root/radiance/ray/src/rt/x11.c
Revision: 2.34
Committed: Thu Aug 21 07:05:59 2008 UTC (16 years, 8 months ago) by greg
Changes since 2.33: +3 -1 lines
2 static const char RCSid[] = "$Id: x11.c,v 2.33 2007/11/21 16:42:03 greg Exp $";
5 * x11.c - driver for X-windows version 11
6 */
7
8 #include "copyright.h"
9
10 #include "standard.h"
11 #include <sys/ioctl.h>
12 #if !defined(FNDELAY) && defined(O_NONBLOCK)
13 #define FNDELAY O_NONBLOCK
14 #endif
15
16 #include <X11/Xlib.h>
17 #include <X11/cursorfont.h>
18 #include <X11/Xutil.h>
19
20 #include "platform.h"
21 #include "color.h"
22 #include "driver.h"
23 #include "x11twind.h"
24 #include "x11icon.h"
25
26 #define GAMMA 2.2 /* default exponent correction */
27
28 #define MINWIDTH (32*COMCW) /* minimum graphics window width */
29 #define MINHEIGHT (MINWIDTH/2) /* minimum graphics window height */
30
31 #define BORWIDTH 5 /* border width */
32 #define COMHEIGHT (COMLH*COMCH) /* command line height (pixels) */
33
34 #define COMFN "8x13" /* command line font name */
35 #define COMLH 3 /* number of command lines */
36 #define COMCW 8 /* approx. character width (pixels) */
37 #define COMCH 14 /* approx. character height (pixels) */
38
39 #define ourscreen DefaultScreen(ourdisplay)
40 #define ourroot RootWindow(ourdisplay,ourscreen)
41
42 #define levptr(etype) ((etype *)&currentevent)
43
44 static XEvent currentevent; /* current event */
45
46 static int ncolors = 0; /* color table size */
47 static int mapped = 0; /* window is mapped? */
48 static unsigned long *pixval = NULL; /* allocated pixels */
49 static unsigned long ourblack=0, ourwhite=1;
50
51 static Display *ourdisplay = NULL; /* our display */
52
53 static XVisualInfo ourvinfo; /* our visual information */
54
55 static Window gwind = 0; /* our graphics window */
56
57 static Cursor pickcursor = 0; /* cursor used for picking */
58
59 static int gwidth, gheight; /* graphics window size */
60
61 static int comheight; /* desired comline height */
62 static TEXTWIND *comline = NULL; /* our command line */
63
64 static char c_queue[64]; /* input queue */
65 static int c_first = 0; /* first character in queue */
66 static int c_last = 0; /* last character in queue */
67
68 static GC ourgc = 0; /* our graphics context for drawing */
69
70 static Colormap ourmap = 0; /* our color map */
71
72 #define IC_X11 0
73 #define IC_IOCTL 1
74 #define IC_READ 2
75
76 static int inpcheck; /* whence to check input */
77
78 static void x11_errout(char *msg);
79
80 static dr_closef_t x11_close;
81 static dr_clearf_t x11_clear;
82 static dr_paintrf_t x11_paintr;
83 static dr_getcurf_t x11_getcur;
84 static dr_comoutf_t x11_comout;
85 static dr_cominf_t x11_comin;
86 static dr_flushf_t x11_flush;
87
88 static dr_cominf_t std_comin;
89 static dr_comoutf_t std_comout;
90
91 static struct driver x11_driver = {
92 x11_close, x11_clear, x11_paintr, x11_getcur,
93 NULL, NULL, x11_flush, 1.0
94 };
95
96 static dr_getchf_t x11_getc;
97
98 static void freepixels(void);
99 static int getpixels(void);
100 static dr_newcolrf_t xnewcolr;
101 static unsigned long true_pixel(COLOR col);
102 static void getevent(void);
103 static void getkey(XKeyPressedEvent *ekey);
104 static void fixwindow(XExposeEvent *eexp);
105 static void resizewindow(XConfigureEvent *ersz);
106
107 extern dr_initf_t x11_init; /* XXX this should be in a seperate header file */
108
109
110 extern struct driver *
111 x11_init( /* initialize driver */
112 char *name,
113 char *id
114 )
115 {
116 char *gv;
117 int nplanes;
