Minor fixes
Fixed Windows bug in mkillum by initializing rmax
Fixed bug in last change to allow aliased virtual source materials
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changed source marking routines not to look past non-instanced objects
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
improved vstestvis() to work with source partitioning
minor fix
minor bug fix
bug fixes in source sampling routines
fixed bug introduced in earlier revision
changed number of presamples for distant sources
improved some of the source pretesting code
changed calculation of number of presamples slightly
changed fatal error to warning
made computation of number of sample rays more accurate and fixed calculation of solid angle for virtuals sources spots
fixed improper creation and testing of spots
added rayclear() function
added redirecting materials
fixed urand problems in multiple dimensions
increased MINSAMP again
fixed bug in solid angle determination for local sources
changed minimum number of tests from 1 to 3
fixed bug relating to return value of checkspot()
another minor bug in vstestvis()
fixed small bug in pretesting routine
fixed problems with virtual source pretesting
improved presampling
added test for relay object on same side as virtual source
residual bug fixes
bug fixes and enhancements
minor fixes
