1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for simulating virtual light sources |
9 |
* Thus far, we only support planar mirrors. |
10 |
11 |
12 |
#include "ray.h" |
13 |
14 |
#include "octree.h" |
15 |
16 |
#include "otypes.h" |
17 |
18 |
#include "source.h" |
19 |
20 |
#include "random.h" |
21 |
22 |
#define MINSAMPLES 5 /* minimum number of pretest samples */ |
23 |
#define STESTMAX 30 /* maximum seeks per sample */ |
24 |
25 |
26 |
double getdisk(); |
27 |
28 |
static OBJECT *vobject; /* virtual source objects */ |
29 |
static int nvobjects = 0; /* number of virtual source objects */ |
30 |
31 |
32 |
markvirtuals() /* find and mark virtual sources */ |
33 |
34 |
register OBJREC *o; |
35 |
register int i; |
36 |
/* check number of direct relays */ |
37 |
if (directrelay <= 0) |
38 |
return; |
39 |
/* find virtual source objects */ |
40 |
for (i = 0; i < nobjects; i++) { |
41 |
o = objptr(i); |
42 |
if (!issurface(o->otype) || o->omod == OVOID) |
43 |
continue; |
44 |
if (!isvlight(objptr(o->omod)->otype)) |
45 |
continue; |
46 |
if (sfun[o->otype].of == NULL || |
47 |
sfun[o->otype].of->getpleq == NULL) |
48 |
objerror(o, USER, "illegal material"); |
49 |
if (nvobjects == 0) |
50 |
vobject = (OBJECT *)malloc(sizeof(OBJECT)); |
51 |
else |
52 |
vobject = (OBJECT *)realloc((char *)vobject, |
53 |
(unsigned)(nvobjects+1)*sizeof(OBJECT)); |
54 |
if (vobject == NULL) |
55 |
error(SYSTEM, "out of memory in addvirtuals"); |
56 |
vobject[nvobjects++] = i; |
57 |
58 |
59 |
return; |
60 |
#ifdef DEBUG |
61 |
fprintf(stderr, "found %d virtual source objects\n", nvobjects); |
62 |
#endif |
63 |
/* append virtual sources */ |
64 |
for (i = nsources; i-- > 0; ) |
65 |
addvirtuals(i, directrelay); |
66 |
/* done with our object list */ |
67 |
free((char *)vobject); |
68 |
nvobjects = 0; |
69 |
70 |
71 |
72 |
addvirtuals(sn, nr) /* add virtuals associated with source */ |
73 |
int sn; |
74 |
int nr; |
75 |
76 |
register int i; |
77 |
/* check relay limit first */ |
78 |
if (nr <= 0) |
79 |
return; |
80 |
if (source[sn].sflags & SSKIP) |
81 |
return; |
82 |
/* check each virtual object for projection */ |
83 |
for (i = 0; i < nvobjects; i++) |
84 |
/* vproject() calls us recursively */ |
85 |
vproject(objptr(vobject[i]), sn, nr-1); |
86 |
87 |
88 |
89 |
vproject(o, sn, n) /* create projected source(s) if they exist */ |
90 |
OBJREC *o; |
91 |
int sn; |
92 |
int n; |
93 |
94 |
register int i; |
95 |
register VSMATERIAL *vsmat; |
96 |
MAT4 proj; |
97 |
int ns; |
98 |
99 |
if (o == source[sn].so) /* objects cannot project themselves */ |
100 |
return; |
101 |
/* get virtual source material */ |
102 |
vsmat = sfun[objptr(o->omod)->otype].mf; |
103 |
/* project virtual sources */ |
104 |
for (i = 0; i < vsmat->nproj; i++) |
105 |
if ((*vsmat->vproj)(proj, o, &source[sn], i)) |
106 |
if ((ns = makevsrc(o, sn, proj)) >= 0) { |
107 |
source[ns].sa.sv.pn = i; |
108 |
