root/radiance/ray/src/rt/x11.c
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.31: +86 -47 lines
Diff to previous 2.31 , to selected 1.7
Mon Jul 21 22:30:19 2003 UTC (22 years ago) by schorsch
Changes since 2.30: +5 -3 lines
Diff to previous 2.30 , to selected 1.7
Tue Feb 25 02:47:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.29: +1 -56 lines
Diff to previous 2.29 , to selected 1.7
Sat Feb 22 02:07:29 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.28: +81 -31 lines
Diff to previous 2.28 , to selected 1.7
Tue Dec 2 15:57:45 1997 UTC (27 years, 8 months ago) by gregl
Diff to previous 2.27 , to selected 1.7
fixed bug in passing empty string to x11_comout()
Tue Nov 11 20:03:02 1997 UTC (27 years, 8 months ago) by gregl
Changes since 2.26: +19 -21 lines
Diff to previous 2.26 , to selected 1.7
Tue Dec 5 10:54:39 1995 UTC (29 years, 8 months ago) by greg
Diff to previous 2.25 , to selected 1.7
made initialization work for TrueColor visuals with depths < 24
Fri Sep 29 20:20:37 1995 UTC (29 years, 10 months ago) by greg
Changes since 2.24: +14 -7 lines
Diff to previous 2.24 , to selected 1.7
fixed x11d driver for POSIX source
Tue Mar 7 14:18:34 1995 UTC (30 years, 4 months ago) by greg
Changes since 2.23: +9 -0 lines
Diff to previous 2.23 , to selected 1.7
bug fix due in std_comin() with IC_READ
Mon Dec 12 16:47:29 1994 UTC (30 years, 7 months ago) by greg
Changes since 2.22: +5 -0 lines
Diff to previous 2.22 , to selected 1.7
added appropriate headers for Solaris (I hope)
Mon Dec 12 11:22:20 1994 UTC (30 years, 7 months ago) by greg
Changes since 2.21: +6 -0 lines
Diff to previous 2.21 , to selected 1.7
removed some code for Solaris (idiot OS)
Wed Oct 26 10:04:15 1994 UTC (30 years, 9 months ago) by greg
Changes since 2.20: +7 -4 lines
Diff to previous 2.20 , to selected 1.7
changed getcombuf() to tocombuf() for multiple commands
Mon Oct 3 12:58:58 1994 UTC (30 years, 10 months ago) by greg
Changes since 2.19: +1 -0 lines
Diff to previous 2.19 , to selected 1.7
added flush to std_comout()
Mon Oct 3 11:01:23 1994 UTC (30 years, 10 months ago) by greg
Changes since 2.18: +24 -4 lines
Diff to previous 2.18 , to selected 1.7
made x11d driver work with System V pipes
Tue Sep 20 15:46:34 1994 UTC (30 years, 10 months ago) by greg
Diff to previous 2.17 , to selected 1.7
changed GAMMA environment variable to DISPLAY_GAMMA
Mon Sep 12 15:57:55 1994 UTC (30 years, 10 months ago) by greg
Changes since 2.16: +79 -28 lines
Diff to previous 2.16 , to selected 1.7
added "x11d" driver for using stdin & stdout instead of command line
Mon Sep 12 14:41:54 1994 UTC (30 years, 10 months ago) by greg
Changes since 2.15: +7 -7 lines
Diff to previous 2.15 , to selected 1.7
minor improvements on last change
Fri Sep 9 16:16:06 1994 UTC (30 years, 10 months ago) by greg
Changes since 2.14: +14 -3 lines
Diff to previous 2.14 , to selected 1.7
added ability to read commands from stdin
still a problem when image is all done!
