--- ray/src/rt/virtuals.c 1991/06/20 16:36:48 1.4 +++ ray/src/rt/virtuals.c 1991/06/21 13:25:42 1.6 @@ -16,7 +16,7 @@ static char SCCSid[] = "$SunId$ LBL"; #include "source.h" -double intercircle(); +double intercircle(), getdisk(); static OBJECT *vobject; /* virtual source objects */ static int nvobjects = 0; /* number of virtual source objects */ @@ -97,7 +97,7 @@ int n; if ((*vsmat->vproj)(proj, o, &source[sn], i)) if ((ns = makevsrc(o, sn, proj)) >= 0) { #ifdef DEBUG - virtverb(&source[sn], stderr); + virtverb(ns, stderr); #endif addvirtuals(ns, n); } @@ -110,103 +110,108 @@ OBJREC *op; register int sn; MAT4 pm; { - register int nsn; - FVECT nsloc, ocent, nsnorm; - int nsflags; + FVECT nsloc, nsnorm, ocent; double maxrad2; + int nsflags; double d1; SPOT theirspot, ourspot; register int i; - nsflags = (source[sn].sflags|(SVIRTUAL|SFOLLOW)) & ~SSPOT; + nsflags = source[sn].sflags | (SVIRTUAL|SSPOT|SFOLLOW); /* get object center and max. radius */ - if (sfun[op->otype].of->getdisk != NULL) { - maxrad2 = (*sfun[op->otype].of->getdisk)(ocent, op); - if (maxrad2 <= FTINY) /* too small? */ - return(NULL); - nsflags |= SSPOT; - } + maxrad2 = getdisk(ocent, op, sn); + if (maxrad2 <= FTINY) /* too small? */ + return(-1); /* get location and spot */ if (source[sn].sflags & SDISTANT) { /* distant source */ if (source[sn].sflags & SPROX) - return(NULL); /* should never get here! */ + return(-1); /* should never get here! */ multv3(nsloc, source[sn].sloc, pm); - if (nsflags & SSPOT) { - VCOPY(ourspot.aim, ocent); - ourspot.siz = PI*maxrad2; - ourspot.flen = 0.; - } + VCOPY(ourspot.aim, ocent); + ourspot.siz = PI*maxrad2; + ourspot.flen = 0.; if (source[sn].sflags & SSPOT) { copystruct(&theirspot, source[sn].sl.s); multp3(theirspot.aim, source[sn].sl.s->aim, pm); - if (nsflags & SSPOT && - !commonbeam(&ourspot, &theirspot, nsloc)) - return(NULL); /* no overlap */ + if (!commonbeam(&ourspot, &theirspot, nsloc)) + return(-1); /* no overlap */ } } else { /* local source */ multp3(nsloc, source[sn].sloc, pm); - if (nsflags & SSPOT) { - for (i = 0; i < 3; i++) - ourspot.aim[i] = ocent[i] - nsloc[i]; - if ((d1 = normalize(ourspot.aim)) == 0.) - return(NULL); /* at source!! */ - if (source[sn].sflags & SPROX && - d1 > source[sn].sl.prox) - return(NULL); /* too far away */ - ourspot.siz = 2.*PI*(1. - d1/sqrt(d1*d1+maxrad2)); - ourspot.flen = 0.; - } else if (source[sn].sflags & SPROX) { - FVECT norm; - double offs; - /* use distance from plane */ - offs = (*sfun[op->otype].of->getpleq)(norm, op); - d1 = DOT(norm, nsloc) - offs; - if (d1 < 0.) d1 = -d1; - if (d1 > source[sn].sl.prox) - return(NULL); /* too far away */ - } + for (i = 0; i < 3; i++) + ourspot.aim[i] = ocent[i] - nsloc[i]; + if ((d1 = normalize(ourspot.aim)) == 0.) + return(-1); /* at source!! */ + if (source[sn].sflags & SPROX && d1 > source[sn].sl.prox) + return(-1); /* too far away */ + ourspot.siz = 2.*PI*(1. - d1/sqrt(d1*d1+maxrad2)); + ourspot.flen = 0.; if (source[sn].sflags & SSPOT) { copystruct(&theirspot, source[sn].sl.s); multv3(theirspot.aim, source[sn].sl.s->aim, pm); - if (nsflags & SSPOT) { - if (!commonspot(&ourspot, &theirspot, nsloc)) - return(NULL); /* no overlap */ - ourspot.flen = theirspot.flen; - } + if (!commonspot(&ourspot, &theirspot, nsloc)) + return(-1); /* no overlap */ + ourspot.flen = theirspot.flen; } if (source[sn].sflags & SFLAT) { /* behind source? */ multv3(nsnorm, source[sn].snorm, pm); - if (nsflags & SSPOT && checkspot(&ourspot, nsnorm) < 0) - return(NULL); + if (checkspot(&ourspot, nsnorm) < 0) + return(-1); } } /* everything is OK, make source */ - if ((nsn = newsource()) < 0) + if ((i = newsource()) < 0) goto memerr; - source[nsn].sflags = nsflags; - VCOPY(source[nsn].sloc, nsloc); + source[i].sflags = nsflags; + VCOPY(source[i].sloc, nsloc); if (nsflags & SFLAT) - VCOPY(source[nsn].snorm, nsnorm); - source[nsn].ss = source[sn].ss; source[nsn].ss2 = source[sn].ss2; - if ((nsflags | source[sn].sflags) & SSPOT) { - if ((source[nsn].