#ifdef DEBUG |
109 |
virtverb(ns, stderr); |
110 |
#endif |
111 |
addvirtuals(ns, n); |
112 |
113 |
114 |
115 |
116 |
int |
117 |
makevsrc(op, sn, pm) /* make virtual source if reasonable */ |
118 |
OBJREC *op; |
119 |
register int sn; |
120 |
MAT4 pm; |
121 |
122 |
FVECT nsloc, nsnorm, ocent, v; |
123 |
double maxrad2, d; |
124 |
int nsflags; |
125 |
SPOT theirspot, ourspot; |
126 |
register int i; |
127 |
128 |
nsflags = source[sn].sflags | (SVIRTUAL|SSPOT|SFOLLOW); |
129 |
/* get object center and max. radius */ |
130 |
maxrad2 = getdisk(ocent, op, sn); |
131 |
if (maxrad2 <= FTINY) /* too small? */ |
132 |
return(-1); |
133 |
/* get location and spot */ |
134 |
if (source[sn].sflags & SDISTANT) { /* distant source */ |
135 |
if (source[sn].sflags & SPROX) |
136 |
return(-1); /* should never get here! */ |
137 |
multv3(nsloc, source[sn].sloc, pm); |
138 |
normalize(nsloc); |
139 |
VCOPY(ourspot.aim, ocent); |
140 |
ourspot.siz = PI*maxrad2; |
141 |
ourspot.flen = 0.; |
142 |
if (source[sn].sflags & SSPOT) { |
143 |
copystruct(&theirspot, source[sn].sl.s); |
144 |
multp3(theirspot.aim, source[sn].sl.s->aim, pm); |
145 |
d = ourspot.siz; |
146 |
if (!commonbeam(&ourspot, &theirspot, nsloc)) |
147 |
return(-1); /* no overlap */ |
148 |
if (ourspot.siz < d-FTINY) { /* it shrunk */ |
149 |
d = beamdisk(v, op, &ourspot, nsloc); |
150 |
if (d <= FTINY) |
151 |
return(-1); |
152 |
if (d < maxrad2) { |
153 |
maxrad2 = d; |
154 |
VCOPY(ocent, v); |
155 |
156 |
157 |
158 |
} else { /* local source */ |
159 |
multp3(nsloc, source[sn].sloc, pm); |
160 |
for (i = 0; i < 3; i++) |
161 |
ourspot.aim[i] = ocent[i] - nsloc[i]; |
162 |
if ((d = normalize(ourspot.aim)) == 0.) |
163 |
return(-1); /* at source!! */ |
164 |
if (source[sn].sflags & SPROX && d > source[sn].sl.prox) |
165 |
return(-1); /* too far away */ |
166 |
167 |
if (d*d > maxrad2) |
168 |
ourspot.siz = 2.*PI*(1. - sqrt(1.-maxrad2/(d*d))); |
169 |
else |
170 |
nsflags &= ~SSPOT; |
171 |
172 |
173 |
multv3(theirspot.aim, source[sn].sl.s->aim, pm); |
174 |
normalize(theirspot.aim); |
175 |
if (nsflags & SSPOT) { |
176 |
ourspot.flen = theirspot.flen; |
177 |
d = ourspot.siz; |
178 |
if (!commonspot(&ourspot, &theirspot, nsloc)) |
179 |
180 |
} else { |
181 |
nsflags |= SSPOT; |
182 |
copystruct(&ourspot, &theirspot); |
183 |
d = 2.*ourspot.siz; |
184 |
185 |
186 |
d = spotdisk(v, op, &ourspot, nsloc); |
187 |
if (d <= FTINY) |
188 |
return(-1); |
189 |
190 |
maxrad2 = d; |
191 |
VCOPY(ocent, v); |
192 |
193 |
194 |
195 |
if (source[sn].sflags & SFLAT) { /* behind source? */ |
196 |
multv3(nsnorm, source[sn].snorm, pm); |
197 |
normalize(nsnorm); |
198 |
if (!checkspot(&ourspot, nsnorm)) |
199 |
return(-1); |
200 |
201 |
202 |
/* pretest visibility */ |
203 |
nsflags = vstestvis(nsflags, op, ocent, maxrad2, sn); |
204 |
if (nsflags & SSKIP) |
205 |
return(-1); /* obstructed */ |
206 |
/* it all checks out, so make it */ |
