--- ray/src/rt/virtuals.c 1991/06/25 08:52:04 1.8 +++ ray/src/rt/virtuals.c 1991/06/25 13:29:22 1.10 @@ -115,10 +115,9 @@ OBJREC *op; register int sn; MAT4 pm; { - FVECT nsloc, nsnorm, ocent; - double maxrad2; + FVECT nsloc, nsnorm, ocent, v; + double maxrad2, d; int nsflags; - double d1; SPOT theirspot, ourspot; register int i; @@ -138,24 +137,44 @@ MAT4 pm; if (source[sn].sflags & SSPOT) { copystruct(&theirspot, source[sn].sl.s); multp3(theirspot.aim, source[sn].sl.s->aim, pm); + d = ourspot.siz; if (!commonbeam(&ourspot, &theirspot, nsloc)) - return(-1); /* no overlap */ + return(-1); /* no overlap */ + if (ourspot.siz < d-FTINY) { /* it shrunk */ + d = beamdisk(v, op, &ourspot, nsloc); + if (d <= FTINY) + return(-1); + if (d < maxrad2) { + maxrad2 = d; + VCOPY(ocent, v); + } + } } } else { /* local source */ multp3(nsloc, source[sn].sloc, pm); for (i = 0; i < 3; i++) ourspot.aim[i] = ocent[i] - nsloc[i]; - if ((d1 = normalize(ourspot.aim)) == 0.) + if ((d = normalize(ourspot.aim)) == 0.) return(-1); /* at source!! */ - if (source[sn].sflags & SPROX && d1 > source[sn].sl.prox) + if (source[sn].sflags & SPROX && d > source[sn].sl.prox) return(-1); /* too far away */ - ourspot.siz = 2.*PI*(1. - d1/sqrt(d1*d1+maxrad2)); + ourspot.siz = 2.*PI*(1. - d/sqrt(d*d+maxrad2)); ourspot.flen = 0.; if (source[sn].sflags & SSPOT) { copystruct(&theirspot, source[sn].sl.s); multv3(theirspot.aim, source[sn].sl.s->aim, pm); + d = ourspot.siz; if (!commonspot(&ourspot, &theirspot, nsloc)) return(-1); /* no overlap */ + if (ourspot.siz < d-FTINY) { /* it shrunk */ + d = spotdisk(v, op, &ourspot, nsloc); + if (d <= FTINY) + return(-1); + if (d < maxrad2) { + maxrad2 = d; + VCOPY(ocent, v); + } + } ourspot.flen = theirspot.flen; } if (source[sn].sflags & SFLAT) { /* behind source? */ @@ -198,11 +217,11 @@ register int sn; double rad2, roffs, offs, d, rd, rdoto; FVECT rnrm, nrm; /* first, use object getdisk function */ - rad2 = (*sfun[op->otype].of->getdisk)(oc, op); + rad2 = getmaxdisk(oc, op); if (!(source[sn].sflags & SVIRTUAL)) return(rad2); /* all done for normal source */ /* check for correct side of relay surface */ - roffs = (*sfun[source[sn].so->otype].of->getpleq)(rnrm, source[sn].so); + roffs = getplaneq(rnrm, source[sn].so); rd = DOT(rnrm, source[sn].sloc); /* source projection */ if (!(source[sn].sflags & SDISTANT)) rd -= roffs; @@ -210,9 +229,9 @@ register int sn; if ((d > 0.) ^ (rd > 0.)) return(rad2); /* OK if opposite sides */ if (d*d >= rad2) - return(.0); /* no relay is possible */ + return(0.); /* no relay is possible */ /* we need a closer look */ - offs = (*sfun[op->otype].of->getpleq)(nrm, op); + offs = getplaneq(nrm, op); rdoto = DOT(rnrm, nrm); if (d*d >= rad2*(1.-rdoto*rdoto)) return(0.); /* disk entirely on projection side */ @@ -235,34 +254,42 @@ register int sn; /* target source number */ double or, d; int infront; int ssn; - int nok, nhit; + int nhit; register int i, n; /* return if pretesting disabled */ if (vspretest <= 0) return(f); /* get surface normal */ - (*sfun[o->otype].of->getpleq)(onorm, o); + getplaneq(onorm, o); /* set number of rays to sample */ if (source[sn].sflags & SDISTANT) { n = (2./3.*PI*PI)*or2/(thescene.cusize*thescene.cusize)* vspretest + .5; infront = DOT(onorm, source[sn].sloc) > 0.; } else { - n = or2/dist2(oc,source[sn].sloc)*vspretest + .5; for (i = 0; i < 3; i++) offsdir[i] = source[sn].sloc[i] - oc[i]; + n = or2/DOT(offsdir,offsdir)*vspretest + .5; infront = DOT(onorm, offsdir) > 0.; } if (n < 1) n = 1; +#ifdef DEBUG + fprintf(stderr, "pretesting source %d in object %s with %d rays\n", + sn, o->oname, n); +#endif /* sample */ or = sqrt(or2); - ssn = 7*n; - nhit = nok = 0; + ssn = 25*n; + nhit = 0; while (n-- > 0) { /* get sample point */ do { - if (--ssn < 0) + if (--ssn < 0) { +#ifdef DEBUG + fprintf(stderr, "\ttoo hard to hit\n"); +#endif return(f); /* too small a target! */ + } for (i = 0; i < 3; i++) offsdir[i] = or*(1. - 2.*urand(931*i+5827+ssn)); @@ -283,26 +310,35 @@ register int sn; /* target source number */ } while (!(*ofun[o->otype].funp)(o, &sr)); /* check against source */ samplendx++; - if (srcray(&sr, NULL, sn) == 0.0) + if (srcray(&sr, NULL, sn) == 0.) continue; sr.revf = srcvalue; rayvalue(&sr); if (bright(sr.rcol) <= FTINY) continue; - nok++; /* check against obstructions */ srcray(&sr, NULL, sn); rayvalue(&sr); - if (bright(sr.rcol) <= FTINY) - continue; - nhit++; + if (bright(sr.rcol) <= FTINY) { + if (nhit > 0) { +#ifdef DEBUG + fprintf(stderr, "\tpartially occluded\n"); +#endif + return(f); /* need to shadow test */ + } + } else + nhit++; } - /* interpret results */ - if (nhit == 0) + if (nhit == 0) { +#ifdef DEBUG + fprintf(stderr, "\t0%% hit rate\n"); +#endif return(f | SSKIP); /* 0% hit rate: totally occluded */ - if (nhit == nok) - return(f & ~SFOLLOW); /* 100% hit rate: no occlusion */ - return(f); /* no comment */ + } +#ifdef DEBUG + fprintf(stderr, "\t100%% hit rate\n"); +#endif + return(f & ~SFOLLOW); /* 100% hit rate: no occlusion */ }
