--- ray/src/rt/x11.c 1990/12/21 17:27:31 1.17 +++ ray/src/rt/x11.c 2004/03/30 16:13:01 2.32 @@ -1,31 +1,37 @@ #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: x11.c,v 2.32 2004/03/30 16:13:01 schorsch Exp $"; #endif - -/* Copyright (c) 1989 Regents of the University of California */ - /* - * x11.c - driver for X-windows version 11.3 - * - * Jan 1990 + * x11.c - driver for X-windows version 11 */ -#include +#include "copyright.h" +#include "standard.h" #include +#ifdef sparc +#include +#include +#include +#endif +#if !defined(FNDELAY) && defined(O_NONBLOCK) +#define FNDELAY O_NONBLOCK +#endif #include #include #include +#include "platform.h" #include "color.h" #include "driver.h" #include "x11twind.h" +#include "x11icon.h" -#define GAMMA 2.2 /* exponent for color correction */ +#define GAMMA 2.2 /* default exponent correction */ #define MINWIDTH (32*COMCW) /* minimum graphics window width */ -#define MINHEIGHT MINWIDTH /* minimum graphics window height */ +#define MINHEIGHT (MINWIDTH/2) /* minimum graphics window height */ #define BORWIDTH 5 /* border width */ #define COMHEIGHT (COMLH*COMCH) /* command line height (pixels) */ @@ -37,19 +43,19 @@ static char SCCSid[] = "$SunId$ LBL"; #define ourscreen DefaultScreen(ourdisplay) #define ourroot RootWindow(ourdisplay,ourscreen) -#define ourwhite WhitePixel(ourdisplay,ourscreen) -#define ourblack BlackPixel(ourdisplay,ourscreen) #define levptr(etype) ((etype *)¤tevent) static XEvent currentevent; /* current event */ static int ncolors = 0; /* color table size */ +static int mapped = 0; /* window is mapped? */ static unsigned long *pixval = NULL; /* allocated pixels */ +static unsigned long ourblack=0, ourwhite=1; static Display *ourdisplay = NULL; /* our display */ -static Visual *ourvisual; /* our visual structure */ +static XVisualInfo ourvinfo; /* our visual information */ static Window gwind = 0; /* our graphics window */ @@ -57,6 +63,7 @@ static Cursor pickcursor = 0; /* cursor used for pic static int gwidth, gheight; /* graphics window size */ +static int comheight; /* desired comline height */ static TEXTWIND *comline = NULL; /* our command line */ static char c_queue[64]; /* input queue */ @@ -67,96 +74,162 @@ static GC ourgc = 0; /* our graphics context for dr static Colormap ourmap = 0; /* our color map */ -extern char *malloc(), *getcombuf(); +#define IC_X11 0 +#define IC_IOCTL 1 +#define IC_READ 2 -static int x11_close(), x11_clear(), x11_paintr(), x11_errout(), - x11_getcur(), x11_comout(), x11_comin(), x11_flush(); +static int inpcheck; /* whence to check input */ +static void x11_errout(char *msg); + +static dr_closef_t x11_close; +static dr_clearf_t x11_clear; +static dr_paintrf_t x11_paintr; +static dr_getcurf_t x11_getcur; +static dr_comoutf_t x11_comout; +static dr_cominf_t x11_comin; +static dr_flushf_t x11_flush; + +static dr_cominf_t std_comin; +static dr_comoutf_t std_comout; + static struct driver x11_driver = { x11_close, x11_clear, x11_paintr, x11_getcur, - x11_comout, x11_comin, x11_flush, 1.0 + NULL, NULL, x11_flush, 1.0 }; +static dr_getchf_t x11_getc; -struct driver * -x11_init(name, id) /* initialize driver */ -char *name, *id; +static void freepixels(void); +static int getpixels(void); +static dr_newcolrf_t xnewcolr; +static unsigned long true_pixel(COLOR col); +static void getevent(void); +static void getkey(XKeyPressedEvent *ekey); +static void fixwindow(XExposeEvent *eexp); +static void resizewindow(XConfigureEvent *ersz); + +extern dr_initf_t x11_init; /* XXX this should be in a seperate header file */ + + +extern struct driver * +x11_init( /* initialize driver */ + char *name, + char *id +) { + char *gv; int nplanes; - XVisualInfo ourvinfo; XSetWindowAttributes ourwinattr; XWMHints ourxwmhints; XSizeHints oursizhints; - + /* open display server */ ourdisplay = XOpenDisplay(NULL); if (ourdisplay == NULL) { - stderr_v("cannot open X-windows; DISPLAY variable set?