--- ray/src/rt/x11.c 1990/01/12 11:33:05 1.2 +++ ray/src/rt/x11.c 2011/05/20 02:06:39 2.35 @@ -1,29 +1,33 @@ #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: x11.c,v 2.35 2011/05/20 02:06:39 greg Exp $"; #endif - -/* Copyright (c) 1989 Regents of the University of California */ - /* - * x11.c - driver for X-windows version 10.4 - * - * 1989 + * x11.c - driver for X-windows version 11 */ -#include +#include "copyright.h" +#include "standard.h" #include +#if !defined(FNDELAY) && defined(O_NONBLOCK) +#define FNDELAY O_NONBLOCK +#endif #include -#include -#include +#include +#include +#include "platform.h" #include "color.h" #include "driver.h" #include "x11twind.h" +#include "x11icon.h" -#define GAMMA 2.2 /* exponent for color correction */ +#define GAMMA 2.2 /* default exponent correction */ +#define MINWIDTH (32*COMCW) /* minimum graphics window width */ +#define MINHEIGHT (MINWIDTH/2) /* minimum graphics window height */ + #define BORWIDTH 5 /* border width */ #define COMHEIGHT (COMLH*COMCH) /* command line height (pixels) */ @@ -32,30 +36,29 @@ static char SCCSid[] = "$SunId$ LBL"; #define COMCW 8 /* approx. character width (pixels) */ #define COMCH 14 /* approx. character height (pixels) */ -#ifndef WFLUSH -#define WFLUSH 30 /* flush after this many rays */ -#endif +#define ourscreen DefaultScreen(ourdisplay) +#define ourroot RootWindow(ourdisplay,ourscreen) -#define checkinp() while (XPending(ourdisplay) > 0) getevent() +#define levptr(etype) ((etype *)¤tevent) -#define levptr(etype) ((etype *)&thisevent) +static XEvent currentevent; /* current event */ -static char *clientname; /* calling client's name */ - -static XEvent thisevent; /* current event */ - static int ncolors = 0; /* color table size */ -static int *pixval = NULL; /* allocated pixels */ +static int mapped = 0; /* window is mapped? */ +static unsigned long *pixval = NULL; /* allocated pixels */ +static unsigned long ourblack=0, ourwhite=1; static Display *ourdisplay = NULL; /* our display */ +static XVisualInfo ourvinfo; /* our visual information */ + static Window gwind = 0; /* our graphics window */ static Cursor pickcursor = 0; /* cursor used for picking */ -static int gwidth = 0; /* graphics window width */ -static int gheight = 0; /* graphics window height */ +static int gwidth, gheight; /* graphics window size */ +static int comheight; /* desired comline height */ static TEXTWIND *comline = NULL; /* our command line */ static char c_queue[64]; /* input queue */ @@ -64,211 +67,378 @@ static int c_last = 0; /* last character in queue * static GC ourgc = 0; /* our graphics context for drawing */ -static Colormap ourmap; /* our color map */ +static Colormap ourmap = 0; /* our color map */ -extern char *malloc(); +#define IC_X11 0 +#define IC_IOCTL 1 +#define IC_READ 2 -int x11_close(), x11_clear(), x11_paintr(), x11_errout(), - x11_getcur(), x11_comout(), x11_comin(); +static int inpcheck; /* whence to check input */ +static void x11_errout(char *msg); + +static dr_closef_t x11_close; +static dr_clearf_t x11_clear; +static dr_paintrf_t x11_paintr; +static dr_getcurf_t x11_getcur; +static dr_comoutf_t x11_comout; +static dr_cominf_t x11_comin; +static dr_flushf_t x11_flush; + +static dr_cominf_t std_comin; +static dr_comoutf_t std_comout; + static struct driver x11_driver = { x11_close, x11_clear, x11_paintr, x11_getcur, - x11_comout, x11_comin, 1.0 + NULL, NULL, x11_flush, 1.0 }; +static dr_getchf_t x11_getc; -struct driver * -x11_init(name, id) /* initialize driver */ -char *name, *id; -{ - Pixmap bmCursorSrc, bmCursorMsk; +static void freepixels(void); +static int