--- ray/src/rt/virtuals.c 1991/07/11 16:43:38 1.16 +++ ray/src/rt/virtuals.c 1991/10/21 12:58:18 1.28 @@ -19,8 +19,8 @@ static char SCCSid[] = "$SunId$ LBL"; #include "random.h" -#define MINSAMPLES 5 /* minimum number of pretest samples */ -#define STESTMAX 30 /* maximum seeks per sample */ +#define MINSAMPLES 16 /* minimum number of pretest samples */ +#define STESTMAX 32 /* maximum seeks per sample */ double getdisk(); @@ -44,8 +44,10 @@ markvirtuals() /* find and mark virtual sources */ if (!isvlight(objptr(o->omod)->otype)) continue; if (sfun[o->otype].of == NULL || - sfun[o->otype].of->getpleq == NULL) - objerror(o, USER, "illegal material"); + sfun[o->otype].of->getpleq == NULL) { + objerror(o,WARNING,"secondary sources not supported"); + continue; + } if (nvobjects == 0) vobject = (OBJECT *)malloc(sizeof(OBJECT)); else @@ -104,6 +106,7 @@ int n; for (i = 0; i < vsmat->nproj; i++) if ((*vsmat->vproj)(proj, o, &source[sn], i)) if ((ns = makevsrc(o, sn, proj)) >= 0) { + source[ns].sa.sv.pn = i; #ifdef DEBUG virtverb(ns, stderr); #endif @@ -134,12 +137,16 @@ MAT4 pm; if (source[sn].sflags & SPROX) return(-1); /* should never get here! */ multv3(nsloc, source[sn].sloc, pm); + normalize(nsloc); VCOPY(ourspot.aim, ocent); ourspot.siz = PI*maxrad2; ourspot.flen = 0.; if (source[sn].sflags & SSPOT) { - copystruct(&theirspot, source[sn].sl.s); multp3(theirspot.aim, source[sn].sl.s->aim, pm); + d = sqrt(dist2(ourspot.aim, theirspot.aim)); + d = sqrt(source[sn].sl.s->siz/PI) + d*source[sn].srad; + theirspot.siz = PI*d*d; + ourspot.flen = theirspot.flen = source[sn].sl.s->flen; d = ourspot.siz; if (!commonbeam(&ourspot, &theirspot, nsloc)) return(-1); /* no overlap */ @@ -162,13 +169,15 @@ MAT4 pm; if (source[sn].sflags & SPROX && d > source[sn].sl.prox) return(-1); /* too far away */ ourspot.flen = 0.; - if (d*d > maxrad2) - ourspot.siz = 2.*PI*(1. - sqrt(1.-maxrad2/(d*d))); + d = (sqrt(maxrad2) + source[sn].srad) / d; + if (d < 1.-FTINY) + ourspot.siz = 2.*PI*(1. - sqrt(1.-d*d)); else nsflags &= ~SSPOT; if (source[sn].sflags & SSPOT) { copystruct(&theirspot, source[sn].sl.s); multv3(theirspot.aim, source[sn].sl.s->aim, pm); + normalize(theirspot.aim); if (nsflags & SSPOT) { ourspot.flen = theirspot.flen; d = ourspot.siz; @@ -191,7 +200,8 @@ MAT4 pm; } if (source[sn].sflags & SFLAT) { /* behind source? */ multv3(nsnorm, source[sn].snorm, pm); - if (!checkspot(&ourspot, nsnorm)) + normalize(nsnorm); + if (nsflags & SSPOT && !checkspot(&ourspot, nsnorm)) return(-1); } } @@ -204,9 +214,13 @@ MAT4 pm; goto memerr; source[i].sflags = nsflags; VCOPY(source[i].sloc, nsloc); + multv3(source[i].ss[SU], source[sn].ss[SU], pm); + multv3(source[i].ss[SV], source[sn].ss[SV], pm); if (nsflags & SFLAT) VCOPY(source[i].snorm, nsnorm); - source[i].ss = source[sn].ss; source[i].ss2 = source[sn].ss2; + else + multv3(source[i].ss[SW], source[sn].ss[SW], pm); + source[i].ss2 = source[sn].ss2; if (nsflags & SSPOT) { if ((source[i].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) goto memerr; @@ -214,7 +228,7 @@ MAT4 pm; } if (nsflags & SPROX) source[i].sl.prox = source[sn].sl.prox; - source[i].sa.svnext = sn; + source[i].sa.sv.sn = sn; source[i].so = op; return(i); memerr: @@ -265,6 +279,7 @@ register int sn; /* target source number */ RAY sr; FVECT onorm; FVECT offsdir; + SRCINDEX si; double or, d; int infront; int stestlim, ssn; @@ -277,13 +292,17 @@ register int sn; /* target source number */ getplaneq(onorm, o); /* set number of rays to sample */ if (source[sn].sflags & SDISTANT) { - n = (2./3.*PI*PI)*or2/(thescene.cusize*thescene.cusize)* - vspretest + .5; + /* 32. == heuristic constant */ + n = 32.*or2/(thescene.cusize*thescene.cusize)*vspretest + .5; infront = DOT(onorm, source[sn].sloc) > 0.; } else { for (i = 0; i < 3; i++) offsdir[i] = source[sn].sloc[i] - oc[i]; - n = or2/DOT(offsdir,offsdir)*vspretest + .5; + d = DOT(offsdir,offsdir); + if (d <= FTINY) + n = 2.*PI * vspretest + .5; + else + n = 2.*PI * (1.-sqrt(1./(1.+or2/d)))*vspretest + .5; infront = DOT(onorm, offsdir) > 0.; } if (n < MINSAMPLES) n = MINSAMPLES; @@ -305,9 +324,9 @@ register int sn; /* target source number */ #endif return(f); /* too small a target! */ } + multisamp(offsdir, 3, urand(sn*931+5827+ssn)); for (i = 0; i < 3; i++) - offsdir[i] = or*(1. - - 2.*urand(urind(931*i+5827,ssn))); + offsdir[i] = or*(1. - 2.*offsdir[i]); ssn++; for (i = 0; i < 3; i++) sr.rorg[i] = oc[i] + offsdir[i]; @@ -325,8 +344,11 @@ register int sn; /* target source number */ rayorigin(&sr, NULL, PRIMARY, 1.0); } while (!(*ofun[o->otype].funp)(o, &sr)); /* check against source */ + initsrcindex(&si); + si.sn = sn; + nopart(&si, sr.rorg); samplendx++; - if (srcray(&sr, NULL, sn) == 0.) + if (!srcray(&sr, NULL, &si) || sr.rsrc != sn) continue; sr.revf = srcvalue; rayvalue(&sr); @@ -334,7 +356,8 @@ register int sn; /* target source number */ continue; nok++; /* check against obstructions */ - srcray(&sr, NULL, sn); + rayclear(&sr); + sr.revf = raytrace; rayvalue(&sr); if (bright(sr.rcol) > FTINY) nhit++; @@ -372,7 +395,7 @@ FILE *fp; fprintf(fp, "\tat (%f,%f,%f)\n", source[sn].sloc[0], source[sn].sloc[1], source[sn].sloc[2]); fprintf(fp, "\tlinked to source %d (%s)\n", - source[sn].sa.svnext, source[source[sn].sa.svnext].so->oname); + source[sn].sa.sv.sn, source[source[sn].sa.sv.sn].so->oname); if (source[sn].sflags & SFOLLOW) fprintf(fp, "\talways followed\n"); else
