--- ray/src/rt/virtuals.c 1991/06/20 17:08:39 1.5 +++ ray/src/rt/virtuals.c 2014/07/15 23:44:53 2.21 @@ -1,48 +1,70 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: virtuals.c,v 2.21 2014/07/15 23:44:53 greg Exp $"; #endif - /* * Routines for simulating virtual light sources * Thus far, we only support planar mirrors. + * + * External symbols declared in source.h */ +#include "copyright.h" + #include "ray.h" #include "otypes.h" #include "source.h" +#include "random.h" -double intercircle(); +#define MINSAMPLES 16 /* minimum number of pretest samples */ +#define STESTMAX 32 /* maximum seeks per sample */ +#define FEQ(a,b) ((a)-(b)+FTINY >= 0 && (b)-(a)+FTINY >= 0) + + static OBJECT *vobject; /* virtual source objects */ static int nvobjects = 0; /* number of virtual source objects */ -markvirtuals() /* find and mark virtual sources */ +static int +isident4(MAT4 m) { - register OBJREC *o; - register int i; + int i, j; + + for (i = 4; i--; ) + for (j = 4; j--; ) + if (!FEQ(m[i][j], i==j)) + return(0); + return(1); +} + + +void +markvirtuals(void) /* find and mark virtual sources */ +{ + OBJREC *o; + int i; /* check number of direct relays */ if (directrelay <= 0) return; /* find virtual source objects */ - for (i = 0; i < nobjects; i++) { + for (i = 0; i < nsceneobjs; i++) { o = objptr(i); if (!issurface(o->otype) || o->omod == OVOID) continue; - if (!isvlight(objptr(o->omod)->otype)) + if (!isvlight(vsmaterial(o)->otype)) continue; if (sfun[o->otype].of == NULL || - sfun[o->otype].of->getpleq == NULL) - objerror(o, USER, "illegal material"); + sfun[o->otype].of->getpleq == NULL) { + objerror(o,WARNING,"secondary sources not supported"); + continue; + } if (nvobjects == 0) vobject = (OBJECT *)malloc(sizeof(OBJECT)); else - vobject = (OBJECT *)realloc((char *)vobject, + vobject = (OBJECT *)realloc((void *)vobject, (unsigned)(nvobjects+1)*sizeof(OBJECT)); if (vobject == NULL) error(SYSTEM, "out of memory in addvirtuals"); @@ -55,22 +77,25 @@ markvirtuals() /* find and mark virtual sources */ #endif /* append virtual sources */ for (i = nsources; i-- > 0; ) - if (!(source[i].sflags & SSKIP)) - addvirtuals(i, directrelay); + addvirtuals(i, directrelay); /* done with our object list */ - free((char *)vobject); + free((void *)vobject); nvobjects = 0; } -addvirtuals(sn, nr) /* add virtuals associated with source */ -int sn; -int nr; +void +addvirtuals( /* add virtuals associated with source */ + int sn, + int nr +) { - register int i; + int i; /* check relay limit first */ if (nr <= 0) return; + if (source[sn].sflags & SSKIP) + return; /* check each virtual object for projection */ for (i = 0; i < nvobjects; i++) /* vproject() calls us recursively */ @@ -78,256 +103,351 @@ int nr; } -vproject(o, sn, n) /* create projected source(s) if they exist */ -OBJREC *o; -int sn; -int n; +void +vproject( /* create projected source(s) if they exist */ + OBJREC *o, + int sn, + int n +) { - register int i; - register VSMATERIAL *vsmat; + int i; + VSMATERIAL *vsmat; MAT4 proj; int ns; if (o == source[sn].so) /* objects cannot project themselves */ return; /* get virtual source material */ - vsmat = sfun[objptr(o->omod)->otype].mf; + vsmat = sfun[vsmaterial(o)->otype].mf; /* project virtual sources */ for (i = 0; i < vsmat->nproj; i++) if ((*vsmat->vproj)(proj, o, &source[sn], i)) if ((ns = makevsrc(o, sn, proj)) >= 0) { + source[ns].sa.sv.pn = i; #ifdef DEBUG - virtverb(&source[ns], stderr); + virtverb(ns, stderr); #endif addvirtuals(ns, n); } } +OBJREC * +vsmaterial( /* get virtual source material pointer */ + OBJREC *o +) +{ + int i; + OBJREC *m; + + i = o->omod; + m = findmaterial(objptr(i)); + if (m == NULL) + return(objptr(i)); + if (m->otype != MAT_ILLUM || m->oargs.nsargs < 1 || + !strcmp(m->oargs.sarg[0], VOIDID) || + (i = lastmod(objndx(m), m->oargs.sarg[0])) == OVOID) + return(m); /* direct modifier */ + return(objptr(i)); /* illum alternate */ +} + + int -makevsrc(op, sn, pm) /* make virtual source if reasonable */ -OBJREC *op; -register int sn; -MAT4 pm; +makevsrc( /* make virtual source if reasonable */ + OBJREC *op, + int sn, + MAT4 pm +) { - register int nsn; - FVECT nsloc, ocent, nsnorm; + FVECT nsloc, nsnorm, ocent, v; + double maxrad2, d; int nsflags; - double maxrad2; - double d1; SPOT theirspot, ourspot; - register int i; - - nsflags = (source[sn].sflags|(SVIRTUAL|SFOLLOW)) & ~SSPOT; + int i; + /* check for no-op */ + if (isident4(pm)) + return(0); + nsflags = source[sn].sflags | (SVIRTUAL|SSPOT|SFOLLOW); /* get object center and max. radius */ - if (sfun[op->otype].of->getdisk != NULL) { - maxrad2 = (*sfun[op->otype].of->getdisk)(ocent, op); - if (maxrad2 <= FTINY) /* too small? */ - return(-1); - nsflags |= SSPOT; - } + maxrad2 = getdisk(ocent, op, sn); + if (maxrad2 <= FTINY) /* too small? */ + return(-1); /* get location and spot */ if (source[sn].sflags & SDISTANT) { /* distant source */ if (source[sn].sflags & SPROX) return(-1); /* should never get here! */ multv3(nsloc, source[sn].sloc, pm); - if (nsflags & SSPOT) { - VCOPY(ourspot.aim, ocent); - ourspot.siz = PI*maxrad2; - ourspot.flen = 0.; - } + normalize(nsloc); + VCOPY(ourspot.aim, ocent); + ourspot.siz = PI*maxrad2; + ourspot.flen = -1.; if (source[sn].sflags & SSPOT) { - copystruct(&theirspot, source[sn].sl.s); multp3(theirspot.aim, source[sn].sl.s->aim, pm); - if (nsflags & SSPOT && - !commonbeam(&ourspot, &theirspot, nsloc)) - return(-1); /* no overlap */ + /* adjust for source size */ + d = sqrt(dist2(ourspot.aim, theirspot.aim)); + d = sqrt(source[sn].sl.s->siz/PI) + d*source[sn].srad; + theirspot.siz = PI*d*d; + ourspot.flen = theirspot.flen = source[sn].sl.s->flen; + d = ourspot.siz; + if (!commonbeam(&ourspot, &theirspot, nsloc)) + return(-1); /* no overlap */ + if (ourspot.siz < d-FTINY) { /* it shrunk */ + d = beamdisk(v, op, &ourspot, nsloc); + if (d <= FTINY) + return(-1); + if (d < maxrad2) { + maxrad2 = d; + VCOPY(ocent, v); + } + } } } else { /* local source */ multp3(nsloc, source[sn].sloc, pm); - if (nsflags & SSPOT) { - for (i = 0; i < 3; i++) - ourspot.aim[i] = ocent[i] - nsloc[i]; - if ((d1 = normalize(ourspot.aim)) == 0.) - return(-1); /* at source!! */ - if (source[sn].sflags & SPROX && - d1 > source[sn].sl.prox) - return(-1); /* too far away */ - ourspot.siz = 2.*PI*(1. - d1/sqrt(d1*d1+maxrad2)); - ourspot.flen = 0.; - } else if (source[sn].sflags & SPROX) { - FVECT norm; - double offs; - /* use distance from plane */ - offs = (*sfun[op->otype].of->getpleq)(norm, op); - d1 = DOT(norm, nsloc) - offs; - if (d1 < 0.) d1 = -d1; - if (d1 > source[sn].sl.prox) - return(-1); /* too far away */ - } + for (i = 0; i < 3; i++) + ourspot.aim[i] = ocent[i] - nsloc[i]; + if ((d = normalize(ourspot.aim)) == 0.) + return(-1); /* at source!! */ + if (source[sn].sflags & SPROX && d > source[sn].sl.prox) + return(-1); /* too far away */ + ourspot.flen = 0.; + /* adjust for source size */ + d = (sqrt(maxrad2) + source[sn].srad) / d; + if (d < 1.