getpixels(void); +static dr_newcolrf_t xnewcolr; +static unsigned long true_pixel(COLOR col); +static void getevent(void); +static void getkey(XKeyPressedEvent *ekey); +static void fixwindow(XExposeEvent *eexp); +static void resizewindow(XConfigureEvent *ersz); +extern dr_initf_t x11_init; /* XXX this should be in a seperate header file */ + + +extern struct driver * +x11_init( /* initialize driver */ + char *name, + char *id +) +{ + char *gv; + int nplanes; + XSetWindowAttributes ourwinattr; + XWMHints ourxwmhints; + XSizeHints oursizhints; + /* open display server */ ourdisplay = XOpenDisplay(NULL); if (ourdisplay == NULL) { - stderr_v("cannot open X-windows; DISPLAY variable set?\n"); + eputs("cannot open X-windows; DISPLAY variable set?\n"); return(NULL); } - if (DisplayPlanes(ourdisplay, DefaultScreen(ourdisplay)) < 4) { - stderr_v("not enough colors\n"); + /* find a usable visual */ + nplanes = DisplayPlanes(ourdisplay, ourscreen); + if (XMatchVisualInfo(ourdisplay,ourscreen, + nplanes>12?nplanes:24,TrueColor,&ourvinfo) || + XMatchVisualInfo(ourdisplay,ourscreen, + nplanes>12?nplanes:24,DirectColor,&ourvinfo)) { + ourblack = 0; + ourwhite = ourvinfo.red_mask | + ourvinfo.green_mask | + ourvinfo.blue_mask ; + } else { + if (nplanes < 4) { + eputs("not enough colors\n"); + return(NULL); + } + if (!XMatchVisualInfo(ourdisplay,ourscreen, + nplanes,PseudoColor,&ourvinfo) && + !XMatchVisualInfo(ourdisplay,ourscreen, + nplanes,GrayScale,&ourvinfo)) { + eputs("unsupported visual type\n"); + return(NULL); + } + ourblack = BlackPixel(ourdisplay,ourscreen); + ourwhite = WhitePixel(ourdisplay,ourscreen); + } + /* set gamma */ + if ((gv = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL + || (gv = getenv("DISPLAY_GAMMA")) != NULL) + make_gmap(atof(gv)); + else + make_gmap(GAMMA); + /* X11 command line or no? */ + if (!strcmp(name, "x11")) + comheight = COMHEIGHT; + else /* "x11d" */ { + comheight = 0; +#ifndef FNDELAY + eputs("warning: x11d driver not fully functional on this machine\n"); +#endif + } + /* open window */ + ourwinattr.background_pixel = ourblack; + ourwinattr.border_pixel = ourblack; + /* this is stupid */ + ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot, + ourvinfo.visual, AllocNone); + gwind = XCreateWindow(ourdisplay, ourroot, 0, 0, + DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH, + DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH, + BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual, + CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr); + if (gwind == 0) { + eputs("cannot create window\n"); return(NULL); } - ourmap = DefaultColormap(ourdisplay,DefaultScreen(ourdisplay)); - make_gmap(GAMMA); /* make color map */ - /* - bmCursorSrc = XCreateBitmapFromData(ourdisplay, - gwind, bcross_bits, - bcross_width, bcross_height); - bmCursorMsk = XCreateBitmapFromData(ourdisplay, - gwind, bcross_mask_bits, - bcross_width, bcross_height); - - pickcursor = XCreatePixmapCursor(ourdisplay, - bmCursorSrc, bmCursorMsk, - BlackPixel(ourdisplay, - DefaultScreen(ourdisplay)), - WhitePixel(ourdisplay, - DefaultScreen(ourdisplay)), - bcross_x_hot, bcross_y_hot); - XFreePixmap(ourdisplay, bmCursorSrc); - XFreePixmap(ourdisplay, bmCursorMsk); - */ + XStoreName(ourdisplay, gwind, id); /* create a cursor */ - pickcursor = XCreateFontCursor (ourdisplay, XC_diamond_cross); - /* new */ - clientname = id; - x11_driver.xsiz = DisplayWidth(ourdisplay,DefaultScreen(ourdisplay)) - - 2*BORWIDTH; - x11_driver.ysiz = DisplayHeight(ourdisplay,DefaultScreen(ourdisplay)) - - (COMHEIGHT + 2*BORWIDTH); + pickcursor = XCreateFontCursor(ourdisplay, XC_diamond_cross); + ourgc = XCreateGC(ourdisplay, gwind, 0, NULL); + ourxwmhints.flags = InputHint|IconPixmapHint; + ourxwmhints.input = True; + ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay, + gwind, x11icon_bits, x11icon_width, x11icon_height); + XSetWMHints(ourdisplay, gwind, &ourxwmhints); + oursizhints.min_width = MINWIDTH; + oursizhints.min_height = MINHEIGHT+comheight; + oursizhints.flags = PMinSize; + XSetNormalHints(ourdisplay, gwind, &oursizhints); + XSelectInput(ourdisplay, gwind, ExposureMask); + XMapWindow(ourdisplay, gwind); + XWindowEvent(ourdisplay, gwind, ExposureMask, levptr(XEvent)); + gwidth = levptr(XExposeEvent)->width; + gheight = levptr(XExposeEvent)->height - comheight; + x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth; + x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight; x11_driver.inpready = 0; - cmdvec = x11_comout; /* set error vectors */ - if (wrnvec != NULL) - wrnvec = x11_errout; + mapped = 1; + /* set i/o vectors */ + if (comheight) { + x11_driver.comin = x11_comin; + x11_driver.comout = x11_comout; + erract[COMMAND].pf = x11_comout; + /* doesn't work with raypcalls.c + if (erract[WARNING].pf != NULL) + erract[WARNING].pf = x11_errout; + */ + inpcheck = IC_X11; + } else { + x11_driver.comin = std_comin; + x11_driver.comout = std_comout; + erract[COMMAND].pf = std_comout; + inpcheck = IC_IOCTL; + } return(&x11_driver); } -static -x11_close() /* close our display */ +static void +x11_close(void) /* close our display */ { - cmdvec = NULL; /* reset error vectors */ - if (wrnvec != NULL) - wrnvec = stderr_v; + erract[COMMAND].pf = NULL; /* reset error vectors */ + if (erract[WARNING].pf != NULL) + erract[WARNING].pf = wputs; if (ourdisplay == NULL) return; if (comline != NULL) { xt_close(comline); comline = NULL; } - if (gwind != 0) { - XFreeGC(ourdisplay, ourgc); - XDestroyWindow(ourdisplay, gwind); - gwind = 0; - gwidth = gheight = 0; - ourgc = 0; - } - XFreeCursor(ourdisplay, pickcursor); freepixels(); + XFreeGC(ourdisplay, ourgc); + XDestroyWindow(ourdisplay, gwind); + gwind = 0; + ourgc = 0; + XFreeCursor(ourdisplay, pickcursor); XCloseDisplay(ourdisplay); ourdisplay = NULL; } -static -x11_clear(xres, yres) /* clear our display */ -int xres, yres; +static void +x11_clear( /* clear our display */ + int xres, + int yres +) { - XWMHints ourxwmhints; - XSetWindowAttributes ourwindowattr; - - if (xres != gwidth || yres != gheight) { /* change window */ - if (comline != NULL) - xt_close(comline); - if (gwind == 0) { /* new window */ - ourwindowattr.backing_store = Always; - ourwindowattr.background_pixel = - WhitePixel(ourdisplay, DefaultScreen(ourdisplay)); - ourwindowattr.border_pixel = - BlackPixel(ourdisplay, DefaultScreen(ourdisplay)); - gwind = XCreateWindow(ourdisplay, - RootWindow(ourdisplay, - DefaultScreen(ourdisplay)), - 0, 0, xres, yres+COMHEIGHT, BORWIDTH, - 0, InputOutput, CopyFromParent, - CWBackingStore|CWBackPixel|CWBorderPixel, - &ourwindowattr); - if (gwind == 0) - goto fail; - XStoreName(ourdisplay, gwind, clientname); - ourgc = XCreateGC(ourdisplay, gwind, 0, NULL); - ourxwmhints.flags = InputHint; - ourxwmhints.input = True; - XSetWMHints(ourdisplay, gwind, &ourxwmhints); - XSelectInput(ourdisplay, gwind, - KeyPressMask|ButtonPressMask); - XMapWindow(ourdisplay, gwind); - } else /* resize window */ - XResizeWindow(ourdisplay, gwind, xres, yres+COMHEIGHT); - comline = xt_open(ourdisplay, - DefaultGC(ourdisplay,DefaultScreen(ourdisplay)), - gwind, 0, yres, xres, COMHEIGHT, 0, COMFN); - if (comline == NULL) - goto fail; + /* check limits */ + if (xres < MINWIDTH) + xres = MINWIDTH; + if (yres < MINHEIGHT) + yres = MINHEIGHT; + /* resize window */ + if (xres != gwidth || yres != gheight) { + XSelectInput(ourdisplay, gwind, 0); + XResizeWindow(ourdisplay, gwind, xres, yres+comheight); gwidth = xres; gheight = yres; - } else /* just clear */ - XClearWindow(ourdisplay, gwind); + XFlush(ourdisplay); + sleep(2); /* wait for window manager */ + XSync(ourdisplay, 1); /* discard input */ + } + XClearWindow(ourdisplay, gwind); /* reinitialize color table */ - if (ncolors == 0 && getpixels() == 0) - stderr_v("cannot allocate colors\n"); - else - new_ctab(ncolors); - return; -fail: - stderr_v("Failure opening window in x11_clear\n"); - quit(1); + if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) { + if (getpixels() == 0) + eputs("cannot allocate colors\n"); + else + new_ctab(ncolors); + } + /* get new command line */ + if (comline != NULL) + xt_close(comline); + if (comheight) { + comline = xt_open(ourdisplay, gwind, 0, gheight, gwidth, + comheight, 0, ourblack, ourwhite, COMFN); + if (comline == NULL) { + eputs("cannot open command line window\n"); + quit(1); + } + XSelectInput(ourdisplay, comline->w, ExposureMask); + /* remove earmuffs */ + XSelectInput(ourdisplay, gwind, + StructureNotifyMask|ExposureMask|KeyPressMask|ButtonPressMask); + } else /* remove earmuffs */ + XSelectInput(ourdisplay, gwind, + StructureNotifyMask|ExposureMask|ButtonPressMask); } -static -x11_paintr(col, xmin, ymin, xmax, ymax) /* fill a rectangle */ -COLOR col; -int xmin, ymin, xmax, ymax; +static void +x11_paintr( /* fill a rectangle */ + COLOR col, + int xmin, + int ymin, + int xmax, + int ymax +) { - extern long nrays; /* global ray count */ - extern int xnewcolr(); /* pixel assignment routine */ - static long lastflush = 0; /* ray count at last flush */ + unsigned long pixel; - if (ncolors > 0) { - XSetForeground(ourdisplay, ourgc, - pixval[get_pixel(col, xnewcolr)]); - XFillRectangle(ourdisplay, gwind, - ourgc, xmin, gheight-ymax, xmax-xmin, ymax-ymin); + if (!mapped) + return; + if (ncolors > 0) + pixel = pixval[get_pixel(col, xnewcolr)]; + else + pixel = true_pixel(col); + XSetForeground(ourdisplay, ourgc, pixel); + XFillRectangle(ourdisplay, gwind, + ourgc, xmin, gheight-ymax, xmax-xmin, ymax-ymin); +} + + +static void +x11_flush(void) /* flush output */ +{ + char buf[256]; + int n; + /* check for input */ + XNoOp(ourdisplay); + n = XPending(ourdisplay); /* from X server */ + while (n-- > 0) + getevent(); +#ifdef FNDELAY + if (inpcheck == IC_IOCTL) { /* from stdin */ +#ifdef FIONREAD + if (ioctl(fileno(stdin), FIONREAD, &n) < 0) { +#else + if (1) { +#endif + if (fcntl(fileno(stdin), F_SETFL, FNDELAY) < 0) { + eputs("cannot change input mode\n"); + quit(1); + } + inpcheck = IC_READ; + } else + x11_driver.inpready += n; } - if (nrays - lastflush >= WFLUSH) { - if (ncolors <= 0) /* output necessary for death */ - XFillRectangle(ourdisplay, gwind, - ourgc, 0, 0, 1 ,1); - checkinp(); - lastflush = nrays; + if (inpcheck == IC_READ) { + n = read(fileno(stdin), buf, sizeof(buf)-1); + if (n > 0) { + buf[n] = '\0'; + tocombuf(buf, &x11_driver); + } } +#endif } -static -x11_comin(inp) /* read in a command line */ -char *inp; +static void +x11_comin( /* read in a command line */ + char *inp, + char *prompt +) { - int x11_getc(), x11_comout(); - + if (prompt != NULL) { + x11_flush(); /* make sure we get everything */ + if (fromcombuf(inp, &x11_driver)) + return; + xt_puts(prompt, comline); + } xt_cursor(comline, TBLKCURS); editline(inp, x11_getc, x11_comout); xt_cursor(comline, TNOCURS); } -static -x11_comout(out) /* output a string