--- ray/src/rt/virtuals.c 1991/06/20 13:43:38 1.3 +++ ray/src/rt/virtuals.c 1991/06/20 16:36:48 1.4 @@ -15,13 +15,8 @@ static char SCCSid[] = "$SunId$ LBL"; #include "source.h" -#include "cone.h" -#include "face.h" - - double intercircle(); -SRCREC *makevsrc(); static OBJECT *vobject; /* virtual source objects */ static int nvobjects = 0; /* number of virtual source objects */ @@ -55,18 +50,21 @@ markvirtuals() /* find and mark virtual sources */ } if (nvobjects == 0) return; +#ifdef DEBUG + fprintf(stderr, "found %d virtual source objects\n", nvobjects); +#endif /* append virtual sources */ for (i = nsources; i-- > 0; ) if (!(source[i].sflags & SSKIP)) - addvirtuals(&source[i], directrelay); + addvirtuals(i, directrelay); /* done with our object list */ free((char *)vobject); nvobjects = 0; } -addvirtuals(sr, nr) /* add virtual sources associated with sr */ -SRCREC *sr; +addvirtuals(sn, nr) /* add virtuals associated with source */ +int sn; int nr; { register int i; @@ -76,36 +74,43 @@ int nr; /* check each virtual object for projection */ for (i = 0; i < nvobjects; i++) /* vproject() calls us recursively */ - vproject(objptr(i), sr, nr-1); + vproject(objptr(vobject[i]), sn, nr-1); } -vproject(o, s, n) /* create projected source(s) if they exist */ +vproject(o, sn, n) /* create projected source(s) if they exist */ OBJREC *o; -SRCREC *s; +int sn; int n; { register int i; register VSMATERIAL *vsmat; MAT4 proj; - SRCREC *ns; + int ns; + + if (o == source[sn].so) /* objects cannot project themselves */ + return; /* get virtual source material */ vsmat = sfun[objptr(o->omod)->otype].mf; /* project virtual sources */ for (i = 0; i < vsmat->nproj; i++) - if ((*vsmat->vproj)(proj, o, s, i)) - if ((ns = makevsrc(o, s, proj)) != NULL) + if ((*vsmat->vproj)(proj, o, &source[sn], i)) + if ((ns = makevsrc(o, sn, proj)) >= 0) { +#ifdef DEBUG + virtverb(&source[sn], stderr); +#endif addvirtuals(ns, n); + } } -SRCREC * -makevsrc(op, sp, pm) /* make virtual source if reasonable */ +int +makevsrc(op, sn, pm) /* make virtual source if reasonable */ OBJREC *op; -register SRCREC *sp; +register int sn; MAT4 pm; { - register SRCREC *newsrc; + register int nsn; FVECT nsloc, ocent, nsnorm; int nsflags; double maxrad2; @@ -113,7 +118,7 @@ MAT4 pm; SPOT theirspot, ourspot; register int i; - nsflags = (sp->sflags|(SVIRTUAL|SFOLLOW)) & ~SSPOT; + nsflags = (source[sn].sflags|(SVIRTUAL|SFOLLOW)) & ~SSPOT; /* get object center and max. radius */ if (sfun[op->otype].of->getdisk != NULL) { maxrad2 = (*sfun[op->otype].of->getdisk)(ocent, op); @@ -122,78 +127,81 @@ MAT4 pm; nsflags |= SSPOT; } /* get location and spot */ - if (sp->sflags & SDISTANT) { /* distant source */ - if (sp->sflags & SPROX) + if (source[sn].sflags & SDISTANT) { /* distant source */ + if (source[sn].sflags & SPROX) return(NULL); /* should never get here! */ - multv3(nsloc, sp->sloc, pm); + multv3(nsloc, source[sn].sloc, pm); if (nsflags & SSPOT) { VCOPY(ourspot.aim, ocent); ourspot.siz = PI*maxrad2; ourspot.flen = 0.; } - if (sp->sflags & SSPOT) { - copystruct(&theirspot, sp->sl.s); - multp3(theirspot.aim, sp->sl.s->aim, pm); + if (source[sn].sflags & SSPOT) { + copystruct(&theirspot, source[sn].sl.s); + multp3(theirspot.aim, source[sn].sl.s->aim, pm); if (nsflags & SSPOT && !commonbeam(&ourspot, &theirspot, nsloc)) return(NULL); /* no overlap */ } } else { /* local source */ - multp3(nsloc, sp->sloc, pm); + multp3(nsloc, source[sn].sloc, pm); if (nsflags & SSPOT) { for (i = 0; i < 3; i++) ourspot.aim[i] = ocent[i] - nsloc[i]; if ((d1 = normalize(ourspot.aim)) == 0.) return(NULL); /* at source!! */ - if (sp->sflags & SPROX && d1 > sp->sl.prox) + if (source[sn].sflags & SPROX && + d1 > source[sn].sl.prox) return(NULL); /* too far away */ ourspot.siz = 2.