1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: virtuals.c,v 2.20 2012/09/14 13:34:02 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Routines for simulating virtual light sources |
6 |
* Thus far, we only support planar mirrors. |
7 |
8 |
* External symbols declared in source.h |
9 |
10 |
11 |
#include "copyright.h" |
12 |
13 |
#include "ray.h" |
14 |
15 |
#include "otypes.h" |
16 |
17 |
#include "source.h" |
18 |
19 |
#include "random.h" |
20 |
21 |
#define MINSAMPLES 16 /* minimum number of pretest samples */ |
22 |
#define STESTMAX 32 /* maximum seeks per sample */ |
23 |
24 |
#define FEQ(a,b) ((a)-(b)+FTINY >= 0 && (b)-(a)+FTINY >= 0) |
25 |
26 |
27 |
static OBJECT *vobject; /* virtual source objects */ |
28 |
static int nvobjects = 0; /* number of virtual source objects */ |
29 |
30 |
31 |
static int |
32 |
isident4(MAT4 m) |
33 |
34 |
int i, j; |
35 |
36 |
for (i = 4; i--; ) |
37 |
for (j = 4; j--; ) |
38 |
if (!FEQ(m[i][j], i==j)) |
39 |
return(0); |
40 |
return(1); |
41 |
42 |
43 |
44 |
void |
45 |
markvirtuals(void) /* find and mark virtual sources */ |
46 |
47 |
OBJREC *o; |
48 |
int i; |
49 |
/* check number of direct relays */ |
50 |
if (directrelay <= 0) |
51 |
return; |
52 |
/* find virtual source objects */ |
53 |
for (i = 0; i < nsceneobjs; i++) { |
54 |
o = objptr(i); |
55 |
if (!issurface(o->otype) || o->omod == OVOID) |
56 |
continue; |
57 |
if (!isvlight(vsmaterial(o)->otype)) |
58 |
continue; |
59 |
if (sfun[o->otype].of == NULL || |
60 |
sfun[o->otype].of->getpleq == NULL) { |
61 |
objerror(o,WARNING,"secondary sources not supported"); |
62 |
continue; |
63 |
64 |
if (nvobjects == 0) |
65 |
vobject = (OBJECT *)malloc(sizeof(OBJECT)); |
66 |
else |
67 |
vobject = (OBJECT *)realloc((void *)vobject, |
68 |
(unsigned)(nvobjects+1)*sizeof(OBJECT)); |
69 |
if (vobject == NULL) |
70 |
error(SYSTEM, "out of memory in addvirtuals"); |
71 |
vobject[nvobjects++] = i; |
72 |
73 |
74 |
return; |
75 |
#ifdef DEBUG |
76 |
fprintf(stderr, "found %d virtual source objects\n", nvobjects); |
77 |
#endif |
78 |
/* append virtual sources */ |
79 |
for (i = nsources; i-- > 0; ) |
80 |
addvirtuals(i, directrelay); |
81 |
/* done with our object list */ |
82 |
free((void *)vobject); |
83 |
nvobjects = 0; |
84 |
85 |
86 |
87 |
void |
88 |
addvirtuals( /* add virtuals associated with source */ |
89 |
int sn, |
90 |
int nr |
91 |
92 |
93 |
int i; |
94 |
/* check relay limit first */ |
95 |
if (nr <= 0) |
96 |
return; |
97 |
if (source[sn].sflags & SSKIP) |
98 |
return; |
99 |
/* check each virtual object for projection */ |
100 |
for (i = 0; i < nvobjects; i++) |
101 |
/* vproject() calls us recursively */ |
102 |
vproject(objptr(vobject[i]), sn, nr-1); |