to command line */ -char *out; +static void +x11_comout( /* output a string to command line */ + char *outp +) { - if (comline != NULL) - xt_puts(out, comline); - XFlush(ourdisplay); + if (comline == NULL || outp == NULL || !outp[0]) + return; + xt_puts(outp, comline); + if (outp[strlen(outp)-1] == '\n') + XFlush(ourdisplay); } -static -x11_errout(msg) /* output an error message */ -char *msg; +static void +x11_errout( /* output an error message */ + char *msg +) { + eputs(msg); /* send to stderr also! */ x11_comout(msg); - stderr_v(msg); /* send to stderr also! */ } +static void +std_comin( /* read in command line from stdin */ + char *inp, + char *prompt +) +{ + if (prompt != NULL) { + if (fromcombuf(inp, &x11_driver)) + return; + if (!x11_driver.inpready) + std_comout(prompt); + } +#ifdef FNDELAY + if (inpcheck == IC_READ) { /* turn off FNDELAY */ + if (fcntl(fileno(stdin), F_SETFL, 0) < 0) { + eputs("cannot change input mode\n"); + quit(1); + } + inpcheck = IC_IOCTL; + } +#endif + if (gets(inp) == NULL) { + strcpy(inp, "quit"); + return; + } + x11_driver.inpready -= strlen(inp) + 1; + if (x11_driver.inpready < 0) + x11_driver.inpready = 0; +} + + +static void +std_comout( /* write out string to stdout */ + char *outp +) +{ + fputs(outp, stdout); + fflush(stdout); +} + + static int -x11_getcur(xp, yp) /* get cursor position */ -int *xp, *yp; +x11_getcur( /* get cursor position */ + int *xp, + int *yp +) { while (XGrabPointer(ourdisplay, gwind, True, ButtonPressMask, GrabModeAsync, GrabModeAsync, None, pickcursor, @@ -285,22 +455,23 @@ int *xp, *yp; if (c_last > c_first) /* key pressed */ return(x11_getc()); /* button pressed */ - if (levptr(XButtonPressedEvent)->button & Button1) + if (levptr(XButtonPressedEvent)->button == Button1) return(MB1); - if (levptr(XButtonPressedEvent)->button & Button2) + if (levptr(XButtonPressedEvent)->button == Button2) return(MB2); - if (levptr(XButtonPressedEvent)->button & Button3) + if (levptr(XButtonPressedEvent)->button == Button3) return(MB3); - if (levptr(XButtonPressedEvent)->button & (Button4|Button5)) - return(MB1); return(ABORT); } -static -xnewcolr(ndx, r, g, b) /* enter a color into hardware table */ -int ndx; -int r, g, b; +static void +xnewcolr( /* enter a color into hardware table */ + int ndx, + int r, + int g, + int b +) { XColor xcolor; @@ -315,36 +486,90 @@ int r, g, b; static int -getpixels() /* get the color map */ +getpixels(void) /* get the color map */ { - Visual *ourvis = DefaultVisual(ourdisplay,DefaultScreen(ourdisplay)); + XColor thiscolor; + register int i, j; - freepixels(); - for (ncolors=(ourvis->map_entries)-3; ncolors>12; ncolors=ncolors*.937){ - pixval = (int *)malloc(ncolors*sizeof(int)); + if (ncolors > 0) + return(ncolors); + if (ourvinfo.visual == DefaultVisual(ourdisplay,ourscreen)) { + ourmap = DefaultColormap(ourdisplay,ourscreen); + goto loop; + } +newmap: + ourmap = XCreateColormap(ourdisplay,gwind,ourvinfo.visual,AllocNone); +loop: + for (ncolors = ourvinfo.colormap_size; + ncolors > ourvinfo.colormap_size/3; + ncolors = ncolors*.937) { + pixval = (unsigned long *)malloc(ncolors*sizeof(unsigned long)); if (pixval == NULL) + return(ncolors = 0); + if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,pixval,ncolors)) break; - if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0, - pixval,ncolors) != 0) - return(ncolors); - free((char *)pixval); + free((void *)pixval); + pixval = NULL; } - return(ncolors = 0); + if (pixval == NULL) { + if (ourmap == DefaultColormap(ourdisplay,ourscreen)) + goto newmap; /* try it with our map */ + else + return(ncolors = 0); /* failed */ + } + if (ourmap != DefaultColormap(ourdisplay,ourscreen)) + for (i = 0; i < ncolors; i++) { /* reset black and white */ + if (pixval[i] != ourblack && pixval[i] != ourwhite) + continue; + thiscolor.pixel = pixval[i]; + thiscolor.flags = DoRed|DoGreen|DoBlue; + XQueryColor(ourdisplay, + DefaultColormap(ourdisplay,ourscreen), + &thiscolor); + XStoreColor(ourdisplay, ourmap, &thiscolor); + for (j = i; j+1 < ncolors; j++) + pixval[j] = pixval[j+1]; + ncolors--; + i--; + } + XSetWindowColormap(ourdisplay, gwind, ourmap); + return(ncolors); } -static -freepixels() /* free our pixels */ +static void +freepixels(void) /* free our pixels */ { if (ncolors == 0) return; XFreeColors(ourdisplay,ourmap,pixval,ncolors,0L); + free((void *)pixval); + pixval = NULL; ncolors = 0; + if (ourmap != DefaultColormap(ourdisplay,ourscreen)) + XFreeColormap(ourdisplay, ourmap); + ourmap = 0; } +static unsigned long +true_pixel( /* return true pixel value for color */ + COLOR col +) +{ + unsigned long rval; + uby8 rgb[3]; + + map_color(rgb, col); + rval = ourvinfo.red_mask*rgb[RED]/255 & ourvinfo.red_mask; + rval |= ourvinfo.green_mask*rgb[GRN]/255 & ourvinfo.green_mask; + rval |= ourvinfo.blue_mask*rgb[BLU]/255 & ourvinfo.blue_mask; + return(rval); +} + + static int -x11_getc() /* get a command character */ +x11_getc(void) /* get a command character */ { while (c_last <= c_first) { c_first = c_last = 0; /* reset */ @@ -355,11 +580,31 @@ x11_getc() /* get a command character */ } -static -getevent() /* get next event */ +static void +getevent(void) /* get next event */ { XNextEvent(ourdisplay, levptr(XEvent)); switch (levptr(XEvent)->type) { + case ConfigureNotify: + resizewindow(levptr(XConfigureEvent)); + break; + case UnmapNotify: + mapped = 0; + freepixels(); + break; + case MapNotify: + if (ourvinfo.class == PseudoColor || + ourvinfo.class == GrayScale) { + if (getpixels() == 0) + eputs("cannot allocate colors\n"); + else + new_ctab(ncolors); + } + mapped = 1; + break; + case Expose: + fixwindow(levptr(XExposeEvent)); + break; case KeyPress: getkey(levptr(XKeyPressedEvent)); break; @@ -369,25 +614,51 @@ getevent() /* get next event */ } -static -getkey(ekey) /* get input key */ -register XKeyPressedEvent *ekey; +static void +getkey( /* get input key */ + register XKeyPressedEvent *ekey +) { - c_last += XLookupString(ekey, c_queue+c_last, sizeof(c_queue)-c_last, + register int n; + + n = XLookupString(ekey, c_queue+c_last, sizeof(c_queue)-c_last, NULL, NULL); - x11_driver.inpready = c_last-c_first; + c_last += n; + x11_driver.inpready += n; } -#ifdef notdef -static -fixwindow(eexp) /* repair damage to window */ -register XExposeEvent *eexp; +static void +fixwindow( /* repair damage to window */ + register XExposeEvent *eexp +) { - if (eexp->subwindow == 0) - repaint(eexp->x, gheight - eexp->y - eexp->height, + char buf[80]; + + if (eexp->window == gwind) { + sprintf(buf, "repaint %d %d %d %d\n", + eexp->x, gheight - eexp->y - eexp->height, eexp->x + eexp->width, gheight - eexp->y); - else if (eexp->subwindow == comline->w) - xt_redraw(comline); + tocombuf(buf, &x11_driver); + } else if (eexp->window == comline->w) { + if (eexp->count == 0) + xt_redraw(comline); + } } -#endif + + +static void +resizewindow( /* resize window */ + register XConfigureEvent *ersz +) +{ + if (ersz->width == gwidth && ersz->height-comheight == gheight) + return; + + gwidth = ersz->width; + gheight = ersz->height-comheight; + x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth; + x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight; + + tocombuf("new\n", &x11_driver); +}
