--- ray/src/rt/x11.c 1992/06/24 09:12:50 2.6
+++ ray/src/rt/x11.c 2003/02/22 02:07:29 2.29
@@ -1,18 +1,77 @@
-/* Copyright (c) 1992 Regents of the University of California */
#ifndef lint
-static char SCCSid[] = "$SunId$ LBL";
+static const char RCSid[] = "$Id: x11.c,v 2.29 2003/02/22 02:07:29 greg Exp $";
#endif
* x11.c - driver for X-windows version 11
+ * The Radiance Software License, Version 1.0
- * Jan 1990
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
-#include
+#include "standard.h"
#include
+#ifdef sparc
+#include
+#include
+#include
+#endif
+#if !defined(FNDELAY) && defined(O_NONBLOCK)
+#define FNDELAY O_NONBLOCK
+#endif
#include
#include
@@ -26,7 +85,7 @@ static char SCCSid[] = "$SunId$ LBL";
#define GAMMA 2.2 /* default exponent correction */
#define MINWIDTH (32*COMCW) /* minimum graphics window width */
-#define MINHEIGHT MINWIDTH /* minimum graphics window height */
+#define MINHEIGHT (MINWIDTH/2) /* minimum graphics window height */
#define BORWIDTH 5 /* border width */
#define COMHEIGHT (COMLH*COMCH) /* command line height (pixels) */
@@ -44,6 +103,7 @@ static char SCCSid[] = "$SunId$ LBL";
static XEvent currentevent; /* current event */
static int ncolors = 0; /* color table size */
+static int mapped = 0; /* window is mapped? */
static unsigned long *pixval = NULL; /* allocated pixels */
static unsigned long ourblack=0, ourwhite=1;
@@ -57,6 +117,7 @@ static Cursor pickcursor = 0; /* cursor used for pic
static int gwidth, gheight; /* graphics window size */
+static int comheight; /* desired comline height */
static TEXTWIND *comline = NULL; /* our command line */
static char c_queue[64]; /* input queue */
@@ -67,63 +128,85 @@ static GC ourgc = 0; /* our graphics context for dr
static Colormap ourmap = 0; /* our color map */
-extern char *malloc(), *getcombuf();
+#define IC_X11 0
+#define IC_IOCTL 1
+#define IC_READ 2
-static int x11_close(), x11_clear(), x11_paintr(), x11_errout(),
- x11_getcur(), x11_comout(), x11_comin(), x11_flush();
+static int inpcheck; /* whence to check input */
+static int x11_getcur();
+static void x11_close(), x11_clear(), x11_paintr(), x11_errout(),
+ x11_comout(), x11_comin(), x11_flush();
+static void std_comin(), std_comout();
static struct driver x11_driver = {
x11_close, x11_clear, x11_paintr, x11_getcur,
- x11_comout, x11_comin, x11_flush, 1.0
+ NULL, NULL, x11_flush, 1.0
+static int getpixels(), x11_getc();
+static void xnewcolr(), freepixels(), resizewindow(),
+ getevent(), getkey(), fixwindow();
+static unsigned long true_pixel();
struct driver *
x11_init(name, id) /* initialize driver */
char *name, *id;
- extern char *getenv();
char *gv;
int nplanes;
XSetWindowAttributes ourwinattr;
XWMHints ourxwmhints;
XSizeHints oursizhints;
+ /* open display server */
ourdisplay = XOpenDisplay(NULL);
if (ourdisplay == NULL) {
- stderr_v("cannot open X-windows; DISPLAY variable set?\n");
+ eputs("cannot open X-windows; DISPLAY variable set?\n");
return(NULL);
/* find a usable visual */
nplanes = DisplayPlanes(ourdisplay, ourscreen);
if (XMatchVisualInfo(ourdisplay,ourscreen,
- 24,TrueColor,&ourvinfo) ||
+ nplanes>12?nplanes:24,TrueColor,&ourvinfo) ||
- 24,DirectColor,&ourvinfo)) {
+ nplanes>12?nplanes:24,DirectColor,&ourvinfo)) {
ourblack = 0;
ourwhite = ourvinfo.red_mask |
ourvinfo.green_mask |
ourvinfo.blue_mask ;