103 |
104 |
105 |
106 |
void |
107 |
vproject( /* create projected source(s) if they exist */ |
108 |
OBJREC *o, |
109 |
int sn, |
110 |
int n |
111 |
112 |
113 |
int i; |
114 |
VSMATERIAL *vsmat; |
115 |
MAT4 proj; |
116 |
int ns; |
117 |
118 |
if (o == source[sn].so) /* objects cannot project themselves */ |
119 |
return; |
120 |
/* get virtual source material */ |
121 |
vsmat = sfun[vsmaterial(o)->otype].mf; |
122 |
/* project virtual sources */ |
123 |
for (i = 0; i < vsmat->nproj; i++) |
124 |
if ((*vsmat->vproj)(proj, o, &source[sn], i)) |
125 |
if ((ns = makevsrc(o, sn, proj)) >= 0) { |
126 |
source[ns].sa.sv.pn = i; |
127 |
#ifdef DEBUG |
128 |
virtverb(ns, stderr); |
129 |
#endif |
130 |
addvirtuals(ns, n); |
131 |
132 |
133 |
134 |
135 |
OBJREC * |
136 |
vsmaterial( /* get virtual source material pointer */ |
137 |
OBJREC *o |
138 |
139 |
140 |
int i; |
141 |
OBJREC *m; |
142 |
143 |
i = o->omod; |
144 |
m = findmaterial(objptr(i)); |
145 |
if (m == NULL) |
146 |
return(objptr(i)); |
147 |
if (m->otype != MAT_ILLUM || m->oargs.nsargs < 1 || |
148 |
!strcmp(m->oargs.sarg[0], VOIDID) || |
149 |
(i = lastmod(objndx(m), m->oargs.sarg[0])) == OVOID) |
150 |
return(m); /* direct modifier */ |
151 |
return(objptr(i)); /* illum alternate */ |
152 |
153 |
154 |
155 |
int |
156 |
makevsrc( /* make virtual source if reasonable */ |
157 |
OBJREC *op, |
158 |
int sn, |
159 |
MAT4 pm |
160 |
161 |
162 |
FVECT nsloc, nsnorm, ocent, v; |
163 |
double maxrad2, d; |
164 |
int nsflags; |
165 |
SPOT theirspot, ourspot; |
166 |
int i; |
167 |
/* check for no-op */ |
168 |
if (isident4(pm)) |
169 |
return(0); |
170 |
nsflags = source[sn].sflags | (SVIRTUAL|SSPOT|SFOLLOW); |
171 |
/* get object center and max. radius */ |
172 |
maxrad2 = getdisk(ocent, op, sn); |
173 |
if (maxrad2 <= FTINY) /* too small? */ |
174 |
return(-1); |
175 |
/* get location and spot */ |
176 |
if (source[sn].sflags & SDISTANT) { /* distant source */ |
177 |
if (source[sn].sflags & SPROX) |
178 |
return(-1); /* should never get here! */ |
179 |
multv3(nsloc, source[sn].sloc, pm); |
180 |
normalize(nsloc); |
181 |
VCOPY(ourspot.aim, ocent); |
182 |
ourspot.siz = PI*maxrad2; |
183 |
ourspot.flen = -1.; |
184 |
if (source[sn].sflags & SSPOT) { |
185 |
multp3(theirspot.aim, source[sn].sl.s->aim, pm); |
186 |
/* adjust for source size */ |
187 |
d = sqrt(dist2(ourspot.aim, theirspot.aim)); |
188 |
d = sqrt(source[sn].sl.s->siz/PI) + d*source[sn].srad; |
189 |
theirspot.siz = PI*d*d; |
190 |
ourspot.flen = theirspot.flen = source[sn].sl.s->flen; |
191 |
d = ourspot.siz; |
192 |
if (!commonbeam(&ourspot, &theirspot, nsloc)) |
193 |
return(-1); /* no overlap */ |
194 |
if (ourspot.siz < d-FTINY) { /* it shrunk */ |
