--- ray/src/rt/virtuals.c 1991/06/25 13:29:22 1.10 +++ ray/src/rt/virtuals.c 2021/02/12 00:41:19 2.25 @@ -1,52 +1,66 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: virtuals.c,v 2.25 2021/02/12 00:41:19 greg Exp $"; #endif - /* * Routines for simulating virtual light sources * Thus far, we only support planar mirrors. + * + * External symbols declared in source.h */ -#include "ray.h" +#include "copyright.h" -#include "octree.h" - +#include "ray.h" #include "otypes.h" - +#include "otspecial.h" #include "source.h" - #include "random.h" +#define MINSAMPLES 16 /* minimum number of pretest samples */ +#define STESTMAX 32 /* maximum seeks per sample */ -double getdisk(); static OBJECT *vobject; /* virtual source objects */ static int nvobjects = 0; /* number of virtual source objects */ -markvirtuals() /* find and mark virtual sources */ +static int +isident4(MAT4 m) { - register OBJREC *o; - register int i; + int i, j; + + for (i = 4; i--; ) + for (j = 4; j--; ) + if (!FABSEQ(m[i][j], i==j)) + return(0); + return(1); +} + + +void +markvirtuals(void) /* find and mark virtual sources */ +{ + OBJREC *o; + int i; /* check number of direct relays */ if (directrelay <= 0) return; /* find virtual source objects */ - for (i = 0; i < nobjects; i++) { + for (i = 0; i < nsceneobjs; i++) { o = objptr(i); if (!issurface(o->otype) || o->omod == OVOID) continue; - if (!isvlight(objptr(o->omod)->otype)) + if (!isvlight(vsmaterial(o)->otype)) continue; if (sfun[o->otype].of == NULL || - sfun[o->otype].of->getpleq == NULL) - objerror(o, USER, "illegal material"); + sfun[o->otype].of->getpleq == NULL) { + objerror(o,WARNING,"secondary sources not supported"); + continue; + } if (nvobjects == 0) vobject = (OBJECT *)malloc(sizeof(OBJECT)); else - vobject = (OBJECT *)realloc((char *)vobject, + vobject = (OBJECT *)realloc((void *)vobject, (unsigned)(nvobjects+1)*sizeof(OBJECT)); if (vobject == NULL) error(SYSTEM, "out of memory in addvirtuals"); @@ -61,16 +75,18 @@ markvirtuals() /* find and mark virtual sources */ for (i = nsources; i-- > 0; ) addvirtuals(i, directrelay); /* done with our object list */ - free((char *)vobject); + free((void *)vobject); nvobjects = 0; } -addvirtuals(sn, nr) /* add virtuals associated with source */ -int sn; -int nr; +void +addvirtuals( /* add virtuals associated with source */ + int sn, + int nr +) { - register int i; + int i; /* check relay limit first */ if (nr <= 0) return; @@ -83,24 +99,27 @@ int nr; } -vproject(o, sn, n) /* create projected source(s) if they exist */ -OBJREC *o; -int sn; -int n; +void +vproject( /* create projected source(s) if they exist */ + OBJREC *o, + int sn, + int n +) { - register int i; - register VSMATERIAL *vsmat; + int i; + VSMATERIAL *vsmat; MAT4 proj; int ns; if (o == source[sn].so) /* objects cannot project themselves */ return; /* get virtual source material */ - vsmat = sfun[objptr(o->omod)->otype].mf; + vsmat = sfun[vsmaterial(o)->otype].mf; /* project virtual sources */ for (i = 0; i < vsmat->nproj; i++) if ((*vsmat->vproj)(proj, o, &source[sn], i)) if ((ns = makevsrc(o, sn, proj)) >= 0) { + source[ns].sa.sv.pn = i; #ifdef DEBUG virtverb(ns, stderr); #endif @@ -109,18 +128,41 @@ int n; } +OBJREC * +vsmaterial( /* get virtual source material pointer */ + OBJREC *o +) +{ + int i; + OBJREC *m; + + i = o->omod; + m = findmaterial(o); + if (m == NULL) + return(objptr(i)); + if (m->otype != MAT_ILLUM || m->oargs.nsargs < 1 || + !strcmp(m->oargs.sarg[0], VOIDID) || + (i = lastmod(objndx(m), m->oargs.sarg[0])) == OVOID) + return(m); /* direct modifier */ + return(objptr(i)); /* illum alternate */ +} + + int -makevsrc(op, sn, pm) /* make virtual source if reasonable */ -OBJREC *op; -register int sn; -MAT4 pm; +makevsrc( /* make virtual source if reasonable */ + OBJREC *op, + int sn, + MAT4 pm +) { FVECT nsloc, nsnorm, ocent, v; double maxrad2, d; int nsflags; SPOT theirspot, ourspot; - register int i; - + int i; + /* check for no-op */ + if (isident4(pm)) + return(0); nsflags = source[sn].sflags | (SVIRTUAL|SSPOT|SFOLLOW); /* get object center and max. radius */ maxrad2 = getdisk(ocent, op, sn); @@ -131,12 +173,17 @@ MAT4 pm; if (source[sn].sflags & SPROX) return(-1); /* should never get here! */ multv3(nsloc, source[sn].sloc, pm); + normalize(nsloc); VCOPY(ourspot.aim, ocent); ourspot.siz = PI*maxrad2; - ourspot.flen = 0.; + ourspot.flen = -1.; if (source[sn].sflags & SSPOT) { - copystruct(&theirspot, source[sn].sl.s); multp3(theirspot.aim, source[sn].sl.s->aim, pm); + /* adjust for source size */ + d = sqrt(dist2(ourspot.aim, theirspot.aim)); + d = sqrt(source[sn].sl.s->siz/PI) + d*source[sn].srad; + theirspot.siz = PI*d*d; + ourspot.flen = theirspot.flen = source[sn].sl.s->flen; d = ourspot.siz; if (!commonbeam(&ourspot, &theirspot, nsloc)) return(-1); /* no overlap */ @@ -158,14 +205,27 @@ MAT4 pm; return(-1); /* at source!! */ if (source[sn].sflags & SPROX && d > source[sn].sl.prox) return(-1); /* too far away */ - ourspot.siz = 2.*PI*(1. - d/sqrt(d*d+maxrad2)); ourspot.flen = 0.; + /* adjust for source size */ + d = (sqrt(maxrad2) + source[sn].srad) / d; + if (d < 1.-FTINY) + ourspot.siz = 2.*PI*(1. - sqrt(1.-d*d)); + else + nsflags &= ~SSPOT; if (source[sn].sflags & SSPOT) { - copystruct(&theirspot, source[sn].sl.s); + theirspot = *(source[sn].sl.s); multv3(theirspot.aim, source[sn].sl.s->aim, pm); - d = ourspot.siz; - if (!commonspot(&ourspot, &theirspot, nsloc)) - return(-1); /* no overlap */ + normalize(theirspot.aim); + if (nsflags & SSPOT) { + ourspot.flen = theirspot.flen; + d = ourspot.siz; + if (!commonspot(&ourspot, &theirspot, nsloc)) + return(-1); /* no overlap */ + } else { + nsflags |= SSPOT; + ourspot = theirspot; + d = 2.