-FTINY) + ourspot.siz = 2.*PI*(1. - sqrt(1.-d*d)); + else + nsflags &= ~SSPOT; if (source[sn].sflags & SSPOT) { - copystruct(&theirspot, source[sn].sl.s); + theirspot = *(source[sn].sl.s); multv3(theirspot.aim, source[sn].sl.s->aim, pm); + normalize(theirspot.aim); if (nsflags & SSPOT) { + ourspot.flen = theirspot.flen; + d = ourspot.siz; if (!commonspot(&ourspot, &theirspot, nsloc)) return(-1); /* no overlap */ - ourspot.flen = theirspot.flen; + } else { + nsflags |= SSPOT; + ourspot = theirspot; + d = 2.*ourspot.siz; } + if (ourspot.siz < d-FTINY) { /* it shrunk */ + d = spotdisk(v, op, &ourspot, nsloc); + if (d <= FTINY) + return(-1); + if (d < maxrad2) { + maxrad2 = d; + VCOPY(ocent, v); + } + } } if (source[sn].sflags & SFLAT) { /* behind source? */ multv3(nsnorm, source[sn].snorm, pm); - if (nsflags & SSPOT && checkspot(&ourspot, nsnorm) < 0) + normalize(nsnorm); + if (nsflags & SSPOT && !checkspot(&ourspot, nsnorm)) return(-1); } } - /* everything is OK, make source */ - if ((nsn = newsource()) < 0) + /* pretest visibility */ + nsflags = vstestvis(nsflags, op, ocent, maxrad2, sn); + if (nsflags & SSKIP) + return(-1); /* obstructed */ + /* it all checks out, so make it */ + if ((i = newsource()) < 0) goto memerr; - source[nsn].sflags = nsflags; - VCOPY(source[nsn].sloc, nsloc); + source[i].sflags = nsflags; + VCOPY(source[i].sloc, nsloc); + multv3(source[i].ss[SU], source[sn].ss[SU], pm); + multv3(source[i].ss[SV], source[sn].ss[SV], pm); if (nsflags & SFLAT) - VCOPY(source[nsn].snorm, nsnorm); - source[nsn].ss = source[sn].ss; source[nsn].ss2 = source[sn].ss2; - if ((nsflags | source[sn].sflags) & SSPOT) { - if ((source[nsn].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) + VCOPY(source[i].snorm, nsnorm); + else + multv3(source[i].ss[SW], source[sn].ss[SW], pm); + source[i].srad = source[sn].srad; + source[i].ss2 = source[sn].ss2; + if (nsflags & SSPOT) { + if ((source[i].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) goto memerr; - if (nsflags & SSPOT) - copystruct(source[nsn].sl.s, &ourspot); - else - copystruct(source[nsn].sl.s, &theirspot); - source[nsn].sflags |= SSPOT; + *(source[i].sl.s) = ourspot; } if (nsflags & SPROX) - source[nsn].sl.prox = source[sn].sl.prox; - source[nsn].sa.svnext = sn; - source[nsn].so = op; - return(nsn); + source[i].sl.prox = source[sn].sl.prox; + source[i].sa.sv.sn = sn; + source[i].so = op; + return(i); memerr: error(SYSTEM, "out of memory in makevsrc"); + return -1; /* pro forma return */ } -commonspot(sp1, sp2, org) /* set sp1 to intersection of sp1 and sp2 */ -register SPOT *sp1, *sp2; -FVECT org; +double +getdisk( /* get visible object disk */ + FVECT oc, + OBJREC *op, + int sn +) { - FVECT cent; - double rad2, cos1, cos2; - - cos1 = 1. - sp1->siz/(2.*PI); - cos2 = 1. - sp2->siz/(2.*PI); - if (sp2->siz >= 2.*PI-FTINY) /* BIG, just check overlap */ - return(DOT(sp1->aim,sp2->aim) >= cos1*cos2 - - sqrt((1.-cos1*cos1)*(1.