--- ray/src/rt/x11.c 1994/09/12 15:57:55 2.17
+++ ray/src/rt/x11.c 2003/02/22 02:07:29 2.29
@@ -1,18 +1,77 @@
-/* Copyright (c) 1992 Regents of the University of California */
#ifndef lint
-static char SCCSid[] = "$SunId$ LBL";
+static const char RCSid[] = "$Id: x11.c,v 2.29 2003/02/22 02:07:29 greg Exp $";
#endif
* x11.c - driver for X-windows version 11
+ * The Radiance Software License, Version 1.0
- * Jan 1990
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
-#include
-#include
+#include "standard.h"
#include
+#ifdef sparc
+#include
+#include
+#include
+#endif
+#if !defined(FNDELAY) && defined(O_NONBLOCK)
+#define FNDELAY O_NONBLOCK
+#endif
#include
#include
@@ -69,20 +128,27 @@ static GC ourgc = 0; /* our graphics context for dr
static Colormap ourmap = 0; /* our color map */
-extern char *malloc(), *getcombuf();
+#define IC_X11 0
+#define IC_IOCTL 1
+#define IC_READ 2
-static int x11_close(), x11_clear(), x11_paintr(), x11_errout(),
- x11_getcur(), x11_comout(), x11_comin(), x11_flush();
+static int inpcheck; /* whence to check input */
-static int std_comin(), std_comout();
+static int x11_getcur();
+static void x11_close(), x11_clear(), x11_paintr(), x11_errout(),
+ x11_comout(), x11_comin(), x11_flush();
+static void std_comin(), std_comout();
static struct driver x11_driver = {
x11_close, x11_clear, x11_paintr, x11_getcur,
NULL, NULL, x11_flush, 1.0
-static int getpixels(), xnewcolr(), freepixels(), resizewindow(),
- getevent(), getkey(), fixwindow(), x11_getc();
+static int getpixels(), x11_getc();
+static void xnewcolr(), freepixels(), resizewindow(),
+ getevent(), getkey(), fixwindow();
static unsigned long true_pixel();
@@ -90,7 +156,6 @@ struct driver *
x11_init(name, id) /* initialize driver */
char *name, *id;
- extern char *getenv();
char *gv;
int nplanes;
XSetWindowAttributes ourwinattr;
@@ -99,29 +164,29 @@ char *name, *id;
/* open display server */
ourdisplay = XOpenDisplay(NULL);
if (ourdisplay == NULL) {
- stderr_v("cannot open X-windows; DISPLAY variable set?\n");
+ eputs("cannot open X-windows; DISPLAY variable set?\n");
return(NULL);
/* find a usable visual */
nplanes = DisplayPlanes(ourdisplay, ourscreen);
if (XMatchVisualInfo(ourdisplay,ourscreen,
- 24,TrueColor,&ourvinfo) ||
+ nplanes>12?nplanes:24,TrueColor,&ourvinfo) ||
- 24,DirectColor,&ourvinfo)) {
+ nplanes>12?nplanes:24,DirectColor,&ourvinfo)) {
ourblack = 0;
ourwhite = ourvinfo.red_mask |
ourvinfo.green_mask |
ourvinfo.blue_mask ;
} else {
if (nplanes < 4) {
- stderr_v("not enough colors\n");
+ eputs("not enough colors\n");
return(NULL);
if (!XMatchVisualInfo(ourdisplay,ourscreen,
nplanes,PseudoColor,&ourvinfo) &&
nplanes,GrayScale,&ourvinfo)) {
- stderr_v("unsupported visual type\n");
+ eputs("unsupported visual type\n");
return(NULL);
ourblack = BlackPixel(ourdisplay,ourscreen);
@@ -129,15 +194,19 @@ char *name, *id;
/* set gamma */
if ((gv = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
- || (gv = getenv("GAMMA")) != NULL)
+ || (gv = getenv("DISPLAY_GAMMA")) != NULL)
make_gmap(atof(gv));
else
make_gmap(GAMMA);