207 |
if ((i = newsource()) < 0) |
208 |
goto memerr; |
209 |
source[i].sflags = nsflags; |
210 |
VCOPY(source[i].sloc, nsloc); |
211 |
if (nsflags & SFLAT) |
212 |
VCOPY(source[i].snorm, nsnorm); |
213 |
source[i].ss = source[sn].ss; source[i].ss2 = source[sn].ss2; |
214 |
215 |
if ((source[i].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) |
216 |
goto memerr; |
217 |
copystruct(source[i].sl.s, &ourspot); |
218 |
219 |
if (nsflags & SPROX) |
220 |
source[i].sl.prox = source[sn].sl.prox; |
221 |
source[i].sa.sv.sn = sn; |
222 |
source[i].so = op; |
223 |
return(i); |
224 |
memerr: |
225 |
error(SYSTEM, "out of memory in makevsrc"); |
226 |
227 |
228 |
229 |
double |
230 |
getdisk(oc, op, sn) /* get visible object disk */ |
231 |
FVECT oc; |
232 |
OBJREC *op; |
233 |
register int sn; |
234 |
235 |
double rad2, roffs, offs, d, rd, rdoto; |
236 |
FVECT rnrm, nrm; |
237 |
/* first, use object getdisk function */ |
238 |
rad2 = getmaxdisk(oc, op); |
239 |
if (!(source[sn].sflags & SVIRTUAL)) |
240 |
return(rad2); /* all done for normal source */ |
241 |
/* check for correct side of relay surface */ |
242 |
roffs = getplaneq(rnrm, source[sn].so); |
243 |
rd = DOT(rnrm, source[sn].sloc); /* source projection */ |
244 |
if (!(source[sn].sflags & SDISTANT)) |
245 |
rd -= roffs; |
246 |
d = DOT(rnrm, oc) - roffs; /* disk distance to relay plane */ |
247 |
if ((d > 0.) ^ (rd > 0.)) |
248 |
return(rad2); /* OK if opposite sides */ |
249 |
if (d*d >= rad2) |
250 |
return(0.); /* no relay is possible */ |
251 |
/* we need a closer look */ |
252 |
offs = getplaneq(nrm, op); |
253 |
rdoto = DOT(rnrm, nrm); |
254 |
if (d*d >= rad2*(1.-rdoto*rdoto)) |
255 |
return(0.); /* disk entirely on projection side */ |
256 |
/* should shrink disk but I'm lazy */ |
257 |
return(rad2); |
258 |
259 |
260 |
261 |
int |
262 |
vstestvis(f, o, oc, or2, sn) /* pretest source visibility */ |
263 |
int f; /* virtual source flags */ |
264 |
OBJREC *o; /* relay object */ |
265 |
FVECT oc; /* relay object center */ |
266 |
double or2; /* relay object radius squared */ |
267 |
register int sn; /* target source number */ |
268 |
269 |
RAY sr; |
270 |
FVECT onorm; |
271 |
FVECT offsdir; |
272 |
double or, d; |
273 |
int infront; |
274 |
int stestlim, ssn; |
275 |
int nhit, nok; |
276 |
register int i, n; |
277 |
/* return if pretesting disabled */ |
278 |
if (vspretest <= 0) |
279 |
return(f); |
280 |
/* get surface normal */ |
281 |
getplaneq(onorm, o); |
282 |
/* set number of rays to sample */ |
283 |
if (source[sn].sflags & SDISTANT) { |
284 |
n = (2./3.*PI*PI)*or2/(thescene.cusize*thescene.cusize)* |
285 |
vspretest + .5; |
286 |
infront = DOT(onorm, source[sn].sloc) > 0.; |
287 |
} else { |
288 |
289 |
offsdir[i] = source[sn].sloc[i] - oc[i]; |
290 |
n = or2/DOT(offsdir,offsdir)*vspretest + .5; |
291 |
infront = DOT(onorm, offsdir) > 0.; |
292 |
293 |
if (n < MINSAMPLES) n = MINSAMPLES; |
