root/radiance/ray/src/rt/virtuals.c
Wed Nov 15 18:02:53 2023 UTC (18 months, 1 week ago) by greg
Diff to previous 2.25 , to selected 2.10
Fri Feb 12 00:41:19 2021 UTC (4 years, 3 months ago) by greg
Changes since 2.24: +2 -4 lines
Diff to previous 2.24 , to selected 2.10
refactor: Created comparison macros for RREAL and FVECT types
Mon Feb 1 16:19:49 2021 UTC (4 years, 3 months ago) by greg
Diff to previous 2.23 , to selected 2.10
perf: made use of OVOID and findmaterial() more consistent and efficient
Thu Nov 8 00:54:07 2018 UTC (6 years, 6 months ago) by greg
Changes since 2.22: +2 -4 lines
Diff to previous 2.22 , to selected 2.10
Fri May 22 11:20:43 2015 UTC (10 years ago) by greg
Diff to previous 2.21 , to selected 2.10
Added missing assigment to rmax
Tue Jul 15 23:44:53 2014 UTC (10 years, 10 months ago) by greg
Changes since 2.20: +3 -4 lines
Diff to previous 2.20 , to selected 2.10
Fixed potential type conflict
Fri Sep 14 13:34:02 2012 UTC (12 years, 8 months ago) by greg
Changes since 2.19: +40 -23 lines
Diff to previous 2.19 , to selected 2.10
Added early check for no-op in virtual light source creation
Tue Aug 16 18:09:53 2011 UTC (13 years, 9 months ago) by greg
Changes since 2.18: +1 -3 lines
Diff to previous 2.18 , to selected 2.10
Minor fixes
Thu Oct 28 09:38:46 2010 UTC (14 years, 6 months ago) by greg
Changes since 2.17: +1 -2 lines
Diff to previous 2.17 , to selected 2.10
Fixed Windows bug in mkillum by initializing rmax
Thu Sep 7 05:20:54 2006 UTC (18 years, 8 months ago) by greg
Changes since 2.16: +14 -5 lines
Diff to previous 2.16 , to selected 2.10
Tue Apr 19 01:15:07 2005 UTC (20 years, 1 month ago) by greg
Diff to previous 2.15 , to selected 2.10
Fri Apr 15 04:44:52 2005 UTC (20 years, 1 month ago) by greg
Changes since 2.13: +44 -36 lines
Tue Mar 2 01:13:45 2004 UTC (21 years, 2 months ago) by greg
Fixed bug in last change to allow aliased virtual source materials
Mon Mar 1 18:11:20 2004 UTC (21 years, 2 months ago) by greg
Mon Jul 21 22:30:19 2003 UTC (21 years, 10 months ago) by schorsch
Wed May 14 20:43:46 2003 UTC (22 years ago) by greg
Changed source marking routines not to look past non-instanced objects
Wed Apr 23 00:52:34 2003 UTC (22 years, 1 month ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 3 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.6: +65 -9 lines
Mon Aug 10 18:37:06 1998 UTC (26 years, 9 months ago) by gwlarson
Tue Nov 7 12:40:25 1995 UTC (29 years, 6 months ago) by greg
Sat Aug 26 14:07:46 1995 UTC (29 years, 9 months ago) by greg
Changes since 2.3: +17 -25 lines
improved vstestvis() to work with source partitioning
Tue Dec 20 20:18:43 1994 UTC (30 years, 5 months ago) by greg
Sat May 23 08:03:19 1992 UTC (33 years ago) by greg
minor fix
Tue Nov 12 17:10:33 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.31: +0 -0 lines
Diff to previous 1.31 , to selected 2.10
Fri Nov 8 16:34:27 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.30: +19 -2 lines
Diff to previous 1.30 , to selected 2.10
Wed Oct 23 08:49:40 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.29 , to selected 2.10
minor bug fix
Tue Oct 22 11:23:51 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.28: +3 -0 lines
Diff to previous 1.28 , to selected 2.10
bug fixes in source sampling routines
Mon Oct 21 12:58:18 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.27: +12 -4 lines
Diff to previous 1.27 , to selected 2.10
Tue Oct 1 14:29:16 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.26: +3 -1 lines
Diff to previous 1.26 , to selected 2.10
fixed bug introduced in earlier revision
Mon Aug 26 10:10:43 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.25: +2 -1 lines
Diff to previous 1.25 , to selected 2.10
changed number of presamples for distant sources
Thu Aug 22 11:56:52 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.24 , to selected 2.10