*PI*(1. - d1/sqrt(d1*d1+maxrad2)); ourspot.flen = 0.; - } else if (sp->sflags & SPROX) { + } else if (source[sn].sflags & SPROX) { FVECT norm; double offs; /* use distance from plane */ offs = (*sfun[op->otype].of->getpleq)(norm, op); d1 = DOT(norm, nsloc) - offs; - if (d1 > sp->sl.prox || d1 < -sp->sl.prox) + if (d1 < 0.) d1 = -d1; + if (d1 > source[sn].sl.prox) return(NULL); /* too far away */ } - if (sp->sflags & SSPOT) { - copystruct(&theirspot, sp->sl.s); - multv3(theirspot.aim, sp->sl.s->aim, pm); + if (source[sn].sflags & SSPOT) { + copystruct(&theirspot, source[sn].sl.s); + multv3(theirspot.aim, source[sn].sl.s->aim, pm); if (nsflags & SSPOT) { if (!commonspot(&ourspot, &theirspot, nsloc)) return(NULL); /* no overlap */ ourspot.flen = theirspot.flen; } } - if (sp->sflags & SFLAT) { /* check for behind source */ - multv3(nsnorm, sp->snorm, pm); + if (source[sn].sflags & SFLAT) { /* behind source? */ + multv3(nsnorm, source[sn].snorm, pm); if (nsflags & SSPOT && checkspot(&ourspot, nsnorm) < 0) return(NULL); } } /* everything is OK, make source */ - if ((newsrc = newsource()) == NULL) + if ((nsn = newsource()) < 0) goto memerr; - newsrc->sflags = nsflags; - VCOPY(newsrc->sloc, nsloc); + source[nsn].sflags = nsflags; + VCOPY(source[nsn].sloc, nsloc); if (nsflags & SFLAT) - VCOPY(newsrc->snorm, nsnorm); - newsrc->ss = sp->ss; newsrc->ss2 = sp->ss2; - if ((nsflags | sp->sflags) & SSPOT) { - if ((newsrc->sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) + VCOPY(source[nsn].snorm, nsnorm); + source[nsn].ss = source[sn].ss; source[nsn].ss2 = source[sn].ss2; + if ((nsflags | source[sn].sflags) & SSPOT) { + if ((source[nsn].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) goto memerr; if (nsflags & SSPOT) - copystruct(newsrc->sl.s, &ourspot); + copystruct(source[nsn].sl.s, &ourspot); else - copystruct(newsrc->sl.s, &theirspot); - newsrc->sflags |= SSPOT; + copystruct(source[nsn].sl.s, &theirspot); + source[nsn].sflags |= SSPOT; } if (nsflags & SPROX) - newsrc->sl.prox = sp->sl.prox; - newsrc->sa.svnext = sp - source; - return(newsrc); + source[nsn].sl.prox = source[sn].sl.prox; + source[nsn].sa.svnext = sn; + source[nsn].so = op; + return(nsn); memerr: error(SYSTEM, "out of memory in makevsrc"); } @@ -296,3 +304,30 @@ double r1s, r2s; /* radii squared */ cc[i] = c1[i] + l*disp[i]; return(a2); } + + +#ifdef DEBUG +virtverb(vs, fp) /* print verbose description of virtual source */ +register SRCREC *vs; +FILE *fp; +{ + register int i; + + fprintf(fp, "%s virtual source %d in %s %s\n", + vs->sflags & SDISTANT ? "distant" : "local", + vs-source, ofun[vs->so->otype].funame, vs->so->oname); + fprintf(fp, "\tat (%f,%f,%f)\n", + vs->sloc[0], vs->sloc[1], vs->sloc[2]); + fprintf(fp, "\tlinked to source %d (%s)\n", + vs->sa.svnext, source[vs->sa.svnext].so->oname); + if (vs->sflags & SFOLLOW) + fprintf(fp, "\talways followed\n"); + else + fprintf(fp, "\tnever followed\n"); + if (!(vs->sflags & SSPOT)) + return; + fprintf(fp, "\twith spot aim (%f,%f,%f) and size %f\n", + vs->sl.s->aim[0], vs->sl.s->aim[1], vs->sl.s->aim[2], + vs->sl.s->siz); +} +#endif
