/* Copyright (c) 1987 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; #endif /* * x10.c - driver for X-windows version 10.4 * * 5/7/87 */ #include #include #include #include #include #include "color.h" #include "driver.h" #include "xtwind.h" #define GAMMA 2.0 /* exponent for color correction */ #define BORWIDTH 5 /* border width */ #define BARHEIGHT 25 /* menu bar size */ #define COMHEIGHT (COMLH*COMCH) /* command line height (pixels) */ #define COMFN "8x13" /* command line font name */ #define COMLH 3 /* number of command lines */ #define COMCW 8 /* approx. character width (pixels) */ #define COMCH 13 /* approx. character height (pixels) */ #ifndef WFLUSH #define WFLUSH 30 /* flush after this many rays */ #endif #define hashcolr(c) ((67*(c)[RED]+59*(c)[GRN]+71*(c)[BLU])%ncolors) #define checkinp() while (XPending() > 0) getevent() #define levptr(etype) ((etype *)&thisevent) static char *clientname; /* calling client's name */ static XEvent thisevent; /* current event */ static int colres = 128; /* color resolution */ static COLR colrmap[256]; /* our color mapping */ static int ncolors = 0; /* color table size */ static COLR *colrtbl; /* our color table */ static int *pixval; /* associated pixel values */ static Display *ourdisplay = NULL; /* our display */ static Window gwind = 0; /* our graphics window */ static Cursor pickcursor = 0; /* cursor used for picking */ static int gwidth = 0; /* graphics window width */ static int gheight = 0; /* graphics window height */ static TEXTWIND *comline = NULL; /* our command line */ static int c_erase, c_kill; /* erase and kill characters */ static char c_queue[64]; /* input queue */ static int c_first = 0; /* first character in queue */ static int c_last = 0; /* last character in queue */ extern char *malloc(); int x_close(), x_clear(), x_paintr(), x_errout(), x_getcur(), x_comout(), x_comin(); static struct driver x_driver = { x_close, x_clear, x_paintr, x_getcur, x_comout, x_comin, MAXRES, MAXRES }; struct driver * x_init(name) /* initialize driver */ char *name; { struct sgttyb ttymode; if (isatty(0)) { ioctl(0, TIOCGETP, &ttymode); c_erase = ttymode.sg_erase; c_kill = ttymode.sg_kill; } else { c_erase = 'H'-'@'; c_kill = 'U'-'@'; } ourdisplay = XOpenDisplay(NULL); if (ourdisplay == NULL) { stderr_v("cannot open X-windows; DISPLAY variable set?\n"); return(NULL); } if (DisplayPlanes() < 4) { stderr_v("not enough colors\n"); return(NULL); } if (getmap() < 0) /* not fatal */ stderr_v("cannot allocate colors\n"); pickcursor = XCreateCursor(bcross_width, bcross_height, bcross_bits, bcross_mask_bits, bcross_x_hot, bcross_y_hot, BlackPixel, WhitePixel, GXcopy); clientname = name; x_driver.inpready = 0; cmdvec = x_comout; /* set error vectors */ if (wrnvec != NULL) wrnvec = x_errout; return(&x_driver); } static x_close() /* close our display */ { cmdvec = NULL; /* reset error vectors */ if (wrnvec != NULL) wrnvec = stderr_v; if (ourdisplay == NULL) return; if (comline != NULL) { xt_close(comline); comline = NULL; } if (gwind != 0) { XDestroyWindow(gwind); gwind = 0; gwidth = gheight = 0; } XFreeCursor(pickcursor); freemap(); XCloseDisplay(ourdisplay); ourdisplay = NULL; } static x_clear(xres, yres) /* clear our display */ int xres, yres; { if (xres != gwidth || yres != gheight) { /* new window */ if (comline != NULL) xt_close(comline); if (gwind != 0) XDestroyWindow(gwind); gwind = XCreateWindow(RootWindow, 0, BARHEIGHT, xres, yres+COMHEIGHT, BORWIDTH, BlackPixmap, BlackPixmap); if (gwind == 0) goto fail; comline = xt_open(gwind, 0, yres, xres, COMHEIGHT, 0, COMFN); if (comline == NULL) goto fail; XMapWindow(gwind); XSelectInput(gwind, KeyPressed|ButtonPressed|ExposeWindow|ExposeRegion|UnmapWindow); XStoreName(gwind, clientname); gwidth = xres; gheight = yres; } else /* just clear */ XClear(gwind); newmap(); checkinp(); return; fail: stderr_v("Failure opening window in x_clear\n"); quit(1); } static x_paintr(col, xmin, ymin, xmax, ymax) /* fill a rectangle */ COLOR col; int xmin, ymin, xmax, ymax; { extern long nrays; /* global ray count */ static long lastflush = 0; /* ray count at last flush */ int ndx; if (ncolors > 0) { if ((ndx = colindex(col)) < 0) { colres >>= 1; redraw(); return; } XPixSet(gwind, xmin, gheight-ymax, xmax-xmin, ymax-ymin, pixval[ndx]); } if (nrays - lastflush >= WFLUSH) { if (ncolors <= 0) /* output