118 XSetWindowAttributes ourwinattr;
119 XWMHints ourxwmhints;
120 XSizeHints oursizhints;
121 /* open display server */
122 ourdisplay = XOpenDisplay(NULL);
123 if (ourdisplay == NULL) {
124 eputs("cannot open X-windows; DISPLAY variable set?\n");
125 return(NULL);
126 }
127 /* find a usable visual */
128 nplanes = DisplayPlanes(ourdisplay, ourscreen);
129 if (XMatchVisualInfo(ourdisplay,ourscreen,
130 nplanes>12?nplanes:24,TrueColor,&ourvinfo) ||
131 XMatchVisualInfo(ourdisplay,ourscreen,
132 nplanes>12?nplanes:24,DirectColor,&ourvinfo)) {
133 ourblack = 0;
134 ourwhite = ourvinfo.red_mask |
135 ourvinfo.green_mask |
136 ourvinfo.blue_mask ;
137 } else {
138 if (nplanes < 4) {
139 eputs("not enough colors\n");
140 return(NULL);
141 }
142 if (!XMatchVisualInfo(ourdisplay,ourscreen,
143 nplanes,PseudoColor,&ourvinfo) &&
144 !XMatchVisualInfo(ourdisplay,ourscreen,
145 nplanes,GrayScale,&ourvinfo)) {
146 eputs("unsupported visual type\n");
147 return(NULL);
148 }
149 ourblack = BlackPixel(ourdisplay,ourscreen);
150 ourwhite = WhitePixel(ourdisplay,ourscreen);
151 }
152 /* set gamma */
153 if ((gv = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
154 || (gv = getenv("DISPLAY_GAMMA")) != NULL)
155 make_gmap(atof(gv));
156 else
157 make_gmap(GAMMA);
158 /* X11 command line or no? */
159 if (!strcmp(name, "x11"))
160 comheight = COMHEIGHT;
161 else /* "x11d" */ {
162 comheight = 0;
163 #ifndef FNDELAY
164 eputs("warning: x11d driver not fully functional on this machine\n");
165 #endif
166 }
167 /* open window */
168 ourwinattr.background_pixel = ourblack;
169 ourwinattr.border_pixel = ourblack;
170 /* this is stupid */
171 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
172 ourvinfo.visual, AllocNone);
173 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
174 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
175 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
176 BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual,
177 CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr);
178 if (gwind == 0) {
179 eputs("cannot create window\n");
180 return(NULL);
181 }
182 XStoreName(ourdisplay, gwind, id);
183 /* create a cursor */
184 pickcursor = XCreateFontCursor(ourdisplay, XC_diamond_cross);
185 ourgc = XCreateGC(ourdisplay, gwind, 0, NULL);
186 ourxwmhints.flags = InputHint|IconPixmapHint;
187 ourxwmhints.input = True;
188 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
189 gwind, x11icon_bits, x11icon_width, x11icon_height);
190 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
191 oursizhints.min_width = MINWIDTH;
192 oursizhints.min_height = MINHEIGHT+comheight;
193 oursizhints.flags = PMinSize;
194 XSetNormalHints(ourdisplay, gwind, &oursizhints);
195 XSelectInput(ourdisplay, gwind, ExposureMask);
196 XMapWindow(ourdisplay, gwind);
197 XWindowEvent(ourdisplay, gwind, ExposureMask, levptr(XEvent));
198 gwidth = levptr(XExposeEvent)->width;
199 gheight = levptr(XExposeEvent)->height - comheight;
200 x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth;
201 x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight;
202 x11_driver.inpready = 0;
203 mapped = 1;
204 /* set i/o vectors */
205 if (comheight) {
206 x11_driver.comin = x11_comin;
207 x11_driver.comout = x11_comout;
208 erract[COMMAND].pf = x11_comout;
209 /* doesn't work with raypcalls.c
210 if (erract[WARNING].pf != NULL)
211 erract[WARNING].pf = x11_errout;
212 */
213 inpcheck = IC_X11;
214 } else {
215 x11_driver.comin = std_comin;