195 |
d = beamdisk(v, op, &ourspot, nsloc); |
196 |
if (d <= FTINY) |
197 |
return(-1); |
198 |
if (d < maxrad2) { |
199 |
maxrad2 = d; |
200 |
VCOPY(ocent, v); |
201 |
202 |
203 |
204 |
} else { /* local source */ |
205 |
multp3(nsloc, source[sn].sloc, pm); |
206 |
for (i = 0; i < 3; i++) |
207 |
ourspot.aim[i] = ocent[i] - nsloc[i]; |
208 |
if ((d = normalize(ourspot.aim)) == 0.) |
209 |
return(-1); /* at source!! */ |
210 |
if (source[sn].sflags & SPROX && d > source[sn].sl.prox) |
211 |
return(-1); /* too far away */ |
212 |
ourspot.flen = 0.; |
213 |
214 |
d = (sqrt(maxrad2) + source[sn].srad) / d; |
215 |
if (d < 1.-FTINY) |
216 |
ourspot.siz = 2.*PI*(1. - sqrt(1.-d*d)); |
217 |
else |
218 |
nsflags &= ~SSPOT; |
219 |
220 |
theirspot = *(source[sn].sl.s); |
221 |
multv3(theirspot.aim, source[sn].sl.s->aim, pm); |
222 |
normalize(theirspot.aim); |
223 |
if (nsflags & SSPOT) { |
224 |
ourspot.flen = theirspot.flen; |
225 |
d = ourspot.siz; |
226 |
if (!commonspot(&ourspot, &theirspot, nsloc)) |
227 |
228 |
} else { |
229 |
nsflags |= SSPOT; |
230 |
ourspot = theirspot; |
231 |
d = 2.*ourspot.siz; |
232 |
233 |
234 |
d = spotdisk(v, op, &ourspot, nsloc); |
235 |
if (d <= FTINY) |
236 |
return(-1); |
237 |
238 |
maxrad2 = d; |
239 |
VCOPY(ocent, v); |
240 |
241 |
242 |
243 |
if (source[sn].sflags & SFLAT) { /* behind source? */ |
244 |
multv3(nsnorm, source[sn].snorm, pm); |
245 |
normalize(nsnorm); |
246 |
if (nsflags & SSPOT && !checkspot(&ourspot, nsnorm)) |
247 |
return(-1); |
248 |
249 |
250 |
/* pretest visibility */ |
251 |
nsflags = vstestvis(nsflags, op, ocent, maxrad2, sn); |
252 |
if (nsflags & SSKIP) |
253 |
return(-1); /* obstructed */ |
254 |
/* it all checks out, so make it */ |
255 |
if ((i = newsource()) < 0) |
256 |
goto memerr; |
257 |
source[i].sflags = nsflags; |
258 |
VCOPY(source[i].sloc, nsloc); |
259 |
multv3(source[i].ss[SU], source[sn].ss[SU], pm); |
260 |
multv3(source[i].ss[SV], source[sn].ss[SV], pm); |
261 |
if (nsflags & SFLAT) |
262 |
VCOPY(source[i].snorm, nsnorm); |
263 |
else |
264 |
multv3(source[i].ss[SW], source[sn].ss[SW], pm); |
265 |
source[i].srad = source[sn].srad; |
266 |
source[i].ss2 = source[sn].ss2; |
267 |
268 |
if ((source[i].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) |
269 |
goto memerr; |
270 |
*(source[i].sl.s) = ourspot; |
271 |
272 |
if (nsflags & SPROX) |
273 |
source[i].sl.prox = source[sn].sl.prox; |
274 |
source[i].sa.sv.sn = sn; |
275 |
source[i].so = op; |
276 |
return(i); |
277 |
memerr: |
278 |
error(SYSTEM, "out of memory in makevsrc"); |
279 |
return -1; /* pro forma return */ |
280 |
281 |
282 |
283 |
double |
284 |
getdisk( /* get visible object disk */ |
285 |
FVECT oc, |
286 |