} else {
if (nplanes < 4) {
- stderr_v("not enough colors\n");
+ eputs("not enough colors\n");
return(NULL);
if (!XMatchVisualInfo(ourdisplay,ourscreen,
nplanes,PseudoColor,&ourvinfo) &&
nplanes,GrayScale,&ourvinfo)) {
- stderr_v("unsupported visual type\n");
+ eputs("unsupported visual type\n");
return(NULL);
ourblack = BlackPixel(ourdisplay,ourscreen);
ourwhite = WhitePixel(ourdisplay,ourscreen);
/* set gamma */
- if ((gv = getenv("GAMMA")) != NULL)
+ if ((gv = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
+ || (gv = getenv("DISPLAY_GAMMA")) != NULL)
make_gmap(atof(gv));
else
make_gmap(GAMMA);
+ /* X11 command line or no? */
+ if (!strcmp(name, "x11"))
+ comheight = COMHEIGHT;
+ else /* "x11d" */ {
+ comheight = 0;
+#ifndef FNDELAY
+ eputs("warning: x11d driver not fully functional on this machine\n");
+#endif
/* open window */
ourwinattr.background_pixel = ourblack;
ourwinattr.border_pixel = ourblack;
@@ -136,7 +219,7 @@ char *name, *id;
BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual,
CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr);
if (gwind == 0) {
- stderr_v("cannot create window\n");
+ eputs("cannot create window\n");
return(NULL);
XStoreName(ourdisplay, gwind, id);
@@ -149,30 +232,42 @@ char *name, *id;
gwind, x11icon_bits, x11icon_width, x11icon_height);
XSetWMHints(ourdisplay, gwind, &ourxwmhints);
oursizhints.min_width = MINWIDTH;
- oursizhints.min_height = MINHEIGHT+COMHEIGHT;
+ oursizhints.min_height = MINHEIGHT+comheight;
oursizhints.flags = PMinSize;
XSetNormalHints(ourdisplay, gwind, &oursizhints);
XSelectInput(ourdisplay, gwind, ExposureMask);
XMapWindow(ourdisplay, gwind);
XWindowEvent(ourdisplay, gwind, ExposureMask, levptr(XEvent));
gwidth = levptr(XExposeEvent)->width;
- gheight = levptr(XExposeEvent)->height - COMHEIGHT;
+ gheight = levptr(XExposeEvent)->height - comheight;
x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth;
x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight;
x11_driver.inpready = 0;
- cmdvec = x11_comout; /* set error vectors */
- if (wrnvec != NULL)
- wrnvec = x11_errout;
+ mapped = 1;
+ /* set i/o vectors */
+ if (comheight) {
+ x11_driver.comin = x11_comin;
+ x11_driver.comout = x11_comout;
+ erract[COMMAND].pf = x11_comout;
+ if (erract[WARNING].pf != NULL)
+ erract[WARNING].pf = x11_errout;
+ inpcheck = IC_X11;
+ } else {
+ x11_driver.comin = std_comin;
+ x11_driver.comout = std_comout;
+ erract[COMMAND].pf = std_comout;
+ inpcheck = IC_IOCTL;
return(&x11_driver);
-static
+static void
x11_close() /* close our display */
- cmdvec = NULL; /* reset error vectors */
- wrnvec = stderr_v;
+ erract[COMMAND].pf = NULL; /* reset error vectors */
+ erract[WARNING].pf = wputs;
return;
if (comline != NULL) {
@@ -190,7 +285,7 @@ x11_close() /* close our display */
-static
+static void
x11_clear(xres, yres) /* clear our display */
int xres, yres;
@@ -202,7 +297,7 @@ int xres, yres;
/* resize window */
if (xres != gwidth || yres != gheight) {
XSelectInput(ourdisplay, gwind, 0);
- XResizeWindow(ourdisplay, gwind, xres, yres+COMHEIGHT);
+ XResizeWindow(ourdisplay, gwind, xres, yres+comheight);
gwidth = xres;
gheight = yres;
XFlush(ourdisplay);
@@ -213,93 +308,159 @@ int xres, yres;
/* reinitialize color table */
if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale)
if (getpixels() == 0)
