root/radiance/ray/src/rt/x10.c
Revision 2.7
Changes since 2.6: +0 -0 lines
FILE REMOVED
Tue Nov 11 20:03:02 1997 UTC (27 years, 6 months ago) by gregl
Changes since 2.5: +14 -15 lines
Diff to previous 2.5 , to selected 1.17
Tue Sep 20 15:50:00 1994 UTC (30 years, 7 months ago) by greg
Diff to previous 2.4 , to selected 1.17
changed GAMMA to DISPLAY_GAMMA
Fri Sep 9 15:10:25 1994 UTC (30 years, 8 months ago) by greg
Changes since 2.3: +0 -1 lines
Diff to previous 2.3 , to selected 1.17
removed unneeded reference to ioctl.h
Fri Jun 4 14:48:35 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.2 , to selected 1.17
added math.h for atof() usage
Wed Jun 24 13:32:31 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.1: +7 -1 lines
Diff to previous 2.1 , to selected 1.17
added code to get GAMMA environment variable
Tue Nov 12 17:09:36 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.29: +0 -0 lines
Diff to previous 1.29 , to selected 1.17
Tue Jul 10 12:19:46 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.28: +8 -8 lines
Diff to previous 1.28 , to selected 1.17
fixed command line initialization in x_clear()
Mon Mar 12 11:08:46 1990 UTC (35 years, 2 months ago) by greg
Diff to previous 1.27 , to selected 1.17
fixed function predeclarations for fussy compilers
Mon Mar 5 09:14:15 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.26: +6 -4 lines
Diff to previous 1.26 , to selected 1.17
minor change to flushing in x_comout()
Fri Feb 23 08:55:18 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.25: +1 -1 lines
Diff to previous 1.25 , to selected 1.17
increased minimum window width to equal minimum height
Thu Feb 22 11:46:20 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.24: +13 -16 lines
Diff to previous 1.24 , to selected 1.17
Wed Feb 21 18:17:56 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.23: +11 -12 lines
Diff to previous 1.23 , to selected 1.17
fixed initialization of gwidth and gheight
Tue Jan 30 11:37:48 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.22: +7 -4 lines
Diff to previous 1.22 , to selected 1.17
Tue Jan 30 09:47:21 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.21: +4 -3 lines
Diff to previous 1.21 , to selected 1.17
changed allocation and freeing of color table slightly
Wed Jan 10 10:04:30 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.20: +3 -1 lines
Diff to previous 1.20 , to selected 1.17
changed call to XCreate()
Tue Jan 9 09:07:03 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.19: +3 -2 lines
Diff to previous 1.19 , to selected 1.17
changed inpready updating in getkey()
Mon Jan 8 14:45:05 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.18: +27 -24 lines
Diff to previous 1.18 , to selected 1.17
added window resizing
Mon Jan 8 13:38:41 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.17: +43 -14 lines
Diff to previous 1.17
Revision 1.17 - (view) (download) (annotate) - [selected]
Wed Oct 25 17:17:09 1989 UTC (35 years, 6 months ago) by greg
Changes since 1.16: +23 -21 lines
Diff to previous 1.16
changed x_clear() to resize rather than recreate window
Wed Oct 25 15:37:24 1989 UTC (35 years, 6 months ago) by greg
Diff to previous 1.15 , to selected 1.17
Wed Oct 4 09:18:54 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.14: +2 -4 lines
Diff to previous 1.14 , to selected 1.17
Changed new_ctab() error handling
Tue Oct 3 14:06:56 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.13: +5 -6 lines
Diff to previous 1.13 , to selected 1.17
Changed calling conventions slightly and added custom color map.
Tue Oct 3 13:02:57 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.12: +15 -35 lines
Diff to previous 1.12 , to selected 1.17
Improved color table allocation, second cut.
Mon Oct 2 17:12:39 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.11: +35 -88 lines
Diff to previous 1.11 , to selected 1.17
Fri Sep 29 13:23:59 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.10: +1 -13 lines
Diff to previous 1.10 , to selected 1.17
Added word erase and allowed ^H or ^?, ^U or ^X in editline.
Wed Jun 7 13:22:52 1989 UTC (35 years, 11 months ago) by greg
Diff to previous 1.9 , to selected 1.17
Reduced WFLUSH, since change in direct calculation reduces rays
Fri Jun 2 17:21:26 1989 UTC (35 years, 11 months ago) by greg
Changes since 1.8: +3 -1 lines
Diff to previous 1.8 , to selected 1.17
Changed WFLUSH value and added output to flush so rview would
die with X-windows when the server was killed and rview iconified
Tue May 30 09:53:10 1989 UTC (35 years, 11 months ago) by greg
Changes since 1.7: +5 -8 lines
Diff to previous 1.7 , to selected 1.17
QLength() macro doesn't seem to work, unfortunately
Sat May 27 09:18:45 1989 UTC (35 years, 11 months ago) by greg
Changes since 1.6: +5 -2 lines
Diff to previous 1.6 , to selected 1.17
Changed input checking procedure
Fri May 26 10:27:18 1989 UTC (35 years, 11 months ago) by greg
Changes since 1.5: +1 -0 lines
Diff to previous 1.5 , to selected 1.17
reinstated flush in command line output
Thu May 25 19:33:19 1989 UTC (35 years, 11 months ago) by greg
Changes since 1.4: +2 -5 lines
Diff to previous 1.4 , to selected 1.17
eliminated duplication of standard error output and assoc. problems
Thu May 25 14:59:05 1989 UTC (35 years, 11 months ago) by greg
Diff to previous 1.3 , to selected 1.17
added comments on event processing
Thu May 25 14:53:13 1989 UTC (35 years, 11 months ago) by greg
Diff to previous 1.2 , to selected 1.17
Fixed x_comout so it doesn't process pending input
Mon Apr 10 20:01:30 1989 UTC (36 years, 1 month ago) by greg
Diff to previous 1.1 , to selected 1.17
changed cannot open error message
Thu Feb 2 10:41:50 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 1.17
