--- ray/src/rt/virtuals.c 1991/06/21 13:25:42 1.6 +++ ray/src/rt/virtuals.c 1991/06/25 15:48:11 1.11 @@ -11,13 +11,17 @@ static char SCCSid[] = "$SunId$ LBL"; #include "ray.h" +#include "octree.h" + #include "otypes.h" #include "source.h" +#include "random.h" -double intercircle(), getdisk(); +double getdisk(); + static OBJECT *vobject; /* virtual source objects */ static int nvobjects = 0; /* number of virtual source objects */ @@ -55,8 +59,7 @@ markvirtuals() /* find and mark virtual sources */ #endif /* append virtual sources */ for (i = nsources; i-- > 0; ) - if (!(source[i].sflags & SSKIP)) - addvirtuals(i, directrelay); + addvirtuals(i, directrelay); /* done with our object list */ free((char *)vobject); nvobjects = 0; @@ -71,6 +74,8 @@ int nr; /* check relay limit first */ if (nr <= 0) return; + if (source[sn].sflags & SSKIP) + return; /* check each virtual object for projection */ for (i = 0; i < nvobjects; i++) /* vproject() calls us recursively */ @@ -110,10 +115,9 @@ OBJREC *op; register int sn; MAT4 pm; { - FVECT nsloc, nsnorm, ocent; - double maxrad2; + FVECT nsloc, nsnorm, ocent, v; + double maxrad2, d; int nsflags; - double d1; SPOT theirspot, ourspot; register int i; @@ -133,24 +137,44 @@ MAT4 pm; if (source[sn].sflags & SSPOT) { copystruct(&theirspot, source[sn].sl.s); multp3(theirspot.aim, source[sn].sl.s->aim, pm); + d = ourspot.siz; if (!commonbeam(&ourspot, &theirspot, nsloc)) - return(-1); /* no overlap */ + return(-1); /* no overlap */ + if (ourspot.siz < d-FTINY) { /* it shrunk */ + d = beamdisk(v, op, &ourspot, nsloc); + if (d <= FTINY) + return(-1); + if (d < maxrad2) { + maxrad2 = d; + VCOPY(ocent, v); + } + } } } else { /* local source */ multp3(nsloc, source[sn].sloc, pm); for (i = 0; i < 3; i++) ourspot.aim[i] = ocent[i] - nsloc[i]; - if ((d1 = normalize(ourspot.aim)) == 0.) + if ((d = normalize(ourspot.aim)) == 0.) return(-1); /* at source!! */ - if (source[sn].sflags & SPROX && d1 > source[sn].sl.prox) + if (source[sn].sflags & SPROX && d > source[sn].sl.prox) return(-1); /* too far away */ - ourspot.siz = 2.*PI*(1. - d1/sqrt(d1*d1+maxrad2)); + ourspot.siz = 2.*PI*(1. - d/sqrt(d*d+maxrad2)); ourspot.flen = 0.; if (source[sn].sflags & SSPOT) { copystruct(&theirspot, source[sn].sl.s); multv3(theirspot.aim, source[sn].sl.s->aim, pm); + d = ourspot.siz; if (!commonspot(&ourspot, &theirspot, nsloc)) return(-1); /* no overlap */ + if (ourspot.siz < d-FTINY) { /* it shrunk */ + d = spotdisk(v, op, &ourspot, nsloc); + if (d <= FTINY) + return(-1); + if (d < maxrad2) { + maxrad2 = d; + VCOPY(ocent, v); + } + } ourspot.flen = theirspot.flen; } if (source[sn].sflags & SFLAT) { /* behind source? */ @@ -159,7 +183,11 @@ MAT4 pm; return(-1); } } - /* everything is OK, make source */ + /* pretest visibility */ + nsflags = vstestvis(nsflags, op, ocent, maxrad2, sn); + if (nsflags & SSKIP) + return(-1); /* obstructed */ + /* it all checks out, so make it */ if ((i = newsource()) < 0) goto memerr; source[i].sflags = nsflags; @@ -189,11 +217,11 @@ register int sn; double rad2, roffs, offs, d, rd, rdoto; FVECT rnrm, nrm; /* first, use object getdisk function */ - rad2 = (*sfun[op->otype].of->getdisk)(oc, op); + rad2 = getmaxdisk(oc, op); if (!