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) - goto memerr; - if (nsflags & SSPOT) - copystruct(source[nsn].sl.s, &ourspot); - else - copystruct(source[nsn].sl.s, &theirspot); - source[nsn].sflags |= SSPOT; - } + VCOPY(source[i].snorm, nsnorm); + source[i].ss = source[sn].ss; source[i].ss2 = source[sn].ss2; + if ((source[i].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) + goto memerr; + copystruct(source[i].sl.s, &ourspot); if (nsflags & SPROX) - source[nsn].sl.prox = source[sn].sl.prox; - source[nsn].sa.svnext = sn; - source[nsn].so = op; - return(nsn); + source[i].sl.prox = source[sn].sl.prox; + source[i].sa.svnext = sn; + source[i].so = op; + return(i); memerr: error(SYSTEM, "out of memory in makevsrc"); } +double +getdisk(oc, op, sn) /* get visible object disk */ +FVECT oc; +OBJREC *op; +register int sn; +{ + double rad2, roffs, offs, d, rd, rdoto; + FVECT rnrm, nrm; + /* first, use object getdisk function */ + rad2 = (*sfun[op->otype].of->getdisk)(oc, op); + if (!(source[sn].sflags & SVIRTUAL)) + return(rad2); /* all done for normal source */ + /* check for correct side of relay surface */ + roffs = (*sfun[source[sn].so->otype].of->getpleq)(rnrm, source[sn].so); + rd = DOT(rnrm, source[sn].sloc); /* source projection */ + if (!(source[sn].sflags & SDISTANT)) + rd -= roffs; + d = DOT(rnrm, oc) - roffs; /* disk distance to relay plane */ + if ((d > 0.) ^ (rd > 0.)) + return(rad2); /* OK if opposite sides */ + if (d*d >= rad2) + return(.0); /* no relay is possible */ + /* we need a closer look */ + offs = (*sfun[op->otype].of->getpleq)(nrm, op); + rdoto = DOT(rnrm, nrm); + if (d*d >= rad2*(1.-rdoto*rdoto)) + return(0.); /* disk entirely on projection side */ + /* should shrink disk but I'm lazy */ + return(rad2); +} + + commonspot(sp1, sp2, org) /* set sp1 to intersection of sp1 and sp2 */ register SPOT *sp1, *sp2; FVECT org; @@ -307,27 +312,28 @@ double r1s, r2s; /* radii squared */ #ifdef DEBUG -virtverb(vs, fp) /* print verbose description of virtual source */ -register SRCREC *vs; +virtverb(sn, fp) /* print verbose description of virtual source */ +register int sn; FILE *fp; { register int i; fprintf(fp, "%s virtual source %d in %s %s\n", - vs->sflags & SDISTANT ? "distant" : "local", - vs-source, ofun[vs->so->otype].funame, vs->so->oname); + source[sn].sflags & SDISTANT ? "distant" : "local", + sn, ofun[source[sn].so->otype].funame, + source[sn].so->oname); fprintf(fp, "\tat (%f,%f,%f)\n", - vs->sloc[0], vs->sloc[1], vs->sloc[2]); + source[sn].sloc[0], source[sn].sloc[1], source[sn].sloc[2]); fprintf(fp, "\tlinked to source %d (%s)\n", - vs->sa.svnext, source[vs->sa.svnext].so->oname); - if (vs->sflags & SFOLLOW) + source[sn].sa.svnext, source[source[sn].sa.svnext].so->oname); + if (source[sn].sflags & SFOLLOW) fprintf(fp, "\talways followed\n"); else fprintf(fp, "\tnever followed\n"); - if (!(vs->sflags & SSPOT)) + if (!(source[sn].sflags & SSPOT)) return; fprintf(fp, "\twith spot aim (%f,%f,%f) and size %f\n", - vs->sl.s->aim[0], vs->sl.s->aim[1], vs->sl.s->aim[2], - vs->sl.s->siz); + source[sn].sl.s->aim[0], source[sn].sl.s->aim[1], + source[sn].sl.s->aim[2], source[sn].sl.s->siz); } #endif
