--- ray/src/rt/x11.c 1991/11/12 17:10:04 2.1 +++ ray/src/rt/x11.c 1992/05/29 10:57:15 2.2 @@ -50,7 +50,7 @@ static unsigned long *pixval = NULL; /* allocated pix static Display *ourdisplay = NULL; /* our display */ -static Visual *ourvisual; /* our visual structure */ +static XVisualInfo ourvinfo; /* our visual information */ static Window gwind = 0; /* our graphics window */ @@ -84,7 +84,6 @@ x11_init(name, id) /* initialize driver */ char *name, *id; { int nplanes; - XVisualInfo ourvinfo; XSetWindowAttributes ourwinattr; XWMHints ourxwmhints; XSizeHints oursizhints; @@ -94,34 +93,34 @@ char *name, *id; stderr_v("cannot open X-windows; DISPLAY variable set?\n"); return(NULL); } + /* find a usable visual */ nplanes = DisplayPlanes(ourdisplay, ourscreen); - if (nplanes < 4) { - stderr_v("not enough colors\n"); - return(NULL); - } else if (nplanes <= 12) { - if (!XMatchVisualInfo(ourdisplay,ourscreen, - nplanes,PseudoColor,&ourvinfo)) { - stderr_v("PseudoColor server required\n"); + if ( !XMatchVisualInfo(ourdisplay,ourscreen, + 24,TrueColor,&ourvinfo) && + !XMatchVisualInfo(ourdisplay,ourscreen, + 24,DirectColor,&ourvinfo) ) + if (nplanes < 4) { + stderr_v("not enough colors\n"); return(NULL); + } else if (!XMatchVisualInfo(ourdisplay,ourscreen, + nplanes,PseudoColor,&ourvinfo) && + !XMatchVisualInfo(ourdisplay,ourscreen, + nplanes,GrayScale,&ourvinfo)) { + stderr_v("unsupported visual type\n"); + return(NULL); } - } else if (!XMatchVisualInfo(ourdisplay,ourscreen, - nplanes,TrueColor,&ourvinfo) && - /* kludge for DirectColor */ - !XMatchVisualInfo(ourdisplay,ourscreen, - nplanes,DirectColor,&ourvinfo)) { - stderr_v("TrueColor server required\n"); - return(NULL); - } - ourvisual = ourvinfo.visual; make_gmap(GAMMA); /* open window */ ourwinattr.background_pixel = ourblack; ourwinattr.border_pixel = ourblack; + /* this is a waste! */ + ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot, + ourvinfo.visual, AllocNone); gwind = XCreateWindow(ourdisplay, ourroot, 0, 0, DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH, DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH, - BORWIDTH, nplanes, InputOutput, ourvisual, - CWBackPixel|CWBorderPixel, &ourwinattr); + BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual, + CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr); if (gwind == 0) { stderr_v("cannot create window\n"); return(NULL); @@ -198,7 +197,7 @@ int xres, yres; } XClearWindow(ourdisplay, gwind); /* reinitialize color table */ - if (ourvisual->class == PseudoColor) + if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) if (getpixels() == 0) stderr_v("cannot allocate colors\n"); else @@ -231,7 +230,7 @@ int xmin, ymin, xmax, ymax; if (ncolors > 0) pixel = pixval[get_pixel(col, xnewcolr)]; - else if (ourvisual->class != PseudoColor) + else if (ourvinfo.class == TrueColor || ourvinfo.class == DirectColor) pixel = true_pixel(col); else return; @@ -343,16 +342,16 @@ getpixels() /* get the color map */ register int i, j; if (ncolors > 0) - goto donecolors; - if (ourvisual == DefaultVisual(ourdisplay,ourscreen)) { + return(ncolors); + if (ourvinfo.visual == DefaultVisual(ourdisplay,ourscreen)) { ourmap = DefaultColormap(ourdisplay,ourscreen); goto loop; } newmap: - ourmap = XCreateColormap(ourdisplay,gwind,ourvisual,AllocNone); + ourmap = XCreateColormap(ourdisplay,gwind,ourvinfo.visual,AllocNone); loop: - for (ncolors = ourvisual->map_entries; - ncolors > ourvisual->map_entries/3; + for (ncolors = ourvinfo.colormap_size; + ncolors > ourvinfo.colormap_size/3; ncolors = ncolors*.937) { pixval = (unsigned long *)malloc(ncolors*sizeof(unsigned long)); if (pixval == NULL) @@ -385,15 +384,6 @@ loop: i--; } XSetWindowColormap(ourdisplay, gwind, ourmap); -donecolors: -#ifdef DEBUG - thiscolor.flags = DoRed|DoGreen|DoBlue; - thiscolor.red = thiscolor.green = thiscolor.blue = 0; - for (i = 0; i < ncolors; i++) { - thiscolor.pixel = pixval[i]; - XStoreColor(ourdisplay, ourmap, &thiscolor); - } -#endif return(ncolors); } @@ -419,9 +409,9 @@ COLOR col; BYTE rgb[3]; map_color(rgb, col); - rval = ourvisual->red_mask*rgb[RED]/255 & ourvisual->red_mask; - rval |= ourvisual->green_mask*rgb[GRN]/255 & ourvisual->green_mask; - rval |= ourvisual->blue_mask*rgb[BLU]/255 & ourvisual->blue_mask; + rval = ourvinfo.red_mask*rgb[RED]/255 & ourvinfo.red_mask; + rval |= ourvinfo.green_mask*rgb[GRN]/255 & ourvinfo.green_mask; + rval |= ourvinfo.blue_mask*rgb[BLU]/255 & ourvinfo.blue_mask; return(rval); } @@ -450,7 +440,8 @@ getevent() /* get next event */ freepixels(); break; case MapNotify: - if (ourvisual->class == PseudoColor) + if (ourvinfo.class == PseudoColor || + ourvinfo.class == GrayScale) if (getpixels() == 0) stderr_v("Cannot allocate colors\n"); else