/* X11 command line or no? */
if (!strcmp(name, "x11"))
comheight = COMHEIGHT;
- else /* "x11d" */
+ else /* "x11d" */ {
comheight = 0;
+#ifndef FNDELAY
+ eputs("warning: x11d driver not fully functional on this machine\n");
+#endif
/* open window */
ourwinattr.background_pixel = ourblack;
ourwinattr.border_pixel = ourblack;
@@ -150,7 +219,7 @@ char *name, *id;
BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual,
CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr);
if (gwind == 0) {
- stderr_v("cannot create window\n");
+ eputs("cannot create window\n");
return(NULL);
XStoreName(ourdisplay, gwind, id);
@@ -179,24 +248,26 @@ char *name, *id;
if (comheight) {
x11_driver.comin = x11_comin;
x11_driver.comout = x11_comout;
- cmdvec = x11_comout;
- if (wrnvec != NULL)
- wrnvec = x11_errout;
+ erract[COMMAND].pf = x11_comout;
+ if (erract[WARNING].pf != NULL)
+ erract[WARNING].pf = x11_errout;
+ inpcheck = IC_X11;
} else {
x11_driver.comin = std_comin;
x11_driver.comout = std_comout;
- cmdvec = std_comout;
+ erract[COMMAND].pf = std_comout;
+ inpcheck = IC_IOCTL;
return(&x11_driver);
-static
+static void
x11_close() /* close our display */
- cmdvec = NULL; /* reset error vectors */
- wrnvec = stderr_v;
+ erract[COMMAND].pf = NULL; /* reset error vectors */
+ erract[WARNING].pf = wputs;
return;
if (comline != NULL) {
@@ -214,7 +285,7 @@ x11_close() /* close our display */
-static
+static void
x11_clear(xres, yres) /* clear our display */
int xres, yres;
@@ -237,7 +308,7 @@ int xres, yres;
/* reinitialize color table */
if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale)
if (getpixels() == 0)
- stderr_v("cannot allocate colors\n");
+ eputs("cannot allocate colors\n");
else
new_ctab(ncolors);
/* get new command line */
@@ -247,7 +318,7 @@ int xres, yres;
comline = xt_open(ourdisplay, gwind, 0, gheight, gwidth,
comheight, 0, ourblack, ourwhite, COMFN);
if (comline == NULL) {
- stderr_v("Cannot open command line window\n");
+ eputs("cannot open command line window\n");
quit(1);
XSelectInput(ourdisplay, comline->w, ExposureMask);
@@ -260,7 +331,7 @@ int xres, yres;
-static
+static void
x11_paintr(col, xmin, ymin, xmax, ymax) /* fill a rectangle */
COLOR col;
int xmin, ymin, xmax, ymax;
@@ -279,26 +350,43 @@ int xmin, ymin, xmax, ymax;
-static
+static void
x11_flush() /* flush output */
+ char buf[256];
int n;
/* check for input */
XNoOp(ourdisplay);
n = XPending(ourdisplay); /* from X server */
while (n-- > 0)
getevent();
- if (x11_driver.comin == std_comin) { /* from stdin */
+#ifdef FNDELAY
+ if (inpcheck == IC_IOCTL) { /* from stdin */
+#ifdef FIONREAD
if (ioctl(fileno(stdin), FIONREAD, &n) < 0) {
- stderr_v("ioctl error on stdin\n");
- quit(1);
+#else
+ if (1) {
+#endif
+ if (fcntl(fileno(stdin), F_SETFL, FNDELAY) < 0) {
+ eputs("cannot change input mode\n");
+ quit(1);
+ inpcheck = IC_READ;
+ } else
+ x11_driver.inpready += n;
+ if (inpcheck == IC_READ) {
+ n = read(fileno(stdin), buf, sizeof(buf)-1);
+ if (n > 0) {
+ buf[n] = '\0';
+ tocombuf(buf, &x11_driver);
- x11_driver.inpready += n;