(source[sn].sflags & SVIRTUAL)) return(rad2); /* all done for normal source */ /* check for correct side of relay surface */ - roffs = (*sfun[source[sn].so->otype].of->getpleq)(rnrm, source[sn].so); + roffs = getplaneq(rnrm, source[sn].so); rd = DOT(rnrm, source[sn].sloc); /* source projection */ if (!(source[sn].sflags & SDISTANT)) rd -= roffs; @@ -201,9 +229,9 @@ register int sn; if ((d > 0.) ^ (rd > 0.)) return(rad2); /* OK if opposite sides */ if (d*d >= rad2) - return(.0); /* no relay is possible */ + return(0.); /* no relay is possible */ /* we need a closer look */ - offs = (*sfun[op->otype].of->getpleq)(nrm, op); + offs = getplaneq(nrm, op); rdoto = DOT(rnrm, nrm); if (d*d >= rad2*(1.-rdoto*rdoto)) return(0.); /* disk entirely on projection side */ @@ -212,104 +240,107 @@ register int sn; } -commonspot(sp1, sp2, org) /* set sp1 to intersection of sp1 and sp2 */ -register SPOT *sp1, *sp2; -FVECT org; +int +vstestvis(f, o, oc, or2, sn) /* pretest source visibility */ +int f; /* virtual source flags */ +OBJREC *o; /* relay object */ +FVECT oc; /* relay object center */ +double or2; /* relay object radius squared */ +register int sn; /* target source number */ { - FVECT cent; - double rad2, cos1, cos2; - - cos1 = 1. - sp1->siz/(2.*PI); - cos2 = 1. - sp2->siz/(2.*PI); - if (sp2->siz >= 2.*PI-FTINY) /* BIG, just check overlap */ - return(DOT(sp1->aim,sp2->aim) >= cos1*cos2 - - sqrt((1.-cos1*cos1)*(1.-cos2*cos2))); - /* compute and check disks */ - rad2 = intercircle(cent, sp1->aim, sp2->aim, - 1./(cos1*cos1) - 1., 1./(cos2*cos2) - 1.); - if (rad2 <= FTINY || normalize(cent) == 0.) - return(0); - VCOPY(sp1->aim, cent); - sp1->siz = 2.*PI*(1. - 1./sqrt(1.+rad2)); - return(1); -} - - -commonbeam(sp1, sp2, dir) /* set sp1 to intersection of sp1 and sp2 */ -register SPOT *sp1, *sp2; -FVECT dir; -{ - FVECT cent, c1, c2; - double rad2, d; - register int i; - /* move centers to common plane */ - d = DOT(sp1->aim, dir); - for (i = 0; i < 3; i++) - c1[i] = sp1->aim[i] - d*dir[i]; - d = DOT(sp2->aim, dir); - for (i = 0; i < 3; i++) - c2[i] = sp2->aim[i] - d*dir[i]; - /* compute overlap */ - rad2 = intercircle(cent, c1, c2, sp1->siz/PI, sp2->siz/PI); - if (rad2 <= FTINY) - return(0); - VCOPY(sp1->aim, cent); - sp1->siz = PI*rad2; - return(1); -} - - -checkspot(sp, nrm) /* check spotlight for behind source */ -register SPOT *sp; -FVECT nrm; -{ - double d, d1; - - d = DOT(sp->aim, nrm); - if (d > FTINY) /* center in front? */ - return(0); - /* else check horizon */ - d1 = 1. - sp->siz/(2.*PI); - return(1.