*ourspot.siz; + } if (ourspot.siz < d-FTINY) { /* it shrunk */ d = spotdisk(v, op, &ourspot, nsloc); if (d <= FTINY) @@ -175,11 +235,11 @@ MAT4 pm; VCOPY(ocent, v); } } - ourspot.flen = theirspot.flen; } if (source[sn].sflags & SFLAT) { /* behind source? */ multv3(nsnorm, source[sn].snorm, pm); - if (checkspot(&ourspot, nsnorm) < 0) + normalize(nsnorm); + if (nsflags & SSPOT && !checkspot(&ourspot, nsnorm)) return(-1); } } @@ -192,27 +252,36 @@ MAT4 pm; goto memerr; source[i].sflags = nsflags; VCOPY(source[i].sloc, nsloc); + multv3(source[i].ss[SU], source[sn].ss[SU], pm); + multv3(source[i].ss[SV], source[sn].ss[SV], pm); if (nsflags & SFLAT) VCOPY(source[i].snorm, nsnorm); - source[i].ss = source[sn].ss; source[i].ss2 = source[sn].ss2; - if ((source[i].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) - goto memerr; - copystruct(source[i].sl.s, &ourspot); + else + multv3(source[i].ss[SW], source[sn].ss[SW], pm); + source[i].srad = source[sn].srad; + source[i].ss2 = source[sn].ss2; + if (nsflags & SSPOT) { + if ((source[i].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) + goto memerr; + *(source[i].sl.s) = ourspot; + } if (nsflags & SPROX) source[i].sl.prox = source[sn].sl.prox; - source[i].sa.svnext = sn; + source[i].sa.sv.sn = sn; source[i].so = op; return(i); memerr: error(SYSTEM, "out of memory in makevsrc"); + return -1; /* pro forma return */ } double -getdisk(oc, op, sn) /* get visible object disk */ -FVECT oc; -OBJREC *op; -register int sn; +getdisk( /* get visible object disk */ + FVECT oc, + OBJREC *op, + int sn +) { double rad2, roffs, offs, d, rd, rdoto; FVECT rnrm, nrm; @@ -241,21 +310,22 @@ register int sn; int -vstestvis(f, o, oc, or2, sn) /* pretest source visibility */ -int f; /* virtual source flags */ -OBJREC *o; /* relay object */ -FVECT oc; /* relay object center */ -double or2; /* relay object radius squared */ -register int sn; /* target source number */ +vstestvis( /* pretest source visibility */ + int f, /* virtual source flags */ + OBJREC *o, /* relay object */ + FVECT oc, /* relay object center */ + double or2, /* relay object radius squared */ + int sn /* target source number */ +) { RAY sr; FVECT onorm; - FVECT offsdir; - double or, d; - int infront; - int ssn; - int nhit; - register int i, n; + double offsdir[3]; + SRCINDEX si; + double or, d, d1; + int stestlim, ssn; + int nhit, nok; + int i, n; /* return if pretesting disabled */ if (vspretest <= 0) return(f); @@ -263,71 +333,81 @@ register int sn; /* target source number */ getplaneq(onorm, o); /* set number of rays to sample */ if (source[sn].sflags & SDISTANT) { - n = (2./3.*PI*PI)*or2/(thescene.cusize*thescene.cusize)* - vspretest + .5; - infront = DOT(onorm, source[sn].sloc) > 0.; + /* 32. == heuristic constant */ + n = 32.*or2/(thescene.cusize*thescene.cusize)*vspretest + .5; } else { - for (i = 0; i < 3; i++) - offsdir[i] = source[sn].sloc[i] - oc[i]; - n = or2/DOT(offsdir,offsdir)*vspretest + .5; - infront = DOT(onorm, offsdir) > 0.; + VSUB(offsdir, source[sn].sloc, oc); + d = DOT(offsdir,offsdir); + if (d <= FTINY) + n = 2.*PI * vspretest + .5; + else + n = 2.*PI * (1.-sqrt(1./(1.