1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* vga.c - driver for VGA graphics adaptor under MS-DOS |
9 |
10 |
11 |
#include "standard.h" |
12 |
13 |
#include <graph.h> |
14 |
15 |
#include "driver.h" |
16 |
17 |
#include "color.h" |
18 |
19 |
#define GAMMA 2.2 /* exponent for color correction */ |
20 |
21 |
22 |
int vga_close(), vga_clear(), vga_paintr(), vga_comout(), vga_errout(), |
23 |
vga_comin(); |
24 |
25 |
static struct driver vga_driver = { |
26 |
vga_close, vga_clear, vga_paintr, NULL, |
27 |
vga_comout, vga_comin, NULL, 1.0 |
28 |
29 |
30 |
static char fatalerr[128]; |
31 |
32 |
static struct videoconfig config; |
33 |
34 |
extern char *getenv(); |
35 |
36 |
37 |
struct driver * |
38 |
vga_init(name, id) /* open VGA */ |
39 |
char *name, *id; |
40 |
41 |
static short mode_pref[] = {_MRES256COLOR, -1}; |
42 |
static short smode_pref[] = {_XRES256COLOR, _SVRES256COLOR, |
43 |
_VRES256COLOR, _MRES256COLOR, -1}; |
44 |
char *ep; |
45 |
register short *mp; |
46 |
47 |
mp = !strcmp(name, "vga") ? mode_pref : smode_pref; |
48 |
for ( ; *mp != -1; mp++) |
49 |
if (_setvideomode(*mp)) |
50 |
break; |
51 |
if (*mp == -1) { |
52 |
_setvideomode(_DEFAULTMODE); |
53 |
eputs(name); |
54 |
eputs(": card not present or insufficient VGA memory\n"); |
55 |
return(NULL); |
56 |
57 |
_getvideoconfig(&config); |
58 |
_settextwindow(config.numtextrows-2, 1, |
59 |
config.numtextrows, config.numtextcols); |
60 |
vga_driver.xsiz = config.numxpixels; |
61 |
vga_driver.ysiz = (long)config.numypixels*(config.numtextrows-3) |
62 |
/config.numtextrows; |
63 |
switch (config.mode) { /* correct problems */ |
64 |
case _XRES256COLOR: |
65 |
vga_driver.ysiz -= 16; |
66 |
break; |
67 |
case _MRES256COLOR: |
68 |
vga_driver.pixaspect = 1.2; |
69 |
break; |
70 |
71 |
_setviewport(0, 0, vga_driver.xsiz, vga_driver.ysiz); |
72 |
if ((ep = getenv("GAMMA")) != NULL) /* make gamma map */ |
73 |
make_gmap(atof(ep)); |
74 |
else |
75 |
make_gmap(GAMMA); |
76 |
_remappalette(1, _BRIGHTWHITE); |
77 |
_settextcolor(1); |
78 |
ms_gcinit(&vga_driver); |
79 |
erract[USER].pf = |
80 |
erract[SYSTEM].pf = |
81 |
erract[INTERNAL].pf = |
82 |
erract[CONSISTENCY].pf = vga_errout; |
83 |
erract[COMMAND].pf = vga_comout; |
84 |
if (erract[WARNING].pf != NULL) |
85 |
erract[WARNING].pf = vga_comout; |
86 |
return(&vga_driver); |
87 |
88 |
89 |
90 |
static |
91 |
vga_close() /* close VGA */ |
92 |
93 |
ms_gcdone(&vga_driver); |
94 |
95 |
erract[USER].pf = /* reset error vector */ |
96 |
97 |
98 |
erract[CONSISTENCY].pf = eputs; |
99 |
erract[COMMAND].pf = NULL; |
100 |
101 |
erract[WARNING].pf = wputs; |
102 |
if (fatalerr[0]) |
103 |
eputs(fatalerr); /* repeat error message */ |
104 |
105 |
106 |
107 |
static |
108 |
vga_clear(x, y) /* clear VGA */ |
109 |
int x, y; |
110 |
111 |
_clearscreen(_GCLEARSCREEN); |
112 |
new_ctab(config.numcolors-2); /* init color table */ |
113 |
114 |
115 |
116 |
static |
117 |
vga_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */ |
118 |
COLOR col; |
119 |
int xmin, ymin, xmax, ymax; |
120 |
121 |
extern int vgacolr(); |
122 |
123 |
_setcolor(get_pixel(col, vgacolr)+2); |
124 |
_rectangle(_GFILLINTERIOR, xmin, vga_driver.ysiz-ymax, |
125 |
xmax-1, vga_driver.ysiz-1-ymin); |
126 |
vga_driver.inpready = kbhit(); |
127 |
128 |
129 |
130 |
static |
131 |
vga_comout(s) /* put s to text output */ |
132 |
register char *s; |
133 |
134 |
struct rccoord tpos; |
135 |
char buf[128]; |
136 |
register char *cp; |
137 |
138 |
for (cp = buf; ; s++) { |
139 |
switch (*s) { |
140 |
case '\b': |
141 |
case '\r': |
142 |
case '\0': |
143 |
if (cp > buf) { |
144 |
*cp = '\0'; |
145 |
_outtext(cp = buf); |
146 |
147 |
if (*s == '\0') |
148 |
break; |
149 |
tpos = _gettextposition(); |
150 |
_settextposition(tpos.row, *s=='\r' ? 1 : tpos.col-1); |
151 |
continue; |
152 |
default: |
153 |
*cp++ = *s; |
154 |
continue; |
155 |
156 |
return(0); |
157 |
158 |
fatalerr[0] = '\0'; |
159 |
160 |
161 |
162 |
static |
163 |
vga_errout(msg) |
164 |
register char *msg; |
165 |
166 |
static char *fep = fatalerr; |
167 |
168 |
_outtext(msg); |
169 |
while (*msg) |
170 |
*fep++ = *msg++; |
171 |
*fep = '\0'; |
172 |
if (fep > fatalerr && fep[-1] == '\n') |
173 |
fep = fatalerr; |
174 |
175 |
176 |
177 |
static |
178 |
vga_comin(buf, prompt) /* get input line from console */ |
179 |
char *buf; |
180 |
char *prompt; |
181 |
182 |
extern int getch(); |
183 |
184 |
if (prompt != NULL) |
185 |
_outtext(prompt); |
186 |
editline(buf, getch, vga_comout); |
187 |
188 |
189 |
190 |
191 |
static |
192 |
vgacolr(index, r, g, b) /* enter a color into our table */ |
193 |
int index; |
194 |
int r, g, b; |
195 |
196 |
register long cl; |
197 |
198 |
cl = (long)b<<14 & 0x3f0000L; |
199 |
cl |= g<<6 & 0x3f00; |
200 |
cl |= r>>2; |
201 |
_remappalette(index+2, cl); |
202 |
