1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for simulating virtual light sources |
9 |
* Thus far, we only support planar mirrors. |
10 |
11 |
12 |
#include "ray.h" |
13 |
14 |
#include "octree.h" |
15 |
16 |
#include "otypes.h" |
17 |
18 |
#include "source.h" |
19 |
20 |
#include "random.h" |
21 |
22 |
23 |
#define DISKTFRAC 0.25 /* disk area pretest fraction */ |
24 |
25 |
double getdisk(); |
26 |
27 |
static OBJECT *vobject; /* virtual source objects */ |
28 |
static int nvobjects = 0; /* number of virtual source objects */ |
29 |
30 |
31 |
markvirtuals() /* find and mark virtual sources */ |
32 |
33 |
register OBJREC *o; |
34 |
register int i; |
35 |
/* check number of direct relays */ |
36 |
if (directrelay <= 0) |
37 |
return; |
38 |
/* find virtual source objects */ |
39 |
for (i = 0; i < nobjects; i++) { |
40 |
o = objptr(i); |
41 |
if (!issurface(o->otype) || o->omod == OVOID) |
42 |
continue; |
43 |
if (!isvlight(objptr(o->omod)->otype)) |
44 |
continue; |
45 |
if (sfun[o->otype].of == NULL || |
46 |
sfun[o->otype].of->getpleq == NULL) |
47 |
objerror(o, USER, "illegal material"); |
48 |
if (nvobjects == 0) |
49 |
vobject = (OBJECT *)malloc(sizeof(OBJECT)); |
50 |
else |
51 |
vobject = (OBJECT *)realloc((char *)vobject, |
52 |
(unsigned)(nvobjects+1)*sizeof(OBJECT)); |
53 |
if (vobject == NULL) |
54 |
error(SYSTEM, "out of memory in addvirtuals"); |
55 |
vobject[nvobjects++] = i; |
56 |
57 |
58 |
return; |
59 |
#ifdef DEBUG |
60 |
fprintf(stderr, "found %d virtual source objects\n", nvobjects); |
61 |
#endif |
62 |
/* append virtual sources */ |
63 |
for (i = nsources; i-- > 0; ) |
64 |
addvirtuals(i, directrelay); |
65 |
/* done with our object list */ |
66 |
free((char *)vobject); |
67 |
nvobjects = 0; |
68 |
69 |
70 |
71 |
addvirtuals(sn, nr) /* add virtuals associated with source */ |
72 |
int sn; |
73 |
int nr; |
74 |
75 |
register int i; |
76 |
/* check relay limit first */ |
77 |
if (nr <= 0) |
78 |
return; |
79 |
if (source[sn].sflags & SSKIP) |
80 |
return; |
81 |
/* check each virtual object for projection */ |
82 |
for (i = 0; i < nvobjects; i++) |
83 |
/* vproject() calls us recursively */ |
84 |
vproject(objptr(vobject[i]), sn, nr-1); |
85 |
86 |
87 |
88 |
vproject(o, sn, n) /* create projected source(s) if they exist */ |
89 |
OBJREC *o; |
90 |
int sn; |
91 |
int n; |
92 |
93 |
register int i; |
94 |
register VSMATERIAL *vsmat; |
95 |
MAT4 proj; |
96 |
int ns; |
97 |
98 |
if (o == source[sn].so) /* objects cannot project themselves */ |
99 |
return; |
100 |
/* get virtual source material */ |
101 |
vsmat = sfun[objptr(o->omod)->otype].mf; |
102 |
/* project virtual sources */ |
103 |
for (i = 0; i < vsmat->nproj; i++) |
104 |
if ((*vsmat->vproj)(proj, o, &source[sn], i)) |
105 |
if ((ns = makevsrc(o, sn, proj)) >= 0) { |
106 |
#ifdef DEBUG |
107 |
virtverb(ns, stderr); |
108 |
#endif |
109 |
addvirtuals(ns, n); |
110 |
111 |
112 |
113 |
114 |
int |
115 |
makevsrc(op, sn, pm) /* make virtual source if reasonable */ |
116 |
OBJREC *op; |
117 |
register int sn; |
118 |
MAT4 pm; |
119 |
120 |
FVECT nsloc, nsnorm, ocent; |
121 |
double maxrad2; |
122 |
int nsflags; |
123 |
double d1; |
124 |
SPOT theirspot, ourspot; |
125 |
register int i; |
126 |
127 |
