root/radiance/ray/src/rt/vga.c
Revision: 2.3
Committed: Tue Oct 13 17:42:22 1992 UTC (31 years, 7 months ago) by greg
Changes for 32-bit PC port
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * vga.c - driver for VGA graphics adaptor under MS-DOS
9 */
10
11 #include <stdio.h>
12
13 #include <graph.h>
14
15 #include "driver.h"
16
17 #include "color.h"
18
19 #define GAMMA 2.2 /* exponent for color correction */
20
21
22 int vga_close(), vga_clear(), vga_paintr(), vga_comout(), vga_errout(),
23 vga_comin();
24
25 static struct driver vga_driver = {
26 vga_close, vga_clear, vga_paintr, NULL,
27 vga_comout, vga_comin, NULL, 1.0
28 };
29
30 static char fatalerr[128];
31
32 static struct videoconfig config;
33
34 extern char *getenv();
35
36
37 struct driver *
38 vga_init(name, id) /* open VGA */
39 char *name, *id;
40 {
41 static short mode_pref[] = {_XRES256COLOR, _SVRES256COLOR,
42 _VRES256COLOR, _MRES256COLOR, -1};
43 char *ep;
44 register int i;
45
46 for (i = 0; mode_pref[i] != -1; i++)
47 if (_setvideomode(mode_pref[i]))
48 break;
49 if (mode_pref[i] == -1) {
50 _setvideomode(_DEFAULTMODE);
51 stderr_v(name);
52 stderr_v(": card not present or insufficient VGA memory\n");
53 return(NULL);
54 }
55 _getvideoconfig(&config);
56 _settextwindow(config.numtextrows-2, 1,
57 config.numtextrows, config.numtextcols);
58 vga_driver.xsiz = config.numxpixels;
59 vga_driver.ysiz = (long)config.numypixels*(config.numtextrows-3)
60 /config.numtextrows;
61 switch (config.mode) { /* correct problems */
62 case _XRES256COLOR:
63 vga_driver.ysiz -= 16;
64 break;
65 case _MRES256COLOR:
66 vga_driver.pixaspect = 1.2;
67 break;
68 }
69 _setviewport(0, 0, vga_driver.xsiz, vga_driver.ysiz);
70 if ((ep = getenv("GAMMA")) != NULL) /* make gamma map */
71 make_gmap(atof(ep));
72 else
73 make_gmap(GAMMA);
74 _remappalette(1, _BRIGHTWHITE);
75 _settextcolor(1);
76 ms_gcinit(&vga_driver);
77 errvec = vga_errout;
78 cmdvec = vga_comout;
79 if (wrnvec != NULL)
80 wrnvec = vga_comout;
81 return(&vga_driver);
82 }
83
84
85 static
86 vga_close() /* close VGA */
87 {
88 _setvideomode(_DEFAULTMODE);
89 errvec = stderr_v; /* reset error vectors */
90 cmdvec = NULL;
91 if (wrnvec != NULL)
92 wrnvec = stderr_v;
93 if (fatalerr[0])
94 stderr_v(fatalerr); /* repeat error message */
95 }
96
97
98 static
99 vga_clear(x, y) /* clear VGA */
100 int x, y;
101 {
102 _clearscreen(_GCLEARSCREEN);
103 new_ctab(config.numcolors-2); /* init color table */
104 }
105
106
107 static
108 vga_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
109 COLOR col;
110 int xmin, ymin, xmax, ymax;
111 {
112 extern int vgacolr();
113
114 _setcolor(get_pixel(col, vgacolr)+2);
115 _rectangle(_GFILLINTERIOR, xmin, vga_driver.ysiz-ymax,
116 xmax-1, vga_driver.ysiz-1-ymin);
117 vga_driver.inpready = kbhit();
118 }
119
120
121 static
122 vga_comout(s) /* put s to text output */
123 register char *s;
124 {
125 struct rccoord tpos;
126 char buf[128];
127 register char *cp;
128
129 for (cp = buf; ; s++) {
130 switch (*s) {
131 case '\b':
132 case '\r':
133 case '\0':
134 if (cp > buf) {
135 *cp = '\0';
136 _outtext(cp = buf);
137 }
138 if (*s == '\0')
139 break;
140 tpos = _gettextposition();
141 _settextposition(tpos.row, *s=='\r' ? 1 : tpos.col-1);
142 continue;
143 default:
144 *cp++ = *s;
145 continue;
146 }
147 return(0);
148 }
149 fatalerr[0] = '\0';
150 }
151
152
153 static
154 vga_errout(msg)
155 register char *msg;
156 {
157 static char *fep = fatalerr;
158
159 _outtext(msg);
160 while (*msg)
161 *fep++ = *msg++;
162 *fep = '\0';
163 if (fep > fatalerr && fep[-1] == '\n')
164 fep = fatalerr;
165 }
166
167
168 static
169 vga_comin(buf, prompt) /* get input line from console */
170 char *buf;
171 char *prompt;
172 {
173 extern int getch();
174
175 if (prompt != NULL)
176 _outtext(prompt);
177 editline(buf, getch, vga_comout);
178 vga_driver.inpready = kbhit();
179 }
180
181
182 static
183 vgacolr(index, r, g, b) /* enter a color into our table */
184 int index;
185 int r, g, b;
186 {
187 register long cl;
188
189 cl = (long)b<<14 & 0x3f0000L;
190 cl |= g<<6 & 0x3f00;
191 cl |= r>>2;
192 _remappalette(index+2, cl);
193 }