- stderr_v("cannot allocate colors\n");
+ eputs("cannot allocate colors\n");
else
new_ctab(ncolors);
/* get new command line */
xt_close(comline);
- comline = xt_open(ourdisplay, gwind, 0, gheight,
- gwidth, COMHEIGHT, 0, ourblack, ourwhite, COMFN);
- if (comline == NULL) {
- stderr_v("Cannot open command line window\n");
- quit(1);
- XSelectInput(ourdisplay, comline->w, ExposureMask);
+ if (comheight) {
+ comline = xt_open(ourdisplay, gwind, 0, gheight, gwidth,
+ comheight, 0, ourblack, ourwhite, COMFN);
+ if (comline == NULL) {
+ eputs("cannot open command line window\n");
+ quit(1);
+ XSelectInput(ourdisplay, comline->w, ExposureMask);
/* remove earmuffs */
- XSelectInput(ourdisplay, gwind,
+ XSelectInput(ourdisplay, gwind,
StructureNotifyMask|ExposureMask|KeyPressMask|ButtonPressMask);
+ } else /* remove earmuffs */
+ StructureNotifyMask|ExposureMask|ButtonPressMask);
-static
+static void
x11_paintr(col, xmin, ymin, xmax, ymax) /* fill a rectangle */
COLOR col;
int xmin, ymin, xmax, ymax;
- extern int xnewcolr(); /* pixel assignment routine */
- extern unsigned long true_pixel();
unsigned long pixel;
+ if (!mapped)
+ return;
if (ncolors > 0)
pixel = pixval[get_pixel(col, xnewcolr)];
- else if (ourvinfo.class == TrueColor || ourvinfo.class == DirectColor)
- pixel = true_pixel(col);
else
- return;
+ pixel = true_pixel(col);
XSetForeground(ourdisplay, ourgc, pixel);
XFillRectangle(ourdisplay, gwind,
ourgc, xmin, gheight-ymax, xmax-xmin, ymax-ymin);
-static
+static void
x11_flush() /* flush output */
+ char buf[256];
+ int n;
+ /* check for input */
XNoOp(ourdisplay);
- while (XPending(ourdisplay) > 0)
+ n = XPending(ourdisplay); /* from X server */
+ while (n-- > 0)
getevent();
+#ifdef FNDELAY
+ if (inpcheck == IC_IOCTL) { /* from stdin */
+#ifdef FIONREAD
+ if (ioctl(fileno(stdin), FIONREAD, &n) < 0) {
+#else
+ if (1) {
+#endif
+ if (fcntl(fileno(stdin), F_SETFL, FNDELAY) < 0) {
+ eputs("cannot change input mode\n");
+ quit(1);
+ inpcheck = IC_READ;
+ } else
+ x11_driver.inpready += n;
+ if (inpcheck == IC_READ) {
+ n = read(fileno(stdin), buf, sizeof(buf)-1);
+ if (n > 0) {
+ buf[n] = '\0';
+ tocombuf(buf, &x11_driver);
+#endif
-static
+static void
x11_comin(inp, prompt) /* read in a command line */
char *inp, *prompt;
- extern int x11_getc();
- if (prompt != NULL)
+ if (prompt != NULL) {
+ x11_flush(); /* make sure we get everything */
if (fromcombuf(inp, &x11_driver))
return;
- else
- xt_puts(prompt, comline);
+ xt_puts(prompt, comline);
xt_cursor(comline, TBLKCURS);
editline(inp, x11_getc, x11_comout);
xt_cursor(comline, TNOCURS);
-static
-x11_comout(out) /* output a string to command line */
-char *out;
+static void
+x11_comout(outp) /* output a string to command line */
+char *outp;
+ if (comline == NULL || outp == NULL || !outp[0])
return;
- xt_puts(out, comline);
- if (out[strlen(out)-1] == '\n')
+ xt_puts(outp, comline);
+ if (outp[strlen(outp)-1] == '\n')
XFlush(ourdisplay);
-static
+static void
x11_errout(msg) /* output an error message */
char *msg;
- stderr_v(msg); /* send to stderr also! */
+ eputs(msg); /* send to stderr also! */
x11_comout(msg);
+static void
+std_comin(inp, prompt) /* read in command line from stdin */
+char *inp, *prompt;
+ if (fromcombuf(inp, &x11_driver))
+ return;
+ if (!x11_driver.inpready)
+ std_comout(prompt);
