root/radiance/ray/src/rt/x11.c
Revision: 2.33
Committed: Wed Nov 21 16:42:03 2007 UTC (16 years, 6 months ago) by greg
Changes since 2.32: +1 -6 lines
Removed out-of-date includes for Solaris
2 static const char RCSid[] = "$Id: x11.c,v 2.32 2004/03/30 16:13:01 schorsch Exp $";
5 * x11.c - driver for X-windows version 11
6 */
7
8 #include "copyright.h"
9
10 #include "standard.h"
11 #include <sys/ioctl.h>
12 #if !defined(FNDELAY) && defined(O_NONBLOCK)
13 #define FNDELAY O_NONBLOCK
14 #endif
15
16 #include <X11/Xlib.h>
17 #include <X11/cursorfont.h>
18 #include <X11/Xutil.h>
19
20 #include "platform.h"
21 #include "color.h"
22 #include "driver.h"
23 #include "x11twind.h"
24 #include "x11icon.h"
25
26 #define GAMMA 2.2 /* default exponent correction */
27
28 #define MINWIDTH (32*COMCW) /* minimum graphics window width */
29 #define MINHEIGHT (MINWIDTH/2) /* minimum graphics window height */
30
31 #define BORWIDTH 5 /* border width */
32 #define COMHEIGHT (COMLH*COMCH) /* command line height (pixels) */
33
34 #define COMFN "8x13" /* command line font name */
35 #define COMLH 3 /* number of command lines */
36 #define COMCW 8 /* approx. character width (pixels) */
37 #define COMCH 14 /* approx. character height (pixels) */
38
39 #define ourscreen DefaultScreen(ourdisplay)
40 #define ourroot RootWindow(ourdisplay,ourscreen)
41
42 #define levptr(etype) ((etype *)&currentevent)
43
44 static XEvent currentevent; /* current event */
45
46 static int ncolors = 0; /* color table size */
47 static int mapped = 0; /* window is mapped? */
48 static unsigned long *pixval = NULL; /* allocated pixels */
49 static unsigned long ourblack=0, ourwhite=1;
50
51 static Display *ourdisplay = NULL; /* our display */
52
53 static XVisualInfo ourvinfo; /* our visual information */
54
55 static Window gwind = 0; /* our graphics window */
56
57 static Cursor pickcursor = 0; /* cursor used for picking */
58
59 static int gwidth, gheight; /* graphics window size */
60
61 static int comheight; /* desired comline height */
62 static TEXTWIND *comline = NULL; /* our command line */
63
64 static char c_queue[64]; /* input queue */
65 static int c_first = 0; /* first character in queue */
66 static int c_last = 0; /* last character in queue */
67
68 static GC ourgc = 0; /* our graphics context for drawing */
69
70 static Colormap ourmap = 0; /* our color map */
71
72 #define IC_X11 0
73 #define IC_IOCTL 1
74 #define IC_READ 2
75
76 static int inpcheck; /* whence to check input */
77
78 static void x11_errout(char *msg);
79
80 static dr_closef_t x11_close;
81 static dr_clearf_t x11_clear;
82 static dr_paintrf_t x11_paintr;
83 static dr_getcurf_t x11_getcur;
84 static dr_comoutf_t x11_comout;
85 static dr_cominf_t x11_comin;
86 static dr_flushf_t x11_flush;
87
88 static dr_cominf_t std_comin;
89 static dr_comoutf_t std_comout;
90
91 static struct driver x11_driver = {
92 x11_close, x11_clear, x11_paintr, x11_getcur,
93 NULL, NULL, x11_flush, 1.0
94 };
95
96 static dr_getchf_t x11_getc;
97
98 static void freepixels(void);
99 static int getpixels(void);
100 static dr_newcolrf_t xnewcolr;
101 static unsigned long true_pixel(COLOR col);
102 static void getevent(void);
103 static void getkey(XKeyPressedEvent *ekey);
104 static void fixwindow(XExposeEvent *eexp);
105 static void resizewindow(XConfigureEvent *ersz);
106
107 extern dr_initf_t x11_init; /* XXX this should be in a seperate header file */
108
109
110 extern struct driver *
111 x11_init( /* initialize driver */
112 char *name,
