/* Copyright (c) 1987 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; #endif /* * x10.c - driver for X-windows version 10.4 * * 5/7/87 */ #include #include #include #include #include #include "color.h" #include "driver.h" #include "xtwind.h" #define GAMMA 2.2 /* exponent for color correction */ #define BORWIDTH 5 /* border width */ #define COMHEIGHT (COMLH*COMCH) /* command line height (pixels) */ #define MINWIDTH (32*COMCW) /* minimum graphics window width */ #define MINHEIGHT 64 /* minimum graphics window height */ #define COMFN "8x13" /* command line font name */ #define COMLH 3 /* number of command lines */ #define COMCW 8 /* approx. character width (pixels) */ #define COMCH 13 /* approx. character height (pixels) */ #ifndef WFLUSH #define WFLUSH 30 /* flush after this many rays */ #endif #define checkinp() while (XPending() > 0) getevent() #define levptr(etype) ((etype *)&thisevent) static XEvent thisevent; /* current event */ static int ncolors = 0; /* color table size */ static int *pixval; /* allocated pixel values */ static Display *ourdisplay = NULL; /* our display */ static Window gwind = 0; /* our graphics window */ static Cursor pickcursor = 0; /* cursor used for picking */ static int gwidth, gheight; /* graphics window size */ static TEXTWIND *comline = NULL; /* our command line */ static char c_queue[64]; /* input queue */ static int c_first = 0; /* first character in queue */ static int c_last = 0; /* last character in queue */ extern char *malloc(), *getcombuf(); extern char *progname; int x_close(), x_clear(), x_paintr(), x_errout(), x_getcur(), x_comout(), x_comin(); static struct driver x_driver = { x_close, x_clear, x_paintr, x_getcur, x_comout, x_comin, 1.0 }; struct driver * x_init(name, id) /* initialize driver */ char *name, *id; { char defgeom[32]; OpaqueFrame mainframe; ourdisplay = XOpenDisplay(NULL); if (ourdisplay == NULL) { stderr_v("cannot open X-windows; DISPLAY variable set?\n"); return(NULL); } if (DisplayPlanes() < 4) { stderr_v("not enough colors\n"); return(NULL); } make_gmap(GAMMA); /* make color map */ pickcursor = XCreateCursor(bcross_width, bcross_height, bcross_bits, bcross_mask_bits, bcross_x_hot, bcross_y_hot, BlackPixel, WhitePixel, GXcopy); mainframe.bdrwidth = BORWIDTH; mainframe.border = BlackPixmap; mainframe.background = BlackPixmap; sprintf(defgeom, "=%dx%d+0+22", DisplayWidth()-(2*BORWIDTH), DisplayHeight()-(2*BORWIDTH+22)); gwind = XCreate("X10 display driver", progname, NULL, defgeom, &mainframe, MINWIDTH, MINHEIGHT+COMHEIGHT); if (gwind == 0) { stderr_v("can't create window\n"); return(NULL); } XStoreName(gwind, id); XSelectInput(gwind, KeyPressed|ButtonPressed| ExposeWindow|ExposeRegion|UnmapWindow); gwidth = mainframe.width; gheight = mainframe.height-COMHEIGHT; x_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth; x_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight; x_driver.inpready = 0; cmdvec = x_comout; /* set error vectors */ if (wrnvec != NULL) wrnvec = x_errout; return(&x_driver); } static x_close() /* close our display */ { cmdvec = NULL; /* reset error vectors */ if (wrnvec != NULL) wrnvec = stderr_v; if (ourdisplay == NULL) return; if (comline != NULL) { xt_close(comline); comline = NULL; } if (gwind != 0) { XDestroyWindow(gwind); gwind = 0; } XFreeCursor(pickcursor); freepixels(); XCloseDisplay(ourdisplay); ourdisplay = NULL; } static x_clear(xres, yres) /* clear our display */ int xres, yres; { if (xres != gwidth || yres != gheight) { /* new window */ if (comline != NULL) xt_close(comline); XChangeWindow(gwind, xres, yres+COMHEIGHT); comline = xt_open(gwind, 0, yres, xres, COMHEIGHT, 0, COMFN); if (comline == NULL) { stderr_v("Cannot open command line window\n"); quit(1); } gwidth = xres; gheight = yres; } else /* just clear */ XClear(gwind); /* reinitialize color table */ if (getpixels() == 0) stderr_v("cannot allocate colors\n"); else new_ctab(ncolors); XMapWindow(gwind); /* make sure it's mapped */ XSync(1); /* discard input */ return; } static x_paintr(col, xmin, ymin, xmax, ymax) /* fill a rectangle */ COLOR col; int