Mon Nov 22 11:33:02 1993 UTC (31 years, 8 months ago) by greg
Diff to previous 2.13 , to selected 1.7
added check for radiance.gamma resource from server
Thu Nov 18 09:43:06 1993 UTC (31 years, 8 months ago) by greg
Changes since 2.12: +2 -4 lines
Diff to previous 2.12 , to selected 1.7
minor compiler warning fixes
Fri Jun 4 14:48:52 1993 UTC (32 years, 2 months ago) by greg
Diff to previous 2.11 , to selected 1.7
added math.h for atof() usage
Mon Mar 8 12:51:45 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.10 , to selected 1.7
portability fixes
Tue Mar 2 10:56:33 1993 UTC (32 years, 5 months ago) by greg
Changes since 2.9: +3 -5 lines
Diff to previous 2.9 , to selected 1.7
fixed minor bug in mouse button handling
Thu Feb 11 16:33:10 1993 UTC (32 years, 5 months ago) by greg
Diff to previous 2.8 , to selected 1.7
reduced minimum graphics window height to half minimum width
Wed Sep 16 16:15:42 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.7: +8 -5 lines
Diff to previous 2.7 , to selected 1.7
test for unmapped window in 24-bit mode
Thu Jun 25 13:32:47 1992 UTC (33 years, 1 month ago) by greg
Diff to previous 2.6 , to selected 1.7
fixed minor oversight in freeing pixval array
Wed Jun 24 09:12:50 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.5: +9 -3 lines
Diff to previous 2.5 , to selected 1.7
Thu Jun 18 14:55:24 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.4: +0 -1 lines
Diff to previous 2.4 , to selected 1.7
fixed problem with creation of tty subwindow with no colormap
Sat May 30 09:32:18 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.3: +17 -13 lines
Diff to previous 2.3 , to selected 1.7
small modification to white/black assignment in 24-bit mode
Fri May 29 15:42:49 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.2: +10 -6 lines
Diff to previous 2.2 , to selected 1.7
fixed text and background color for 24-bit screens
Fri May 29 10:57:15 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.1: +31 -40 lines
Diff to previous 2.1 , to selected 1.7
made to work with GrayScale screens
Tue Nov 12 17:10:04 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.18 , to selected 1.7
Fri Apr 19 15:02:54 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.17: +4 -1 lines
Diff to previous 1.17 , to selected 1.7
added icon bitmap
Fri Dec 21 17:27:31 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.16: +3 -3 lines
Diff to previous 1.16 , to selected 1.7
minor compiler complaints
Wed Jul 18 12:25:07 1990 UTC (35 years ago) by greg
Changes since 1.15: +15 -7 lines
Diff to previous 1.15 , to selected 1.7
added debugging for color routines
Tue Jul 10 08:47:07 1990 UTC (35 years ago) by greg
Changes since 1.14: +7 -4 lines
Diff to previous 1.14 , to selected 1.7
added temporary fix for DirectColor until I decide what to do
Mon Mar 12 11:08:48 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.13 , to selected 1.7
fixed function predeclarations for fussy compilers
Fri Mar 9 09:17:30 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.12: +9 -11 lines
Diff to previous 1.12 , to selected 1.7
changed order of windowing in x11_clear()
Thu Mar 8 10:09:58 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.11: +29 -14 lines
Diff to previous 1.11 , to selected 1.7
put limit on minimum window resize
Thu Mar 8 09:47:23 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.10: +5 -3 lines
Diff to previous 1.10 , to selected 1.7
changed flushing in x11_comout()
Fri Mar 2 15:05:26 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.9: +9 -6 lines
Diff to previous 1.9 , to selected 1.7
changed call to XCreateWindow to support different visuals
Fri Mar 2 10:08:01 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.8: +2 -1 lines
Diff to previous 1.8 , to selected 1.7
improved flushing action
Thu Mar 1 08:22:44 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.7: +10 -13 lines
Diff to previous 1.7
minor changes
Revision 1.7 - (view) (download) (annotate) - [selected]
Fri Feb 23 14:50:38 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.6: +5 -2 lines
Diff to previous 1.6
fixed handling of inpready
Fri Feb 23 10:26:30 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.5: +101 -28 lines
added support for TrueColor and multiple color maps
Thu Feb 22 11:46:26 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.4: +12 -17 lines
Thu Feb 22 10:22:01 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.3: +100 -84 lines
added response to resize, iconify, etc.
Tue Jan 30 11:37:54 1990 UTC (35 years, 6 months ago) by greg
Fri Jan 12 11:33:05 1990 UTC (35 years, 6 months ago) by greg
Changes since 1.1: +6 -12 lines
*** empty log message ***
Tue Dec 19 12:54:30 1989 UTC (35 years, 7 months ago) by greg
Diff to selected 1.7