nsflags = source[sn].sflags | (SVIRTUAL|SSPOT|SFOLLOW); |
128 |
/* get object center and max. radius */ |
129 |
maxrad2 = getdisk(ocent, op, sn); |
130 |
if (maxrad2 <= FTINY) /* too small? */ |
131 |
return(-1); |
132 |
/* get location and spot */ |
133 |
if (source[sn].sflags & SDISTANT) { /* distant source */ |
134 |
if (source[sn].sflags & SPROX) |
135 |
return(-1); /* should never get here! */ |
136 |
multv3(nsloc, source[sn].sloc, pm); |
137 |
VCOPY(ourspot.aim, ocent); |
138 |
ourspot.siz = PI*maxrad2; |
139 |
ourspot.flen = 0.; |
140 |
if (source[sn].sflags & SSPOT) { |
141 |
copystruct(&theirspot, source[sn].sl.s); |
142 |
multp3(theirspot.aim, source[sn].sl.s->aim, pm); |
143 |
if (!commonbeam(&ourspot, &theirspot, nsloc)) |
144 |
return(-1); /* no overlap */ |
145 |
146 |
} else { /* local source */ |
147 |
multp3(nsloc, source[sn].sloc, pm); |
148 |
for (i = 0; i < 3; i++) |
149 |
ourspot.aim[i] = ocent[i] - nsloc[i]; |
150 |
if ((d1 = normalize(ourspot.aim)) == 0.) |
151 |
return(-1); /* at source!! */ |
152 |
if (source[sn].sflags & SPROX && d1 > source[sn].sl.prox) |
153 |
return(-1); /* too far away */ |
154 |
ourspot.siz = 2.*PI*(1. - d1/sqrt(d1*d1+maxrad2)); |
155 |
156 |
157 |
158 |
multv3(theirspot.aim, source[sn].sl.s->aim, pm); |
159 |
if (!commonspot(&ourspot, &theirspot, nsloc)) |
160 |
161 |
ourspot.flen = theirspot.flen; |
162 |
163 |
if (source[sn].sflags & SFLAT) { /* behind source? */ |
164 |
multv3(nsnorm, source[sn].snorm, pm); |
165 |
if (checkspot(&ourspot, nsnorm) < 0) |
166 |
return(-1); |
167 |
168 |
169 |
/* pretest visibility */ |
170 |
nsflags = vstestvis(nsflags, op, ocent, maxrad2, sn); |
171 |
if (nsflags & SSKIP) |
172 |
return(-1); /* obstructed */ |
173 |
/* it all checks out, so make it */ |
174 |
if ((i = newsource()) < 0) |
175 |
goto memerr; |
176 |
source[i].sflags = nsflags; |
177 |
VCOPY(source[i].sloc, nsloc); |
178 |
if (nsflags & SFLAT) |
179 |
VCOPY(source[i].snorm, nsnorm); |
180 |
source[i].ss = source[sn].ss; source[i].ss2 = source[sn].ss2; |
181 |
if ((source[i].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) |
182 |
goto memerr; |
183 |
copystruct(source[i].sl.s, &ourspot); |
184 |
if (nsflags & SPROX) |
185 |
source[i].sl.prox = source[sn].sl.prox; |
186 |
source[i].sa.svnext = sn; |
187 |
source[i].so = op; |
188 |
return(i); |
189 |
memerr: |
190 |
error(SYSTEM, "out of memory in makevsrc"); |
191 |
192 |
193 |
194 |
double |
195 |
getdisk(oc, op, sn) /* get visible object disk */ |
196 |
FVECT oc; |
197 |
OBJREC *op; |
198 |
register int sn; |
199 |
200 |
double rad2, roffs, offs, d, rd, rdoto; |
201 |
FVECT rnrm, nrm; |
202 |
/* first, use object getdisk function */ |
203 |
rad2 = (*sfun[op->otype].of->getdisk)(oc, op); |
204 |
if (!(source[sn].sflags & SVIRTUAL)) |
205 |
return(rad2); /* all done for normal source */ |
206 |
/* check for correct side of relay surface */ |
207 |
roffs = (*sfun[source[sn].so->otype].of->getpleq)(rnrm, source[sn].so); |
208 |
rd = DOT(rnrm, source[sn].sloc); /* source projection */ |
209 |
if (!(source[sn].sflags & SDISTANT)) |
210 |
rd -= roffs; |
211 |
d = DOT(rnrm, oc) - roffs; /* disk distance to relay plane */ |
212 |
if ((d > 0.) ^ (rd > 0.)) |
213 |
return(rad2); /* OK if opposite sides */ |
214 |
if (d*d >= rad2) |