xmin, ymin, xmax, ymax; { extern long nrays; /* global ray count */ extern int xnewcolr(); /* pixel assignment routine */ static long lastflush = 0; /* ray count at last flush */ if (ncolors > 0) { XPixSet(gwind, xmin, gheight-ymax, xmax-xmin, ymax-ymin, pixval[get_pixel(col, xnewcolr)]); } if (nrays - lastflush >= WFLUSH) { if (ncolors <= 0) /* output necessary for death */ XPixSet(gwind,0,0,1,1,BlackPixel); checkinp(); lastflush = nrays; } } static x_comin(inp, prompt) /* read in a command line */ char *inp, *prompt; { int x_getc(), x_comout(); if (prompt != NULL) if (fromcombuf(inp, &x_driver)) return; else xt_puts(prompt, comline); xt_cursor(comline, TBLKCURS); editline(inp, x_getc, x_comout); xt_cursor(comline, TNOCURS); } static x_comout(out) /* output a string to command line */ char *out; { if (comline != NULL) xt_puts(out, comline); XFlush(); } static x_errout(msg) /* output an error message */ char *msg; { x_comout(msg); stderr_v(msg); /* send to stderr also! */ } static int x_getcur(xp, yp) /* get cursor position */ int *xp, *yp; { while (XGrabMouse(gwind, pickcursor, ButtonPressed) == 0) sleep(1); XFocusKeyboard(gwind); do getevent(); while (c_last <= c_first && levptr(XEvent)->type != ButtonPressed); *xp = levptr(XKeyOrButtonEvent)->x; *yp = gheight-1 - levptr(XKeyOrButtonEvent)->y; XFocusKeyboard(RootWindow); XUngrabMouse(); XFlush(); /* insure release */ if (c_last > c_first) /* key pressed */ return(x_getc()); /* button pressed */ switch (levptr(XKeyOrButtonEvent)->detail & 0377) { case LeftButton: return(MB1); case MiddleButton: return(MB2); case RightButton: return(MB3); } return(ABORT); } static xnewcolr(ndx, r, g, b) /* enter a color into hardware table */ int ndx; int r, g, b; { Color xcolor; xcolor.pixel = pixval[ndx]; xcolor.red = r << 8; xcolor.green = g << 8; xcolor.blue = b << 8; XStoreColor(&xcolor); } static int getpixels() /* get the color map */ { int planes; if (ncolors > 0) return(ncolors); for (ncolors=(1<12; ncolors=ncolors*.937){ pixval = (int *)malloc(ncolors*sizeof(int)); if (pixval == NULL) break; if (XGetColorCells(0,ncolors,0,&planes,pixval) != 0) return(ncolors); free((char *)pixval); } return(ncolors = 0); } static freepixels() /* free our pixels */ { if (ncolors == 0) return; XFreeColors(pixval, ncolors, 0); free((char *)pixval); ncolors = 0; } static int x_getc() /* get a command character */ { while (c_last <= c_first) { c_first = c_last = 0; /* reset */ getevent(); /* wait for key */ } x_driver.inpready--; return(c_queue[c_first++]); } static getevent() /* get next event */ { XNextEvent(levptr(XEvent)); switch (levptr(XEvent)->type) { case KeyPressed: getkey(levptr(XKeyPressedEvent)); break; case ExposeWindow: windowchange(levptr(XExposeEvent)); break; case ExposeRegion: fixwindow(levptr(XExposeEvent)); break; case UnmapWindow: if (levptr(XUnmapEvent)->subwindow == 0) freepixels(); break; case ButtonPressed: /* handled in x_getcur() */ break; } } static windowchange(eexp) /* process window change event */ register XExposeEvent *eexp; { if (eexp->subwindow != 0) { fixwindow(eexp); return; } /* check for change in size */ if (eexp->width != gwidth || eexp->height-COMHEIGHT != gheight) { gwidth = eexp->width; gheight = eexp->height-COMHEIGHT; x_driver.xsiz = gwidth < MINWIDTH ? MINWIDTH : gwidth; x_driver.ysiz = gheight < MINHEIGHT ? MINHEIGHT : gheight; strcpy(getcombuf(&x_driver), "new\n"); return; } /* remap colors */ if (getpixels() == 0) { stderr_v("cannot allocate colors\n"); return; } new_ctab(ncolors); /* redraw */ fixwindow(eexp); } static getkey(ekey) /* get input key */ register XKeyPressedEvent *ekey; { int n; register char *str; str = XLookupMapping(ekey, &n); while (n-- > 0 && c_last < sizeof(c_queue)) { c_queue[c_last++] = *str++; x_driver.inpready++; } } static fixwindow(eexp) /* repair damage to window */ register XExposeEvent *eexp; { if (eexp->subwindow == 0) sprintf(getcombuf(&x_driver), "repaint %d %d %d %d\n", eexp->x, gheight - eexp->y - eexp->height, eexp->x + eexp->width, gheight - eexp->y); else if (eexp->subwindow == comline->w) xt_redraw(comline); }