216 x11_driver.comout = std_comout;
217 erract[COMMAND].pf = std_comout;
218 inpcheck = IC_IOCTL;
219 }
220 return(&x11_driver);
221 }
222
223
224 static void
225 x11_close(void) /* close our display */
226 {
227 erract[COMMAND].pf = NULL; /* reset error vectors */
228 if (erract[WARNING].pf != NULL)
229 erract[WARNING].pf = wputs;
230 if (ourdisplay == NULL)
231 return;
232 if (comline != NULL) {
233 xt_close(comline);
234 comline = NULL;
235 }
236 freepixels();
237 XFreeGC(ourdisplay, ourgc);
238 XDestroyWindow(ourdisplay, gwind);
239 gwind = 0;
240 ourgc = 0;
241 XFreeCursor(ourdisplay, pickcursor);
242 XCloseDisplay(ourdisplay);
243 ourdisplay = NULL;
244 }
245
246
247 static void
248 x11_clear( /* clear our display */
249 int xres,
250 int yres
251 )
252 {
253 /* check limits */
254 if (xres < MINWIDTH)
255 xres = MINWIDTH;
256 if (yres < MINHEIGHT)
257 yres = MINHEIGHT;
258 /* resize window */
259 if (xres != gwidth || yres != gheight) {
260 XSelectInput(ourdisplay, gwind, 0);
261 XResizeWindow(ourdisplay, gwind, xres, yres+comheight);
262 gwidth = xres;
263 gheight = yres;
264 XFlush(ourdisplay);
265 sleep(2); /* wait for window manager */
266 XSync(ourdisplay, 1); /* discard input */
267 }
268 XClearWindow(ourdisplay, gwind);
269 /* reinitialize color table */
270 if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) {
271 if (getpixels() == 0)
272 eputs("cannot allocate colors\n");
273 else
274 new_ctab(ncolors);
275 }
276 /* get new command line */
277 if (comline != NULL)
278 xt_close(comline);
279 if (comheight) {
280 comline = xt_open(ourdisplay, gwind, 0, gheight, gwidth,
281 comheight, 0, ourblack, ourwhite, COMFN);
282 if (comline == NULL) {
283 eputs("cannot open command line window\n");
284 quit(1);
285 }
286 XSelectInput(ourdisplay, comline->w, ExposureMask);
287 /* remove earmuffs */
288 XSelectInput(ourdisplay, gwind,
289 StructureNotifyMask|ExposureMask|KeyPressMask|ButtonPressMask);
290 } else /* remove earmuffs */
291 XSelectInput(ourdisplay, gwind,
292 StructureNotifyMask|ExposureMask|ButtonPressMask);
293 }
294
295
296 static void
297 x11_paintr( /* fill a rectangle */
298 COLOR col,
299 int xmin,
300 int ymin,
301 int xmax,
302 int ymax
303 )
304 {
305 unsigned long pixel;
306
307 if (!mapped)
308 return;
309 if (ncolors > 0)
310 pixel = pixval[get_pixel(col, xnewcolr)];
311 else
312 pixel = true_pixel(col);
313 XSetForeground(ourdisplay, ourgc, pixel);
314 XFillRectangle(ourdisplay, gwind,
315 ourgc, xmin, gheight-ymax, xmax-xmin, ymax-ymin);
316 }
317
318
319 static void
320 x11_flush(void) /* flush output */
321 {
322 char buf[256];
323 int n;
324 /* check for input */
325 XNoOp(ourdisplay);
326 n = XPending(ourdisplay); /* from X server */
327 while (n-- > 0)
328 getevent();
329 #ifdef FNDELAY
330 if (inpcheck == IC_IOCTL) { /* from stdin */
331 #ifdef FIONREAD
332 if (ioctl(fileno(stdin), FIONREAD, &n) < 0) {
333 #else
334 if (1) {
335 #endif
336 if (fcntl(fileno(stdin), F_SETFL, FNDELAY) < 0) {
337 eputs("cannot change input mode\n");
338 quit(1);
339 }
340 inpcheck = IC_READ;
341 } else
342 x11_driver.inpready += n;
343 }
344 if (inpcheck == IC_READ) {
345 n = read(fileno(stdin), buf, sizeof(buf)-1);
346 if (n > 0) {
347 buf[n] = '\0';
348 tocombuf(buf, &x11_driver);
349 }
350 }
351 #endif
352 }
353
354
355 static void
356 x11_comin( /* read in a command line */
357 char *inp,
358 char *prompt
359 )
360 {
361 if (prompt != NULL) {
362 x11_flush(); /* make sure we get everything */
363 if (fromcombuf(inp, &x11_driver))