215 |
return(.0); /* no relay is possible */ |
216 |
/* we need a closer look */ |
217 |
offs = (*sfun[op->otype].of->getpleq)(nrm, op); |
218 |
rdoto = DOT(rnrm, nrm); |
219 |
if (d*d >= rad2*(1.-rdoto*rdoto)) |
220 |
return(0.); /* disk entirely on projection side */ |
221 |
/* should shrink disk but I'm lazy */ |
222 |
return(rad2); |
223 |
224 |
225 |
226 |
int |
227 |
vstestvis(f, o, oc, or2, sn) /* pretest source visibility */ |
228 |
int f; /* virtual source flags */ |
229 |
OBJREC *o; /* relay object */ |
230 |
FVECT oc; /* relay object center */ |
231 |
double or2; /* relay object radius squared */ |
232 |
register int sn; /* target source number */ |
233 |
234 |
RAY sr; |
235 |
FVECT onorm; |
236 |
FVECT offsdir; |
237 |
double or, d; |
238 |
int nok, nhit; |
239 |
register int i, n; |
240 |
/* return if pretesting disabled */ |
241 |
if (vspretest <= 0) |
242 |
return(f); |
243 |
/* get surface normal */ |
244 |
(*sfun[o->otype].of->getpleq)(onorm, o); |
245 |
/* set number of rays to sample */ |
246 |
if (source[sn].sflags & SDISTANT) |
247 |
n = (2./3.*PI*PI)*or2/(thescene.cusize*thescene.cusize)* |
248 |
vspretest + .5; |
249 |
else |
250 |
n = or2/dist2(oc,source[sn].sloc)*vspretest + .5; |
251 |
if (n < 1) n = 1; |
252 |
/* limit tests to central region */ |
253 |
or = DISKTFRAC*sqrt(or2); |
254 |
/* sample */ |
255 |
nhit = nok = 0; |
256 |
while (n-- > 0) { |
257 |
samplendx++; |
258 |
259 |
* We're being real sloppy with our sample locations here. |
260 |
261 |
262 |
offsdir[i] = or*(1. - 2.*urand(931*i+5821+n)); |
263 |
d = DOT(offsdir,onorm); |
264 |
265 |
sr.rorg[i] = oc[i] + (1.-d)*offsdir[i]; |
266 |
/* check against source */ |
267 |
if (srcray(&sr, NULL, sn) == 0.0) |
268 |
continue; |
269 |
sr.revf = srcvalue; |
270 |
rayvalue(&sr); |
271 |
if (bright(sr.rcol) <= FTINY) |
272 |
continue; |
273 |
nok++; |
274 |
/* check against obstructions */ |
275 |
srcray(&sr, NULL, sn); |
276 |
rayvalue(&sr); |
277 |
278 |
continue; |
279 |
nhit++; |
280 |
281 |
/* interpret results */ |
282 |
if (nhit == 0) |
283 |
return(f | SSKIP); /* 0% hit rate: totally occluded */ |
284 |
if (nhit == nok) |
285 |
return(f & ~SFOLLOW); /* 100% hit rate: no occlusion */ |
286 |
return(f); /* no comment */ |
287 |
288 |
289 |
290 |
#ifdef DEBUG |
291 |
virtverb(sn, fp) /* print verbose description of virtual source */ |
292 |
register int sn; |
293 |
FILE *fp; |
294 |
295 |
register int i; |
296 |
297 |
fprintf(fp, "%s virtual source %d in %s %s\n", |
298 |
source[sn].sflags & SDISTANT ? "distant" : "local", |
299 |
sn, ofun[source[sn].so->otype].funame, |
300 |
source[sn].so->oname); |
301 |
fprintf(fp, "\tat (%f,%f,%f)\n", |
302 |
source[sn].sloc[0], source[sn].sloc[1], source[sn].sloc[2]); |
303 |
fprintf(fp, "\tlinked to source %d (%s)\n", |
304 |
source[sn].sa.svnext, source[source[sn].sa.svnext].so->oname); |
305 |
if (source[sn].sflags & SFOLLOW) |
306 |
fprintf(fp, "\talways followed\n"); |
307 |
else |
308 |
fprintf(fp, "\tnever followed\n"); |
309 |
if (!(source[sn].sflags & SSPOT)) |
310 |
return; |
311 |
fprintf(fp, "\twith spot aim (%f,%f,%f) and size %f\n", |
312 |
source[sn].sl.s->aim[0], source[sn].sl.s->aim[1], |
313 |
source[sn].sl.s->aim[2], source[sn].sl.s->siz); |
314 |
315 |
#endif |