-cos2*cos2))); - /* compute and check disks */ - rad2 = intercircle(cent, sp1->aim, sp2->aim, - 1./(cos1*cos1) - 1., 1./(cos2*cos2) - 1.); - if (rad2 <= FTINY || normalize(cent) == 0.) - return(0); - VCOPY(sp1->aim, cent); - sp1->siz = 2.*PI*(1. - 1./sqrt(1.+rad2)); - return(1); + double rad2, roffs, offs, d, rd, rdoto; + FVECT rnrm, nrm; + /* first, use object getdisk function */ + rad2 = getmaxdisk(oc, op); + if (!(source[sn].sflags & SVIRTUAL)) + return(rad2); /* all done for normal source */ + /* check for correct side of relay surface */ + roffs = getplaneq(rnrm, source[sn].so); + rd = DOT(rnrm, source[sn].sloc); /* source projection */ + if (!(source[sn].sflags & SDISTANT)) + rd -= roffs; + d = DOT(rnrm, oc) - roffs; /* disk distance to relay plane */ + if ((d > 0.) ^ (rd > 0.)) + return(rad2); /* OK if opposite sides */ + if (d*d >= rad2) + return(0.); /* no relay is possible */ + /* we need a closer look */ + offs = getplaneq(nrm, op); + rdoto = DOT(rnrm, nrm); + if (d*d >= rad2*(1.-rdoto*rdoto)) + return(0.); /* disk entirely on projection side */ + /* should shrink disk but I'm lazy */ + return(rad2); } -commonbeam(sp1, sp2, dir) /* set sp1 to intersection of sp1 and sp2 */ -register SPOT *sp1, *sp2; -FVECT dir; +int +vstestvis( /* pretest source visibility */ + int f, /* virtual source flags */ + OBJREC *o, /* relay object */ + FVECT oc, /* relay object center */ + double or2, /* relay object radius squared */ + int sn /* target source number */ +) { - FVECT cent, c1, c2; - double rad2, d; - register int i; - /* move centers to common plane */ - d = DOT(sp1->aim, dir); - for (i = 0; i < 3; i++) - c1[i] = sp1->aim[i] - d*dir[i]; - d = DOT(sp2->aim, dir); - for (i = 0; i < 3; i++) - c2[i] = sp2->aim[i] - d*dir[i]; - /* compute overlap */ - rad2 = intercircle(cent, c1, c2, sp1->siz/PI, sp2->siz/PI); - if (rad2 <= FTINY) - return(0); - VCOPY(sp1->aim, cent); - sp1->siz = PI*rad2; - return(1); -} - - -checkspot(sp, nrm) /* check spotlight for behind source */ -register SPOT *sp; -FVECT nrm; -{ - double d, d1; - - d = DOT(sp->aim, nrm); - if (d > FTINY) /* center in front? */ - return(0); - /* else check horizon */ - d1 = 1. - sp->siz/(2.*PI); - return(1.-FTINY-d*d > d1*d1); -} - - -double -intercircle(cc, c1, c2, r1s, r2s) /* intersect two circles */ -FVECT cc; /* midpoint (return value) */ -FVECT c1, c2; /* circle centers */ -double r1s, r2s; /* radii squared */ -{ - double a2, d2, l; - FVECT disp; - register int i; - - for (i = 0; i < 3; i++) - disp[i] = c2[i] - c1[i]; - d2 = DOT(disp,disp); - /* circle within overlap? */ - if (r1s < r2s) { - if (r2s >= r1s + d2) { - VCOPY(cc, c1); - return(r1s); - } + RAY sr; + FVECT onorm; + double offsdir[3]; + SRCINDEX si; + double or, d, d1; + int stestlim, ssn; + int nhit, nok; + int i, n; + /* return if pretesting disabled */ + if (vspretest <= 0) + return(f); + /* get surface normal */ + getplaneq(onorm, o); + /* set number of rays to sample */ + if (source[sn].sflags & SDISTANT) { + /* 32. == heuristic constant */ + n = 32.*or2/(thescene.cusize*thescene.cusize)*vspretest + .5; } else { - if (r1s >= r2s + d2) { - VCOPY(cc, c2); - return(r2s); + VSUB(offsdir, source[sn].sloc, oc); + d = DOT(offsdir,offsdir); + if (d <= FTINY) + n = 2.*PI * vspretest + .5; + else + n = 2.*PI * (1.-sqrt(1./(1.