--- ray/src/rt/virtuals.c 1991/10/23 08:49:40 1.30 +++ ray/src/rt/virtuals.c 1998/08/10 18:37:06 2.6 @@ -1,7 +1,7 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static char SCCSid[] = "$SunId$ SGI"; #endif /* @@ -41,7 +41,7 @@ markvirtuals() /* find and mark virtual sources */ o = objptr(i); if (!issurface(o->otype) || o->omod == OVOID) continue; - if (!isvlight(objptr(o->omod)->otype)) + if (!isvlight(vsmaterial(o)->otype)) continue; if (sfun[o->otype].of == NULL || sfun[o->otype].of->getpleq == NULL) { @@ -101,7 +101,7 @@ int n; if (o == source[sn].so) /* objects cannot project themselves */ return; /* get virtual source material */ - vsmat = sfun[objptr(o->omod)->otype].mf; + vsmat = sfun[vsmaterial(o)->otype].mf; /* project virtual sources */ for (i = 0; i < vsmat->nproj; i++) if ((*vsmat->vproj)(proj, o, &source[sn], i)) @@ -115,6 +115,23 @@ int n; } +OBJREC * +vsmaterial(o) /* get virtual source material pointer */ +OBJREC *o; +{ + register int i; + register OBJREC *m; + + i = o->omod; + m = objptr(i); + if (m->otype != MAT_ILLUM || m->oargs.nsargs < 1 || + !strcmp(m->oargs.sarg[0], VOIDID) || + (i = lastmod(objndx(m), m->oargs.sarg[0])) == OVOID) + return(m); /* direct modifier */ + return(objptr(i)); /* illum alternate */ +} + + int makevsrc(op, sn, pm) /* make virtual source if reasonable */ OBJREC *op; @@ -140,7 +157,7 @@ MAT4 pm; normalize(nsloc); VCOPY(ourspot.aim, ocent); ourspot.siz = PI*maxrad2; - ourspot.flen = 0.; + ourspot.flen = -1.; if (source[sn].sflags & SSPOT) { multp3(theirspot.aim, source[sn].sl.s->aim, pm); /* adjust for source size */ @@ -284,7 +301,6 @@ register int sn; /* target source number */ FVECT offsdir; SRCINDEX si; double or, d; - int infront; int stestlim, ssn; int nhit, nok; register int i, n; @@ -297,7 +313,6 @@ register int sn; /* target source number */ if (source[sn].sflags & SDISTANT) { /* 32. == heuristic constant */ n = 32.*or2/(thescene.cusize*thescene.cusize)*vspretest + .5; - infront = DOT(onorm, source[sn].sloc) > 0.; } else { for (i = 0; i < 3; i++) offsdir[i] = source[sn].sloc[i] - oc[i]; @@ -306,7 +321,6 @@ register int sn; /* target source number */ n = 2.*PI * vspretest + .5; else n = 2.*PI * (1.-sqrt(1./(1.+or2/d)))*vspretest + .5; - infront = DOT(onorm, offsdir) > 0.; } if (n < MINSAMPLES) n = MINSAMPLES; #ifdef DEBUG @@ -318,6 +332,7 @@ register int sn; /* target source number */ stestlim = n*STESTMAX; ssn = 0; nhit = nok = 0; + initsrcindex(&si); while (n-- > 0) { /* get sample point */ do { @@ -331,34 +346,29 @@ register int sn; /* target source number */ for (i = 0; i < 3; i++) offsdir[i] = or*(1. - 2.*offsdir[i]); ssn++; - for (i = 0; i < 3; i++) - sr.rorg[i] = oc[i] + offsdir[i]; - d = DOT(offsdir,onorm); - if (infront) - for (i = 0; i < 3; i++) { - sr.rorg[i] -= (d-.0001)*onorm[i]; - sr.rdir[i] = -onorm[i]; - } - else - for (i = 0; i < 3; i++) { - sr.rorg[i] -= (d+.0001)*onorm[i]; - sr.rdir[i] = onorm[i]; - } + d = 1. - DOT(offsdir, onorm); + for (i = 0; i < 3; i++) { + sr.rorg[i] = oc[i] + offsdir[i] + d*onorm[i]; + sr.rdir[i] = -onorm[i]; + } + sr.rmax = 0.0; rayorigin(&sr, NULL, PRIMARY, 1.0); } while (!(*ofun[o->otype].funp)(o, &sr)); /* check against source */ - initsrcindex(&si); - si.sn = sn; - nopart(&si, &sr); + VCOPY(sr.rorg, sr.rop); /* starting from intersection */ samplendx++; - if (!srcray(&sr, NULL, &si) || sr.rsrc != sn) - continue; + if (si.sp >= si.np-1 || + !srcray(&sr, NULL, &si) || sr.rsrc != sn) { + si.sn = sn-1; /* reset index to our source */ + si.np = 0; + if (!srcray(&sr, NULL, &si) || sr.rsrc != sn) + continue; /* can't get there from here */ + } sr.revf = srcvalue; - rayvalue(&sr); + rayvalue(&sr); /* check sample validity */ if (bright(sr.rcol) <= FTINY) continue; - nok++; - /* check against obstructions */ + nok++; /* got sample; check obstructions */ rayclear(&sr); sr.revf = raytrace; rayvalue(&sr);