Fri Aug 16 09:23:15 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.23: +2 -4 lines
Diff to previous 1.23 , to selected 2.10
improved some of the source pretesting code
Tue Aug 13 12:16:43 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.22 , to selected 2.10
Tue Aug 6 15:02:36 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.21: +3 -4 lines
Diff to previous 1.21 , to selected 2.10
changed calculation of number of presamples slightly
Mon Aug 5 09:02:42 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.20 , to selected 2.10
changed fatal error to warning
Fri Aug 2 10:30:27 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.19: +6 -2 lines
Diff to previous 1.19 , to selected 2.10
made computation of number of sample rays more accurate
and fixed calculation of solid angle for virtuals sources spots
Tue Jul 30 18:23:45 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.18: +7 -3 lines
Diff to previous 1.18 , to selected 2.10
fixed improper creation and testing of spots
Wed Jul 17 12:38:52 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.17: +2 -1 lines
Diff to previous 1.17 , to selected 2.10
added rayclear() function
Tue Jul 16 15:56:51 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.16: +6 -2 lines
Diff to previous 1.16 , to selected 2.10
added redirecting materials
Thu Jul 11 16:43:38 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.15: +6 -4 lines
Diff to previous 1.15 , to selected 2.10
fixed urand problems in multiple dimensions
Wed Jun 26 14:26:52 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.14 , to selected 2.10
increased MINSAMP again
Wed Jun 26 11:54:43 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.13: +19 -8 lines
Diff to previous 1.13 , to selected 2.10
fixed bug in solid angle determination for local sources
Wed Jun 26 08:55:10 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.12: +5 -2 lines
Diff to previous 1.12 , to selected 2.10
changed minimum number of tests from 1 to 3
Tue Jun 25 16:42:05 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.11 , to selected 2.10
fixed bug relating to return value of checkspot()
Tue Jun 25 15:48:11 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.10: +9 -9 lines
Diff to previous 1.10 , to selected 2.10
another minor bug in vstestvis()
Tue Jun 25 13:29:22 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.9: +6 -4 lines
Diff to previous 1.9 , to selected 2.10
fixed small bug in pretesting routine
Tue Jun 25 13:11:53 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.8: +60 -26 lines
Diff to previous 1.8 , to selected 2.10
fixed problems with virtual source pretesting
Tue Jun 25 08:52:04 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.7: +34 -15 lines
Diff to previous 1.7 , to selected 2.10
improved presampling
Mon Jun 24 16:10:59 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.6: +75 -99 lines
Diff to previous 1.6 , to selected 2.10
Fri Jun 21 13:25:42 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.5: +79 -73 lines
Diff to previous 1.5 , to selected 2.10
added test for relay object on same side as virtual source
Thu Jun 20 17:08:39 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.4: +9 -9 lines
Diff to previous 1.4 , to selected 2.10
residual bug fixes
Thu Jun 20 16:36:48 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.3: +82 -47 lines
Diff to previous 1.3 , to selected 2.10
bug fixes and enhancements
Thu Jun 20 13:43:38 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.2: +80 -216 lines
Diff to previous 1.2 , to selected 2.10
Thu Jun 20 09:37:38 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.1: +13 -24 lines
Diff to previous 1.1 , to selected 2.10
minor fixes
Wed Jun 19 16:36:14 1991 UTC (33 years, 11 months ago) by greg
Diff to selected 2.10