113 char *id
114 )
115 {
116 char *gv;
117 int nplanes;
118 XSetWindowAttributes ourwinattr;
119 XWMHints ourxwmhints;
120 XSizeHints oursizhints;
121 /* open display server */
122 ourdisplay = XOpenDisplay(NULL);
123 if (ourdisplay == NULL) {
124 eputs("cannot open X-windows; DISPLAY variable set?\n");
125 return(NULL);
126 }
127 /* find a usable visual */
128 nplanes = DisplayPlanes(ourdisplay, ourscreen);
129 if (XMatchVisualInfo(ourdisplay,ourscreen,
130 nplanes>12?nplanes:24,TrueColor,&ourvinfo) ||
131 XMatchVisualInfo(ourdisplay,ourscreen,
132 nplanes>12?nplanes:24,DirectColor,&ourvinfo)) {
133 ourblack = 0;
134 ourwhite = ourvinfo.red_mask |
135 ourvinfo.green_mask |
136 ourvinfo.blue_mask ;
137 } else {
138 if (nplanes < 4) {
139 eputs("not enough colors\n");
140 return(NULL);
141 }
142 if (!XMatchVisualInfo(ourdisplay,ourscreen,
143 nplanes,PseudoColor,&ourvinfo) &&
144 !XMatchVisualInfo(ourdisplay,ourscreen,
145 nplanes,GrayScale,&ourvinfo)) {
146 eputs("unsupported visual type\n");
147 return(NULL);
148 }
149 ourblack = BlackPixel(ourdisplay,ourscreen);
150 ourwhite = WhitePixel(ourdisplay,ourscreen);
151 }
152 /* set gamma */
153 if ((gv = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
154 || (gv = getenv("DISPLAY_GAMMA")) != NULL)
155 make_gmap(atof(gv));
156 else
157 make_gmap(GAMMA);
158 /* X11 command line or no? */
159 if (!strcmp(name, "x11"))
160 comheight = COMHEIGHT;
161 else /* "x11d" */ {
162 comheight = 0;
163 #ifndef FNDELAY
164 eputs("warning: x11d driver not fully functional on this machine\n");
165 #endif
166 }
167 /* open window */
168 ourwinattr.background_pixel = ourblack;
169 ourwinattr.border_pixel = ourblack;
170 /* this is stupid */
171 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
172 ourvinfo.visual, AllocNone);
173 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
174 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
175 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
176 BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual,
177 CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr);
178 if (gwind == 0) {
179 eputs("cannot create window\n");
180 return(NULL);
181 }
182 XStoreName(ourdisplay, gwind, id);
183 /* create a cursor */
184 pickcursor = XCreateFontCursor(ourdisplay, XC_diamond_cross);
185 ourgc = XCreateGC(ourdisplay, gwind, 0, NULL);
186 ourxwmhints.flags = InputHint|IconPixmapHint;
187 ourxwmhints.input = True;
188 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
189 gwind, x11icon_bits, x11icon_width, x11icon_height);
190 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
191 oursizhints.min_width = MINWIDTH;
192 oursizhints.min_height = MINHEIGHT+comheight;
193 oursizhints.flags = PMinSize;
194 XSetNormalHints(ourdisplay, gwind, &oursizhints);
195 XSelectInput(ourdisplay, gwind, ExposureMask);
196 XMapWindow(ourdisplay, gwind);
197 XWindowEvent(ourdisplay, gwind, ExposureMask, levptr(XEvent));
198 gwidth = levptr(XExposeEvent)->width;
199 gheight = levptr(XExposeEvent)->height - comheight;
200 x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth;
201 x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight;
202 x11_driver.inpready = 0;
203 mapped = 1;
204 /* set i/o vectors */
205 if (comheight) {
206 x11_driver.comin = x11_comin;
207 x11_driver.comout = x11_comout;
208 erract[COMMAND].pf = x11_comout;
209 if (erract[WARNING].pf != NULL)
210 erract[WARNING].pf = x11_errout;
211 inpcheck = IC_X11;
212 } else {
213 x11_driver.comin = std_comin;