\n"); + eputs("cannot open X-windows; DISPLAY variable set?\n"); return(NULL); } + /* find a usable visual */ nplanes = DisplayPlanes(ourdisplay, ourscreen); - if (nplanes < 4) { - stderr_v("not enough colors\n"); - return(NULL); - } else if (nplanes <= 12) { + if (XMatchVisualInfo(ourdisplay,ourscreen, + nplanes>12?nplanes:24,TrueColor,&ourvinfo) || + XMatchVisualInfo(ourdisplay,ourscreen, + nplanes>12?nplanes:24,DirectColor,&ourvinfo)) { + ourblack = 0; + ourwhite = ourvinfo.red_mask | + ourvinfo.green_mask | + ourvinfo.blue_mask ; + } else { + if (nplanes < 4) { + eputs("not enough colors\n"); + return(NULL); + } if (!XMatchVisualInfo(ourdisplay,ourscreen, - nplanes,PseudoColor,&ourvinfo)) { - stderr_v("PseudoColor server required\n"); + nplanes,PseudoColor,&ourvinfo) && + !XMatchVisualInfo(ourdisplay,ourscreen, + nplanes,GrayScale,&ourvinfo)) { + eputs("unsupported visual type\n"); return(NULL); } - } else if (!XMatchVisualInfo(ourdisplay,ourscreen, - nplanes,TrueColor,&ourvinfo) && - /* kludge for DirectColor */ - !XMatchVisualInfo(ourdisplay,ourscreen, - nplanes,DirectColor,&ourvinfo)) { - stderr_v("TrueColor server required\n"); - return(NULL); + ourblack = BlackPixel(ourdisplay,ourscreen); + ourwhite = WhitePixel(ourdisplay,ourscreen); } - ourvisual = ourvinfo.visual; - make_gmap(GAMMA); - /* open window */ + /* set gamma */ + if ((gv = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL + || (gv = getenv("DISPLAY_GAMMA")) != NULL) + make_gmap(atof(gv)); + else + make_gmap(GAMMA); + /* X11 command line or no? */ + if (!strcmp(name, "x11")) + comheight = COMHEIGHT; + else /* "x11d" */ { + comheight = 0; +#ifndef FNDELAY + eputs("warning: x11d driver not fully functional on this machine\n"); +#endif + } + /* open window */ ourwinattr.background_pixel = ourblack; ourwinattr.border_pixel = ourblack; + /* this is stupid */ + ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot, + ourvinfo.visual, AllocNone); gwind = XCreateWindow(ourdisplay, ourroot, 0, 0, DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH, DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH, - BORWIDTH, nplanes, InputOutput, ourvisual, - CWBackPixel|CWBorderPixel, &ourwinattr); + BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual, + CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr); if (gwind == 0) { - stderr_v("cannot create window\n"); + eputs("cannot create window\n"); return(NULL); } - XStoreName(ourdisplay, gwind, id); + XStoreName(ourdisplay, gwind, id); /* create a cursor */ pickcursor = XCreateFontCursor(ourdisplay, XC_diamond_cross); ourgc = XCreateGC(ourdisplay, gwind, 0, NULL); - ourxwmhints.flags = InputHint; + ourxwmhints.flags = InputHint|IconPixmapHint; ourxwmhints.input = True; + ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay, + gwind, x11icon_bits, x11icon_width, x11icon_height); XSetWMHints(ourdisplay, gwind, &ourxwmhints); oursizhints.min_width = MINWIDTH; - oursizhints.min_height = MINHEIGHT+COMHEIGHT; + oursizhints.min_height = MINHEIGHT+comheight; oursizhints.flags = PMinSize; XSetNormalHints(ourdisplay, gwind, &oursizhints); XSelectInput(ourdisplay, gwind, ExposureMask); XMapWindow(ourdisplay, gwind); XWindowEvent(ourdisplay, gwind, ExposureMask, levptr(XEvent)); gwidth = levptr(XExposeEvent)->width; - gheight = levptr(XExposeEvent)->height - COMHEIGHT; + gheight = levptr(XExposeEvent)->height - comheight; x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth; x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight; x11_driver.inpready = 0; - cmdvec = x11_comout; /* set error vectors */ - if (wrnvec != NULL) - wrnvec = x11_errout; + mapped = 1; + /* set i/o vectors */ + if (comheight) { + x11_driver.comin = x11_comin; + x11_driver.comout = x11_comout; + erract[COMMAND].pf = x11_comout; + if (erract[WARNING].pf != NULL) + erract[WARNING].pf = x11_errout; + inpcheck = IC_X11; + } else { + x11_driver.comin = std_comin; + x11_driver.comout = std_comout; + erract[COMMAND].pf = std_comout; + inpcheck = IC_IOCTL; + } return(&x11_driver); } -static -x11_close() /* close our display */ +static void +x11_close(void) /* close our display */ { - cmdvec = NULL; /* reset error vectors */ - if (wrnvec != NULL) - wrnvec = stderr_v; + erract[COMMAND].pf = NULL; /* reset error vectors */ + if (erract[WARNING].pf != NULL) + erract[WARNING].pf = wputs; if (ourdisplay == NULL) return; if (comline != NULL) { @@ -174,9 +247,11 @@ x11_close() /* close our display */ } -static -x11_clear(xres, yres) /* clear our display */ -int xres, yres; +static void +x11_clear( /* clear our display */ + int xres, + int yres +) { /* check limits */ if (xres < MINWIDTH) @@ -186,7 +261,7 @@ int xres, yres; /* resize window */ if (xres != gwidth || yres != gheight) { XSelectInput(ourdisplay, gwind, 0); - XResizeWindow(ourdisplay, gwind, xres, yres+COMHEIGHT); + XResizeWindow(ourdisplay, gwind, xres, yres+comheight); gwidth = xres; gheight = yres; XFlush(ourdisplay); @@ -195,99 +270,178 @@ int xres, yres; } XClearWindow(ourdisplay, gwind); /* reinitialize color table */ - if (ourvisual->class == PseudoColor) + if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) { if (getpixels() == 0) - stderr_v("cannot allocate colors\n"); + eputs("cannot allocate colors\n"); else new_ctab(ncolors); + } /* get new command line */ if (comline != NULL) xt_close(comline); - comline = xt_open(ourdisplay, - DefaultGC(ourdisplay,ourscreen), - gwind, 0, gheight, gwidth, COMHEIGHT, 0, COMFN); - if (comline == NULL) { - stderr_v("Cannot open command line window\n"); - quit(1); - } - XSelectInput(ourdisplay, comline->w, ExposureMask); + if (comheight) { + comline = xt_open(ourdisplay, gwind, 0, gheight, gwidth, + comheight, 0, ourblack, ourwhite, COMFN); + if (comline == NULL) { + eputs("cannot open command line window\n"); + quit(1); + } + XSelectInput(ourdisplay, comline->w, ExposureMask); /* remove earmuffs */ - XSelectInput(ourdisplay, gwind, + XSelectInput(ourdisplay, gwind, StructureNotifyMask|ExposureMask|KeyPressMask|ButtonPressMask); + } else /* remove earmuffs */ + XSelectInput(ourdisplay, gwind, + StructureNotifyMask|ExposureMask|ButtonPressMask); } -static -x11_paintr(col, xmin, ymin, xmax, ymax) /* fill a rectangle */ -COLOR col; -int xmin, ymin, xmax, ymax; +static void +x11_paintr( /* fill a rectangle */ + COLOR col, + int xmin, + int ymin, + int xmax, + int ymax +) { - extern int xnewcolr(); /* pixel assignment routine */ - extern unsigned long true_pixel(); unsigned long pixel; + if (!mapped) + return; if (ncolors > 0) pixel = pixval[get_pixel(col, xnewcolr)]; - else if (ourvisual->class != PseudoColor) - pixel = true_pixel(col); else - return; + pixel = true_pixel(col); XSetForeground(ourdisplay, ourgc, pixel); XFillRectangle(ourdisplay, gwind, ourgc, xmin, gheight-ymax, xmax-xmin, ymax-ymin); } -static -x11_flush() /* flush output */ +static void +x11_flush(void) /* flush output */ { + char buf[256]; + int n; + /* check for input */ XNoOp(ourdisplay); - while (XPending(ourdisplay) > 0) + n = XPending(ourdisplay); /* from X server */ + while (n-- > 0) getevent(); +#ifdef FNDELAY + if (inpcheck == IC_IOCTL) { /* from stdin */ +#ifdef FIONREAD + if (ioctl(fileno(stdin), FIONREAD, &n) < 0) { +#else + if (1) { +#endif + if (fcntl(fileno(stdin), F_SETFL, FNDELAY) < 0) { + eputs("cannot change input mode\n"); + quit(1); + } + inpcheck = IC_READ; + } else + x11_driver.inpready += n; + } + if (inpcheck == IC_READ) { + n = read(fileno(stdin), buf, sizeof(buf)-1); + if (n > 0) { + buf[n] = '\0'; + tocombuf(buf, &x11_driver); + } + } +#endif } -static -x11_comin(inp, prompt) /* read in a command line */ -char *inp, *prompt; +static void +x11_comin( /* read in a command line */ + char *inp, + char *prompt +) { - extern int x11_getc(); - - if (prompt != NULL) + if (prompt != NULL) { + x11_flush(); /* make sure we get everything */ if (fromcombuf(inp, &x11_driver)) return; - else - xt_puts(prompt, comline); + xt_puts(prompt, comline); + } xt_cursor(comline, TBLKCURS); editline(inp, x11_getc, x11_comout); xt_cursor(comline, TNOCURS); } -static -x11_comout(out) /* output a string to command line */ -char *out; +static void +x11_comout( /* output a string to command line */ + char *outp +) { - if (comline == NULL) + if (comline == NULL || outp == NULL || !outp[0]) return; - xt_puts(out, comline); - if (out[strlen(out)-1] == '\n') + xt_puts(outp, comline); + if (outp[strlen(outp)-1] == '\n') XFlush(ourdisplay); } -static -x11_errout(msg) /* output an error message */ -char *msg; +static void +x11_errout( /* output an error message */ + char *msg +) { - stderr_v(msg); /* send to stderr also! */ + eputs(msg); /* send to stderr also! */ x11_comout(msg); } +static void +std_comin( /* read in command line from stdin */ + char *inp, + char *prompt +) +{ + if (prompt != NULL) { + if (fromcombuf(inp, &x11_driver)) + return; + if (!x11_driver.inpready) + std_comout(prompt); + } +#ifdef FNDELAY + if (inpcheck == IC_READ) { /* turn off FNDELAY */ + if (fcntl(fileno(stdin), F_SETFL, 0) < 0) { + eputs("cannot change input mode\n"); + quit(1); + } + inpcheck = IC_IOCTL; + } +#endif + if (gets(inp) == NULL) { + strcpy(inp, "quit"); + return; + } + x11_driver.inpready -= strlen(inp) + 1; + if (x11_driver.inpready < 0) + x11_driver.inpready = 0; +} + + +static void +std_comout( /* write out string to stdout */ + char *outp +) +{ + fputs(outp, stdout); + fflush(stdout); +} + + static int -x11_getcur(xp, yp) /* get cursor position */ -int *xp, *yp; +x11_getcur( /* get cursor position */ + int *xp, + int *yp +) { while (XGrabPointer(ourdisplay, gwind, True, ButtonPressMask, GrabModeAsync, GrabModeAsync, None, pickcursor, @@ -304,22 +458,23 @@ int *xp, *yp; if (c_last > c_first) /* key pressed */ return(x11_getc()); /* button pressed */ - if (levptr(XButtonPressedEvent)->button & Button1) + if (levptr(XButtonPressedEvent)->button == Button1) return(MB1); - if (levptr(XButtonPressedEvent)->button & Button2) + if (levptr(XButtonPressedEvent)->button == Button2) return(MB2); - if (levptr(XButtonPressedEvent)->button & Button3) + if (levptr(XButtonPressedEvent)->button == Button3) return(MB3); - if (levptr(XButtonPressedEvent)->button & (Button4|Button5)) - return(MB1); return(ABORT); } -static -xnewcolr(ndx, r, g, b) /* enter a color into hardware table */ -int ndx; -int r, g, b; +static void +xnewcolr( /* enter a color into hardware table */ + int ndx, + int r, + int g, + int b +) { XColor xcolor; @@ -334,30 +489,29 @@ int r, g, b; static int -getpixels() /* get the color map */ +getpixels(void) /* get the color map */ { XColor thiscolor; register int i, j; if (ncolors > 0) - goto donecolors; - if (ourvisual == DefaultVisual(ourdisplay,ourscreen)) { + return(ncolors); + if (ourvinfo.visual == DefaultVisual(ourdisplay,ourscreen)) { ourmap = DefaultColormap(ourdisplay,ourscreen); goto loop; } newmap: - ourmap = XCreateColormap(ourdisplay,gwind,ourvisual,AllocNone); + ourmap = XCreateColormap(ourdisplay,gwind,ourvinfo.visual,AllocNone); loop: - for (ncolors = ourvisual->map_entries; - ncolors > ourvisual->map_entries/3; + for (ncolors = ourvinfo.colormap_size; + ncolors > ourvinfo.colormap_size/3; ncolors = ncolors*.937) { pixval = (unsigned long *)malloc(ncolors*sizeof(unsigned long)); if (pixval == NULL) return(ncolors = 0); - if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0, - pixval,ncolors) != 