364 return;
365 xt_puts(prompt, comline);
366 }
367 xt_cursor(comline, TBLKCURS);
368 editline(inp, x11_getc, x11_comout);
369 xt_cursor(comline, TNOCURS);
370 }
371
372
373 static void
374 x11_comout( /* output a string to command line */
375 char *outp
376 )
377 {
378 if (comline == NULL || outp == NULL || !outp[0])
379 return;
380 xt_puts(outp, comline);
381 if (outp[strlen(outp)-1] == '\n')
382 XFlush(ourdisplay);
383 }
384
385
386 static void
387 x11_errout( /* output an error message */
388 char *msg
389 )
390 {
391 eputs(msg); /* send to stderr also! */
392 x11_comout(msg);
393 }
394
395
396 static void
397 std_comin( /* read in command line from stdin */
398 char *inp,
399 char *prompt
400 )
401 {
402 if (prompt != NULL) {
403 if (fromcombuf(inp, &x11_driver))
404 return;
405 if (!x11_driver.inpready)
406 std_comout(prompt);
407 }
408 #ifdef FNDELAY
409 if (inpcheck == IC_READ) { /* turn off FNDELAY */
410 if (fcntl(fileno(stdin), F_SETFL, 0) < 0) {
411 eputs("cannot change input mode\n");
412 quit(1);
413 }
414 inpcheck = IC_IOCTL;
415 }
416 #endif
417 if (gets(inp) == NULL) {
418 strcpy(inp, "quit");
419 return;
420 }
421 x11_driver.inpready -= strlen(inp) + 1;
422 if (x11_driver.inpready < 0)
423 x11_driver.inpready = 0;
424 }
425
426
427 static void
428 std_comout( /* write out string to stdout */
429 char *outp
430 )
431 {
432 fputs(outp, stdout);
433 fflush(stdout);
434 }
435
436
437 static int
438 x11_getcur( /* get cursor position */
439 int *xp,
440 int *yp
441 )
442 {
443 while (XGrabPointer(ourdisplay, gwind, True, ButtonPressMask,
444 GrabModeAsync, GrabModeAsync, None, pickcursor,
445 CurrentTime) != GrabSuccess)
446 sleep(2);
447
448 do
449 getevent();
450 while (c_last <= c_first && levptr(XEvent)->type != ButtonPress);
451 *xp = levptr(XButtonPressedEvent)->x;
452 *yp = gheight-1 - levptr(XButtonPressedEvent)->y;
453 XUngrabPointer(ourdisplay, CurrentTime);
454 XFlush(ourdisplay); /* insure release */
455 if (c_last > c_first) /* key pressed */
456 return(x11_getc());
457 /* button pressed */
458 if (levptr(XButtonPressedEvent)->button == Button1)
459 return(MB1);
460 if (levptr(XButtonPressedEvent)->button == Button2)
461 return(MB2);
462 if (levptr(XButtonPressedEvent)->button == Button3)
463 return(MB3);
464 return(ABORT);
465 }
466
467
468 static void
469 xnewcolr( /* enter a color into hardware table */
470 int ndx,
471 int r,
472 int g,
473 int b
474 )
475 {
476 XColor xcolor;
477
478 xcolor.pixel = pixval[ndx];
479 xcolor.red = r << 8;
480 xcolor.green = g << 8;
481 xcolor.blue = b << 8;
482 xcolor.flags = DoRed|DoGreen|DoBlue;
483
484 XStoreColor(ourdisplay, ourmap, &xcolor);
485 }
486
487
488 static int
489 getpixels(void) /* get the color map */
490 {
491 XColor thiscolor;
492 register int i, j;
493
494 if (ncolors > 0)
495 return(ncolors);
496 if (ourvinfo.visual == DefaultVisual(ourdisplay,ourscreen)) {
497 ourmap = DefaultColormap(ourdisplay,ourscreen);
498 goto loop;
499 }
500 newmap:
501 ourmap = XCreateColormap(ourdisplay,gwind,ourvinfo.visual,AllocNone);
502 loop:
503 for (ncolors = ourvinfo.colormap_size;
504 ncolors > ourvinfo.colormap_size/3;
505 ncolors = ncolors*.937) {
506 pixval = (unsigned long *)malloc(ncolors*sizeof(unsigned long));
507 if (pixval == NULL)
508 return(ncolors = 0);
509 if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,pixval,ncolors))
510 break;
511 free((void *)pixval);
512 pixval = NULL;
513 }
514 if (pixval == NULL) {
515 if (ourmap == DefaultColormap(ourdisplay,ourscreen))