214 x11_driver.comout = std_comout;
215 erract[COMMAND].pf = std_comout;
216 inpcheck = IC_IOCTL;
217 }
218 return(&x11_driver);
219 }
220
221
222 static void
223 x11_close(void) /* close our display */
224 {
225 erract[COMMAND].pf = NULL; /* reset error vectors */
226 if (erract[WARNING].pf != NULL)
227 erract[WARNING].pf = wputs;
228 if (ourdisplay == NULL)
229 return;
230 if (comline != NULL) {
231 xt_close(comline);
232 comline = NULL;
233 }
234 freepixels();
235 XFreeGC(ourdisplay, ourgc);
236 XDestroyWindow(ourdisplay, gwind);
237 gwind = 0;
238 ourgc = 0;
239 XFreeCursor(ourdisplay, pickcursor);
240 XCloseDisplay(ourdisplay);
241 ourdisplay = NULL;
242 }
243
244
245 static void
246 x11_clear( /* clear our display */
247 int xres,
248 int yres
249 )
250 {
251 /* check limits */
252 if (xres < MINWIDTH)
253 xres = MINWIDTH;
254 if (yres < MINHEIGHT)
255 yres = MINHEIGHT;
256 /* resize window */
257 if (xres != gwidth || yres != gheight) {
258 XSelectInput(ourdisplay, gwind, 0);
259 XResizeWindow(ourdisplay, gwind, xres, yres+comheight);
260 gwidth = xres;
261 gheight = yres;
262 XFlush(ourdisplay);
263 sleep(2); /* wait for window manager */
264 XSync(ourdisplay, 1); /* discard input */
265 }
266 XClearWindow(ourdisplay, gwind);
267 /* reinitialize color table */
268 if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) {
269 if (getpixels() == 0)
270 eputs("cannot allocate colors\n");
271 else
272 new_ctab(ncolors);
273 }
274 /* get new command line */
275 if (comline != NULL)
276 xt_close(comline);
277 if (comheight) {
278 comline = xt_open(ourdisplay, gwind, 0, gheight, gwidth,
279 comheight, 0, ourblack, ourwhite, COMFN);
280 if (comline == NULL) {
281 eputs("cannot open command line window\n");
282 quit(1);
283 }
284 XSelectInput(ourdisplay, comline->w, ExposureMask);
285 /* remove earmuffs */
286 XSelectInput(ourdisplay, gwind,
287 StructureNotifyMask|ExposureMask|KeyPressMask|ButtonPressMask);
288 } else /* remove earmuffs */
289 XSelectInput(ourdisplay, gwind,
290 StructureNotifyMask|ExposureMask|ButtonPressMask);
291 }
292
293
294 static void
295 x11_paintr( /* fill a rectangle */
296 COLOR col,
297 int xmin,
298 int ymin,
299 int xmax,
300 int ymax
301 )
302 {
303 unsigned long pixel;
304
305 if (!mapped)
306 return;
307 if (ncolors > 0)
308 pixel = pixval[get_pixel(col, xnewcolr)];
309 else
310 pixel = true_pixel(col);
311 XSetForeground(ourdisplay, ourgc, pixel);
312 XFillRectangle(ourdisplay, gwind,
313 ourgc, xmin, gheight-ymax, xmax-xmin, ymax-ymin);
314 }
315
316
317 static void
318 x11_flush(void) /* flush output */
319 {
320 char buf[256];
321 int n;
322 /* check for input */
323 XNoOp(ourdisplay);
324 n = XPending(ourdisplay); /* from X server */
325 while (n-- > 0)
326 getevent();
327 #ifdef FNDELAY
328 if (inpcheck == IC_IOCTL) { /* from stdin */
329 #ifdef FIONREAD
330 if (ioctl(fileno(stdin), FIONREAD, &n) < 0) {
331 #else
332 if (1) {
333 #endif
334 if (fcntl(fileno(stdin), F_SETFL, FNDELAY) < 0) {
335 eputs("cannot change input mode\n");
336 quit(1);
337 }
338 inpcheck = IC_READ;
339 } else
340 x11_driver.inpready += n;
341 }
342 if (inpcheck == IC_READ) {
343 n = read(fileno(stdin), buf, sizeof(buf)-1);
344 if (n > 0) {
345 buf[n] = '\0';
346 tocombuf(buf, &x11_driver);
347 }
348 }
349 #endif
350 }
351
352
353 static void
354 x11_comin( /* read in a command line */
355 char *inp,
356 char *prompt
357 )
358 {
359 if (prompt != NULL) {
360 x11_flush(); /* make sure we get everything */
361 if (fromcombuf(inp, &x11_driver))