+#endif
-static
+static void
x11_comin(inp, prompt) /* read in a command line */
char *inp, *prompt;
@@ -314,11 +402,11 @@ char *inp, *prompt;
-static
+static void
x11_comout(outp) /* output a string to command line */
char *outp;
- if (comline == NULL)
+ if (comline == NULL || outp == NULL || !outp[0])
return;
xt_puts(outp, comline);
if (outp[strlen(outp)-1] == '\n')
@@ -326,27 +414,34 @@ char *outp;
-static
+static void
x11_errout(msg) /* output an error message */
char *msg;
- stderr_v(msg); /* send to stderr also! */
+ eputs(msg); /* send to stderr also! */
x11_comout(msg);
-static
+static void
std_comin(inp, prompt) /* read in command line from stdin */
char *inp, *prompt;
- extern char *gets();
if (prompt != NULL) {
if (fromcombuf(inp, &x11_driver))
return;
if (!x11_driver.inpready)
- fputs(prompt, stdout);
+ std_comout(prompt);
+#ifdef FNDELAY
+ if (inpcheck == IC_READ) { /* turn off FNDELAY */
+ if (fcntl(fileno(stdin), F_SETFL, 0) < 0) {
+ quit(1);
+#endif
if (gets(inp) == NULL) {
strcpy(inp, "quit");
return;
@@ -357,11 +452,12 @@ char *inp, *prompt;
-static
+static void
std_comout(outp) /* write out string to stdout */
char *outp;
fputs(outp, stdout);
+ fflush(stdout);
@@ -394,7 +490,7 @@ int *xp, *yp;
-static
+static void
xnewcolr(ndx, r, g, b) /* enter a color into hardware table */
int ndx;
int r, g, b;
@@ -434,7 +530,7 @@ loop:
return(ncolors = 0);
if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,pixval,ncolors))
break;
- free((char *)pixval);
+ free((void *)pixval);
pixval = NULL;
if (pixval == NULL) {
@@ -463,13 +559,13 @@ loop:
-static
+static void
freepixels() /* free our pixels */
if (ncolors == 0)
return;
XFreeColors(ourdisplay,ourmap,pixval,ncolors,0L);
pixval = NULL;
ncolors = 0;
if (ourmap != DefaultColormap(ourdisplay,ourscreen))
@@ -505,7 +601,7 @@ x11_getc() /* get a command character */
-static
+static void
getevent() /* get next event */
XNextEvent(ourdisplay, levptr(XEvent));
@@ -521,7 +617,7 @@ getevent() /* get next event */
- stderr_v("Cannot allocate colors\n");
else
new_ctab(ncolors);
mapped = 1;
@@ -538,7 +634,7 @@ getevent() /* get next event */
-static
+static void
getkey(ekey) /* get input key */
register XKeyPressedEvent *ekey;
@@ -551,14 +647,17 @@ register XKeyPressedEvent *ekey;
-static
+static void
fixwindow(eexp) /* repair damage to window */
register XExposeEvent *eexp;
+ char buf[80];
if (eexp->window == gwind) {
- sprintf(getcombuf(&x11_driver), "repaint %d %d %d %d\n",
+ sprintf(buf, "repaint %d %d %d %d\n",
eexp->x, gheight - eexp->y - eexp->height,
eexp->x + eexp->width, gheight - eexp->y);
} else if (eexp->window == comline->w) {
if (eexp->count == 0)
xt_redraw(comline);
@@ -566,7 +665,7 @@ register XExposeEvent *eexp;
-static
+static void
resizewindow(ersz) /* resize window */
register XConfigureEvent *ersz;
@@ -578,5 +677,5 @@ register XConfigureEvent *ersz;
x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth;
x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight;
- strcpy(getcombuf(&x11_driver), "new\n");
+ tocombuf("new\n", &x11_driver);