OBJREC *op, |
287 |
int sn |
288 |
289 |
290 |
double rad2, roffs, offs, d, rd, rdoto; |
291 |
FVECT rnrm, nrm; |
292 |
/* first, use object getdisk function */ |
293 |
rad2 = getmaxdisk(oc, op); |
294 |
if (!(source[sn].sflags & SVIRTUAL)) |
295 |
return(rad2); /* all done for normal source */ |
296 |
/* check for correct side of relay surface */ |
297 |
roffs = getplaneq(rnrm, source[sn].so); |
298 |
rd = DOT(rnrm, source[sn].sloc); /* source projection */ |
299 |
if (!(source[sn].sflags & SDISTANT)) |
300 |
rd -= roffs; |
301 |
d = DOT(rnrm, oc) - roffs; /* disk distance to relay plane */ |
302 |
if ((d > 0.) ^ (rd > 0.)) |
303 |
return(rad2); /* OK if opposite sides */ |
304 |
if (d*d >= rad2) |
305 |
return(0.); /* no relay is possible */ |
306 |
/* we need a closer look */ |
307 |
offs = getplaneq(nrm, op); |
308 |
rdoto = DOT(rnrm, nrm); |
309 |
if (d*d >= rad2*(1.-rdoto*rdoto)) |
310 |
return(0.); /* disk entirely on projection side */ |
311 |
/* should shrink disk but I'm lazy */ |
312 |
return(rad2); |
313 |
314 |
315 |
316 |
int |
317 |
vstestvis( /* pretest source visibility */ |
318 |
int f, /* virtual source flags */ |
319 |
OBJREC *o, /* relay object */ |
320 |
FVECT oc, /* relay object center */ |
321 |
double or2, /* relay object radius squared */ |
322 |
int sn /* target source number */ |
323 |
324 |
325 |
RAY sr; |
326 |
FVECT onorm; |
327 |
double offsdir[3]; |
328 |
SRCINDEX si; |
329 |
double or, d, d1; |
330 |
int stestlim, ssn; |
331 |
int nhit, nok; |
332 |
int i, n; |
333 |
/* return if pretesting disabled */ |
334 |
if (vspretest <= 0) |
335 |
return(f); |
336 |
/* get surface normal */ |
337 |
getplaneq(onorm, o); |
338 |
/* set number of rays to sample */ |
339 |
if (source[sn].sflags & SDISTANT) { |
340 |
/* 32. == heuristic constant */ |
341 |
n = 32.*or2/(thescene.cusize*thescene.cusize)*vspretest + .5; |
342 |
} else { |
343 |
VSUB(offsdir, source[sn].sloc, oc); |
344 |
d = DOT(offsdir,offsdir); |
345 |
if (d <= FTINY) |
346 |
n = 2.*PI * vspretest + .5; |
347 |
else |
348 |
n = 2.*PI * (1.-sqrt(1./(1.+or2/d)))*vspretest + .5; |
349 |
350 |
if (n < MINSAMPLES) n = MINSAMPLES; |
351 |
#ifdef DEBUG |
352 |
fprintf(stderr, "pretesting source %d in object %s with %d rays\n", |
353 |
sn, o->oname, n); |
354 |
#endif |
355 |
/* sample */ |
356 |
or = sqrt(or2); |
357 |
stestlim = n*STESTMAX; |
358 |
ssn = 0; |
359 |
nhit = nok = 0; |
360 |
initsrcindex(&si); |
361 |
while (n-- > 0) { |
362 |
/* get sample point */ |
363 |
do { |
364 |
if (ssn >= stestlim) { |
365 |
#ifdef DEBUG |
366 |
fprintf(stderr, "\ttoo hard to hit\n"); |
367 |
#endif |
368 |
return(f); /* too small a target! */ |
369 |
370 |
multisamp(offsdir, 3, urand(sn*931+5827+ssn)); |