+or2/d)))*vspretest + .5; } - if (n < 1) n = 1; + if (n < MINSAMPLES) n = MINSAMPLES; #ifdef DEBUG fprintf(stderr, "pretesting source %d in object %s with %d rays\n", sn, o->oname, n); #endif /* sample */ or = sqrt(or2); - ssn = 25*n; - nhit = 0; + stestlim = n*STESTMAX; + ssn = 0; + nhit = nok = 0; + initsrcindex(&si); while (n-- > 0) { /* get sample point */ do { - if (--ssn < 0) { + if (ssn >= stestlim) { #ifdef DEBUG fprintf(stderr, "\ttoo hard to hit\n"); #endif return(f); /* too small a target! */ } + multisamp(offsdir, 3, urand(sn*931+5827+ssn)); for (i = 0; i < 3; i++) - offsdir[i] = or*(1. - - 2.*urand(931*i+5827+ssn)); - for (i = 0; i < 3; i++) - sr.rorg[i] = oc[i] + offsdir[i]; - d = DOT(offsdir,onorm); - if (infront) - for (i = 0; i < 3; i++) { - sr.rorg[i] -= (d-.0001)*onorm[i]; - sr.rdir[i] = -onorm[i]; - } - else - for (i = 0; i < 3; i++) { - sr.rorg[i] -= (d+.0001)*onorm[i]; - sr.rdir[i] = onorm[i]; - } - rayorigin(&sr, NULL, PRIMARY, 1.0); + offsdir[i] = or*(1. - 2.*offsdir[i]); + ssn++; + d = 1. - DOT(offsdir, onorm); + for (i = 0; i < 3; i++) { + sr.rorg[i] = oc[i] + offsdir[i] + d*onorm[i]; + sr.rdir[i] = -onorm[i]; + } + sr.rmax = 0.0; + rayorigin(&sr, PRIMARY, NULL, NULL); } while (!(*ofun[o->otype].funp)(o, &sr)); /* check against source */ + VCOPY(sr.rorg, sr.rop); /* starting from intersection */ samplendx++; - if (srcray(&sr, NULL, sn) == 0.) - continue; + if (si.sp >= si.np-1 || + !srcray(&sr, NULL, &si) || sr.rsrc != sn) { + si.sn = sn-1; /* reset index to our source */ + si.np = 0; + if (!srcray(&sr, NULL, &si) || sr.rsrc != sn) + continue; /* can't get there from here */ + } sr.revf = srcvalue; - rayvalue(&sr); - if (bright(sr.rcol) <= FTINY) + rayvalue(&sr); /* check sample validity */ + if ((d = bright(sr.rcol)) <= FTINY) continue; - /* check against obstructions */ - srcray(&sr, NULL, sn); + nok++; /* got sample; check obstructions */ + rayclear(&sr); + sr.revf = raytrace; rayvalue(&sr); - if (bright(sr.rcol) <= FTINY) { - if (nhit > 0) { + if ((d1 = bright(sr.rcol)) > FTINY) { + if (d - d1 > FTINY) { #ifdef DEBUG - fprintf(stderr, "\tpartially occluded\n"); + fprintf(stderr, "\tpartially shadowed\n"); #endif - return(f); /* need to shadow test */ + return(f); /* intervening transmitter */ } - } else nhit++; + } + if (nhit > 0 && nhit < nok) { +#ifdef DEBUG + fprintf(stderr, "\tpartially occluded\n"); +#endif + return(f); /* need to shadow test */ + } } if (nhit == 0) { #ifdef DEBUG @@ -343,12 +423,12 @@ register int sn; /* target source number */ #ifdef DEBUG -virtverb(sn, fp) /* print verbose description of virtual source */ -register int sn; -FILE *fp; +void +virtverb( /* print verbose description of virtual source */ + int sn, + FILE *fp +) { - register int i; - fprintf(fp, "%s virtual source %d in %s %s\n", source[sn].sflags & SDISTANT ? "distant" : "local", sn, ofun[source[sn].so->otype].funame, @@ -356,7 +436,7 @@ FILE *fp; fprintf(fp, "\tat (%f,%f,%f)\n", source[sn].sloc[0], source[sn].sloc[1], source[sn].sloc[2]); fprintf(fp, "\tlinked to source %d (%s)\n", - source[sn].sa.svnext, source[source[sn].sa.svnext].so->oname); + source[sn].sa.sv.sn, source[source[sn].sa.sv.sn].so->oname); if (source[sn].sflags & SFOLLOW) fprintf(fp, "\talways followed\n"); else
