11 +559,12 @@ freepixels() /* free our pixels */ static unsigned long -true_pixel(col) /* return true pixel value for color */ -COLOR col; +true_pixel( /* return true pixel value for color */ + COLOR col +) { unsigned long rval; - BYTE rgb[3]; + uby8 rgb[3]; map_color(rgb, col); rval = ourvinfo.red_mask*rgb[RED]/255 & ourvinfo.red_mask; @@ -535,7 +575,7 @@ COLOR col; static int -x11_getc() /* get a command character */ +x11_getc(void) /* get a command character */ { while (c_last <= c_first) { c_first = c_last = 0; /* reset */ @@ -547,7 +587,7 @@ x11_getc() /* get a command character */ static void -getevent() /* get next event */ +getevent(void) /* get next event */ { XNextEvent(ourdisplay, levptr(XEvent)); switch (levptr(XEvent)->type) { @@ -560,11 +600,12 @@ getevent() /* get next event */ break; case MapNotify: if (ourvinfo.class == PseudoColor || - ourvinfo.class == GrayScale) + ourvinfo.class == GrayScale) { if (getpixels() == 0) eputs("cannot allocate colors\n"); else new_ctab(ncolors); + } mapped = 1; break; case Expose: @@ -580,8 +621,9 @@ getevent() /* get next event */ static void -getkey(ekey) /* get input key */ -register XKeyPressedEvent *ekey; +getkey( /* get input key */ + register XKeyPressedEvent *ekey +) { register int n; @@ -593,8 +635,9 @@ register XKeyPressedEvent *ekey; static void -fixwindow(eexp) /* repair damage to window */ -register XExposeEvent *eexp; +fixwindow( /* repair damage to window */ + register XExposeEvent *eexp +) { char buf[80]; @@ -611,8 +654,9 @@ register XExposeEvent *eexp; static void -resizewindow(ersz) /* resize window */ -register XConfigureEvent *ersz; +resizewindow( /* resize window */ + register XConfigureEvent *ersz +) { if (ersz->width == gwidth && ersz->height-comheight == gheight) return;