294 |
#ifdef DEBUG |
295 |
fprintf(stderr, "pretesting source %d in object %s with %d rays\n", |
296 |
sn, o->oname, n); |
297 |
#endif |
298 |
/* sample */ |
299 |
or = sqrt(or2); |
300 |
stestlim = n*STESTMAX; |
301 |
ssn = 0; |
302 |
nhit = nok = 0; |
303 |
while (n-- > 0) { |
304 |
/* get sample point */ |
305 |
do { |
306 |
if (ssn >= stestlim) { |
307 |
#ifdef DEBUG |
308 |
fprintf(stderr, "\ttoo hard to hit\n"); |
309 |
#endif |
310 |
return(f); /* too small a target! */ |
311 |
312 |
313 |
offsdir[i] = or*(1. - |
314 |
2.*urand(urind(931*i+5827,ssn))); |
315 |
ssn++; |
316 |
317 |
sr.rorg[i] = oc[i] + offsdir[i]; |
318 |
d = DOT(offsdir,onorm); |
319 |
if (infront) |
320 |
for (i = 0; i < 3; i++) { |
321 |
sr.rorg[i] -= (d-.0001)*onorm[i]; |
322 |
sr.rdir[i] = -onorm[i]; |
323 |
324 |
else |
325 |
326 |
sr.rorg[i] -= (d+.0001)*onorm[i]; |
327 |
sr.rdir[i] = onorm[i]; |
328 |
329 |
rayorigin(&sr, NULL, PRIMARY, 1.0); |
330 |
} while (!(*ofun[o->otype].funp)(o, &sr)); |
331 |
/* check against source */ |
332 |
samplendx++; |
333 |
if (srcray(&sr, NULL, sn) == 0.) |
334 |
continue; |
335 |
sr.revf = srcvalue; |
336 |
rayvalue(&sr); |
337 |
if (bright(sr.rcol) <= FTINY) |
338 |
continue; |
339 |
nok++; |
340 |
/* check against obstructions */ |
341 |
srcray(&sr, NULL, sn); |
342 |
rayvalue(&sr); |
343 |
if (bright(sr.rcol) > FTINY) |
344 |
nhit++; |
345 |
if (nhit > 0 && nhit < nok) { |
346 |
#ifdef DEBUG |
347 |
fprintf(stderr, "\tpartially occluded\n"); |
348 |
#endif |
349 |
return(f); /* need to shadow test */ |
350 |
351 |
352 |
if (nhit == 0) { |
353 |
#ifdef DEBUG |
354 |
fprintf(stderr, "\t0%% hit rate\n"); |
355 |
#endif |
356 |
return(f | SSKIP); /* 0% hit rate: totally occluded */ |
357 |
358 |
#ifdef DEBUG |
359 |
fprintf(stderr, "\t100%% hit rate\n"); |
360 |
#endif |
361 |
return(f & ~SFOLLOW); /* 100% hit rate: no occlusion */ |
362 |
363 |
364 |
365 |
#ifdef DEBUG |
366 |
virtverb(sn, fp) /* print verbose description of virtual source */ |
367 |
register int sn; |
368 |
FILE *fp; |
369 |
370 |
register int i; |
371 |
372 |
fprintf(fp, "%s virtual source %d in %s %s\n", |
373 |
source[sn].sflags & SDISTANT ? "distant" : "local", |
374 |
sn, ofun[source[sn].so->otype].funame, |
375 |
source[sn].so->oname); |
376 |
fprintf(fp, "\tat (%f,%f,%f)\n", |
377 |
source[sn].sloc[0], source[sn].sloc[1], source[sn].sloc[2]); |
378 |
fprintf(fp, "\tlinked to source %d (%s)\n", |
379 |
source[sn].sa.sv.sn, source[source[sn].sa.sv.sn].so->oname); |
380 |
if (source[sn].sflags & SFOLLOW) |
381 |
fprintf(fp, "\talways followed\n"); |
382 |
else |
383 |
fprintf(fp, "\tnever followed\n"); |
384 |
if (!(source[sn].sflags & SSPOT)) |
385 |
return; |
386 |
fprintf(fp, "\twith spot aim (%f,%f,%f) and size %f\n", |
387 |
source[sn].sl.s->aim[0], source[sn].sl.s->aim[1], |
388 |
source[sn].sl.s->aim[2], source[sn].sl.s->siz); |
389 |
390 |
#endif |