-FTINY-d*d > d1*d1); -} - - -double -intercircle(cc, c1, c2, r1s, r2s) /* intersect two circles */ -FVECT cc; /* midpoint (return value) */ -FVECT c1, c2; /* circle centers */ -double r1s, r2s; /* radii squared */ -{ - double a2, d2, l; - FVECT disp; - register int i; - - for (i = 0; i < 3; i++) - disp[i] = c2[i] - c1[i]; - d2 = DOT(disp,disp); - /* circle within overlap? */ - if (r1s < r2s) { - if (r2s >= r1s + d2) { - VCOPY(cc, c1); - return(r1s); - } + RAY sr; + FVECT onorm; + FVECT offsdir; + double or, d; + int infront; + int ssn; + int nhit, nok; + register int i, n; + /* return if pretesting disabled */ + if (vspretest <= 0) + return(f); + /* get surface normal */ + getplaneq(onorm, o); + /* set number of rays to sample */ + if (source[sn].sflags & SDISTANT) { + n = (2./3.*PI*PI)*or2/(thescene.cusize*thescene.cusize)* + vspretest + .5; + infront = DOT(onorm, source[sn].sloc) > 0.; } else { - if (r1s >= r2s + d2) { - VCOPY(cc, c2); - return(r2s); + for (i = 0; i < 3; i++) + offsdir[i] = source[sn].sloc[i] - oc[i]; + n = or2/DOT(offsdir,offsdir)*vspretest + .5; + infront = DOT(onorm, offsdir) > 0.; + } + if (n < 1) n = 1; +#ifdef DEBUG + fprintf(stderr, "pretesting source %d in object %s with %d rays\n", + sn, o->oname, n); +#endif + /* sample */ + or = sqrt(or2); + ssn = 25*n; + nhit = nok = 0; + while (n-- > 0) { + /* get sample point */ + do { + if (--ssn < 0) { +#ifdef DEBUG + fprintf(stderr, "\ttoo hard to hit\n"); +#endif + return(f); /* too small a target! */ + } + for (i = 0; i < 3; i++) + offsdir[i] = or*(1. - + 2.*urand(931*i+5827+ssn)); + for (i = 0; i < 3; i++) + sr.rorg[i] = oc[i] + offsdir[i]; + d = DOT(offsdir,onorm); + if (infront) + for (i = 0; i < 3; i++) { + sr.rorg[i] -= (d-.0001)*onorm[i]; + sr.rdir[i] = -onorm[i]; + } + else + for (i = 0; i < 3; i++) { + sr.rorg[i] -= (d+.0001)*onorm[i]; + sr.rdir[i] = onorm[i]; + } + rayorigin(&sr, NULL, PRIMARY, 1.0); + } while (!(*ofun[o->otype].funp)(o, &sr)); + /* check against source */ + samplendx++; + if (srcray(&sr, NULL, sn) == 0.) + continue; + sr.revf = srcvalue; + rayvalue(&sr); + if (bright(sr.rcol) <= FTINY) + continue; + nok++; + /* check against obstructions */ + srcray(&sr, NULL, sn); + rayvalue(&sr); + if (bright(sr.rcol) > FTINY) + nhit++; + if (nhit > 0 && nhit < nok) { +#ifdef DEBUG + fprintf(stderr, "\tpartially occluded\n"); +#endif + return(f); /* need to shadow test */ } } - a2 = .25*(2.*(r1s+r2s) - d2 - (r2s-r1s)*(r2s-r1s)/d2); - /* no overlap? */ - if (a2 <= 0.) - return(0.); - /* overlap, compute center */ - l = sqrt((r1s - a2)/d2); - for (i = 0; i < 3; i++) - cc[i] = c1[i] + l*disp[i]; - return(a2); + if (nhit == 0) { +#ifdef DEBUG + fprintf(stderr, "\t0%% hit rate\n"); +#endif + return(f | SSKIP); /* 0% hit rate: totally occluded */ + } +#ifdef DEBUG + fprintf(stderr, "\t100%% hit rate\n"); +#endif + return(f & ~SFOLLOW); /* 100% hit rate: no occlusion */ } - + #ifdef DEBUG virtverb(sn, fp) /* print verbose description of virtual source */
