--- ray/src/rt/x11.c 1994/09/20 15:46:34 2.18 +++ ray/src/rt/x11.c 2003/02/25 02:47:23 2.30 @@ -1,18 +1,22 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: x11.c,v 2.30 2003/02/25 02:47:23 greg Exp $"; #endif - /* * x11.c - driver for X-windows version 11 - * - * Jan 1990 */ -#include -#include +#include "copyright.h" + +#include "standard.h" #include +#ifdef sparc +#include +#include +#include +#endif +#if !defined(FNDELAY) && defined(O_NONBLOCK) +#define FNDELAY O_NONBLOCK +#endif #include #include @@ -69,20 +73,27 @@ static GC ourgc = 0; /* our graphics context for dr static Colormap ourmap = 0; /* our color map */ -extern char *malloc(), *getcombuf(); +#define IC_X11 0 +#define IC_IOCTL 1 +#define IC_READ 2 -static int x11_close(), x11_clear(), x11_paintr(), x11_errout(), - x11_getcur(), x11_comout(), x11_comin(), x11_flush(); +static int inpcheck; /* whence to check input */ -static int std_comin(), std_comout(); +static int x11_getcur(); +static void x11_close(), x11_clear(), x11_paintr(), x11_errout(), + x11_comout(), x11_comin(), x11_flush(); + +static void std_comin(), std_comout(); + static struct driver x11_driver = { x11_close, x11_clear, x11_paintr, x11_getcur, NULL, NULL, x11_flush, 1.0 }; -static int getpixels(), xnewcolr(), freepixels(), resizewindow(), - getevent(), getkey(), fixwindow(), x11_getc(); +static int getpixels(), x11_getc(); +static void xnewcolr(), freepixels(), resizewindow(), + getevent(), getkey(), fixwindow(); static unsigned long true_pixel(); @@ -90,7 +101,6 @@ struct driver * x11_init(name, id) /* initialize driver */ char *name, *id; { - extern char *getenv(); char *gv; int nplanes; XSetWindowAttributes ourwinattr; @@ -99,29 +109,29 @@ char *name, *id; /* open display server */ ourdisplay = XOpenDisplay(NULL); if (ourdisplay == NULL) { - stderr_v("cannot open X-windows; DISPLAY variable set?\n"); + eputs("cannot open X-windows; DISPLAY variable set?\n"); return(NULL); } /* find a usable visual */ nplanes = DisplayPlanes(ourdisplay, ourscreen); if (XMatchVisualInfo(ourdisplay,ourscreen, - 24,TrueColor,&ourvinfo) || + nplanes>12?nplanes:24,TrueColor,&ourvinfo) || XMatchVisualInfo(ourdisplay,ourscreen, - 24,DirectColor,&ourvinfo)) { + nplanes>12?nplanes:24,DirectColor,&ourvinfo)) { ourblack = 0; ourwhite = ourvinfo.red_mask | ourvinfo.green_mask | ourvinfo.blue_mask ; } else { if (nplanes < 4) { - stderr_v("not enough colors\n"); + eputs("not enough colors\n"); return(NULL); } if (!XMatchVisualInfo(ourdisplay,ourscreen, nplanes,PseudoColor,&ourvinfo) && !XMatchVisualInfo(ourdisplay,ourscreen, nplanes,GrayScale,&ourvinfo)) { - stderr_v("unsupported visual type\n"); + eputs("unsupported visual type\n"); return(NULL); } ourblack = BlackPixel(ourdisplay,ourscreen); @@ -136,8 +146,12 @@ char *name, *id; /* X11 command line or no? */ if (!strcmp(name, "x11")) comheight = COMHEIGHT; - else /* "x11d" */ + else /* "x11d" */ { comheight = 0; +#ifndef FNDELAY + eputs("warning: x11d driver not fully functional on this machine\n"); +#endif + } /* open window */ ourwinattr.background_pixel = ourblack; ourwinattr.border_pixel = ourblack; @@ -150,7 +164,7 @@ char *name, *id; BORWIDTH, ourvinfo.depth, InputOutput, ourvinfo.visual, CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr); if (gwind == 0) { - stderr_v("cannot create window\n"); + eputs("cannot create window\n"); return(NULL); } XStoreName(ourdisplay, gwind, id); @@ -179,24 +193,26 @@ char *name, *id; if (comheight) { x11_driver.comin = x11_comin; x11_driver.comout = x11_comout; - cmdvec = x11_comout; - if (wrnvec != NULL) - wrnvec = x11_errout; + erract[COMMAND].pf = x11_comout; + if (erract[WARNING].pf != NULL) + erract[WARNING].pf = x11_errout; + inpcheck = IC_X11; } else { x11_driver.comin = std_comin; x11_driver.comout = std_comout; - cmdvec = std_comout; + erract[COMMAND].pf = std_comout; + inpcheck = IC_IOCTL; } return(&x11_driver); } -static +static void x11_close() /* close our display */ { - cmdvec = NULL; /* reset error vectors */ - if (wrnvec != NULL) - wrnvec = stderr_v; + erract[COMMAND].pf = NULL; /* reset error vectors */ + if (erract[WARNING].pf != NULL) + erract[WARNING].pf = wputs; if (ourdisplay == NULL) return; if (comline != NULL) { @@ -214,7 +230,7 @@ x11_close() /* close our display */ } -static +static void x11_clear(xres, yres) /* clear our display */ int xres, yres; { @@ -237,7 +253,7 @@ int xres, yres; /* reinitialize color table */ if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) if (getpixels() == 0) - stderr_v("cannot allocate colors\n"); + eputs("cannot allocate colors\n"); else new_ctab(ncolors); /* get new command line */ @@ -247,7 +263,7 @@ int xres, yres; comline = xt_open(ourdisplay, gwind, 0, gheight, gwidth, comheight, 0, ourblack, ourwhite, COMFN); if (comline == NULL) { - stderr_v("Cannot open command line window\n"); + eputs("cannot open command line window\n"); quit(1); } XSelectInput(ourdisplay, comline->w, ExposureMask); @@ -260,7 +276,7 @@ int xres, yres; } -static +static void x11_paintr(col, xmin, ymin, xmax, ymax) /* fill a rectangle */ COLOR col; int xmin, ymin, xmax, ymax; @@ -279,26 +295,43 @@ int xmin, ymin, xmax, ymax; } -static +static void x11_flush() /* flush output */ { + char buf[256]; int n; /* check for input */ XNoOp(ourdisplay); n = XPending(ourdisplay); /* from X server */ while (n-- > 0) getevent(); - if (x11_driver.comin == std_comin) { /* from stdin */ +#ifdef FNDELAY + if (inpcheck == IC_IOCTL) { /* from stdin */ +#ifdef FIONREAD if (ioctl(fileno(stdin), FIONREAD, &n) < 0) { - stderr_v("ioctl error on stdin\n"); - quit(1); +#else + if (1) { +#endif + if (fcntl(fileno(stdin), F_SETFL, FNDELAY) < 0) { + eputs("cannot change input mode\n"); + quit(1); + } + inpcheck = IC_READ; + } else + x11_driver.inpready += n; + } + if (inpcheck == IC_READ) { + n = read(fileno(stdin), buf, sizeof(buf)-1); + if (n > 0) { + buf[n] = '\0'; + tocombuf(buf, &x11_driver); } - x11_driver.inpready += n; } +#endif } -static +static void x11_comin(inp, prompt) /* read in a command line */ char *inp, *prompt; { @@ -314,11 +347,11 @@ char *inp, *prompt; } -static +static void x11_comout(outp) /* output a string to command line */ char *outp; { - if (comline == NULL) + if (comline == NULL || outp == NULL || !outp[0]) return; xt_puts(outp, comline); if (outp[strlen(outp)-1] == '\n') @@ -326,27 +359,34 @@ char *outp; } -static +static void x11_errout(msg) /* output an error message */ char *msg; { - stderr_v(msg); /* send to stderr also! */ + eputs(msg); /* send to stderr also! */ x11_comout(msg); } -static +static void std_comin(inp, prompt) /* read in command line from stdin */ char *inp, *prompt; { - extern char *gets(); - if (prompt != NULL) { if (fromcombuf(inp, &x11_driver)) return; if (!x11_driver.inpready) - fputs(prompt, stdout); + std_comout(prompt); } +#ifdef FNDELAY + if (inpcheck == IC_READ) { /* turn off FNDELAY */ + if (fcntl(fileno(stdin), F_SETFL, 0) < 0) { + eputs("cannot change input mode\n"); + quit(1); + } + inpcheck = IC_IOCTL; + } +#endif if (gets(inp) == NULL) { strcpy(inp, "quit"); return; @@ -357,11 +397,12 @@ char *inp, *prompt; } -static +static void std_comout(outp) /* write out string to stdout */ char *outp; { fputs(outp, stdout); + fflush(stdout); } @@ -394,7 +435,7 @@ int *xp, *yp; } -static +static void xnewcolr(ndx, r, g, b) /* enter a color into hardware table */ int ndx; int r, g, b; @@ -434,7 +475,7 @@ loop: return(ncolors = 0); if (XAllocColorCells(ourdisplay,ourmap,0,NULL,0,pixval,ncolors)) break; - free((char *)pixval); + free((void *)pixval); pixval = NULL; } if (pixval == NULL) { @@ -463,13 +504,13 @@ loop: } -static +static void freepixels() /* free our pixels */ { if (ncolors == 0) return; XFreeColors(ourdisplay,ourmap,pixval,ncolors,0L); - free((char *)pixval); + free((void *)pixval); pixval = NULL; ncolors = 0; if (ourmap != DefaultColormap(ourdisplay,ourscreen)) @@ -505,7 +546,7 @@ x11_getc() /* get a command character */ } -static +static void getevent() /* get next event */ { XNextEvent(ourdisplay, levptr(XEvent)); @@ -521,7 +562,7 @@ getevent() /* get next event */ if (ourvinfo.class == PseudoColor || ourvinfo.class == GrayScale) if (getpixels() == 0) - stderr_v("Cannot allocate colors\n"); + eputs("cannot allocate colors\n"); else new_ctab(ncolors); mapped = 1; @@ -538,7 +579,7 @@ getevent() /* get next event */ } -static +static void getkey(ekey) /* get input key */ register XKeyPressedEvent *ekey; { @@ -551,14 +592,17 @@ register XKeyPressedEvent *ekey; } -static +static void fixwindow(eexp) /* repair damage to window */ register XExposeEvent *eexp; { + char buf[80]; + if (eexp->window == gwind) { - sprintf(getcombuf(&x11_driver), "repaint %d %d %d %d\n", + sprintf(buf, "repaint %d %d %d %d\n", eexp->x, gheight - eexp->y - eexp->height, eexp->x + eexp->width, gheight - eexp->y); + tocombuf(buf, &x11_driver); } else if (eexp->window == comline->w) { if (eexp->count == 0) xt_redraw(comline); @@ -566,7 +610,7 @@ register XExposeEvent *eexp; } -static +static void resizewindow(ersz) /* resize window */ register XConfigureEvent *ersz; { @@ -578,5 +622,5 @@ register XConfigureEvent *ersz; x11_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth; x11_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight; - strcpy(getcombuf(&x11_driver), "new\n"); + tocombuf("new\n", &x11_driver); }
