--- ray/src/rt/virtuals.c 1991/08/02 10:30:27 1.20 +++ ray/src/rt/virtuals.c 1994/12/20 20:18:43 2.3 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1994 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -19,8 +19,8 @@ static char SCCSid[] = "$SunId$ LBL"; #include "random.h" -#define MINSAMPLES 5 /* minimum number of pretest samples */ -#define STESTMAX 30 /* maximum seeks per sample */ +#define MINSAMPLES 16 /* minimum number of pretest samples */ +#define STESTMAX 32 /* maximum seeks per sample */ double getdisk(); @@ -41,11 +41,13 @@ markvirtuals() /* find and mark virtual sources */ o = objptr(i); if (!issurface(o->otype) || o->omod == OVOID) continue; - if (!isvlight(objptr(o->omod)->otype)) + if (!isvlight(vsmaterial(o)->otype)) continue; if (sfun[o->otype].of == NULL || - sfun[o->otype].of->getpleq == NULL) - objerror(o, USER, "illegal material"); + sfun[o->otype].of->getpleq == NULL) { + objerror(o,WARNING,"secondary sources not supported"); + continue; + } if (nvobjects == 0) vobject = (OBJECT *)malloc(sizeof(OBJECT)); else @@ -99,7 +101,7 @@ int n; if (o == source[sn].so) /* objects cannot project themselves */ return; /* get virtual source material */ - vsmat = sfun[objptr(o->omod)->otype].mf; + vsmat = sfun[vsmaterial(o)->otype].mf; /* project virtual sources */ for (i = 0; i < vsmat->nproj; i++) if ((*vsmat->vproj)(proj, o, &source[sn], i)) @@ -113,6 +115,23 @@ int n; } +OBJREC * +vsmaterial(o) /* get virtual source material pointer */ +OBJREC *o; +{ + register int i; + register OBJREC *m; + + i = o->omod; + m = objptr(i); + if (m->otype != MAT_ILLUM || m->oargs.nsargs < 1 || + !strcmp(m->oargs.sarg[0], VOIDID) || + (i = modifier(m->oargs.sarg[0])) == OVOID) + return(m); /* direct modifier */ + return(objptr(i)); /* illum alternate */ +} + + int makevsrc(op, sn, pm) /* make virtual source if reasonable */ OBJREC *op; @@ -141,8 +160,9 @@ MAT4 pm; ourspot.flen = 0.; if (source[sn].sflags & SSPOT) { multp3(theirspot.aim, source[sn].sl.s->aim, pm); + /* adjust for source size */ d = sqrt(dist2(ourspot.aim, theirspot.aim)); - d = sqrt(source[sn].sl.s->siz/PI) + d*source[sn].ss; + d = sqrt(source[sn].sl.s->siz/PI) + d*source[sn].srad; theirspot.siz = PI*d*d; ourspot.flen = theirspot.flen = source[sn].sl.s->flen; d = ourspot.siz; @@ -167,7 +187,8 @@ MAT4 pm; if (source[sn].sflags & SPROX && d > source[sn].sl.prox) return(-1); /* too far away */ ourspot.flen = 0.; - d = (sqrt(maxrad2) + source[sn].ss) / d; + /* adjust for source size */ + d = (sqrt(maxrad2) + source[sn].srad) / d; if (d < 1.-FTINY) ourspot.siz = 2.*PI*(1. - sqrt(1.-d*d)); else @@ -212,9 +233,14 @@ MAT4 pm; goto memerr; source[i].sflags = nsflags; VCOPY(source[i].sloc, nsloc); + multv3(source[i].ss[SU], source[sn].ss[SU], pm); + multv3(source[i].ss[SV], source[sn].ss[SV], pm); if (nsflags & SFLAT) VCOPY(source[i].snorm, nsnorm); - source[i].ss = source[sn].ss; source[i].ss2 = source[sn].ss2; + else + multv3(source[i].ss[SW], source[sn].ss[SW], pm); + source[i].srad = source[sn].srad; + source[i].ss2 = source[sn].ss2; if (nsflags & SSPOT) { if ((source[i].sl.s = (SPOT *)malloc(sizeof(SPOT))) == NULL) goto memerr; @@ -273,6 +299,7 @@ register int sn; /* target source number */ RAY sr; FVECT onorm; FVECT offsdir; + SRCINDEX si; double or, d; int infront; int stestlim, ssn; @@ -285,8 +312,8 @@ register int sn; /* target source number */ getplaneq(onorm, o); /* set number of rays to sample */ if (source[sn].sflags & SDISTANT) { - n = (2./3.*PI*PI)*or2/(thescene.cusize*thescene.cusize)* - vspretest + .5; + /* 32. == heuristic constant */ + n = 32.*or2/(thescene.cusize*thescene.cusize)*vspretest + .5; infront = DOT(onorm, source[sn].sloc) > 0.; } else { for (i = 0; i < 3; i++) @@ -317,13 +344,14 @@ register int sn; /* target source number */ #endif return(f); /* too small a target! */ } + multisamp(offsdir, 3, urand(sn*931+5827+ssn)); for (i = 0; i < 3; i++) - offsdir[i] = or*(1. - - 2.*urand(urind(931*i+5827,ssn))); + offsdir[i] = or*(1. - 2.*offsdir[i]); ssn++; for (i = 0; i < 3; i++) sr.rorg[i] = oc[i] + offsdir[i]; d = DOT(offsdir,onorm); + sr.rmax = 0.0; if (infront) for (i = 0; i < 3; i++) { sr.rorg[i] -= (d-.0001)*onorm[i]; @@ -337,8 +365,11 @@ register int sn; /* target source number */ rayorigin(&sr, NULL, PRIMARY, 1.0); } while (!(*ofun[o->otype].funp)(o, &sr)); /* check against source */ + initsrcindex(&si); + si.sn = sn; + nopart(&si, &sr); samplendx++; - if (srcray(&sr, NULL, sn) == 0.) + if (!srcray(&sr, NULL, &si) || sr.rsrc != sn) continue; sr.revf = srcvalue; rayvalue(&sr);