371 |
372 |
offsdir[i] = or*(1. - 2.*offsdir[i]); |
373 |
ssn++; |
374 |
d = 1. - DOT(offsdir, onorm); |
375 |
for (i = 0; i < 3; i++) { |
376 |
sr.rorg[i] = oc[i] + offsdir[i] + d*onorm[i]; |
377 |
sr.rdir[i] = -onorm[i]; |
378 |
379 |
rayorigin(&sr, PRIMARY, NULL, NULL); |
380 |
} while (!(*ofun[o->otype].funp)(o, &sr)); |
381 |
/* check against source */ |
382 |
VCOPY(sr.rorg, sr.rop); /* starting from intersection */ |
383 |
samplendx++; |
384 |
if (si.sp >= si.np-1 || |
385 |
!srcray(&sr, NULL, &si) || sr.rsrc != sn) { |
386 |
si.sn = sn-1; /* reset index to our source */ |
387 |
si.np = 0; |
388 |
if (!srcray(&sr, NULL, &si) || sr.rsrc != sn) |
389 |
continue; /* can't get there from here */ |
390 |
391 |
sr.revf = srcvalue; |
392 |
rayvalue(&sr); /* check sample validity */ |
393 |
if ((d = bright(sr.rcol)) <= FTINY) |
394 |
continue; |
395 |
nok++; /* got sample; check obstructions */ |
396 |
rayclear(&sr); |
397 |
sr.revf = raytrace; |
398 |
rayvalue(&sr); |
399 |
if ((d1 = bright(sr.rcol)) > FTINY) { |
400 |
if (d - d1 > FTINY) { |
401 |
#ifdef DEBUG |
402 |
fprintf(stderr, "\tpartially shadowed\n"); |
403 |
#endif |
404 |
return(f); /* intervening transmitter */ |
405 |
406 |
nhit++; |
407 |
408 |
if (nhit > 0 && nhit < nok) { |
409 |
#ifdef DEBUG |
410 |
fprintf(stderr, "\tpartially occluded\n"); |
411 |
#endif |
412 |
return(f); /* need to shadow test */ |
413 |
414 |
415 |
if (nhit == 0) { |
416 |
#ifdef DEBUG |
417 |
fprintf(stderr, "\t0%% hit rate\n"); |
418 |
#endif |
419 |
return(f | SSKIP); /* 0% hit rate: totally occluded */ |
420 |
421 |
#ifdef DEBUG |
422 |
fprintf(stderr, "\t100%% hit rate\n"); |
423 |
#endif |
424 |
return(f & ~SFOLLOW); /* 100% hit rate: no occlusion */ |
425 |
426 |
427 |
428 |
#ifdef DEBUG |
429 |
void |
430 |
virtverb( /* print verbose description of virtual source */ |
431 |
int sn, |
432 |
FILE *fp |
433 |
434 |
435 |
fprintf(fp, "%s virtual source %d in %s %s\n", |
436 |
source[sn].sflags & SDISTANT ? "distant" : "local", |
437 |
sn, ofun[source[sn].so->otype].funame, |
438 |
source[sn].so->oname); |
439 |
fprintf(fp, "\tat (%f,%f,%f)\n", |
440 |
source[sn].sloc[0], source[sn].sloc[1], source[sn].sloc[2]); |
441 |
fprintf(fp, "\tlinked to source %d (%s)\n", |
442 |
source[sn].sa.sv.sn, source[source[sn].sa.sv.sn].so->oname); |
443 |
if (source[sn].sflags & SFOLLOW) |
444 |
fprintf(fp, "\talways followed\n"); |
445 |
else |
446 |
fprintf(fp, "\tnever followed\n"); |
447 |
if (!(source[sn].sflags & SSPOT)) |
448 |
return; |
449 |
fprintf(fp, "\twith spot aim (%f,%f,%f) and size %f\n", |
450 |
source[sn].sl.s->aim[0], source[sn].sl.s->aim[1], |
451 |
source[sn].sl.s->aim[2], source[sn].sl.s->siz); |
452 |
453 |
#endif |