+or2/d)))*vspretest + .5; + } + if (n < MINSAMPLES) n = MINSAMPLES; +#ifdef DEBUG + fprintf(stderr, "pretesting source %d in object %s with %d rays\n", + sn, o->oname, n); +#endif + /* sample */ + or = sqrt(or2); + stestlim = n*STESTMAX; + ssn = 0; + nhit = nok = 0; + initsrcindex(&si); + while (n-- > 0) { + /* get sample point */ + do { + if (ssn >= stestlim) { +#ifdef DEBUG + fprintf(stderr, "\ttoo hard to hit\n"); +#endif + return(f); /* too small a target! */ + } + multisamp(offsdir, 3, urand(sn*931+5827+ssn)); + for (i = 0; i < 3; i++) + offsdir[i] = or*(1. - 2.*offsdir[i]); + ssn++; + d = 1. - DOT(offsdir, onorm); + for (i = 0; i < 3; i++) { + sr.rorg[i] = oc[i] + offsdir[i] + d*onorm[i]; + sr.rdir[i] = -onorm[i]; + } + rayorigin(&sr, PRIMARY, NULL, NULL); + } while (!(*ofun[o->otype].funp)(o, &sr)); + /* check against source */ + VCOPY(sr.rorg, sr.rop); /* starting from intersection */ + samplendx++; + if (si.sp >= si.np-1 || + !srcray(&sr, NULL, &si) || sr.rsrc != sn) { + si.sn = sn-1; /* reset index to our source */ + si.np = 0; + if (!srcray(&sr, NULL, &si) || sr.rsrc != sn) + continue; /* can't get there from here */ } + sr.revf = srcvalue; + rayvalue(&sr); /* check sample validity */ + if ((d = bright(sr.rcol)) <= FTINY) + continue; + nok++; /* got sample; check obstructions */ + rayclear(&sr); + sr.revf = raytrace; + rayvalue(&sr); + if ((d1 = bright(sr.rcol)) > FTINY) { + if (d - d1 > FTINY) { +#ifdef DEBUG + fprintf(stderr, "\tpartially shadowed\n"); +#endif + return(f); /* intervening transmitter */ + } + nhit++; + } + if (nhit > 0 && nhit < nok) { +#ifdef DEBUG + fprintf(stderr, "\tpartially occluded\n"); +#endif + return(f); /* need to shadow test */ + } } - a2 = .25*(2.*(r1s+r2s) - d2 - (r2s-r1s)*(r2s-r1s)/d2); - /* no overlap? */ - if (a2 <= 0.) - return(0.); - /* overlap, compute center */ - l = sqrt((r1s - a2)/d2); - for (i = 0; i < 3; i++) - cc[i] = c1[i] + l*disp[i]; - return(a2); + if (nhit == 0) { +#ifdef DEBUG + fprintf(stderr, "\t0%% hit rate\n"); +#endif + return(f | SSKIP); /* 0% hit rate: totally occluded */ + } +#ifdef DEBUG + fprintf(stderr, "\t100%% hit rate\n"); +#endif + return(f & ~SFOLLOW); /* 100% hit rate: no occlusion */ } + - #ifdef DEBUG -virtverb(vs, fp) /* print verbose description of virtual source */ -register SRCREC *vs; -FILE *fp; +void +virtverb( /* print verbose description of virtual source */ + int sn, + FILE *fp +) { - register int i; - fprintf(fp, "%s virtual source %d in %s %s\n", - vs->sflags & SDISTANT ? "distant" : "local", - vs-source, ofun[vs->so->otype].funame, vs->so->oname); + source[sn].sflags & SDISTANT ? "distant" : "local", + sn, ofun[source[sn].so->otype].funame, + source[sn].so->oname); fprintf(fp, "\tat (%f,%f,%f)\n", - vs->sloc[0], vs->sloc[1], vs->sloc[2]); + source[sn].sloc[0], source[sn].sloc[1], source[sn].sloc[2]); fprintf(fp, "\tlinked to source %d (%s)\n", - vs->sa.svnext, source[vs->sa.svnext].so->oname); - if (vs->sflags & SFOLLOW) + source[sn].sa.sv.sn, source[source[sn].sa.sv.sn].so->oname); + if (source[sn].sflags & SFOLLOW) fprintf(fp, "\talways followed\n"); else fprintf(fp, "\tnever followed\n"); - if (!(vs->sflags & SSPOT)) + if (!(source[sn].sflags & SSPOT)) return; fprintf(fp, "\twith spot aim (%f,%f,%f) and size %f\n", - vs->sl.s->aim[0], vs->sl.s->aim[1], vs->sl.s->aim[2], - vs->sl.s->siz); + source[sn].sl.s->aim[0], source[sn].sl.s->aim[1], + source[sn].sl.s->aim[2], source[sn].sl.s->siz); } #endif