necessary for death */ XPixSet(gwind,0,0,1,1,BlackPixel); checkinp(); lastflush = nrays; } } static x_comin(inp) /* read in a command line */ char *inp; { int x_getc(), x_comout(); xt_cursor(comline, TBLKCURS); editline(inp, x_getc, x_comout, c_erase, c_kill); xt_cursor(comline, TNOCURS); } static x_comout(out) /* output a string to command line */ char *out; { if (comline != NULL) xt_puts(out, comline); XFlush(); } static x_errout(msg) /* output an error message */ char *msg; { x_comout(msg); stderr_v(msg); /* send to stderr also! */ } static int x_getcur(xp, yp) /* get cursor position */ int *xp, *yp; { while (XGrabMouse(gwind, pickcursor, ButtonPressed) == 0) sleep(1); XFocusKeyboard(gwind); do getevent(); while (c_last <= c_first && levptr(XEvent)->type != ButtonPressed); *xp = levptr(XKeyOrButtonEvent)->x; *yp = gheight-1 - levptr(XKeyOrButtonEvent)->y; XFocusKeyboard(RootWindow); XUngrabMouse(); XFlush(); /* insure release */ if (c_last > c_first) /* key pressed */ return(x_getc()); /* button pressed */ switch (levptr(XKeyOrButtonEvent)->detail & 0377) { case LeftButton: return(MB1); case MiddleButton: return(MB2); case RightButton: return(MB3); } return(ABORT); } static int colindex(col) /* return index for color */ COLOR col; { static COLR clr; int hval; register int ndx, i; mapcolor(clr, col); hval = ndx = hashcolr(clr); for (i = 1; i < ncolors; i++) { if (colrtbl[ndx][EXP] == 0) { colrtbl[ndx][RED] = clr[RED]; colrtbl[ndx][GRN] = clr[GRN]; colrtbl[ndx][BLU] = clr[BLU]; colrtbl[ndx][EXP] = COLXS; newcolr(ndx, clr); return(ndx); } if ( colrtbl[ndx][RED] == clr[RED] && colrtbl[ndx][GRN] == clr[GRN] && colrtbl[ndx][BLU] == clr[BLU] ) return(ndx); ndx = (hval + i*i) % ncolors; } return(-1); } static newcolr(ndx, clr) /* enter a color into hardware table */ int ndx; COLR clr; { Color xcolor; xcolor.pixel = pixval[ndx]; xcolor.red = clr[RED] << 8; xcolor.green = clr[GRN] << 8; xcolor.blue = clr[BLU] << 8; XStoreColor(&xcolor); } static mapcolor(clr, col) /* map to our color space */ COLR clr; COLOR col; { register int i, p; /* compute color table value */ for (i = 0; i < 3; i++) { p = colval(col,i) * 255.0 + 0.5; if (p < 0) p = 0; else if (p > 255) p = 255; clr[i] = colrmap[p][i]; } clr[EXP] = COLXS; } static getmap() /* get the color map */ { int planes; for (ncolors=(1<12; ncolors=ncolors*.937){ colrtbl = (COLR *)malloc(ncolors*sizeof(COLR)); pixval = (int *)malloc(ncolors*sizeof(int)); if (colrtbl == NULL || pixval == NULL) return(-1); if (XGetColorCells(0,ncolors,0,&planes,pixval) != 0) return(0); free((char *)colrtbl); free((char *)pixval); } ncolors = 0; return(-1); } static freemap() /* free our color map */ { if (ncolors == 0) return; XFreeColors(pixval, ncolors, 0); free((char *)colrtbl); free((char *)pixval); ncolors = 0; } static newmap() /* initialize the color map */ { double pow(); int val; register int i; for (i = 0; i < 256; i++) { val = pow(i/256.0, 1.0/GAMMA) * colres; val = (val*256 + 128) / colres; colrmap[i][RED] = colrmap[i][GRN] = colrmap[i][BLU] = val; colrmap[i][EXP] = COLXS; } for (i = 0; i < ncolors; i++) colrtbl[i][EXP] = 0; } static int x_getc() /* get a command character */ { while (c_last <= c_first) { c_first = c_last = 0; /* reset */ getevent(); /* wait for key */ } x_driver.inpready--; return(c_queue[c_first++]); } static getevent() /* get next event */ { XNextEvent(levptr(XEvent)); switch (levptr(XEvent)->type) { case KeyPressed: getkey(levptr(XKeyPressedEvent)); break; case ExposeWindow: if (ncolors == 0 && levptr(XExposeEvent)->subwindow == 0) if (getmap() < 0) stderr_v("cannot grab colors\n"); else newmap(); /* fall through */ case ExposeRegion: fixwindow(levptr(XExposeEvent)); break; case UnmapWindow: if (levptr(XUnmapEvent)->subwindow == 0) freemap(); break; case ButtonPressed: /* handled in x_getcur() */ break; } } static getkey(ekey) /* get input key */ register XKeyPressedEvent *ekey; { int n; register char *str; str = XLookupMapping(ekey, &n); while (n-- > 0 && c_last < sizeof(c_queue)) c_queue[c_last++] = *str++; x_driver.inpready = c_last - c_first; } static fixwindow(eexp) /* repair damage to window */ register XExposeEvent *eexp; { if (eexp->subwindow == 0) repaint(eexp->x, gheight - eexp->y - eexp->height, eexp->x + eexp->width, gheight - eexp->y); else if (eexp->subwindow == comline->w) xt_redraw(comline); }