516 goto newmap; /* try it with our map */
517 else
518 return(ncolors = 0); /* failed */
519 }
520 if (ourmap != DefaultColormap(ourdisplay,ourscreen))
521 for (i = 0; i < ncolors; i++) { /* reset black and white */
522 if (pixval[i] != ourblack && pixval[i] != ourwhite)
523 continue;
524 thiscolor.pixel = pixval[i];
525 thiscolor.flags = DoRed|DoGreen|DoBlue;
526 XQueryColor(ourdisplay,
527 DefaultColormap(ourdisplay,ourscreen),
528 &thiscolor);
529 XStoreColor(ourdisplay, ourmap, &thiscolor);
530 for (j = i; j+1 < ncolors; j++)
531 pixval[j] = pixval[j+1];
532 ncolors--;
533 i--;
534 }
535 XSetWindowColormap(ourdisplay, gwind, ourmap);
536 return(ncolors);
537 }
538
539
540 static void
541 freepixels(void) /* free our pixels */
542 {
543 if (ncolors == 0)
544 return;
545 XFreeColors(ourdisplay,ourmap,pixval,ncolors,0L);
546 free((void *)pixval);
547 pixval = NULL;
548 ncolors = 0;
549 if (ourmap != DefaultColormap(ourdisplay,ourscreen))
550 XFreeColormap(ourdisplay, ourmap);
551 ourmap = 0;
552 }
553
554
555 static unsigned long
556 true_pixel( /* return true pixel value for color */
557 COLOR col
558 )
559 {
560 unsigned long rval;
561 BYTE rgb[3];
562
563 map_color(rgb, col);
564 rval = ourvinfo.red_mask*rgb[RED]/255 & ourvinfo.red_mask;
565 rval |= ourvinfo.green_mask*rgb[GRN]/255 & ourvinfo.green_mask;
566 rval |= ourvinfo.blue_mask*rgb[BLU]/255 & ourvinfo.blue_mask;
567 return(rval);
568 }
569
570
571 static int
572 x11_getc(void) /* get a command character */
573 {
574 while (c_last <= c_first) {
575 c_first = c_last = 0; /* reset */
576 getevent(); /* wait for key */
577 }
578 x11_driver.inpready--;
579 return(c_queue[c_first++]);
580 }
581
582
583 static void
584 getevent(void) /* get next event */
585 {
586 XNextEvent(ourdisplay, levptr(XEvent));
587 switch (levptr(XEvent)->type) {
588 case ConfigureNotify:
589 resizewindow(levptr(XConfigureEvent));
590 break;
591 case UnmapNotify:
592 mapped = 0;
593 freepixels();
594 break;
595 case MapNotify:
596 if (ourvinfo.class == PseudoColor ||
597 ourvinfo.class == GrayScale) {
598 if (getpixels() == 0)
599 eputs("cannot allocate colors\n");
600 else
601 new_ctab(ncolors);
602 }
603 mapped = 1;
604 break;
605 case Expose:
606 fixwindow(levptr(XExposeEvent));
607 break;
608 case KeyPress:
609 getkey(levptr(XKeyPressedEvent));
610 break;
611 case ButtonPress:
612 break;
613 }
614 }
615
616
617 static void
618 getkey( /* get input key */
619 register XKeyPressedEvent *ekey
620 )
621 {
622 register int n;
623
624 n = XLookupString(ekey, c_queue+c_last, sizeof(c_queue)-c_last,
625 NULL, NULL);
626 c_last += n;
627 x11_driver.inpready += n;
628 }
629
630
631 static void
632 fixwindow( /* repair damage to window */
633 register XExposeEvent *eexp
634 )
635 {
636 char buf[80];
637
638 if (eexp->window == gwind) {
639 sprintf(buf, "repaint %d %d %d %d\n",
640 eexp->x, gheight - eexp->y - eexp->height,
641 eexp->x + eexp->width, gheight - eexp->y);
642 tocombuf(buf, &x11_driver);
643 } else if (eexp->window == comline->w) {
644 if (eexp->count == 0)
645 xt_redraw(comline);
646 }
647 }
648
649
650 static void
651 resizewindow( /* resize window */
652 register XConfigureEvent *ersz
653 )
654 {
655 if (ersz->width == gwidth && ersz->height-comheight == gheight)
656 return;
657
658 gwidth = ersz->width;
659 gheight = ersz->height-comheight;
660 x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth;
661 x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight;
662
663 tocombuf("new\n", &x11_driver);
664 }