+#ifdef FNDELAY
+ if (inpcheck == IC_READ) { /* turn off FNDELAY */
+ if (fcntl(fileno(stdin), F_SETFL, 0) < 0) {
+ quit(1);
+#endif
+ if (gets(inp) == NULL) {
+ strcpy(inp, "quit");
+ return;
+ x11_driver.inpready -= strlen(inp) + 1;
+ if (x11_driver.inpready < 0)
+ x11_driver.inpready = 0;
+static void
+std_comout(outp) /* write out string to stdout */
+char *outp;
+ fputs(outp, stdout);
+ fflush(stdout);
static int
x11_getcur(xp, yp) /* get cursor position */
int *xp, *yp;
@@ -319,19 +480,17 @@ int *xp, *yp;
if (c_last > c_first) /* key pressed */
return(x11_getc());
/* button pressed */
- if (levptr(XButtonPressedEvent)->button & Button1)
+ if (levptr(XButtonPressedEvent)->button == Button1)
return(MB1);
- if (levptr(XButtonPressedEvent)->button & Button2)
+ if (levptr(XButtonPressedEvent)->button == Button2)
return(MB2);
- if (levptr(XButtonPressedEvent)->button & Button3)
+ if (levptr(XButtonPressedEvent)->button == Button3)
return(MB3);
- if (levptr(XButtonPressedEvent)->button & (Button4|Button5))
- return(MB1);
return(ABORT);
-static
+static void
xnewcolr(ndx, r, g, b) /* enter a color into hardware table */
int ndx;
int r, g, b;
@@ -369,10 +528,9 @@ loop:
pixval = (unsigned long *)malloc(ncolors*sizeof(unsigned long));
if (pixval == NULL)
return(ncolors = 0);
- if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,
- pixval,ncolors) != 0)
+ if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,pixval,ncolors))
break;
- free((char *)pixval);
+ free((void *)pixval);
pixval = NULL;
if (pixval == NULL) {
@@ -401,12 +559,14 @@ loop:
-static
+static void
freepixels() /* free our pixels */
if (ncolors == 0)
return;
XFreeColors(ourdisplay,ourmap,pixval,ncolors,0L);
+ pixval = NULL;
ncolors = 0;
if (ourmap != DefaultColormap(ourdisplay,ourscreen))
XFreeColormap(ourdisplay, ourmap);
@@ -441,7 +601,7 @@ x11_getc() /* get a command character */
-static
+static void
getevent() /* get next event */
XNextEvent(ourdisplay, levptr(XEvent));
@@ -450,15 +610,17 @@ getevent() /* get next event */
resizewindow(levptr(XConfigureEvent));
break;
case UnmapNotify:
+ mapped = 0;
freepixels();
break;
case MapNotify:
- stderr_v("Cannot allocate colors\n");
else
new_ctab(ncolors);
+ mapped = 1;
break;
case Expose:
fixwindow(levptr(XExposeEvent));
@@ -472,7 +634,7 @@ getevent() /* get next event */
-static
+static void
getkey(ekey) /* get input key */
register XKeyPressedEvent *ekey;
@@ -485,14 +647,17 @@ register XKeyPressedEvent *ekey;
-static
+static void
fixwindow(eexp) /* repair damage to window */
register XExposeEvent *eexp;
+ char buf[80];
if (eexp->window == gwind) {
- sprintf(getcombuf(&x11_driver), "repaint %d %d %d %d\n",
+ sprintf(buf, "repaint %d %d %d %d\n",
eexp->x, gheight - eexp->y - eexp->height,
eexp->x + eexp->width, gheight - eexp->y);
} else if (eexp->window == comline->w) {
if (eexp->count == 0)
xt_redraw(comline);
@@ -500,17 +665,17 @@ register XExposeEvent *eexp;
-static
+static void
resizewindow(ersz) /* resize window */
register XConfigureEvent *ersz;
- if (ersz->width == gwidth && ersz->height-COMHEIGHT == gheight)
+ if (ersz->width == gwidth && ersz->height-comheight == gheight)
return;
gwidth = ersz->width;
- gheight = ersz->height-COMHEIGHT;
+ gheight = ersz->height-comheight;
- strcpy(getcombuf(&x11_driver), "new\n");
+ tocombuf("new\n", &x11_driver);