0) + if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,pixval,ncolors)) break; - free((char *)pixval); + free((void *)pixval); pixval = NULL; } if (pixval == NULL) { @@ -382,25 +536,18 @@ loop: i--; } XSetWindowColormap(ourdisplay, gwind, ourmap); -donecolors: -#ifdef DEBUG - thiscolor.flags = DoRed|DoGreen|DoBlue; - thiscolor.red = thiscolor.green = thiscolor.blue = 0; - for (i = 0; i < ncolors; i++) { - thiscolor.pixel = pixval[i]; - XStoreColor(ourdisplay, ourmap, &thiscolor); - } -#endif return(ncolors); } -static -freepixels() /* free our pixels */ +static void +freepixels(void) /* free our pixels */ { if (ncolors == 0) return; XFreeColors(ourdisplay,ourmap,pixval,ncolors,0L); + free((void *)pixval); + pixval = NULL; ncolors = 0; if (ourmap != DefaultColormap(ourdisplay,ourscreen)) XFreeColormap(ourdisplay, ourmap); @@ -409,22 +556,23 @@ freepixels() /* free our pixels */ static unsigned long -true_pixel(col) /* return true pixel value for color */ -COLOR col; +true_pixel( /* return true pixel value for color */ + COLOR col +) { unsigned long rval; BYTE rgb[3]; map_color(rgb, col); - rval = ourvisual->red_mask*rgb[RED]/255 & ourvisual->red_mask; - rval |= ourvisual->green_mask*rgb[GRN]/255 & ourvisual->green_mask; - rval |= ourvisual->blue_mask*rgb[BLU]/255 & ourvisual->blue_mask; + rval = ourvinfo.red_mask*rgb[RED]/255 & ourvinfo.red_mask; + rval |= ourvinfo.green_mask*rgb[GRN]/255 & ourvinfo.green_mask; + rval |= ourvinfo.blue_mask*rgb[BLU]/255 & ourvinfo.blue_mask; return(rval); } static int -x11_getc() /* get a command character */ +x11_getc(void) /* get a command character */ { while (c_last <= c_first) { c_first = c_last = 0; /* reset */ @@ -435,8 +583,8 @@ x11_getc() /* get a command character */ } -static -getevent() /* get next event */ +static void +getevent(void) /* get next event */ { XNextEvent(ourdisplay, levptr(XEvent)); switch (levptr(XEvent)->type) { @@ -444,14 +592,18 @@ getevent() /* get next event */ resizewindow(levptr(XConfigureEvent)); break; case UnmapNotify: + mapped = 0; freepixels(); break; case MapNotify: - if (ourvisual->class == PseudoColor) + if (ourvinfo.class == PseudoColor || + ourvinfo.class == GrayScale) { if (getpixels() == 0) - stderr_v("Cannot allocate colors\n"); + eputs("cannot allocate colors\n"); else new_ctab(ncolors); + } + mapped = 1; break; case Expose: fixwindow(levptr(XExposeEvent)); @@ -465,9 +617,10 @@ getevent() /* get next event */ } -static -getkey(ekey) /* get input key */ -register XKeyPressedEvent *ekey; +static void +getkey( /* get input key */ + register XKeyPressedEvent *ekey +) { register int n; @@ -478,14 +631,18 @@ register XKeyPressedEvent *ekey; } -static -fixwindow(eexp) /* repair damage to window */ -register XExposeEvent *eexp; +static void +fixwindow( /* repair damage to window */ + register XExposeEvent *eexp +) { + char buf[80]; + if (eexp->window == gwind) { - sprintf(getcombuf(&x11_driver), "repaint %d %d %d %d\n", + sprintf(buf, "repaint %d %d %d %d\n", eexp->x, gheight - eexp->y - eexp->height, eexp->x + eexp->width, gheight - eexp->y); + tocombuf(buf, &x11_driver); } else if (eexp->window == comline->w) { if (eexp->count == 0) xt_redraw(comline); @@ -493,17 +650,18 @@ register XExposeEvent *eexp; } -static -resizewindow(ersz) /* resize window */ -register XConfigureEvent *ersz; +static void +resizewindow( /* resize window */ + register XConfigureEvent *ersz +) { - if (ersz->width == gwidth && ersz->height-COMHEIGHT == gheight) + if (ersz->width == gwidth && ersz->height-comheight == gheight) return; gwidth = ersz->width; - gheight = ersz->height-COMHEIGHT; + gheight = ersz->height-comheight; x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth; x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight; - strcpy(getcombuf(&x11_driver), "new\n"); + tocombuf("new\n", &x11_driver); }