362 return;
363 xt_puts(prompt, comline);
364 }
365 xt_cursor(comline, TBLKCURS);
366 editline(inp, x11_getc, x11_comout);
367 xt_cursor(comline, TNOCURS);
368 }
369
370
371 static void
372 x11_comout( /* output a string to command line */
373 char *outp
374 )
375 {
376 if (comline == NULL || outp == NULL || !outp[0])
377 return;
378 xt_puts(outp, comline);
379 if (outp[strlen(outp)-1] == '\n')
380 XFlush(ourdisplay);
381 }
382
383
384 static void
385 x11_errout( /* output an error message */
386 char *msg
387 )
388 {
389 eputs(msg); /* send to stderr also! */
390 x11_comout(msg);
391 }
392
393
394 static void
395 std_comin( /* read in command line from stdin */
396 char *inp,
397 char *prompt
398 )
399 {
400 if (prompt != NULL) {
401 if (fromcombuf(inp, &x11_driver))
402 return;
403 if (!x11_driver.inpready)
404 std_comout(prompt);
405 }
406 #ifdef FNDELAY
407 if (inpcheck == IC_READ) { /* turn off FNDELAY */
408 if (fcntl(fileno(stdin), F_SETFL, 0) < 0) {
409 eputs("cannot change input mode\n");
410 quit(1);
411 }
412 inpcheck = IC_IOCTL;
413 }
414 #endif
415 if (gets(inp) == NULL) {
416 strcpy(inp, "quit");
417 return;
418 }
419 x11_driver.inpready -= strlen(inp) + 1;
420 if (x11_driver.inpready < 0)
421 x11_driver.inpready = 0;
422 }
423
424
425 static void
426 std_comout( /* write out string to stdout */
427 char *outp
428 )
429 {
430 fputs(outp, stdout);
431 fflush(stdout);
432 }
433
434
435 static int
436 x11_getcur( /* get cursor position */
437 int *xp,
438 int *yp
439 )
440 {
441 while (XGrabPointer(ourdisplay, gwind, True, ButtonPressMask,
442 GrabModeAsync, GrabModeAsync, None, pickcursor,
443 CurrentTime) != GrabSuccess)
444 sleep(2);
445
446 do
447 getevent();
448 while (c_last <= c_first && levptr(XEvent)->type != ButtonPress);
449 *xp = levptr(XButtonPressedEvent)->x;
450 *yp = gheight-1 - levptr(XButtonPressedEvent)->y;
451 XUngrabPointer(ourdisplay, CurrentTime);
452 XFlush(ourdisplay); /* insure release */
453 if (c_last > c_first) /* key pressed */
454 return(x11_getc());
455 /* button pressed */
456 if (levptr(XButtonPressedEvent)->button == Button1)
457 return(MB1);
458 if (levptr(XButtonPressedEvent)->button == Button2)
459 return(MB2);
460 if (levptr(XButtonPressedEvent)->button == Button3)
461 return(MB3);
462 return(ABORT);
463 }
464
465
466 static void
467 xnewcolr( /* enter a color into hardware table */
468 int ndx,
469 int r,
470 int g,
471 int b
472 )
473 {
474 XColor xcolor;
475
476 xcolor.pixel = pixval[ndx];
477 xcolor.red = r << 8;
478 xcolor.green = g << 8;
479 xcolor.blue = b << 8;
480 xcolor.flags = DoRed|DoGreen|DoBlue;
481
482 XStoreColor(ourdisplay, ourmap, &xcolor);
483 }
484
485
486 static int
487 getpixels(void) /* get the color map */
488 {
489 XColor thiscolor;
490 register int i, j;
491
492 if (ncolors > 0)
493 return(ncolors);
494 if (ourvinfo.visual == DefaultVisual(ourdisplay,ourscreen)) {
495 ourmap = DefaultColormap(ourdisplay,ourscreen);
496 goto loop;
497 }
498 newmap:
499 ourmap = XCreateColormap(ourdisplay,gwind,ourvinfo.visual,AllocNone);
500 loop:
501 for (ncolors = ourvinfo.colormap_size;
502 ncolors > ourvinfo.colormap_size/3;
503 ncolors = ncolors*.937) {
504 pixval = (unsigned long *)malloc(ncolors*sizeof(unsigned long));
505 if (pixval == NULL)
506 return(ncolors = 0);
507 if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,pixval,ncolors))
508 break;
509 free((void *)pixval);
510 pixval = NULL;
511 }
512 if (pixval == NULL) {
513 if (ourmap == DefaultColormap(ourdisplay,ourscreen))
514 goto newmap; /* try it with our map */
515 else
516 return(ncolors = 0); /* failed */
517 }
518 if (ourmap != DefaultColormap(ourdisplay,ourscreen))
519 for (i = 0; i < ncolors; i++) { /* reset black and white */
520 if (pixval[i] != ourblack && pixval[i] != ourwhite)
521 continue;
522 thiscolor.pixel = pixval[i];
523 thiscolor.flags = DoRed|DoGreen|DoBlue;
524 XQueryColor(ourdisplay,
525 DefaultColormap(ourdisplay,ourscreen),
526 &thiscolor);
527 XStoreColor(ourdisplay, ourmap, &thiscolor);
528 for (j = i; j+1 < ncolors; j++)
529 pixval[j] = pixval[j+1];
530 ncolors--;
531 i--;
532 }
533 XSetWindowColormap(ourdisplay, gwind, ourmap);
534 return(ncolors);
535 }
536
537
538 static void
539 freepixels(void) /* free our pixels */
540 {
541 if (ncolors == 0)
542 return;
543 XFreeColors(ourdisplay,ourmap,pixval,ncolors,0L);
544 free((void *)pixval);
545 pixval = NULL;
546 ncolors = 0;
547 if (ourmap != DefaultColormap(ourdisplay,ourscreen))
548 XFreeColormap(ourdisplay, ourmap);
549 ourmap = 0;
550 }
551
552
553 static unsigned long
554 true_pixel( /* return true pixel value for color */
555 COLOR col
556 )
557 {
558 unsigned long rval;
559 BYTE rgb[3];
560
561 map_color(rgb, col);
562 rval = ourvinfo.red_mask*rgb[RED]/255 & ourvinfo.red_mask;
563 rval |= ourvinfo.green_mask*rgb[GRN]/255 & ourvinfo.green_mask;
564 rval |= ourvinfo.blue_mask*rgb[BLU]/255 & ourvinfo.blue_mask;
565 return(rval);
566 }
567
568
569 static int
570 x11_getc(void) /* get a command character */
571 {
572 while (c_last <= c_first) {
573 c_first = c_last = 0; /* reset */
574 getevent(); /* wait for key */
575 }
576 x11_driver.inpready--;
577 return(c_queue[c_first++]);
578 }
579
580
581 static void
582 getevent(void) /* get next event */
583 {
584 XNextEvent(ourdisplay, levptr(XEvent));
585 switch (levptr(XEvent)->type) {
586 case ConfigureNotify:
587 resizewindow(levptr(XConfigureEvent));
588 break;
589 case UnmapNotify:
590 mapped = 0;
591 freepixels();
592 break;
593 case MapNotify:
594 if (ourvinfo.class == PseudoColor ||
595 ourvinfo.class == GrayScale) {
596 if (getpixels() == 0)
597 eputs("cannot allocate colors\n");
598 else
599 new_ctab(ncolors);
600 }
601 mapped = 1;
602 break;
603 case Expose:
604 fixwindow(levptr(XExposeEvent));
605 break;
606 case KeyPress:
607 getkey(levptr(XKeyPressedEvent));
608 break;
609 case ButtonPress:
610 break;
611 }
612 }
613
614
615 static void
616 getkey( /* get input key */
617 register XKeyPressedEvent *ekey
618 )
619 {
620 register int n;
621
622 n = XLookupString(ekey, c_queue+c_last, sizeof(c_queue)-c_last,
623 NULL, NULL);
624 c_last += n;
625 x11_driver.inpready += n;
626 }
627
628
629 static void
630 fixwindow( /* repair damage to window */
631 register XExposeEvent *eexp
632 )
633 {
634 char buf[80];
635
636 if (eexp->window == gwind) {
637 sprintf(buf, "repaint %d %d %d %d\n",
638 eexp->x, gheight - eexp->y - eexp->height,
639 eexp->x + eexp->width, gheight - eexp->y);
640 tocombuf(buf, &x11_driver);
641 } else if (eexp->window == comline->w) {
642 if (eexp->count == 0)
643 xt_redraw(comline);
644 }
645 }
646
647
648 static void
649 resizewindow( /* resize window */
650 register XConfigureEvent *ersz
651 )
652 {
653 if (ersz->width == gwidth && ersz->height-comheight == gheight)
654 return;
655
656 gwidth = ersz->width;
657 gheight = ersz->height-comheight;
658 x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth;
659 x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight;
660
661 tocombuf("new\n", &x11_driver);
662 }
